  1. Nov 27, 2021 at 8:41 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Bed lights, used a door dome light switch so the lights come on when the gate is open and off when closed. I used a factory switch, a 6” led bar from VLEDS, and a bunch of wire and loom.
    kparrow, GAknight, Part_time and 21 others like this.
  2. Nov 28, 2021 at 3:56 AM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    B6BD599B-79AB-47AA-9DD7-57AEBBB1DD4D.jpg Finally got a around to debadging my Pro. The cleaner look is much nicer. I just like the look of the Pro and tundra indented into the bed.
  3. Nov 28, 2021 at 6:38 AM
    DuneShoot
    DuneShoot New Member
    West Phoenix
    ‘21 Limited Cement
    Quick video testing Fox shocks.
  4. Nov 28, 2021 at 6:40 AM
    Damie Street
    Damie Street New Member
    Edsel
    South Carolina
    2016 MGM CrewMax SR5 TRD OffRoad
    which Fox’s?
  5. Nov 28, 2021 at 6:41 AM
    Damie Street
    Edsel
    South Carolina
    That was probably the first thing I did. That and a shorty antenna.
  6. Nov 28, 2021 at 6:42 AM
    DuneShoot
    West Phoenix
    ‘21 Limited Cement
  7. Nov 28, 2021 at 6:44 AM
    RusPro21
    Don
    Pa.
    Yeah just took some time getting around to it.
  8. Nov 28, 2021 at 6:44 AM
    Damie Street
    Edsel
    South Carolina
    ^ Looks good. I’m torn between the Fox 2.5 and the Blistens. I won’t be wheeling that hard but want to get to some off the beaten path camp site when I get my AT Summit
  9. Nov 28, 2021 at 7:02 AM
    DuneShoot
    West Phoenix
    ‘21 Limited Cement
    Spend the money! It’s worth it.
  10. Nov 28, 2021 at 7:02 AM
    Damie Street
    Edsel
    South Carolina
    On the Fox 2.5s?
  11. Nov 28, 2021 at 7:24 AM
    DuneShoot
    West Phoenix
    ‘21 Limited Cement
    Yes Fox 2.5 DSC.
    Damie Street likes this.
  12. Nov 28, 2021 at 8:32 AM
    tundra121
    tundra121 New Member
    F4F0C819-9F40-4DA3-AC88-8E830BD6C32D.jpg Finally updated the taillights no longer just the lower bulb lighting up. 7A756E7B-DB1A-4586-89DD-BE05E70BD6C7.jpg
    Thanks to Hotshot offroad
  13. Nov 28, 2021 at 10:34 AM
    Badknees
    Badknees New Member
    South Carolina
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    Just another method: I used a side grinder and ground off the inner most rivet heads on both brackets and then drilled out the remainder. Tilted/bent the brackets back at the outer rivets and put a 1/2” spacer with new bolts in place of the inner rivets. This gave enough extra space for my Cooper Discoverer XLT AT3 295/70 R18 spare and the brackets remain functional.
    AZTundra[QUOTED] and 1794TX like this.
  14. Nov 28, 2021 at 11:25 AM
    Tundra John
    Tundra John New Member
    2020 Tundra Platinum 4x4
    4” Readylift, Fuel 20” tires w/ Kenda 35”x12.5 tires, tint, dechromed, Custom Platinum Badging, Running Boards, Auto tailgate lock, LED swap, Changed out stereo system, VLeds Interior floor lights, DirtyDeeds 8” exhaust, TRD air filter, wrapped interior silver components,
    The Fox 2.5’s are amazing especially after being tuned. Tremendous difference in ride quality.
    DuneShoot likes this.
  15. Nov 28, 2021 at 11:52 AM
    Damie Street
    Edsel
    South Carolina
    Ugh…now y’all have me rethinking my entire life. Haha. I guess I could talk myself into the whole buy once cry once mindset. But how often do you have to rebuild the Fox’s?
  16. Nov 28, 2021 at 11:57 AM
    Tundra John
    It should be around 50,000 miles for straight highway use and then it goes down from there depending on how much off road you do.
    Damie Street[QUOTED] likes this.
  17. Nov 28, 2021 at 12:05 PM
    jonclark96
    jonclark96 Not so new member
    Jon
    Maryland
    2021 Army Green SR5
    I did a torque check on the lift I installed a couple of weeks ago. I was surprised that both lower front shock bolts were very loose, along with the LCA bolts. I wonder if the shop that did my alignment forgot to torque things.
