  1. Apr 4, 2022 at 10:14 AM
    d_kinneyjr
    d_kinneyjr New Member
    Dave
    Southern NH
    2018 Crew Max SR5
    Busy Weekend (Saturday)
    Found a good deal for XD820 rims and Kanati Trial Hog AT tires on Facebook Marketplace. Picked them up and installed them. Then my Catalytic Converter Anti-Theft plate came in from Desert Eagle Off Road, so I installed that. Lastly I installed the Rago Center Dash Mount with (2) Ram Mount Phone Attachments. Then it was wash and wax time.
    GarTX526, GAknight, WawaLunar and 7 others like this.
  2. Apr 4, 2022 at 10:28 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Yup, running 1.25” Spidertrax spacers.
    You don’t necessarily need UCA unless if you’re running bigger tires OR if you have wheels with a lower positive offset OR if you’re going past 3” of lift.
    Our stock wheels are a high offset which will result in the tire rubbing the spindle if you increase tire size.
  3. Apr 4, 2022 at 12:11 PM
    k3k0a808
    k3k0a808 New Member
    2021 1794 WCP
    i usually take a lot of pictures but I didn’t this time.. I covered the leather with painters tape, traced out where it was going to go, then I made another line 1/8 inside the outer trace mark. I cut the leather in an “x” inside the inner line. Then I folded the leather back and taped it out of the way. Took a 1/4 drill bit then drilled the corners thru the plastic so I know where they are from the other side, then just used a dremmel/file to cut it out from the underneath. I used the oem 3 switch panel from a Sequoia, I cut the tabs off and just file/grind away until everything fits. Take all the tape off, push the panel thru with the leather, trim off excess leather on the underside, put it in a clamp and epoxy around to lock it in. Rear window switch will fit, I’m going to relocate mine there, I just need to wait for my order of wire to come in
    *edit - when you are positioning where you are going to cut the hole, make sure you try to miss the large tab tower on the left side, i had to cut a bit off of mine.
  4. Apr 4, 2022 at 12:15 PM
    k3k0a808
    k3k0a808 New Member
    2021 1794 WCP
    oem part number 55447-0C011
  5. Apr 4, 2022 at 12:24 PM
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    Yes. I have 3w kit. That connection is the 3w connector
  6. Apr 4, 2022 at 12:49 PM
    tundrasportinMA
    tundrasportinMA New Member
    Western Mass
    2019 Tundra Sport DC
    6112/5160 , SCS Ray 10's, Cooper Discover AT3 -295/70/18, Dirty Deeds 8inch, N-Fab Podium
    Awesome ! Thank you :cheers:
  7. Apr 4, 2022 at 1:02 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    What’s the wheel offset?
  8. Apr 4, 2022 at 2:07 PM
    canadianguy
    canadianguy New Member
    Kevin
    Lloydminster Alberta
    2017 SR5 trd off-road
    All the usual stuff!
    It’s just the little things in life…EBFEE4DE-0D32-4B63-A307-C9D5840E3D4F.jpgC731B5B7-49F9-47BD-BD2B-86221A69A447.jpg
  9. Apr 4, 2022 at 2:29 PM
    1794TX
    Steven
    N.TX
    '20 1794
    Thank you.
  10. Apr 4, 2022 at 4:25 PM
    Mobeyk
    Mobeyk New Member
    Oshawa Ontario Canada
    2012 Tundra TRD pro, 2018 SR5
    Vland headlights, LED fogs, Rough country lower bumper LED bar, third light switch to LED, ICL ceramic coating, hood fender
    I didn't solder. I just cut the wires then spliced in wires for extending and put heat shrink tubing over the splices. Thought about heat shrink connectors first but the splicing went faster ( just weave the two wire strands together, twist and lay flat so shrink tubing goes over it then apply heat. After all that, I used 5-6 zip ties to hold all the wires together and keep things neat at 6" lengths.
    campergf23[QUOTED] likes this.
  11. Apr 4, 2022 at 4:48 PM
    d_kinneyjr
    Dave
    Southern NH
    2018 Crew Max SR5
    @ZPhilip +25 for the rims + 2" wheel spacers (I was debating taking the wheel spacers off, but decided to leave them)
    ZPhilip[QUOTED] likes this.
  12. Apr 4, 2022 at 4:50 PM
    Clemshady
    Clemshady Bama Storm Trooper
    Jeff
    2017 Super White Limited DC TRD 4x4 Offroad
    \ Factory OEM LED Tundra Pro headlight upgrade Diode Dynamic amber Pro fogs 3" DD amber Pro ditch lights SDHQ ditch brackets 42" DD light bar SwitchPro 9100 Pedal Commander Vinyl wrapped bumpers Painted calipers Painted horns Chrome delete complete ARE CX Evolve Topper TRD rear swaybar Matching door handles and mirror caps Oh shit handle upgrade Matching grille surround/hood bulge TRD PRO insert grille BBS Forged TRD PRO wheels Coachbuilder +3 shackles Eibach Pro 2.0 Coilovers and rear shocks
    What I did today. My faux TRD PRO Limited is coming right along. Got my TRD PRO style letters on tailgate. A little pricey but my baby is worth it. A faux TRD PRO with all the luxury options and no bed stamp. :thumbsup:
    GAknight, Velocity72, Sean492 and 4 others like this.
