  1. Mar 27, 2022 at 5:37 AM
    I have the same set and had mine done in line-x premium.
  2. Mar 27, 2022 at 5:46 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Noice. Will it illuminate?
  3. Mar 27, 2022 at 6:40 AM
    sofaking
    sofaking New Member
    Karl
    2021 Toyota Tundra SR5
    Is that the main shield option or their ultimate protection? ($199 extra)
  4. Mar 27, 2022 at 7:18 AM
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    mine just came on too is it the same procedure for a 2018 SR5 ?
  5. Mar 27, 2022 at 7:20 AM
    Metrojaybrown
    Metrojaybrown New Member
    2015 Tundra crewmax XP
    Did a 2 step paint correction with chemical guys compound and polish. I bought my truck used and it had a bunch of swirl marks all over the truck, I got rid of most of it you have to really be looking for imperfections to see anything. It took me a total of 12 hours, split into 3 sessions.
    Will1606, DCB500, SMTundra and 19 others like this.
  6. Mar 27, 2022 at 7:33 AM
    Taco-Spike
    Two Trucks
    It might be. I’m not sure if the center cluster changed on the 2018
  7. Mar 27, 2022 at 7:49 AM
    Brown747
    Brown747 New Member
    2021 Cement Crew Max LTD
    This is Cat Security’s main shield plus the rear cat protector. (+199) free shipping and military discount offered.
    Comes with complete stainless hardware including security bolts and clear instruction sheet. 1/8” and 3/16” options. I ordered the 1/8 and feel as a deterrent that it is stout enough. Rep when I called said the 3/16 is liked by the serious off roaders as skid protection also. The rear plate does leave the rear of the aft cats somewhat exposed. Hopefully the rat bastard that crawls under there will see the work involved to get at the rest and move on. I received the kit within 10 days of placing the order and install was maybe 90 minutes taking my time. Two thumbs up.
  8. Mar 27, 2022 at 7:56 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Nope
    no luck there
    you can hit my build thread for details on the switch install though - first post is hyperlinked to each mod. you’ve done most of the work already getting them in and wired.
  9. Mar 27, 2022 at 7:57 AM
    Bluedevils4life
    Bluedevils4life New Member
    Jeff
    2020 Toyota Tundra
    RBP Running Boards, 20% Window Tint, TRD Exhaust
    Amp Research steps installed and CORSA exhaust.
  10. Mar 27, 2022 at 8:00 AM
    RainMan_PNW
    Casey
    Clark County, WA
    No.
    18+ you go to settings using the pad for the center info display and then there’sa setting for Maintenance to reset it. I just did it yesterday in mine
  11. Mar 27, 2022 at 11:15 AM
    FlyingWolfe
    FlyingWolfe Wolfie
    Crystal
    Maine
    2018 TRD Off-Road Inferno
    Got sick of the giant cupholders not holding any of my drinks so hubby 3D printed an insert for me. :thumbsup:
  12. Mar 27, 2022 at 11:23 AM
    Boisefly
    Boisefly New Member
    Boise, ID
    2014 Crewmax 1794 4WD
    Did you go with the standard one or HD? Mine is supposed to arrive on Tuesday.
  13. Mar 27, 2022 at 11:26 AM
    Taco-Spike
    Two Trucks
    Ah, I knew it changed to be like my Tacoma just wasn’t sure which year it was.
  14. Mar 27, 2022 at 11:54 AM
    drgordon13
    drgordon13 New Member
    2020 Gray Tundra TSS
    I have the switch installed but am not sure which wire goes into which pin hole...there is a blue and yellow wire coming from the mirror...there are two spots from the stock wiring harness i can tap into...also do you know what type of connector fits into that particular harness?
  15. Mar 27, 2022 at 12:30 PM
    tundratoofun
    tundratoofun Yall better rednekonize
    Glendale
    Beast
  16. Mar 27, 2022 at 12:42 PM
    :101010:
  17. Mar 27, 2022 at 1:42 PM
    imcalister
    imcalister New Member
    Scott
    Van Alstyne, TX
    2020 Tundra CM Attitude 5.7L 4x4
    Busy day!!!
    Removed SR5 emblems. Need to get clay bar to remove remnants.
    Painted the cats a bright red. Tried etching last 6 of VIN but the $7 engraver sucks. (Ordered the Cat Security plates).
    Replaced rear chrome bumper end caps. Ordered some gloss black powder coated ones off eBay. Black is super forgiving. Can’t even tell it’s not Attitude Black.
    Added color match hood bulge and TRD Pro grill.
    Added TRD Pro black headlights (used ihacker harnesses for easy install).
  18. Mar 27, 2022 at 1:43 PM
    Cl8NL
    Cl8NL Pocket-Sand
    MKE WI
    2017 SR5 5.7 4x4 quicksand dbl cab
    I inquired about one at my local place. $900 seem reasonable? Tunes in my past vehicles have been like $200
    Toys4tots33 likes this.
  19. Mar 27, 2022 at 1:48 PM
    Cl8NL
    Cl8NL Pocket-Sand
    MKE WI
    300BLK and Toys4tots33 like this.
  20. Mar 27, 2022 at 1:52 PM
    brkncly
    brkncly New Member
    Oregon
    What’s the advantages of ceramic window tint vs non-ceramic window tint? Getting ready to do mine.
