  1. Mar 26, 2022 at 11:00 AM
    Metrojaybrown
    Metrojaybrown New Member
    2015 Tundra crewmax XP
    Installed a 2019 TRD grille on my 2015 SR5. Loving the new look. Now I just gotta get rid of the chrome on the bumper caps. Anyone on here use spray paint to paint the bumper caps black? If so what did you use?
  2. Mar 26, 2022 at 11:24 AM
    Fitzf15E
    Fitzf15E New Member
    2021 Limited DC TRD OR Cement
    Transmission cooler installed. This was one of the MHX-514 "ugly weld" ones that Nicholas had a deal on at the end of last year. The truck didn't get much use over the winter, and I wasn't going to lay on the floor of the shop doing the install when it was 15 degrees out, so just now got around to it.
  3. Mar 26, 2022 at 12:20 PM
    k3k0a808
    k3k0a808 New Member
    2021 1794 WCP
    Painted my caps wind chill Pearl, and center garnish matte black, process is the same, I used 80grit sand paper on my random orbital sander to scuff up the chrome, used self etching primer, color coat (your case black, doesn’t matter flat or gloss), then used 2k matte black (the spray can that you pop the red button to mix). You should only need one can of each
  4. Mar 26, 2022 at 12:28 PM
    HARPER306
    HARPER306 New Member
    SK, Canada
    2020 Voodoo TRD Sport CM
    5100s up front on middle setting the other day, little how it started vs how it's going
  5. Mar 26, 2022 at 12:32 PM
    Bergy24
    Bergy24 New Member
    2021 Cement Crewmax Limited TRD 4X4
    Ran some errands this morning and my wife noticed the door edge guard coming off her door. Since I was only 2 minutes away from the dealer I thought I would stop in and get them to order a new one since it’s under warranty. No problem with that, but… then I see this on my driver seat. They got the ink out but ruined the seat bottom in the process. Now they have the door edge guard and a seat bottom ordered. Should be 4-5 day lead time. I’m not happy about this but I’m sure it wasn’t done intentionally.
  6. Mar 26, 2022 at 12:37 PM
    Bergy24
    Bergy24 New Member
    Did you take the parts off or paint in place?
    Metrojaybrown likes this.
  7. Mar 26, 2022 at 12:37 PM
    redrum448
    redrum448 New Member
    I used this https://www.dipyourcar.com/collecti...black-hyperdip-aerosol?variant=31572374847571
    1 can for front, 1 can for back, looks near exact.
    Steelerjax, Sean492, GAknight and 5 others like this.
  8. Mar 26, 2022 at 3:15 PM
    Echilders75
    Echilders75 New Member
    I just bought a 2014 5.7 liter SR5 tundra with the multi informational display. Does it have an oil change light or reminder? I am a little confused where it is, and is it due for a change?
  9. Mar 26, 2022 at 3:54 PM
    Taco-Spike
    Two Trucks
    Check the dip stick. If it looks dirty, change it. Or low / high just change it. Start off fresh.
    oil change maintenance light comes on every 5k.
    welcome. Congrats on the new truck
  10. Mar 26, 2022 at 3:59 PM
    Echilders75
    Thanks. Where is the oil maintenance reminder on the multi-informational display?
  11. Mar 26, 2022 at 4:01 PM
    Taco-Spike
    Two Trucks
    not a display but just a light that will come one. This is the reset procedure
    Do you have just a base SR5?
    2010bigdog and RegGex like this.
  12. Mar 26, 2022 at 4:03 PM
    Echilders75
  13. Mar 26, 2022 at 4:54 PM
    RobertD
    Robert
    DFW, Texas
    Hit up @memario1214 for a good price
    memario1214 likes this.
  14. Mar 26, 2022 at 4:59 PM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    It will pop up like this.
    Taco-Spike likes this.
  15. Mar 26, 2022 at 5:07 PM
    Echilders75
    Aha, that is what I needed to see. Thank you
  16. Mar 26, 2022 at 6:14 PM
    k3k0a808
    k3k0a808 New Member
    2021 1794 WCP
    i painted the caps in place, i took the middle off
  17. Mar 26, 2022 at 6:26 PM
    RegGex
    RegGex I noticed you copied my beard
    Oregon
    2021 TRD Pro CM
    Got mine done locally. If you’re in Oregon I can pass you on his info if you’re interested.
    Bergy24[QUOTED] likes this.
  18. Mar 26, 2022 at 6:44 PM
    SimpleMan
    SimpleMan New Member
    Chuck
    2021 SR5 TRD OR 4x4
    Diamondback HD
    Finished installing my Carhartt seat covers and installed the OEM remote tailgate lock.
    9blz16E0B0_kpbMlgPEZGqZcSptjFoSLZh_P4lBr_7d31ef4408f63b7c37c5608db16b39c2d437b1a4.jpg
    rebmo, GAknight, Ted4311 and 5 others like this.
