  1. Jan 13, 2022 at 4:22 PM
    pvmike
    pvmike Home Depot flexing
    Los Angeles
    2014 Platinum Super White
    TRD Pro suspension, supercharger, 5.29 gears, Auburn LSD
    Yup, it was like a new truck.
    parkerbows[QUOTED] likes this.
  2. Jan 13, 2022 at 4:26 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Installed my seat jackers today before work. Wow what a difference. Should have added them when I first got the truck. Is crazy how much more comfortable the seat is.
    So, for anyone new looking to mod- These two mods are probably the BEST for the cost for a street driven truck. And some of the cheapest mods at around $300 to do both of them! Desert does it seat jackers and TRD rear sway bar
  3. Jan 13, 2022 at 4:52 PM
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    wow crazy
  4. Jan 13, 2022 at 4:54 PM
    parkerbows
    Jack
    can you explain how different from leaning seat back with controls?
  5. Jan 13, 2022 at 6:00 PM
    AggiePhil
    AggiePhil Texas Chapter President
    College Station, TX
    2020 Smoked Mesquite Platinum 4x4
    Greater range of motion than the built-in adjustment allows.
    That said…I didn’t like them and sent them back. I run my front seat edge lowered so I guess I should’ve predicted this outcome.
  6. Jan 13, 2022 at 6:28 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Do seat jackers lower your payload?
    BlancaLaGordita likes this.
  7. Jan 13, 2022 at 6:34 PM
    TunsofFon
    TunsofFon New Member
    Pacific NW
    2021 MGM Platinum
    No, but they do rob you of horsepower.
  8. Jan 13, 2022 at 6:35 PM
    bflooks
    bflooks New Member
    Metrowest MA
    More than 10?
  9. Jan 13, 2022 at 6:37 PM
    TunsofFon
    Pacific NW
    2021 MGM Platinum
    You can always add a knock off TRD shifter to offset your -10 HP loss. The OEM TRD shifter is +15 if you find it worth the extra $$.
    GAknight, camron1039, Vr0ck and 4 others like this.
  10. Jan 13, 2022 at 8:33 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    :itllbuffout:
    (I hope)
    Hopefully insurance gets you while again. Depending on the amount of damage, look into a “diminished value” claim as well.
  11. Jan 13, 2022 at 8:46 PM
    juice77
    juice77 New Member
    Sacramento, Ca
    2019 SR5 CM TRD 4x4
    Actually yesterday, but swapped out my BD S2 pros for squadron pro’s.. much better! S8 bar next in the hood bulge!
  12. Jan 13, 2022 at 8:58 PM
    TunsofFon
    Pacific NW
    2021 MGM Platinum
    Awesome. I’ll be running the same setup whenever the lights get to me.:confused:
    juice77[QUOTED] likes this.
  13. Jan 13, 2022 at 8:59 PM
    TunsofFon
    Pacific NW
    2021 MGM Platinum
    Did you go white or amber for the S8?
  14. Jan 13, 2022 at 9:51 PM
    twintundra31719
    twintundra31719 New Member
    NV
    Looks good man!
    Superbsdad[QUOTED] likes this.
  15. Jan 13, 2022 at 10:10 PM
    juice77
    juice77 New Member
    Sacramento, Ca
    2019 SR5 CM TRD 4x4
    both
    GAknight, pvn.beluga, YotaBro and 5 others like this.
  16. Jan 13, 2022 at 10:12 PM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    '21 Cavalry TRD Sport CM Tundra & 25 TRD Pro Sequoia
    I run my seat all the way back and all the way down in the rear of the butt and up all the way on the thigh (front) of the seat.
    here is a direct comparison of the seat in the same position but With the added seat jackers. Take a look at the plastic trim on the driver seat and you can see the difference. They rock the seat back giving you a more cradled seating position. Significant improvement in comfort
    GAknight, 3xYOTA, HamHands and 4 others like this.
  17. Jan 13, 2022 at 10:13 PM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    what dreams are made of!! Can’t wait to see it installed!
  18. Jan 13, 2022 at 10:38 PM
    diablodalton
    diablodalton New Member
    Dalton
    Oregon
    2021 Crewmax Platinum MGM
    8" Ready Lift, SPC UCA's., Bilstein B8 8125, Amp Steps, 37/12.5R 20 Cooper STT PRO, On order: Valhalla Armor, Dirty Deeds Exhaust
    90% recovered from COVID (yes vaccinated) which Santa brought me! Finally felt good enough to tackle some projects!
