  1. Mar 20, 2022 at 2:12 PM
    GCanuck
    GCanuck Member since 2020
    Gary
    BC,Canada
    2020 Tundra DC MGM TRD Sport
    TRD Swaybars. Line-X bed liner. Toyota Tri-fold Tonneau. N-fab side bars. TRD cold air. AMP bed extender. Rough Country Level kit. BFG A/T K02. RCI Skids. OEM Tow mirrors. TRD exhaust
    Did you strip out the noise deadening foam underneath?
    BlueRibbon4x4[QUOTED] likes this.
  2. Mar 20, 2022 at 2:44 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Snagged a fully loaded ARE cap that even matches color for a great price! Worth the drive.
    superdenk, GAknight, booya69 and 37 others like this.
  3. Mar 20, 2022 at 2:51 PM
    Clay J
    Clay J Yota Fan
    Clay
    DFW, TX
    2021 CM 4x4 TSS
    Eibach Stage 1, Pro LED headlights, RCI engine skid plate, Retrax MX tonneau, Ranch Hand front bumper.
    Installed a Retrax MX tonneau cover.
  4. Mar 20, 2022 at 2:53 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Thanks!!!
  5. Mar 20, 2022 at 2:53 PM
    BlueRibbon4x4
    Geno
    Nope. Still there.
  6. Mar 20, 2022 at 3:16 PM
    plact88
    plact88 MGM SR5 CM
    Tucson, AZ
    2021 MGM Tundra Crewmax
    VLED Interior VLED Cargo Light VLED Reverse Light Driverside Grab Handle Bilstein 5100 front 2nd setting TRD Dual Exhaust Black Chrome AJT Chrome Delete TRD Air Filter Tyger Side Steps TVD Vinyl Decals MGM Tundra Radio Decals TVD Vinyl Decals MGM Tailgate Handle Decals Tundra Tailgate Badge Chrome Moto Metal 970 wheels 275/70/18 KO2 Tires TRD Rear Sway Bar MGM Door Handles and Mirror Caps TRD Pro LED Black Housing Headlights Black Housing LED Fog Lights AJT Black Door Handles AJT Black Steering Wheel Controls Tacoma Leather Steering Wheel Pedal Commander TRD Pro Hood Scoop 12 Volt Solutions Remote Start Clazzio Leather Seat Covers
    Front sway bar and heritage decal from TVD20220320_150624.jpg 20220320_150615.jpg Vinyl.
  7. Mar 20, 2022 at 4:28 PM
    Yzed608
    Yzed608 New Member
    Wisconsin
    Put a new set of wipers on after almost 5 years. Some Trico Force's from Farm and Fleet. Seem ok so far, the 22" passenger is a touch shorter than the OEM blades though, maybe 1/4-1/2" on the end (just judging off of the wipe arc, I didn't actually measure the arms back to back). Seemed ok with just the wiper fluid test, will see how they are when it rains. Kept the stockers in the back seat until I know they work ok. They weren't destroyed but in salt spray they weren't getting full contact anymore.
    ATV25 likes this.
  8. Mar 20, 2022 at 6:13 PM
    jefroshm0
    jefroshm0 New Member
    Elk Grove, CA
    2018 Cement Tundra Crew 4x4 SR5
    Finally got to use my ARB air up kit and JACO digital gauge. Helped the work car out of a flat.
  9. Mar 20, 2022 at 6:18 PM
    Daganh62
    Daganh62 New Member
    2017 TRD Off Road
    Hyperdipped my bumper end caps. I would say it went OK. Two of the twelve mm bolt holes ended up messed up. One was hard to get out so not sure if it was cross threaded at the factory. The other was severely rusted but I will eventually re tap them and replace the bolts.
    jclem65, mgm16trdpro and WFD473 like this.
  10. Mar 20, 2022 at 7:43 PM
    DPhung
    DPhung Measly Mechanic
    David
    North AL
    2016 MGM Tundra CM
    Had a little fun before the movies. Got some interior goodies on the way, can’t wait!