  19. Mar 26, 2022 at 6:54 PM
    It does have CarPlay. I have no idea if it is compatible with the JBL or not. Someone here will know. My truck is a 2020 SR5 non-JBL with a factory amp under the seat.
  20. Mar 26, 2022 at 7:05 PM
    a522467
    a522467 Life’s short. Live now.
    Michelle
    Ohio
    2020 Black Tundra Doublecab 4X4 SR5 with SX pkg
    Rear spring upgrade, rear shock upgrade, front & rear sway bars, bed step, bed mat, console organizer & tray, black lug nut covers, rear underseat storage box, black seat covers, Bluetooth CarPlay adapter, LED fogs, blue footwell lighting, LED cargo, reverse, tail, and stop bulbs, tinted tail and 3rd stop/cargo lights, tinted glass all around, tinted front emblem, matte black tailgate emblem inserts, retractable tonneau cover w/trac system and load bars, front facing camera, 8” exhaust upgrade, LED bed lights, 8-ball shifter knob, shifter boot, LED headlights, custom wheel center caps, 3”x30’ tow recovery strap, bed rail clamps, LED puddle lights, phone mount, OBD2 scanner, touchscreen glass protector/overlay, trailer hitch lock, tire traction aid, tinted license plate cover, power relay module, 6-way fuse block with cover, stainless mesh cowl screens, LT265/70R18 A/T tires, driver’s side swing case toolbox, dual air horn kit, rear Husky Liner, cat converter theft deterrent covers, front & rear dash cam, LED tail light bar, trailer plug wiring harness, locking fuel door, matte black interior door handles, glovebox & fuel door keyhole decals, TUNDRA sill plates decals, chalk bag cup holder / trash can, HD Roadmaster active suspension kit, HD front struts, Backlit window control panel, tailgate gap cover, matte black radio surround. https://www.tundras.com/threads/740-yota-2020-sr5-4x4-dc-w-sx-pkg.79742/
    Added RAS today. Easy to install. Set at white (25%) tiddlywink spacer; added about 1” of rake. Took it for a test ride. Happy so far.
  21. Mar 26, 2022 at 7:50 PM
    tundratoofun
    tundratoofun Yall better rednekonize
    Glendale
    Beast
    Just a good wash/wax. I am still happy with chemical guys Insta-wax.
    WBW likes this.
  22. Mar 26, 2022 at 8:22 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Boost power fold mirrors came in yesterday so today was the day and man they're sharp.
    Only thing I don't like is the switch doesn't fit into the stock openings and it isn't illuminated. We did the install in a buddy's 2019 as well...
    20220326_124431.jpg 20220326_124436.jpg20220326_203438.jpg 20220326_203504.jpg
  23. Mar 26, 2022 at 8:37 PM
    RobertD
    Robert
    DFW, Texas
    How was the install? Hoping to get mine on this week.
  24. Mar 26, 2022 at 10:10 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    EZ mode. Funnest part is running wires through your door boot. Use baling wire or a wire coat hanger. I had puddle light wiring from my previous lights so I tied onto one of those wires and pulled stuff through.
    RobertD[QUOTED] likes this.
  25. Mar 26, 2022 at 10:54 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Mine come in Tuesday - looking forward to installing.
    a522467[QUOTED] likes this.
  26. Mar 26, 2022 at 10:55 PM
    RainMan_PNW
    Casey
    Clark County, WA
    It is possible to make them work with the factory 2007-2013 Limited power fold switch - then you don't need a separate switch taking up space.
  27. Mar 26, 2022 at 11:12 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Oil change, Engine air filter, cabin air filter, and installed Fumoto oil drain valve and the aluminum oil filter housing.
    Also noticed the powder coat on my NFab stainless steps is coming off pretty bad. I need to get the truck cleaned up and figure out what I want to do about it... Not sure I want sliders that are made out of carbon steel. Might end up pulling these and getting them Line-X'd.
  28. Mar 27, 2022 at 12:57 AM
    k3k0a808
    k3k0a808 New Member
    2021 1794 WCP
    how do you like your tune? Debating on doing this, I did it for my Tacoma and it’s good, but it really needed it with the shifting and my 5.29 gearing
  29. Mar 27, 2022 at 3:43 AM
    Njmike13
    Njmike13 New Member
    Hunterdon county, NJ
    2021 PRO Lunar Rock
    Had the same thing happen on 2017. They sent me a new set for free and let me keep the original set. The bad thing is it happened again to the 2nd set.
    RainMan_PNW[QUOTED] likes this.
  30. Mar 27, 2022 at 3:55 AM
    Bergy24
    Bergy24 New Member
    Which ones did you go with? Where did you order from and how do you like the fit? Any issues with install? After the dealer mishap I posted above, I think I need some covers to prevent future issues.
