  1. Sep 4, 2021 at 12:50 AM
    AZ Red Nek
    AZ Red Nek Native of the Valley, Bowl, Basin, ETC...
    Chuck
    2016 White SR5 Crew 4x4
    Hidden 1200# Waren winch, Baja Desgins lights, Switch Pro switch and controller, S&B air box and in bed tool box.
    Did today what I should have done the day I drove it home. How it looked when working under the hood. How it looks now, and what I used20210903_210802.jpg
  2. Sep 4, 2021 at 8:00 AM
    GELCW
    GELCW New Member
    Erik
    Northern Virginia
    2018 Gray Tundra Platinum
    Sorry man, I keep getting coupons from the dealership in the mail telling me come in for your oil change it’s 25% off, but I don’t trust the dealership. I would rather do it myself. They even sent a letter telling me to make sure my service is done correctly to keep up with manufacturers warranty. I hope your day gets better.
  3. Sep 4, 2021 at 8:03 AM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    While signing the paperwork to purchase my tundra I told them, "No offense, but I hope I never see you guys again." No way they will touch my truck unless it's something that needs to be warrantied. Nobody cares about your truck more than you do.
  4. Sep 4, 2021 at 8:08 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    changing your own oil is a meditation.
    it calms the brain.
    I just did my daughters highlander....they are sooooo much easier than the tundra.
  5. Sep 4, 2021 at 9:40 AM
    aark12
    aark12 AARK12 - Hello All
    New Mexico
    2020 Tundra Limited TRD
    Bilstein 6112, Pedal Commander, TRD Pro BBS Wheels, Gator Tonneau Cover, Bed Step, TRD Pro Grill, Mirror Caps, Grab Handle, Dirty Deeds 10in System, rear bumper step, dash cam
    Great looking truck.
    diablodalton and NakdGpa[QUOTED] like this.
  6. Sep 4, 2021 at 9:50 AM
    TundraTXTSS
    TundraTXTSS New Member
    Conroe
    2020 White TRD Pro
    Window Breakage add on Alarm,Wireless Charger. Console Safe, Rear Dif Breather Relocation, Rear Under seat Storage, Hard wire for Radar Detector, Tonnneau Cover, Brake Sensor Protection,SABM with TRD Filter, Tailgate lock, BFG's, LED Running lights.D-3 Tuner.
    Where did you find this, looks like it would work for bed lights too?
  7. Sep 4, 2021 at 9:55 AM
    CorpsTundra
    CorpsTundra New Member
    Michigan
    2021 Tundra CrewMax SR5-TRD OR - Cement
    It has been a fun couple of months upgrading the Tundra so far. Time to move on to de-chroming the front interior.
    -BBS Forged Pro rims with 275/70/18 Nitto Ridge Grapplers
    -TRD Pro grille, color matched grille surround, hood bulge, bumper end caps and mirror caps.
    -20%ish tint on front windows and 5%? windshield tint strip.
    -Weathertech in-channel window vent visors
    -The windshield tint strip is crooked and seems like it comes down too low to me. Maybe it needs to follow the contour of the roof line or something, but something about it I don’t like. Might see about having it trimmed or taken off altogether.
    -Amp Research bed step (cut the bracket to install)
    -Siless sound deadened the back wall and back floor area
    -Two 10” Arc Audio Arc series subs in a Tech12Volts ported enclosure.
    -Husky Xact Contour floor liners and carpet/foam cut to accommodate the ESP plastic under seat storage bins.
    -ESP plastic under seat storage bins
  8. Sep 4, 2021 at 9:57 AM
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
    I hose mine off. Very easy.
    RainMan_PNW likes this.
  9. Sep 4, 2021 at 10:03 AM
    French Avocado
    Utah / Wyo
    CorpsTundra[QUOTED] likes this.
  10. Sep 4, 2021 at 10:08 AM
    ersg6
    ersg6 New Member
    Steven
    2021 Nighshade Crewmax Tundra
    Hooked up and took out the boat
  11. Sep 4, 2021 at 10:13 AM
    CorpsTundra
    Michigan
    “Black on cement with a splash of red looks really nice.
    Do you have any rubbing with that size of tires or need to remove the front or rear flaps (does not appear so in the pictures)?”
    No rubbing or removing/shaving anything. I read a bunch on here before buying the tires to be sure I didn’t need to alter anything. General consensus on the forum is that there are no issues with the 275/70/18 tire size on stock suspension and I have not had any issues so far.
    Here is a side profile picture of them. I plan to raise the front 2 inches and raise the back 1 inch and will more than likely keep the same size tires.
  12. Sep 4, 2021 at 10:14 AM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    FIFY
    ersg6[QUOTED] and CorpsTundra like this.
  13. Sep 4, 2021 at 10:19 AM
    RoniusMaximus
    RoniusMaximus The One and Only
    J
    Tri-Cities, Washington
    2020 MGM Toyota Tundra TRD PRO
    Synthetic Blinker Fluid
    Finally bit the bullet and bought a set of Toyo Open Country AT3 tires in 295-70-18. (Listed my like new 275-70-18 tire set in the marketplace ;)).
    While I am very happy with the ride, I feel like the jump from 275 to 295 wasnt as noticable cosmetically as I had hoped. Compared to stock TRD Pros im lifted an extra 2" up front and 3.7" in the rear. I kept my spidertrax 1.25" wheel spacers on and the truck did rub at full lock going in reverse. I removed the front mud flaps so hopefully that will help. I am happy to notice that the tires do stick out a bit more so it looks better under the bushwacker fender flares now.
    What I do love most about the change is how smooth the Toyos are. I dont know if its because of the rubber Toyo uses or due to the bigger tire size (or both :cool:) but the ride home was just so smooth.
