  1. Mar 30, 2022 at 2:27 AM
    imcalister
    imcalister New Member
    Scott
    Van Alstyne, TX
    2020 Tundra CM Attitude 5.7L 4x4
    Drove it for 50 miles last night and nothing. We’ll see tomorrow when I drive to Houston for work.
  2. Mar 30, 2022 at 4:32 AM
    Spielightdude
    Spielightdude New Member
    Joseph
    2019 Tundra TRD off road and towing package
    How do you like it? I am looking to order one soon.
  3. Mar 30, 2022 at 6:54 AM
    Ranger2005
    Ranger2005 New Member
    Dean
    TX
    2021 1794 Crewmax
    Running boards, ceramic coating, sound system
    I couldn't agree more. Pollen is bad right now here in SE Texas.
  4. Mar 30, 2022 at 7:21 AM
    Moe2o4
    Moe2o4 New Member
    Corey
    2020 Tundra SR5 Extended Cab TRD Offroad Package 8ft. Bed
    Bilsten 6112's with 2.5" Front Lift w/Bilstein 5160 Rear Shocks
    Did a little upgrade over the weekend! Out with that crappy 2 year old OEM Battery and in with a brand new Northstar AGM 27F!!!!
  5. Mar 30, 2022 at 7:46 AM
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    I want that garage please!!
  6. Mar 30, 2022 at 8:18 AM
    Boisefly
    Boisefly New Member
    Boise, ID
    2014 Crewmax 1794 4WD
    Installed the RAS kit yesterday. Just FYI for anyone who has Toytec shackles like me - you have to remove the leaf from the shackle to fit the RAS hook. IDK why people say it only takes 45 min to install this - it took me 2 hours from start to finish and I am pretty experienced with working on vehicles.
    I did remove the wheels and had to disconnect the rear shocks to get enough droop for the RAS hook to fit through the shackle.
    Review: I'm always skeptical when people say products offer a very noticeable difference. Sometimes its a placebo effect. Anyways, I could feel a difference especially at low speeds on bumpy/windy roads. The rear end feels more "as one" with the cab. I have not tested it fully loaded but I will in the near future. Before installing the kit, I had 1" rake in the rear using the highest lift setting with the Toytec shackles. I dropped down the lower shackle setting and the RAS kit gave me an additional 3/4" lift. I'm now at 1.25" rake in the rear which I like.
    I can't fully recommend the system until I am fully loaded or towing but I am hopeful.
  7. Mar 30, 2022 at 8:29 AM
    You and me both. I would live in that thing.
    a522467, jclem65 and ATV25 like this.
  8. Mar 30, 2022 at 8:37 AM
    Boisefly
    Boisefly New Member
    Boise, ID
    Did you have to mess with the diode for this battery?
  9. Mar 30, 2022 at 8:43 AM
    Moe2o4
    Moe2o4 New Member
    Corey
    Nope just a simple 5 minute swap, Hooked up my Noco Jump starter to my OBDII port so I kept all my settings in the truck while I did the swap!
    NAIVIAN and Boisefly[QUOTED] like this.
  10. Mar 30, 2022 at 8:46 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I literally did the same thing this last weekend...I used my HKB voltage booster and the idiot gauge indicates a higher rate of charge by a hair...I'm happy and its never started this well before either! Ha!
    Moe2o4[QUOTED] likes this.
  11. Mar 30, 2022 at 8:50 AM
    NAIVIAN
    NAIVIAN This is the way....
    Doug
    Spring, TX
    2021 Black SR5
    I would love to hear how you hooked up the NOCO Jump Starter to OBDII port so I can do the same and keep all my settings to do battery swap.
  12. Mar 30, 2022 at 9:15 AM
    Moe2o4
    Moe2o4 New Member
    Corey
    It does start noticeably better for sure!!!
    This little guy right here, hooks up to the output on the NOCO Jump starter and plugs right into the OBDII!
    https://www.amazon.com/NOCO-GBC012-OBD-II-Settings-Keeper/dp/B0772QQP6H?ie=UTF8
  13. Mar 30, 2022 at 9:25 AM
    I was told by NOCO that is no longer made but you can use this one....
    NOCO GC035 GC025 12-Volt Adapter Plug Socket With OBD-II Connector https://www.amazon.com/dp/B07GTLMVV9?_encoding=UTF8
  14. Mar 30, 2022 at 9:52 AM
    Moe2o4
    Moe2o4 New Member
    Corey
  15. Mar 30, 2022 at 10:26 AM
    AZBoatHauler
    So.Arizona
    According to my Kenwood head unit, the HKB bumped my charging voltage by .5v. I was between 13.5-14 now 14-14.5 depending on operating temp.
  16. Mar 30, 2022 at 10:27 AM
    HulkSmurf14
    2014 Tundra Limited
    Same here...upon startup, 14.7; once AIP turns off, I'm right at your numbers...I'm happy with this.
    AZBoatHauler[QUOTED] likes this.
  17. Mar 30, 2022 at 10:28 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Link?
  18. Mar 30, 2022 at 10:46 AM
    Pangaea
    Pangaea New Member
    BC
    2021 Cement Tundra CM TRD Off Road Premium
    Thanks! The F150 is nowhere near the truck (as we all know). Terrible turn radius, sloppy handling, timid acceleration - lacks punch. Just doesn't feel tight. WAY better gas mileage tho. Almost double what mine gets, though mine is significantly heavier.
    GODZILLA[QUOTED] likes this.
  19. Mar 30, 2022 at 10:54 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Wanna trade? I've been in a ram 1500 for 5 months. Horrible everything and worse gas mileage.
    RainMan_PNW likes this.
  20. Mar 30, 2022 at 11:00 AM
    New rule....anyone that leaves a Tundra should be beaten.....especially if they go Dodge or Ford. :smack:
    Ranger2005, Gaston, Moe2o4 and 2 others like this.
  21. Mar 30, 2022 at 11:04 AM
  22. Mar 30, 2022 at 11:05 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Should I have kept the versa?
    RainMan_PNW and GODZILLA like this.
  23. Mar 30, 2022 at 11:18 AM
    Sean492
    Sean492 New Member
    Winston Salem, NC
    2018 MGM Tundra Sport
    Wow. Those look awesome! I especially like the third light. Very nice mod!
  24. Mar 30, 2022 at 1:06 PM
    k3k0a808
    k3k0a808 New Member
    2021 1794 WCP
    I just traded my 17 F250 for a 21' Tundra, what do i get? :monocle:
  25. Mar 30, 2022 at 1:08 PM
    canadianguy
    canadianguy New Member
    Kevin
    Lloydminster Alberta
    2017 SR5 trd off-road
    All the usual stuff!
    Women instead of men!
    ConcordCarlos, pvmike, Gaston and 8 others like this.
  26. Mar 30, 2022 at 1:10 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    As if the pain from repeated visits to the service department weren't enough!
  27. Mar 30, 2022 at 1:17 PM
    k3k0a808
    k3k0a808 New Member
    2021 1794 WCP
    :rofl:Ill take it
  28. Mar 30, 2022 at 1:43 PM
  29. Mar 30, 2022 at 2:00 PM
    The devil...lol.
    Ranger2005, dkahs05, ATV25 and 3 others like this.
  30. Mar 30, 2022 at 2:01 PM
    Made you do it.:rofl:
    Taco-Spike and Tundra234[QUOTED] like this.
