  1. Apr 3, 2022 at 10:10 AM
    DiamondW
    DiamondW Stockblocker
    Kent
    CenTex
    ‘17 CM
    I had all the wire on hand from other projects over the years, but this is the basics. I didn’t price hunt, but the part numbers should be correct. I can go more in depth if anyone needs later.
    Switch hub, really great alternative to 4 separate relays.
    https://www.ebay.com/itm/Stinger-SPXSH440-100-Amp-Solid-State-Switch-Hub-/154782919401
    Blue sea fuse block
    https://www.ebay.com/itm/Power-Prod...e-Compact-Fuse-Block-4-Circuits-/324697540762
    ground buss
    https://www.ebay.com/itm/BLUE-SEA-2304-MINIBUS-5-X-8-32-COMMON-BUS-/284616759344
    2awg to 2x4awg
    https://www.ebay.com/itm/NEW-STINGE...ER-OR-GROUND-DISTRIBUTION-BLOCK-/164381213616
    18 awg 6 conductor for triggers.
    https://www.ebay.com/itm/25-6-Condu...d-25-Foot-Length-6C-18AWG-S1806-/265292074939
    That plus some 2awg and 4awg battery lead and ground cable.
    I did add a piece of 1x1 aluminum angle to the taco tunes plate to mount the splitter as well.
    Army_of_One and AZTundra like this.
  2. Apr 3, 2022 at 10:12 AM
    DiamondW
    Kent
    CenTex
    ‘17 CM
    I used to be a wire jockey before I went into the office, so I’m still a little particular how things are done lol.
    -MRibz- and Army_of_One[QUOTED] like this.
  3. Apr 3, 2022 at 12:30 PM
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    Been hell at work past two weekends. Finally got this done. Took about 15 minutes. 10 minutes was trying to figure out the F-ing wire connection release.
  4. Apr 3, 2022 at 12:38 PM
    Taco-Spike
    Two Trucks
    You do just driver or full truck? Looks great!
    It turns on when you open the door and stays lit for a little while after you turn the truck off.
  5. Apr 3, 2022 at 12:47 PM
    Velocity72
    Velocity72 New Member
    Upstate SC
    2021 Platinum
    Same with the Platinum.
  6. Apr 3, 2022 at 1:05 PM
    Enjoihavok
    Enjoihavok New Member
    Erik
    Chandler,AZ
    Hah, suffered the same issue the other day when changing the door handles and removal the door panels. Struggled with that drivers clip as well.
    Taco-Spike and TomC843[QUOTED] like this.
  7. Apr 3, 2022 at 1:07 PM
    Taco-Spike
    Two Trucks
    You removed the whole door panel? That section pops out without removing the whole panel
  8. Apr 3, 2022 at 1:26 PM
    Mobeyk
    Mobeyk New Member
    Oshawa Ontario Canada
    2012 Tundra TRD pro, 2018 SR5
    Vland headlights, LED fogs, Rough country lower bumper LED bar, third light switch to LED, ICL ceramic coating, hood fender
    Finally completed my FRAC video camera system with second back camera using a video switcher and @abomb60 's three switch panel. I can now switch between OEM back up camera, front camera and second back camera anytime even in reverse. It looks like a wire mess but I had all wires labeled and before putting everything back together organized the wires with zip ties.IMG_0959.jpg
    Relocated the seat heater switch from the front accessory panel to the 3 switch panel for easier access too. It was a pita as I couldn't find a harness for the extension and just extended the wiring ( 7 wires ) to relocate switch.
    Maybe I find one day a better switch for the 2md back camera, for now the fog lights switch I had left got to do the job.
  9. Apr 3, 2022 at 1:49 PM
    Coastboater
    Coastboater New Member
    Wheels & Tires, Power Running Boards
    For the first time the other day I used the Toyota Snatch-O-Matic on a crepe myrtle that needed to go:D
    The Toyota Snatch-O-Matics are available at your local Home Depot. I selected the 5/16” X 20’. Fifty bucks.
  10. Apr 3, 2022 at 3:19 PM
    TomC843
    Tom
    Charleston, SC
    Just driver
    Taco-Spike[QUOTED] likes this.
  11. Apr 3, 2022 at 3:56 PM
    jhardy1979
    jhardy1979 New Member
    Justin
    MGM 2015 Tundra Crewmax Limited 4x4
    The Pro's or Sport?
  12. Apr 3, 2022 at 4:28 PM
    Enjoihavok
    Erik
    Chandler,AZ
    each handle has 2 screws that are only accessed from the back side of the door panel itself, so you just remove the plastic thing behind the handle, remove that screw, move the felt from the hand hold area, remove that screw, then unpop about 8 clips, holding the door panel disconnect the two cables that operate the pulling action of the door handle to open the door, etc…. It’s still only like a 10min job but it’s annoying for like you said swapping a door handle.
  13. Apr 3, 2022 at 4:44 PM
    Taco-Spike
    Two Trucks
    Ahh, you were doing the door handles. Gotcha.