  14. Sep 4, 2021 at 10:25 AM
    CorpsTundra
    Michigan
    I think the tires look great. It seems like I’m in the minority, but I don’t mind some space around the tires and really it makes more practical sense to me to have the space on an off-road truck.
  15. Sep 4, 2021 at 10:28 AM
    RoniusMaximus
    J
    Thank you!
    Now that ive made a pic collage, I do notice more of a difference.
  16. Sep 4, 2021 at 10:34 AM
    CorpsTundra
    Michigan
    100% improvement. Those fender flares really accentuate the tire sizes too. Im envisioning red UCAs on your truck peeking through the wheel well. I’m thinking about getting a set of the factory style bushwackers and keeping them black on my cement truck.
    I want to raise my front end 2 inches and the rear end 1 inch from stock and keep the 275/70/18 tire size. The idea behind getting the slimmer factory style fender flares is to avoid needing to increase the tire size and add spacers to make it look right.
  17. Sep 4, 2021 at 10:41 AM
    RoniusMaximus
    J
    I like it. Avoid the temptation.
  18. Sep 4, 2021 at 10:54 AM
    jr1016
    jr1016 New Member
    Ric
    Sacramento, CA
    2020 CM TRD Sport
    Added some peace of mind front cat plate from valhalla shields.
  19. Sep 4, 2021 at 11:10 AM
    WestexSBK
    WestexSBK New Member
    2019 SuperWhite CM TRD Sport 4x4
    Installed redneck bumper shims today. Used 8 3/8” washers on each bolt. Gave me about 5/8” of an inch of clearance. Break down took an hour as it was a learning curve. Reinstall took 15 minutes. Very happy and no more rubbing.
  20. Sep 4, 2021 at 11:41 AM
    AZ Red Nek
    Chuck
    SDHQ
  21. Sep 4, 2021 at 12:04 PM
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    Nothing too fun just an oil change today. Has almost been 5,000 miles and next month would make 12 months since the last change but it was a nice day, I had the stuff here to do it and I got kinda bored so why not?
    Have to say the Fumoto valve is worth it's damn weight in Rhodium or whatever the most expensive metal is! Last oil change when I installed it I think I spilled a quart on top of my skid plate. Now just pop a tube on, crack the valve and walk away. Easy peasy.
    AZBoatHauler, GELCW, swallace and 4 others like this.
  22. Sep 4, 2021 at 12:38 PM
    romad86
    romad86 New Member
    Warrenton, VA
    2021 Limited Cement
    Truck looks great! I was torn between these Toyos and Falkens. Ended up with the Falkens since they’re performing so well on my T4R. I think I may try the Toyos next time though, I really like that there’s a C load option in the factory size tire.
    RoniusMaximus[QUOTED] likes this.
  23. Sep 4, 2021 at 1:08 PM
    RoniusMaximus
    J
    Thank you!
    I was about to get the Falken AT3W in same size as it would haved saved me almost $300 and the good reviews. Last year, I installed Toyo Open Country AT3s on my wife's Subaru because the KO2s we had just bought were too loud. It was a night and day difference with how much better the Toyos were. Much quieter and handled ice/snow/rain covered roads mire confidently. After buying KO2s for the last 15 or so years I was immediately converted to a Toyo fan, I was that impressed especially after the recent winter storm in Oregon.
    romad86[QUOTED] likes this.
  24. Sep 4, 2021 at 1:17 PM
    CorpsTundra
    Michigan
    I think I might try a couple of these lights out as bed lighting. I don’t need it often and this looks like a quick solution.
  25. Sep 4, 2021 at 2:24 PM
    DerfM
    DerfM Knows nothing about trucks
    South Dakota
    2021 TRD Pro MBM
    Spent the bulk of the afternoon cleaning my truck. Outside will look nice for the next, 27 minutes probably. Inside looks great though. Tire shine really does wonders to Husky Floor Liners, FYI. I do need to find a good bug remover if anyone has a recommendation.
    6zG1gM8Aek72McNO2UOIMDgpBAodvkRll6aGZz7G_73c51e8eca0ffbd3c003d215c2188a8b4de6b46d.jpg
  26. Sep 4, 2021 at 3:03 PM
    Elroy_unlimited
    Elroy_unlimited New Member
    Eric
    Murfreesboro TN
    2017 limited crew max
    Good call as the cat theft has been a HUGE problem in Sacramento. Especially in Natomas . Not sure what part of Sac you’re in.
  27. Sep 4, 2021 at 3:10 PM
    I would add the rear plate as well.
    jr1016[QUOTED] likes this.
  28. Sep 4, 2021 at 3:21 PM
    Elroy_unlimited
    Eric
    Murfreesboro TN
    Got the wheels, Upper control arms and shims delivered today. Just waiting on the suspension to show up and then I can get the new tires mounted and alignment done.
  29. Sep 4, 2021 at 3:58 PM
    cygan1008
    cygan1008 New Member
    “RIP” 2013 Tundra TRD Rock Warrior, 2018 TRD SPORT CM 4x4 SUPER WHITE Eibach Pro 2.0 275/65/20 Recon Grapplers
    Eibach Pro 2.0 coilovers and 275/65/20 Nitto Recon Grapplers
  30. Sep 4, 2021 at 4:53 PM
    jr1016
    jr1016 New Member
    Ric
    Sacramento, CA
    2020 CM TRD Sport
    Yes it's been bad in Sac and I do live in Natomas. My wife uses my truck once in a awhile to work and she said one of her co-worker got hit.
    Will be adding for sure. Just waiting on Tyler (valhalla) to catch up on orders.
    Classy63 and Tundra234[QUOTED] like this.