  21. Mar 27, 2022 at 1:54 PM
    RobertD
    Robert
    DFW, Texas
    The ceramic reflects a ton of heat (from what I hear) so if you leave somewhere hot and or sunny, getting a clear coat on your windshield and your other windows tinted reduces the heat in the cab by a lot. I live in Texas and learned about ceramic tint about 2 months after getting regular tint... it was about 150-200 more to do ceramic and it would have been 100% worth it.
    KingsAustin likes this.
  22. Mar 27, 2022 at 1:57 PM
    18" TRD Off Road Wheels
    Ceramic blocks heat better. You can actually get clear ceramic tint that will block better than some of the darkened non ceramic. Downside to ceramic is it can interfere with things like cell signal.
  23. Mar 27, 2022 at 1:58 PM
    RobertD
    Robert
    DFW, Texas
    Really? I hadn't heard that about the cell signal. Is this just for window tint or also for ceramic coating on your paint?
    GODZILLA[QUOTED] likes this.
  24. Mar 27, 2022 at 2:00 PM
    OOPS! My brain crossed the wires. Ceramic DOES NOT interfere. It was some of the metallic tints that do. They were better at heat deflection than regular tint, but ceramic gets the same bonus without the signal mess.
    RainMan_PNW and RobertD[QUOTED] like this.
  25. Mar 27, 2022 at 2:33 PM
    Ceramic won't fade either. I have it on mine.
  26. Mar 27, 2022 at 2:46 PM
    tundratoofun
    Glendale
    Beast
    :smack:
  27. Mar 27, 2022 at 2:54 PM
    beaver6713
    beaver6713 2015 CM
    Kleve
    Safford Arizona
    2015 Tundra CM
    6 inch Pro Comp lift. OME rear springs with Coach Builder +3 shackles. Coach Builder tie rod ends. ICON 2.5 front and rear shocks with remote res. ICON Hyd bump stops. 35" Nitto Trail Grapplers on 18" fuel rims. Kenwood DNX 892 head unit with JL audio and RF amp pushing 2 Image Dynamics idq10 subs. SABM, S POD switches for 42" in bumper and 32" behind grille LED light bars. Full interior and exterior LED conversion. LED flush mount back up lights in rear bumper. Valentine one radar detector. V Leds under dash and seats foot well lighting. TRD pro head lights and grille. Full AJT dash kit
    4 years ago I had my 2015 CM done with EXPEL PLUS PRO ceramic tint on all 6 windows (70% on front windshield) and also had them put it on my new head light housings as I just bought the 2019 LED ones, it prevents sun fade. The ceramic blocks 98% of radiant heat, the darkness of your tint does not dictate how much heat will be kept in or out. It is the material that does. Pay the extra money and get ceramic if you live in hot areas. I am in Arizona.
  28. Mar 27, 2022 at 3:06 PM
    JJcksn12
    JJcksn12 New Member
    Jay
    2025 MBM Limited TRD OR
    3” TRD Suspension Lift
    X2. Ceramic is 100% the way to go.
  29. Mar 27, 2022 at 5:42 PM
    a522467
    a522467 Life’s short. Live now.
    Michelle
    Ohio
    2020 Black Tundra Doublecab 4X4 SR5 with SX pkg
    Rear spring upgrade, rear shock upgrade, front & rear sway bars, bed step, bed mat, console organizer & tray, black lug nut covers, rear underseat storage box, black seat covers, Bluetooth CarPlay adapter, LED fogs, blue footwell lighting, LED cargo, reverse, tail, and stop bulbs, tinted tail and 3rd stop/cargo lights, tinted glass all around, tinted front emblem, matte black tailgate emblem inserts, retractable tonneau cover w/trac system and load bars, front facing camera, 8” exhaust upgrade, LED bed lights, 8-ball shifter knob, shifter boot, LED headlights, custom wheel center caps, 3”x30’ tow recovery strap, bed rail clamps, LED puddle lights, phone mount, OBD2 scanner, touchscreen glass protector/overlay, trailer hitch lock, tire traction aid, tinted license plate cover, power relay module, 6-way fuse block with cover, stainless mesh cowl screens, LT265/70R18 A/T tires, driver’s side swing case toolbox, dual air horn kit, rear Husky Liner, cat converter theft deterrent covers, front & rear dash cam, LED tail light bar, trailer plug wiring harness, locking fuel door, matte black interior door handles, glovebox & fuel door keyhole decals, TUNDRA sill plates decals, chalk bag cup holder / trash can, HD Roadmaster active suspension kit, HD front struts, Backlit window control panel, tailgate gap cover, matte black radio surround. https://www.tundras.com/threads/740-yota-2020-sr5-4x4-dc-w-sx-pkg.79742/
    HD. I don’t tow, but I often haul heavy cargo long distances. Hoping the RAS will reduce the sag when loaded.
    Boisefly[QUOTED] likes this.
  30. Mar 27, 2022 at 7:39 PM
    Cfincke
    San Antonio
    A buddy got a hunting lease 4.5 hours south, so we decided to go scout 400 of the 700 acres to see where he may want to set up a blind, feeders, and game cams. There were several old blinds, but the structural stability was questionable on a few. Also several oil pump sites, so there were some nicer gravel paths. There were several large berms to act as a back stop to shoot into from 100 yards to 1100 yards.
    I added a few pin stripes to the truck while driving several of the hunting trails.
