  1. Jan 3, 2022 at 8:32 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    touche'
    let's not delve into details.....but, yes.
    1UP[QUOTED] likes this.
  2. Jan 3, 2022 at 9:21 AM
    JPB_VT
    JPB_VT New Member
    Jesse
    ‘21 Nightshade Wind Chill Pearl
    Fox 2.5 Fox DSC front & rear Camburg UCAs Alcan leaf springs Kenwood 1037S HU OEM Audio Plus
    Hey Winter,
    FWIW, I just swapped my stock spare for a 295/70/18 on a +18 Method wheel. Fit just (barely) fine. About 1/2" from the shackle.
    Cheers.
  3. Jan 3, 2022 at 12:02 PM
    HamHands
    HamHands Honey-Glazed Member
    2018 Tundra DC MGM SR5 5.7 TRD 4x4
    Shouldn’t have added the color matched mirrors and door handles. Now every time I look at the truck I want to color match the rest of it. Great!
  4. Jan 3, 2022 at 12:15 PM
    SR5BART
    SR5BART New Member
    Bart
    Chicago
    21 SR5 TRDOR
    Took the truck through her first snow!!
    3xYOTA, DE_Tundra, Beesta and 13 others like this.
  5. Jan 3, 2022 at 12:49 PM
    ArdnuT trd
    ArdnuT trd New Member
    Blake
    2021 Tundra MGM TRD 4x4 CM limited
    Just got my BBS pro wheels on the way. Was going to just use stock michelins but they throw a lot of rocks forward and chip my color matched bumpers.
    I'll post pics. Anyone have a tire recommendation that's more agressive not too heavy that it affects performance and is slightly bigger that I don't need to cut anything? I'm on 6112@1.9 in the front thank you
    NAFlash likes this.
  6. Jan 3, 2022 at 1:01 PM
    jonclark96
    jonclark96 Not so new member
    Jon
    Maryland
    2021 Army Green SR5
    I don't have any personal experience with them, but one of the few options of tires that are available in larger than stock size but aren't E rated (and heavy) are the General Grabber ATX 275/70 R18 SL rated tires.
  7. Jan 3, 2022 at 1:13 PM
    ArdnuT trd
    Blake
    Hey dalton could you tell me what the ddr pro means? Are these your initials? If it is definitely a way to differentiate your truck from others. I'd be out of luck on the idea due to my initials being inadvertently bmw. Bmw pro on a tundra just doesn't work. I like the vintage look with the mgm definitely unique. What lift and size wheel and tire is this?
  8. Jan 3, 2022 at 1:13 PM
    TNTundra16
    TNTundra16 YOU BIG DUMMY!
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    First snow of the year
    3xYOTA, Jego, Rgross2112 and 19 others like this.
  9. Jan 3, 2022 at 1:16 PM
    cwtitan
    cwtitan New Member
    Chad
    2019 white Tundra TRD offroad
    Just had my scs Ray 10s installed. Kept my 275 70 18 Falkens because they are still I excellent condition. Will go bigger rubber next tire swap.20220103_153044.jpg
    Jego, equin, AZ Red Nek and 4 others like this.
  10. Jan 3, 2022 at 1:18 PM
    ArdnuT trd
    Blake
    Thank you for that. Just when I start looking at tires they're not the same between manufacturer with different 32nds of tread depth and so on. I want something that doesn't chip my front end like these michelins that looks more like it should've from the factory. Falkens nitto maybe the Baja boss rt that is brand new. I've read the bfg throws rocks a lot and the falkens have the snow rating but I've never used those. It's my first tundra after being primarily gm and I've out grown the 35 37's for now for my daily
    jonclark96[QUOTED] likes this.
