  1. Dec 18, 2021 at 11:50 AM
    VTYOTER
    VTYOTER Rock
    Torrey
    Vermont
    2021 TRD Pro LR
    35" KO2, METHOD 701, WESTCOTT COLLAR, CB+3, BUMPER SHIMS, CALIRAISED ROCK SLIDERS STEP EDITION, DIAMONDBACK HD
    I tried finding used here but didn’t have luck. Granted I didn’t wait long.
  2. Dec 18, 2021 at 12:16 PM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Yeah for the price there not bad. I rather just put a new set in. Are your fog diodes? Pro or Max?
  3. Dec 18, 2021 at 1:00 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Found some hidden trails today… definitely a nice change of scenery!
  4. Dec 18, 2021 at 1:33 PM
    VTYOTER
    VTYOTER Rock
    Torrey
    Vermont
    2021 TRD Pro LR
    Baja sport W/C. Took em off my Tacoma.
    RusPro21[QUOTED] likes this.
  5. Dec 18, 2021 at 4:39 PM
    Ron_Pro
    Ron_Pro New Member
    California
    2020 Tundra TRD Pro CrewMax
    Mounted some storage boxes and recovery boards.
    saybng, SMTundra, J&ATundra and 8 others like this.
  6. Dec 18, 2021 at 4:42 PM
    twintundra31719
    twintundra31719 New Member
    NV
    Nice!
    Ron_Pro[QUOTED] likes this.
  7. Dec 18, 2021 at 5:29 PM
    Badge618
    Badge618 New Member
    Lassen County, Ca
    2019 TRD Pro Voodoo Blue
    Bath, ESP rear seat storage, Craven Speed phone mount and untenna.
    Why did my pics rotate?
  8. Dec 18, 2021 at 5:42 PM
    Ted4311
    Ted4311 Don't Sweat The Small Stuff
    SOMD
    14 Tundra MGM TRD-OFFROAD 4X4
    A LOT... NEVER ENDS
    I LOVE THE VOODOO BLUE! Thought hard about trading in my MGM for the blue! I just love no payments.
    Badge618[QUOTED] likes this.
  9. Dec 18, 2021 at 5:53 PM
    VTYOTER
    VTYOTER Rock
    Torrey
    Vermont
    2021 TRD Pro LR
    How much higher is that rack than the sharkfin? I want one but I’m getting tight on fitting in the garage!
    SAGE63 and Ron_Pro[QUOTED] like this.
  10. Dec 18, 2021 at 6:24 PM
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    not sure if you got this resolved but here’s a picture of mine close up. Just need to move the left u bolt to the outside of that ABS bracket on top of the axel. Then position the right U bolt the same distance - use where the welds on the axel come to a v point for reference on where to position the right u bolt once you get the correct placement on the left.
  11. Dec 18, 2021 at 7:49 PM
    AZTundra
    Paul
    Phoenix, AZ
    Anyone ever notice the drivers window switch blinking? Just came back from shopping and noticed it was blinking...I don't think I've ever seen that before.
  12. Dec 18, 2021 at 8:44 PM
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    You need to recalibrate the auto window. All toyotas do this when the auto window is reset or out of whack.
    Sean492, AZTundra[QUOTED] and mr0351 like this.
  13. Dec 18, 2021 at 8:58 PM
    Retroboy1989
    Northern Utah
    Install the left bracket left of the brake line bracket as close as possible. Match the distance from center using the welds as a guide. Here is mine:
    DirtyMike5[QUOTED] likes this.
  14. Dec 18, 2021 at 9:46 PM
    Ron_Pro
    Ron_Pro New Member
    California
    About 1/2 inch.
    mgm16trdpro and AggiePhil like this.
  15. Dec 18, 2021 at 11:21 PM
    kuokoa
    kuokoa New Member
    Kailua Kona, HI
    2015 Tundra Crewmax BRM
    finally got my SPC UCA’s and Coachbuilder 1/2” shims installed. also did a 2-step paint correction and ceramic coat. this is a used 2015 that had been neglected by the first owner. Blue Ribbon Metallic is rare in Hawaiʻi.
    currently installed:
    front: 6112’s at 2.5” + 1/2” shims
    rear: 5160’s + Icon AAL’s
    measuring 25-1/2” hub to fender all around
    Ray10’s + 275/70’s (going up to 295/70 or 285/75 soon)
    saybng, GELCW, LyonKing and 17 others like this.
  16. Dec 18, 2021 at 11:24 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    Changed the oil.
    Cleaned the engine bay a bit while the oil drained and the air filter dried.
    Checked the tb while I had the intake off (to clean and spray the MAF sensor). A bit dirtier than I care for. Will prolly take it off for a good cleaning tomorrow, before final reassembly of intake tube and air box.
  17. Dec 19, 2021 at 7:09 AM
    TundraAF
    TundraAF New Member
    Cnote
    21 tundra crewmax TRD off-road
    I didn’t notice much of a tick to start with. Now I’ve got my head in the engine and all I can hear is normal valve noise. No tick.
    also used a Amsoil oil filter. First time I’ve ever changed a filter this style before.