  13. Apr 4, 2022 at 4:56 PM
    tundratoofun
    tundratoofun Yall better rednekonize
    Glendale
    Beast
    Took a couple hours with a shop-vac and a lint roller to get the dog hair out of the carpet. Then I stumbled onto a better way to secure the axe
  14. Apr 4, 2022 at 5:08 PM
    baby-shark
    baby-shark Propaniac and Certified Tundra Enthusiast
    Kevin
    VA
    2021 Wind Chill Pearl Limited CrewMax
    Rear Sway Bar, Retrax Pro, TRD wheels and Cooper Tires, TRD shift knob!!!
  15. Apr 4, 2022 at 8:19 PM
    18DCTRD
    18DCTRD New Member
    Dave
    Dracut, MA
    ‘18 DC TRD Off Road
    Excellent! Great looking truck, what ditch light brackets are those?
    Clemshady[QUOTED] likes this.
  16. Apr 5, 2022 at 12:10 AM
    RoniusMaximus
    RoniusMaximus The One and Only
    J
    Tri-Cities, Washington
    2020 MGM Toyota Tundra TRD PRO
    Synthetic Blinker Fluid
    Added these black center console trim pieces from Amazon. Hardest part was removing the AJT vent surrounds to reinstall over these.Screenshot_20220404-235927_Amazon Shopping.jpg 20220404_183705.jpg 20220404_183657.jpg 20220404_183647.jpg 20220404_183709.jpg
  17. Apr 5, 2022 at 2:21 AM
    James07
    James07 New Member
    James
    Maryland
    2017 CM Platinum in Super White
    Ready Lift 3/2 General Grabbers ATX 35x12.5x17 Icon Alloys Rebounds 17 Window Tint Line-X Bed 32" Rigid Light bar in Bumper Stubby Antenna VLED under dash lights A-Pillar Grab handle Blacked out exhaust tip Shovel/Axe bed mounts
    @d_kinneyjr what display option is that you have on the radio? I have a 2017 Platinum and never seen it split in 3 screens with those features.
  18. Apr 5, 2022 at 4:15 AM
    McLovin
    McLovin New Member
    Harry
    Maryland
    17' QS CM Limited, 14' MGM T4R SR5 Premium,
  19. Apr 5, 2022 at 5:41 AM
    YotaTruckLtd
    YotaTruckLtd Secret Squirrel
    2014 MGM Limited CM
    Bilstein 6112/5160 Boss 4x4 shims Boss 4x4 shackles Fuel Off-Road Vector wheels 20X9 Nitto Terra Grappler G2 35" tires SPC UCAs OEM TRD Pro Grille OEM 2020 LED headlights and OEM LED fog lights OEM color matched mirror caps and door handles OEM black exhaust tip Ecoological color matched front and rear bumpershellz V3 Go Rhino RB20 running boards XPEL Prime XR Plus ceramic tint 30% front 15% rear 70% windshield BAKFlip MX4 tonneau cover Dasaita 13in Vivid Headunit AJT interior chrome delete black kit AJT climate control black knobs AJT V3 shift knob TVD exterior emblem black inlays 3BMakers Yota hitch cover Husky front and back floormats K&N Select engine air filter GTR Lighting Armor Series LEDs Reverse lights Cargo lights 3rd brake light License plate lights
    I was looking at this same company but the black covers for the 3 wood pieces on my Limited. Is the quality good??
  20. Apr 5, 2022 at 6:28 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Installed TRD PRO Led headlights! What a nice upgrade from my stock halogens.
  21. Apr 5, 2022 at 7:21 AM
    zasdds
    zasdds New Member
    2021 Platinum Crewmax
    Yeah, I blew at least 2 fuses during this install. I have a 21' platinum that has Front Driver/Passenger auto switches and I had purchased the only kit available which at the time only had Front Driver Auto. The wiring is completely different even though the connections are the same. I missed the warning on the CTH website not to purchase, but I swear it wasn't up there when I ordered ~1 month ago. For what it's worth, everything did connect and the master switch panel lit up nice and pretty...but upon firing up truck, immediate SRS airbag fault, no A/C, no power locks, no push to start, amongst other things.
    Anyways, I replaced the under dash fuse ECU-B NO.2 and got most functionality back. Still cannot open rear/back windows from master switch, so bit the bullet and crawled back to the dealer with my tail between my legs. The techs traced the issue to a large blown pink Type-B fuse (30amp?) which they had to order and should be replaced tomorrow.