  11. Mar 20, 2022 at 8:09 PM
    InfernoBoyz
    InfernoBoyz YoutubeTech
    Reno, NV
    2016 Inferno Tundra Double Cab OR
    Bad ass truck. Love the DC with the shell. What size tires ?
    Silver17[QUOTED] likes this.
  12. Mar 20, 2022 at 8:43 PM
    GravityGear
    GravityGear Parking Lot Prerunner
    Aurora, CO
    2014 Black DC TSS Off Road 4x4 5.7
    Transfer Flow tank, Pinstripe Suit
    looks like you've got a bit of an alignment issue there.
  13. Mar 20, 2022 at 8:44 PM
    Cfincke
    San Antonio
    Went camping over the weekend.
  14. Mar 20, 2022 at 9:07 PM
    RoniusMaximus
    RoniusMaximus The One and Only
    J
    Tri-Cities, Washington
    2020 MGM Toyota Tundra TRD PRO
    Synthetic Blinker Fluid
    Changed my oil for the first time. I have heard too many horror stories about Toyota dealership mechanics locally that it made me nervous about my initial appointment a few months ago. When I went in for my appointment, I was told it would be a 3-4 hour wait and that the kids area was closed (I had my toddler with me). Also, no loaner cars available either so I went back in my truck and left.
    Anyways, I had such a nightmare with this first oil change (5,406 miles). I replaced the oil drain bolt with a fumoto and that was all good. Then, I switched out the plastic filter with a metal one as recommended by many on here which I felt went smooth. After adding the first 5 quarts of oil, all was good. Once I got to putting in the remaining 3 - 3.5 quarts, I started to hear a water fall and luckily my oil catch pan was at the right place catching all the over flow. Figured I didnt tighten the filter down tight enough so I tightened it some more.
    Cranked the truck and holy cow a waterfall of oil started coming down from the filter area again. I turn off the truck and knowing my local NAPA was going to close soon, I picked up more oil just in case. After removing the oil filter and inspecting it I noticed the large O-ring broke! I swear I put it in the right place but I do recall when I first installed the oil filter housing, there was some strange resistance. I ended up re-using the old large O-ring for now and after checking it over multiple times I was happy to see all was finally good with the truck. The fun part was going back and forth checking my oil level. It appears the oil is a little bit above the high mark but all seemed fine.
  15. Mar 21, 2022 at 5:41 AM
    DPhung
    David
    North AL
    2016 MGM Tundra CM
    What makes you say that? Genuinely curious.
  16. Mar 21, 2022 at 5:50 AM
    tundratoofun
    tundratoofun Yall better rednekonize
    Glendale
    Beast
    Not yet, but Ima try again at cleaning up my bed liner... Dawn and purple power have not worked. So last night a picked up a big ass bottle of purple ZEP, that will get the shit off my truck for sure. Then itll kill all the fishies when I run it down a storm drain. Sorry nature, i tried the friendly stuff, now its time to get down to business!!
    texasrho83 likes this.
  17. Mar 21, 2022 at 5:56 AM
    Silver17
    Eastern PA
    Thank you! The tires are 295/70r17. They’re a good compromise of looks and capability, without giving up too much power.
    InfernoBoyz[QUOTED] likes this.
  18. Mar 21, 2022 at 6:01 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Are you trying to get it back to when you bought it condition or just cleaner than it is now?
  19. Mar 21, 2022 at 6:01 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Oil change mechanics truly are the fry cooks of the automotive world. Who is going to care more, the guy who is paid $15/hr to change oil as fast as he can all day long or the guy who spent $40k on a truck and really doesn't want to screw it up?
  20. Mar 21, 2022 at 6:03 AM
    tundratoofun
    Glendale
    Beast
    Trying to get weird neon paint off of it. I moved some lockers for a skating rink and have that nasty blacklight paint all over it.