    My son busted out his drone practicing for some future trips!
  19. Jan 13, 2022 at 11:03 PM
    TunsofFon
    Pacific NW
    2021 MGM Platinum
    Never thought about doing that with the S8. I like the idea. Mine will be full amber to start. Might have to switch some to clear if I feel it needs it.
    Can’t wait to see pictures of your rig when you finish!
  20. Jan 13, 2022 at 11:47 PM
    The S8 install in the bulge is a pain in the rear. I had to experiment with mine quite a bit. I installed mine as far back as I could and reused the screen from the scoop. I did not like the huge gap that was between the bulge and the bar. The corner clips will be interesting as well.
    juice77[QUOTED] and Toe404 like this.
  21. Jan 14, 2022 at 3:35 AM
    James07
    James07 New Member
    James
    Maryland
    2017 CM Platinum in Super White
    Ready Lift 3/2 General Grabbers ATX 35x12.5x17 Icon Alloys Rebounds 17 Window Tint Line-X Bed 32" Rigid Light bar in Bumper Stubby Antenna VLED under dash lights A-Pillar Grab handle Blacked out exhaust tip Shovel/Axe bed mounts
    @HamHands I used 1/4" steel from HD that I cut, drilled and bent. Then Rhino lined them. Used the T bolts to attach to the bed rail system of the trucks. I used quickfists to attach the tools to the metal brackets i built. Took about an hour total time to build and the fit nicely on the side and do not extend pass the wheel well so full bed useable.
  22. Jan 14, 2022 at 4:15 AM
    house
    house I blame you guys for my mod spending
    2019 MGM CM Limited 4x4
    Removed them, sanded the chrome, then sprayed the liner. The plastic parts have releases/tabs and come off easily.
  23. Jan 14, 2022 at 4:46 AM
    parkerbows
    Jack
    Oh yeah big difference. Thanks
  24. Jan 14, 2022 at 4:59 AM
    Badknees
    Badknees New Member
    South Carolina
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    Dang, how do these get broken unless they did it when trying to loosen/adjust for alignment? Never thought about it until your post, but I'm taking a picture of mine before my next alignment!
  25. Jan 14, 2022 at 5:25 AM
    Ericbike6
    Ericbike6 So we're doing this shit today?
    Eric
    Austin, TX
    2019 Tundra TRD 4X4 sport
    Air bags, ARK liners, misc bullshit added also
    Technically yes they do..
    But what's 8oz's amongst friends??
  26. Jan 14, 2022 at 5:33 AM
    Badknees
    Badknees New Member
    South Carolina
    I never let the wife drive my trucks. I think her Prius has a giant magnet on the rear as she's been hit 3 times in 5 years!...but it is a Prius and the gas pedal feels like a sponge is connected to the throttle.
    Sorry for your troubles and hope a good body shop will make her like new again.
  27. Jan 14, 2022 at 5:42 AM
    Badknees
    Badknees New Member
    South Carolina
    Dang,
    You win the Best looking Top View Tundra award!...sorry, no cash. Just fame.
    3xYOTA, TNTundra16 and Barrett50 like this.
  28. Jan 14, 2022 at 5:56 AM
    frichco228
    Sure. My truck has power driver seat so it does have some height adjustment, etc. Problem is that is does not actually tilt back enough so there is not enough support under your legs. Raise and lower the seat and you can easily feel the seat kinds of tilts forward and as you adjust it you can feel the support of the seat leaving your legs. These little spacers raise the front of the seat about an inch and it really makes a huge difference in comfort. You are not perched on the seat, instead you sit back into it will full support of your legs. Amazing difference for 80 bucks.
  29. Jan 14, 2022 at 6:06 AM
    parkerbows
    Jack
    Cool thanks. next on my list
  30. Jan 14, 2022 at 6:36 AM
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    I mean this a tough one. They have to manipulate the bolts to align so if they break is it really the shops fault? I asked the question if it was already broken and they said when the tech went to adjust the cam bolt it was just spinning and they immediately brought me the broken part. Even if I could prove it happened when they adjusted the bolt - they have to for the alignment so it likely would have broken no matter who touched it. I certainly didn’t want to pay for it but not sure there is any way to avoid it in this case.
    Barrett50 and Badknees[QUOTED] like this.