    Have not noticed any other issues with the truck besides those windows not going down, but have learned my lesson...for now.
    Taco-Spike[QUOTED] likes this.
  22. Apr 5, 2022 at 7:31 AM
    Taco-Spike
    Two Trucks
    Damn, that's crazy. Sorry to hear that, especially when it should light up to begin with. Hope you get it fixed.
    I've come to learn, different model years and some even same year can act different. I've had it a few days, checked everything used all buttons I can and so far so good.
    zasdds[QUOTED] likes this.
  23. Apr 5, 2022 at 7:34 AM
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    The light output is like night and day, the single best upgrade I did as well.
    TomC843 likes this.
  24. Apr 5, 2022 at 8:58 AM
    BamatundraSC
    BamatundraSC New Member
    Greer, SC
    2021 SR5 CM
    TRD Pro grille, color matched hood bulge, TRD Pro headlights, color matched front bumper end caps, Rough Country two inch loaded front struts, Matte black SCS Ray10’s, Cooper Rugged Trek 275/70/18, Rough Country tri fold hard bed cover, Dirty deeds 12” exhaust
    Mine just came in today. I also have the AJT vent surrounds and was waiting on the overlays to come in before before I installed the surrounds to the middle vents.
    I just went out and did a test fit and it doesn’t look like the vent surrounds are going to fit if I install the overlays.
    Did you have to do any trimming on yours to get the vent surrounds back on?
  25. Apr 5, 2022 at 9:11 AM
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Stillen CAI, DD 8” exhaust, Toytec Aluma coilovers, Icon leaf springs, SCS SR8 18x9 wheels, Cooper Rugged Trek 275/70/18 A/T Tires, Ecoological bumper shellz and grill surround, AJT interior black out kit, AJT shift knob. TRD pro style grill, VLED aqua blue footwell lights, MESO custom dome and map LED lights, swing case, Rough country bed mat, TRD pro headlights and fog lights, Morimoto XB tail lights and 3rd brake light.
    I have a similar set up and put the dash overlay first which did leave the chrome surround on the middle vents still exposed making it an easy fit the AJT overlays. Perhaps yours is not quite cut the same. If so I would say just use a Dremel with a sanding drum to trim some out until you see the chrome ring.
  26. Apr 5, 2022 at 9:15 AM
    RoniusMaximus
    J
    The quality is actually good. It matches the AJT black plastic perfectly. Only place I found it in black is on Amazon. If you do plan on getting the AJT vent surround pieces, make sure you wait to install them on the plastic trim cover first otherwise you have to remove them in order to fit these pieces.
    I had a roll of 3m double sided tape. I made it just enough length to match the diameter of the AJT vent covers and then I cut it in half so I had 2 equal length strips, 1 for each side. I then folded each double sided piece of tape in half and stuffed it inside the groove/channel of each AJT vent piece. From there I just put each vent piece over the trim larger side trim pieces and lined it up. It sticks to it perfectly for me. I didnt take pics of this so hopefully I am making sense.
    YotaTruckLtd[QUOTED] likes this.
  27. Apr 5, 2022 at 9:27 AM
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    I put my carrier bearing drop kit in today. I also got to use the foam matt from RC to lay on while putting it in. A lot better than a tarp. 055B239F-0F74-44E7-88C0-0A55B2A19079.jpg 783BADD4-F018-40E2-80FB-FBC786904A88.jpg F0E941FA-0269-4BD2-A963-0E6A4A12A3A1.jpg I didn’t have any vibration before install. But thought I it would be a good idea since I have a 3.5” RC lift and pull a 29’ camper. I’m sure the universal joints will thank me.
  28. Apr 5, 2022 at 9:30 AM
    d_kinneyjr
    Dave
    Southern NH
    2018 Crew Max SR5
    @James07 this was an option in believe in the setting tab for the head unit. You could choose to have 3 window (as I have done), 2 windows or 1 window. In each window you can then choose what you want in it, such as the clock, the radio station and the MPG.
    James07[QUOTED] likes this.
  29. Apr 5, 2022 at 9:36 AM
    T.Durden13
    T.Durden13 New Member
    Tyler
    Iowa
    2019 Voodoo Blue TRD Pro
    A little transformation Tuesday for everyone. Since purchasing the truck last summer I’ve added the following:
    -Coachbuilder TRD Pro Suspension kit
    -Method Mesh 18x9 wheels
    -Nitto Ridge Grappler 295/70R18
    -Go Rhino Sport Bar 2.0
    -Tyger side steps
    -Window tint all the way around
    Have a few other mods planned for the future but really happy with how it’s shaping up.
    Before:
    After:
  30. Apr 5, 2022 at 9:39 AM
    Taco-Spike
    Two Trucks
    Looks awesome!
    T.Durden13[QUOTED] likes this.