  21. Mar 21, 2022 at 6:06 AM
    tundratoofun
    Glendale
    Beast
    If your asking me, I was the oil change guy and that $15/hr was paying for my $45k truck, my chow, and my home. I needed that job more than you know and wasnt trying to fuck it up. Sometimes shit happens, it happens to everybody, just in different shitty ways.
  22. Mar 21, 2022 at 6:15 AM
    Terndrerrr
    Music City
    6UR-FE
    It was a rhetorical question. I've had more issues with other people changing my oil than I'm comfortable with. Mostly younger guys who are paid to get it done quickly. Wrenches left on the cowl under the hood. Filters half screwed on. Oil underfilled by two quarts.
    The last straw was with my 4Runner when one guy put the bigger filter O-ring in the wrong spot (right up against the canister threads) and torqued the filter canister into the housing threads so tight he flattened the O-ring into a washer. I drove the 4Runner like that for two weeks until the first cold snap of Fall when the O-ring shrunk a bit and I walked out very early to a puddle of oil under my 4Runner. It was still dark, and I would not have noticed (I back in to my driveway) if I hadn't walked in front of the 4Runner to move one of my kids' bikes that was left in my way. I am never taking advantage of a free oil change ever again.
    I'm glad you took your job very seriously. In my experience you're the exception. :cheers:
  23. Mar 21, 2022 at 6:19 AM
    raspy87
    raspy87 New Member
    Andrew
    RI
    ‘19 DC SR5 Cement
    2Tall[QUOTED] likes this.
  24. Mar 21, 2022 at 6:48 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Way back in the day I worked at several oil change/quick lube companies. They're sharks. Upsell, upsell, upsell. Jiffy Lube was the worst. Tear wiper blades to sell a set (during inspections was the prime time to do this), create dirty fluid samples to sell replacement services (flushes, fuel filters, etc). I refused to do these things so my tenure was short. I did end up at a dealership but realized the tech helpers there weren't much better unless they were on track to becoming mechanics.
    Minute Man would give a cut to the pit guy and top man (dude handling engine bay) so the upselling was rampant there. My manager was a mostly decent guy except for slow months and days he wanted to push numbers up. He wouldn't screw over old folks and most women though lol.
    I tell everyone I know to do your own maintenance. You have a much higher probability of doing it better via YouTube videos than some hack in Wally World who was doing housewares the week before
  25. Mar 21, 2022 at 8:03 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    I used to change my oil in all my vehicles. Nowadays, it is a PITA to do it all, and the Sequoia and Tundra use more oil, and the prices at the local auto supply shop don't offset the hassle so I just let the dealer do it. I usually make an appointment, wait approximately 45 minutes in the lobby, they recycle the oil for me, and I'm done. I purchase the three (3) oil change packages for around $220 for the Tundra, and $199 for the Avalon.
    I have no issues with my Toyota dealer...
    booya69 likes this.
  26. Mar 21, 2022 at 8:23 AM
    Army_of_One
    Army_of_One New Member
    2019 MGM 4X4 CrewMax, 2005 Cement 4x4 Double Cab
    OEM+
    I got tired of my Tundra coming back from the dealer missing the front skid bolts and retainers...
  27. Mar 21, 2022 at 8:35 AM
    Caliraisedled
    Caliraisedled New Member Vendor
    Jake
    Let us know if you have any questions!
  28. Mar 21, 2022 at 8:45 AM
    Those brackets won't work if there is a transmission cooler installed. The fit is extremely tight. I am against the grill and the cooler....I may end up removing the lights from behind the grill due to this.
    1794TX likes this.
  29. Mar 21, 2022 at 8:46 AM
    1794TX
    Steven
    N.TX
    '20 1794
    thank you sir.
    Tundra234[QUOTED] likes this.
  30. Mar 21, 2022 at 8:48 AM
    GarTX526
    GarTX526 New Member
    2016 QuickSand TRD-Pro
    Many pending.....
    BEASTMODE!!!