  11. Jan 3, 2022 at 1:21 PM
    ArdnuT trd
    Blake
    Is that size great as in no rubbing no chopping but bigger than stock? How do you like the Falkens? Looking for a tire to put on my pro wheels that is beefier doesn't take up power with weight and looks like it should've rolled off the lot originally. I worry 295's would be too much without more modification I'm only running 6112 at 1.9"
  12. Jan 3, 2022 at 2:11 PM
    welshmike
    welshmike New Member
    DFW
    2021 cement Sr5
    Power steps, tonneau cover, blacked out badges, custom under rear seat storage, mirror covers, 2017 Trd pro color matched grill, plasti-dipped rims and bumpers. Trail grid pro FRAC, Start-x remote starter, Loncky leather steering wheel, leather shift knob. Painted cup holder-gear selector trim. Desert eagle off road cat shield, skid plate. Yitamotor floor mats. Calipers painted black. Kenwood amp, pioneer dash tweeters, infinity rear door speakers and tweeters. De-badged, Trd rear sway bar, ham radio antenna. Half console safe. Kenwood DMX1057XR. CDT 6x9’s. Sound deadening on doors.
    I’ll have to keep an out eye out, see if they do it again.
  13. Jan 3, 2022 at 2:35 PM
    Degausser
    Degausser New Member
    Kevin
    GA
    2024 LR SR5
    3dcarstickers.com
  14. Jan 3, 2022 at 2:40 PM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    I like the Toyo AT3's I have now. I'm not even switching to winter tires now, it's not a daily driver but a few hundred km's a month on -30 roads and a foot or so of snow and they've worked better than I expected. Lots of size choices to find what you like.
    GELCW likes this.
  15. Jan 3, 2022 at 3:30 PM
    Crews44
    Crews44 New Member
    Southern NJ
    2025 Platinum TRD MGM CM 3” TRD lift
    getting to the finish line. Got to do some metal glaze on top side but bottom is done. Was able to rebuild braces. Probably ditching bed liner and going LineXCB0BF955-4FE9-49AE-88F2-3F12C63AFBB5.jpg6875EB1C-B06C-4A95-BF64-E4FC9AD3D6F0.jpg8259F1BA-0D0E-4FFA-9BB8-17A81E39C129.jpg
  16. Jan 3, 2022 at 4:07 PM
    D3VA
    D3VA New Member
    NoVA
    2021 TRD Pro in the MGM Master Race!
    Had two weeks of almost 60 degree temps. Yesterday, when it was 62 degrees and I was installing the rear sway, the weatherman said 7-11 inches of snow today and no one believed him; ha, we should have listened, we got 14 inches. Power has been out since 11am and it doesn’t appear it will be back on anytime soon.
    First snow the TRD has experienced…
  17. Jan 3, 2022 at 4:52 PM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Awesome work ! ..quick question: Did you find much rust on frame (while bed is off) and if so what did you do for fix ?
  18. Jan 3, 2022 at 5:04 PM
    Crews44
    Crews44 New Member
    Southern NJ
    frame was fine actually. Jut a little surface rust so nothing to worry about.
  19. Jan 3, 2022 at 5:11 PM
    Blueknights75
    Ron
    Clayton, NC
    Love those RW wheels! Great looking truck!
    mikesTundra77[QUOTED] likes this.
  20. Jan 3, 2022 at 5:34 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Once you start, you can’t stop. Trust me.
  21. Jan 3, 2022 at 5:39 PM
    TampaRD Pro
    TampaRD Pro Cunning Linguist
    Stanley
    Southwest Florida
    2020 MGM CM TRD Pro
    Lots.
    Always loved this truck, it has been the inspiration for many of the mods to my MGM TRD Pro.
    mgm16trdpro[QUOTED] likes this.
  22. Jan 3, 2022 at 5:49 PM
    GreatBasinTundra
    GreatBasinTundra Beer Me!
    Reno, NV
    2020 Tundra SR5 DC
    Kings f/r, TC UCAs, RCI skids, RCI sliders, C4 bumpers f/r, Warn 12s winch, 35s on 17” Rebounds, softopper, wet okole covers
    Ordered the C4 rear bumper.