    Yeah, nice to know it’s the same as my Tacoma. I did the black handle swap years before anyone had covers. But those were actually chrome. Still debating doing the tundra since they aren’t chrome. I told myself I wouldn’t go crazy like I did the Tacoma. Time will tell
  14. Apr 3, 2022 at 4:54 PM
    Lol that's funny.....I'm doing more to my 2020 than I did to my 2013. :D
  15. Apr 3, 2022 at 4:54 PM
    DiamondW
    Kent
    CenTex
    ‘17 CM
    Haha, not go crazy! Good luck with that.
  16. Apr 3, 2022 at 5:14 PM
    Enjoihavok
    Erik
    Chandler,AZ
    Hah, was the same way with my 2015 Tacoma, did way to much armor and suspension work on that, told myself I’d just buy a tundra pro and try to keep myself from doing to much to it, but here I am working on interior appearance lol, at least I think after $600ish I’m done already.
  17. Apr 3, 2022 at 5:16 PM
    Jcmf52
    Jcmf52 New Member
    Rob
    2018-1794 S/C
    Shorty antenna Trifold hard top tonneau cover Center console safe Center console tray Rhino liner TRD air filter TRD rear sway bar TRD front sway bar Center console wireless charger kit Remote start Black 4x4 emblem swap
    Thank you!!
  18. Apr 3, 2022 at 5:51 PM
    campergf23
    campergf23 2021 TRD Sport Premium DC
    Quebec, Canada
    Was this as simple as cutting the wires and sautering/connecting longer wires? I'm hoping to do the same, as I don't like the factory position for our heated seats. Did you sauter or use some sort of connector?
  19. Apr 3, 2022 at 6:39 PM
    Taco-Spike
    Two Trucks
    Okay, got a few different shots for those who asked. Back seat lights are just like the front passenger
    no parking lights
    parking lights
    red map / dome light
    white map / dome light
  20. Apr 3, 2022 at 6:57 PM
    Do58
    Do58 New Member
    Looks good. What are your thoughts of brightness with the red interior lights off? Super bright/distracting or subtle?
    Thanks!
  21. Apr 3, 2022 at 7:56 PM
    k3k0a808
    k3k0a808 New Member
    2021 1794 WCP
    Relocated anytime backup camera switch here, was in the auto headlight spot. Too much feeling around for it there. going to make the other two slots compressor/train horn when i get it
  22. Apr 3, 2022 at 7:57 PM
    Cock-A-Doddle-Do
    Cock-A-Doddle-Do New Member
    Brett
    Cypress, Texas
    2021 TRD Off Road CM -Super White
    Yep, dick and balls 100%
  23. Apr 3, 2022 at 8:18 PM
    Taco-Spike
    Two Trucks
    I thinks it’s pretty subtle.
    I’m use to extra lighting though. My Tacoma has door bowl lights.
  24. Apr 4, 2022 at 4:43 AM
    imcalister
    imcalister New Member
    Scott
    Van Alstyne, TX
    2020 Tundra CM Attitude 5.7L 4x4
    Which 3 gang housing did you use? The eBay one?
    AggiePhil and 1794TX like this.
  25. Apr 4, 2022 at 5:40 AM
    1794TX
    Steven
    N.TX
    '20 1794
    Also very interested in your process on this, if you recorded any of it. Not sure the rear window switch will fit there, but if it does, I'll want to do this. Really nice work.
    TickNvM likes this.
  26. Apr 4, 2022 at 6:51 AM
    TomC843
    Tom
    Charleston, SC
    Had a couple extra pics. Nothing that great.
    GAknight, mgm16trdpro and Taco-Spike like this.
  27. Apr 4, 2022 at 7:00 AM
    Taco-Spike
    Two Trucks
    I thought about talking pics of this, but didn't. I'm bad about that, usually too busy just wanting to get it done rather than stop, take pics, do something and take more pics.
    Thanks for this.
    TomC843[QUOTED] likes this.
  28. Apr 4, 2022 at 7:57 AM
    tundrasportinMA
    tundrasportinMA New Member
    Western Mass
    2019 Tundra Sport DC
    6112/5160 , SCS Ray 10's, Cooper Discover AT3 -295/70/18, Dirty Deeds 8inch, N-Fab Podium
    Anyone know if this will work with the 3Wliners, auto down ? I assume it would but just curious if anyone has done it.
  29. Apr 4, 2022 at 9:08 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Finished the fronts!
    5100s at top clip setting
    SPC UCA
    Spidertrax 1.25” spacers
    Love how it feels so much better than stockers. More grounded and firm.
    Unfortunately didn’t get measurements prior to installing the front, but we’re looking at:
    DF: 38”
    PF: 38.25”
    DR: 38
    PR: 38.25”
    Looks like I have the Tundra lean, but don’t think I’ll be adding a shim to lift the front. Too minuscule.
    Next up to fit 37s:
    CB front bumper shims
    Rear 5100s
    Total Chaos 3/4 Shackles
    BMC
    and we’ll see if I need to do PWM after getting tires mounted.
  30. Apr 4, 2022 at 9:13 AM
    1794TX
    Steven
    N.TX
    '20 1794
    Those look like stock Tundra wheels... Those SPC UCA's fit fine? Do you have spacers?
    I may need UCA's, but have stock wheels with +50 offset, and don't want to add spacers. I've come up with one choice so far - - Zone. Gets the job done, but man those things are fugly. Still doing research.