  18. Dec 19, 2021 at 7:45 AM
    beaver6713
    beaver6713 2015 CM
    Kleve
    Safford Arizona
    2015 Tundra CM
    6 inch Pro Comp lift. OME rear springs with Coach Builder +3 shackles. Coach Builder tie rod ends. ICON 2.5 front and rear shocks with remote res. ICON Hyd bump stops. 35" Nitto Trail Grapplers on 18" fuel rims. Kenwood DNX 892 head unit with JL audio and RF amp pushing 2 Image Dynamics idq10 subs. SABM, S POD switches for 42" in bumper and 32" behind grille LED light bars. Full interior and exterior LED conversion. LED flush mount back up lights in rear bumper. Valentine one radar detector. V Leds under dash and seats foot well lighting. TRD pro head lights and grille. Full AJT dash kit
    Nice set up. I like the way you mounted your control box for the winch in the engine compartment. I need to do that to mine due to the ADD bumper has very limited access to the winch box. Have you considered upgrading your battery terminals to the SDHQ ones? They are expensive but very well worth it.
    saybng, LyonKing, equin and 7 others like this.
  19. Dec 19, 2021 at 11:31 AM
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    Found a place that had the bedliner conditioner with help from another thread. This is the stuff that came with my truck new - works pretty well and seems to last a decent amount of time.
  20. Dec 19, 2021 at 11:44 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    What did you use?
    2010bigdog likes this.
  21. Dec 19, 2021 at 11:54 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Added these Amber covers for my Cali raised led ditch lights!
  22. Dec 19, 2021 at 12:06 PM
    Hcreager
    Hcreager New Member
    Glendale, AZ and Vail, CO
    2017 Black Tundra Platinum
    Winjet Tail Lights, TRD Intake, Magnaflo exhaust, Morimoto Head/Fog Lights, Upgraded LED's interior/exterior, Chrome delete interior, plati-dipped grill and hood bulge grill....hopefully many more to come
    Did the tape on the lights work for you, mine didn't work at all, going to get some gorilla double sided or something and try again.
    AggiePhil likes this.
  23. Dec 19, 2021 at 12:10 PM
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    its the bedliner conditioner that they included with my truck when I bought it. Found some at ultimate linings out of Houston. I’ll send a pic of the stuff when I get back home
  24. Dec 19, 2021 at 12:13 PM
    hudrock
    hudrock New Members only jacket
    So Cal
    25 MGM Limited
    Ran across these on ebay and recalled another member had a DIY about that looked good so I thought I'd gave it a whirl (14-21 Toyota Tundra Headlight Eyelid GLOSS BLACK Precut Vinyl Overlays)....I think the price is good, around 18 bucks all together as lets face it I'm not going to sketch out a template and do that work :)
    They do look nice on the headlights - I included a before shot where you can see all the scratchs on top of the headlight.....Im not sure if I did a great job installing as I still have little bubbles in a lot of places but hoping the sun will work them out. Regardless one of those mods you won't feel bad about if you need to rip it off in the future.
    Motorskinz - https://www.ebay.com/itm/333886941705IMG_7244.jpg IMG_7254.jpg IMG_7255.jpg IMG_7257.jpg
  25. Dec 19, 2021 at 12:13 PM
    drgordon13
    drgordon13 New Member
    2020 Gray Tundra TSS
    Looks great...been looking at that light bar to match my floods...how was the install? Read on the forum where the longer 42" has some problems with the brackets? Is the shorter one the same or no problem? Thanks
  26. Dec 19, 2021 at 12:17 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Thanks man. Yea…the SSO bumper had no extra space with the way the front end of these trucks are designed, so I had to relocate the control box. I wanted it on the driver side so it was easy to access.
    I used a few strips of 1” steel flat bar to make a couple brackets for the control box bottom plate. Attached those to the fuse box cover. The limited amount of wt plus the clips on the fuse box cover, it’s solid. But it’s easy enough where if I need to get to the fuses I can without unbolting anything.
    And yes…I know…I want (and need) some new terminals. I just never remember to order them…
  27. Dec 19, 2021 at 12:30 PM
    MattJakobs
    MattJakobs New Member
    Matthew
    NorCal
    Took it snowboarding yesterday
    Jcmf52, AZBoatHauler, junior and 9 others like this.
  28. Dec 19, 2021 at 12:40 PM
    HaveFun
    HaveFun Happy to be here
    Fair Oaks Ranch, Texas
    2019 Black Tundra CM SR5
    I had trouble when I did mine. I had some extra strips of tape left over. Went back with a cotton ball and rubbing alcohol and wiped the area down really good and let dry. The tape stuck really well after that.
  29. Dec 19, 2021 at 12:46 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Install was fine. The brackets with the 30” are much more solid since they actually sit on the bumper supports. The brackets for the 42” are opposite and don’t have anything to rest on. Add in the larger span and the heavier 42” bar and I can see how the 42” bracket becomes shaky. But the 30” feels solid.
  30. Dec 19, 2021 at 1:09 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Heavenly?