  23. Jan 3, 2022 at 6:58 PM
    NAFlash
    NAFlash New Member
    Randy
    Tundra TRD Sport 4x4
    I put Nitto Ridge Grappler on about 5k miles ago. Love them so far. I was worried about how they would handle in the rain, but this summer we had plenty of heavy rain (Florida) and was impressed. Work great in sand too.
  24. Jan 4, 2022 at 4:50 AM
    Ordered my Timbrens with 10% off, no tax, and free shipping.
  25. Jan 4, 2022 at 8:11 AM
    TundraMidwesterner
    TundraMidwesterner What?
    Northern Illinois
    2019 Magnetic Gray Metallic CrewMax TSSOR 4x4
    Katzkins, Rostra heated seats(4), Tint (all), TRD rear sway bar, TSS wheels, OEM black lug nuts and wheel locks, OEM LED black fog lights, Driver side grab handle, Rough country LED Bumper bar, Rough Country Hard tri fold tonneau cover, AVS ventshades, Bilstein 5100's on top setting in front, Ready lift 1 inch ready block in the rear with Bilstein 5100's. Fluid Film. ESP under seat storage. LED interior lights and cargo lights swapped. Rear USB charger port swapped for 12v port. Remote start. Leather wrapped steering wheel kit. TRD shift knob. Kenwood dmx1037s. Hertz K170 door speakers/ tweeters, Infinity Reference 7005A 5 channel amp, 2 JBL WS1000 10 inch subs. DDI Seat Jackers. RCI engine Skid and Vahalla's Shields (front and rear) 1/4 aluminum. Stillen intake. LED Pro Headlights with iHacker harness. Cartrimhome auto up and down window switches. Coupe's aluminum battery tie down. Color matched mirror caps. Color matched door handles. Chalk bag cup holder. NFab podium step bars, herculined. Powerstop z36 drilled slotted brake discs w/ceramic pads.
    Yesterday I finally had a chance to get a few things done on the Tundra. You will have to excuse the dog hair.
    ESP storage bins, LED interior lights, USB charger swap for the rear seats, remote start installed. Still have a few things left in my pile of parts to go on but it was nice to get some items checked off the list.
    20220103_132629.jpg 20220103_140506.jpg 20220103_132703.jpg 20220103_132710.jpg 20220103_145335.jpg
    3xYOTA, Rgross2112, nhw544 and 17 others like this.
  26. Jan 4, 2022 at 8:14 AM
    Flying Gorilla
    Flying Gorilla New Member
    Austin, TX
    2018 SR5 TSS Blazing Blue Pearl
    Factory Lift 35” Tires Black Rims
    Which Remote start did you go with? Looking hard at making this my new project.
  27. Jan 4, 2022 at 8:23 AM
    TundraMidwesterner
    Northern Illinois
    I would have gone with the Fortin from the member here on the site but I had some Amazon returns/credit and a gift card that pretty much made the start-x kit free.
    https://www.amazon.com/gp/product/B07P1NDL1W?ie=UTF8
    Install was easier than I thought it would be following the video on their site. Took me maybe 45 minutes. I did NOT install the button to disable the remote start if the hood is open as garage space didn't really allow me to at this time. Hopefully the first warm spring day I can tackle that.
    TucsonTundra1794 likes this.
  28. Jan 4, 2022 at 9:00 AM
    Northbound Train
    Northbound Train Masshole
    Glenn
    Western MA
    Black 2016 SR5 Double Cab 4x4 5.7
    Nice work!
  29. Jan 4, 2022 at 12:52 PM
    d_kinneyjr
    d_kinneyjr New Member
    Dave
    Southern NH
    2018 Crew Max SR5
    Your ride looks awesome. Have you put any type of lift on your truck?
  30. Jan 4, 2022 at 1:02 PM
    d_kinneyjr
    Dave
    Southern NH
    2018 Crew Max SR5
    Added the door handle stickers and center console badge from @TRDBeast!