  18. Nov 28, 2021 at 12:21 PM
    biebs96
    PA
    $15 well spent. They aren’t hard to do, but at an awkward angle.
    Badknees[QUOTED] and AZTundra like this.
  19. Nov 28, 2021 at 12:34 PM
    3xYOTA
    3xYOTA Taco/Rav/Tundra
    Far West Texas
    2020 Tundra 1794
    Crazy cant even tell that they are on
  20. Nov 28, 2021 at 12:59 PM
    cavalry bear
    cavalry bear New Member
    Cavalry
    2019 Limited Tundra
    None Yet
    LOL
  21. Nov 28, 2021 at 12:59 PM
    Punisher29073
    Punisher29073 New Member
    Ryan
    White Knoll, SC
    2019 Tundra TRD Pro
    Clearance lights, Light bar in front bumper, Ditch lights, CB Radio, AGM Battery, SLEE Sliders,
    I had this issue as well. Lowes had some little white nylon spacers that worked nicely for me. in the nuts and bolts bins.
    Ryan
  22. Nov 28, 2021 at 1:24 PM
    ErikTRDTUNDRA
    ErikTRDTUNDRA New Member
    Erik
    2018 Tundra crewmax 1794
    Put 50,000 on it
  23. Nov 28, 2021 at 1:33 PM
    SchnauzerMan
    SchnauzerMan New Member
    Southern New Mexico
    2019 SR5 CM 4x4
    Sumo Struts, Tiger Steps, Bed Rug, Undercover Flex Hard Folding Tonneau Cover
    Installed an RCA Jack for the trailer camera.
  24. Nov 28, 2021 at 2:13 PM
    classiccat
    classiccat New Member
    2017 Tundra Limited SuperWhite
    My '17 DC going into her 5th winter in the salt belt.
    Slimed-up with fluid film on/in body panels and I'm trying Blaster surface shield (spraybomb) on areas of high exposure (frame,suspension,rear axle, etc.).
    Transfer case fluid change (31k; I did the front & rear diff back at 30k). orig fluid was clean...just brown; I use 4wd quite a bit.
  25. Nov 28, 2021 at 2:29 PM
    Ron_Pro
    Ron_Pro New Member
    California
    2020 Tundra TRD Pro CrewMax
    Drilled out the rivets on the spare tire brackets in preparation for my full size spare.
  26. Nov 28, 2021 at 2:32 PM
    SpyderRC
    SpyderRC New Member
    2021 Limited Nightshade
    That’ll be my job next spring to fit a 35 under there. Hopefully I don’t get a flat before then… :fingerscrossed:
    1794TX, Ron_Pro[QUOTED] and AZTundra like this.
  27. Nov 28, 2021 at 2:56 PM
    Ron_Pro
    Ron_Pro New Member
    California
    Nice! I’m just waiting for my spare tire to come in. It “should” be here next week. Hopefully I don’t get a flat in the meantime too. Lol
    AZTundra, 1794TX and SpyderRC[QUOTED] like this.
  28. Nov 28, 2021 at 3:24 PM
    TundraTed
    TundraTed New Member
    2020 SR5 TRD Sport Crewmax 4x4
    In order: Orvis dog cover for rear bench seat, OE gun safe, Husky liners front/rear, Tyger tonneau tri fold, Rough Country seat covers
    I swapped my 2020 Sport 275/55/20 OE setup w 2021 275/65/18 Trail Edition wheels/tires recently bought from a fellow member.
    The plan is to rotate the 20s for spring-fall and 18s for winter. I’ll eventually get 295/70/18 but these Michelin’s have a season left.
    A few fun facts:
    • A Tundra lug nut uses a 22mm socket
    • I had to donkey kick 3 of the tires off the hub after removing all lugs (2020, 4300 miles)
    • Read page 509 of the users manual and then improvise
    • 97 foot lb torque for alloy wheels (I hope these are alloy lol)
    • TPMS from 2021 key start does not work with a 2020 push start apparently (thanks Toyota, like the trans cooler)
    Washed before install
    Lots of rust on that center cap
    Tundras favorite place
    TPMS not happy
    Before/After (see ya in the spring 20s)
  29. Nov 28, 2021 at 4:11 PM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    This is what I need to do this week. Tired of my tire rubbing my shackles
  30. Nov 28, 2021 at 4:51 PM
    More info please....alot of us could use a setup like this.
    steved0xTD likes this.
