  1. Aug 27, 2021 at 10:23 AM
    JmikeLKA
    JmikeLKA Loving the truck
    2021 Limited
    Undercover Ultra Flex Cover, Rear Sway Bar, LED interior lights, Cargo Bars attachments, Console Safe, Husky Floor Mats,
    Looks great, love the bed one too.
    How much ground clearance did you loose?
  2. Aug 27, 2021 at 10:35 AM
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    Completely agree to wait and get exactly what you want or would be stuck in that loop of “I wonder if it would’ve looked better with…”
    The bumper shim is for the front of the front tire clearance whereas the bmc is for the rear of the front tire clearance…you could try to push/trim the front liner, to not have to shim the bumper. I ran 33x11.5 with no rubbing at front or rear of the wheel well on 20s w/+50 offset; had to remove mini front mud flap with 35x11.5 on same wheels; when I put my 20s with +10 offset and same 35x11.5, I rubbed significantly at the front, (removed the lower part of the liner that goes behind the front end cap and was going to modify/reinstall, but then decided to change the front bumper altogether) cleared the rear body mount without needing a bmc but had to remove the mud flaps. Running a 3/1 level on my truck for all these scenarios with stock uca
  3. Aug 27, 2021 at 11:47 AM
    Long Duck Dink
    Long Duck Dink Nope
    North Salt Lake, UT
    2019 Super White 1794 Edition Tundra CrewMax 4x4
    3/2" Readylift, TRD Dual Exhaust, TRD Sway Bar, Line-X Bedliner, ArmorFlex Tonneau, ESP 3 bin storage, Amp Power-Steps, Driver Side Grab Handle, Ronin Antenna, Window Tint, ClearBra. Coming Soon: 20" Method MR305NV. BF Goodrich KO2 275/60/20
    Great Info! Thanks!
    I'm planning to put a 20x9 +1mm offset, 275/65 (34" tire). Desperately hoping I can do it by just removing the front of the wheel well mud flap and pushing or trimming the front liner only. No BMC, no shimming, no different front bumper. If I can't do that, I'll go with a 33" tire. I have a 3/2 level and stock UCA.
  4. Aug 27, 2021 at 11:54 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    408F7BB7-752F-4DF4-8BE9-6C7B255BB021.jpg Finished installing my Toyota aluminum running boards. Love em’ so far (had the one side on for a few days). Expensive but looks ten times better. And they sit about a inch, inch and half closer to the cab. No fugly gap anymore…
    1 inch Coach Builder lift (.5 shims) going on the 9th. It going to look like a totally different truck with a few small changes.
  5. Aug 27, 2021 at 12:05 PM
    SchnauzerMan
    SchnauzerMan New Member
    Southern New Mexico
    2019 SR5 CM 4x4
    Sumo Struts, Tiger Steps, Bed Rug, Undercover Flex Hard Folding Tonneau Cover
    Weight?
  6. Aug 27, 2021 at 12:12 PM
    TNTundra16
    TNTundra16 YOU BIG DUMMY!
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    I'm in the 20"+ wheel club. To me they look more proportional for such a big truck. My truck is a daily driver and weekend warrior. It's been in the mud deeper than the wheels on multiple occasions. I have no complaints about ride quality and the roads are sh*tty in my area. I'm running 20x9 +18 and 275/60 Wildpeak at3w. I'm considering stepping up to a 295/60 when these wear out.
  7. Aug 27, 2021 at 12:34 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    About 30 or so pounds per board. Definitely heavier than the brushed stainless steel.
  8. Aug 27, 2021 at 1:54 PM
    Long Duck Dink
    Long Duck Dink Nope
    North Salt Lake, UT
    And yours looks great too! Thanks for helping put my mind at ease. 20" is the way to go (in my honest opinion).
    TNTundra16[QUOTED] likes this.
  9. Aug 27, 2021 at 1:55 PM
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    TNTundra16 I PM'd you, did you see it?
  10. Aug 27, 2021 at 2:03 PM
    Blue By U
    Blue By U New Member
    2nd the 20's. Fuel Vectors 20x10 35x12.5" Nittos.
  11. Aug 27, 2021 at 2:17 PM
    TNTundra16
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    No ma'am. I don't see anything :notsure:
    I just sent you a PM.
  12. Aug 27, 2021 at 2:44 PM
    SAGE63
    San Diego County
    Installed brake sensor guards...
    .20210827_140316.jpg 20210827_140328.jpg 20210827_142317.jpg 20210827_142933.jpg
  13. Aug 27, 2021 at 2:56 PM
    vl184009
    Vicky
    Southern, Ca.
    Nice!
  14. Aug 27, 2021 at 4:21 PM
    MikeyRedFL
    MikeyRedFL New Member
    SWFL
    2021 Limited Crew Max 4x4
    Got my first oil change today @1000 miles... dipstick service writer was trying to tell me to wait until 5000 miles... I have never done that and never will... I don't know if it comes from the factory will full synthetic but this dealer only does full synthetic... That is all I have ever done since... as long as I can remember.
    SAGE63, kbark, Fotnot and 2 others like this.
  15. Aug 27, 2021 at 5:10 PM
    Hamster14
    Hamster14 New Member
    Utah
    2014 Tundra Limited
    -46 gallon tank - shell
    Drove 3,300 miles in 6 days pulling a 7,000lb trailer. I enjoy the tundra reliability over my more fuel efficient always in the shop duramax. Also gave it a good wash from all the bugs 0789E5D2-2192-4C0A-904D-85BAAEA84715.jpg
  16. Aug 27, 2021 at 5:34 PM
    GatorBodine
    GatorBodine New Member
    Got any close up pics of the running boards? I've been trying to decide on a set. I assume you got them from Toyota?
  17. Aug 27, 2021 at 5:42 PM
    trucknut
    trucknut New Member
    2021 Cav blue SR5 TRD Off Road
    Installed a yakima rack on my cover
  18. Aug 27, 2021 at 5:57 PM
    Lassie
    Lassie New Member
    HKM
    TAMPA, FL
    FYI. Yes, I think 17 is better for off-roading. 20 rims can touch the rocks in the trails.
  19. Aug 27, 2021 at 6:27 PM
    t4r2tundra
    t4r2tundra New Member
    2019 Platinum 4x4 - Smoked Mesquite
    See sig for mods...
    1794TX is right. They will fit, I run this size and offset on methods with 35" Nitto Ridge Grapplers. I am 2.5" leveled with BMC. KO2's run slightly smaller than the spec vs RG, etc. You can go to my sig for pictures of how much they stick out
  20. Aug 27, 2021 at 6:51 PM
    Blue By U
    Where do you get these?
  21. Aug 27, 2021 at 6:56 PM
    SAGE63
    San Diego County
    SchnauzerMan likes this.
  22. Aug 27, 2021 at 7:05 PM
    justcuz
    justcuz 2.5 Gen Member
  23. Aug 27, 2021 at 7:53 PM
    TundraTXTSS
    TundraTXTSS New Member
    Conroe
    2020 White TRD Pro
    Window Breakage add on Alarm,Wireless Charger. Console Safe, Rear Dif Breather Relocation, Rear Under seat Storage, Hard wire for Radar Detector, Tonnneau Cover, Brake Sensor Protection,SABM with TRD Filter, Tailgate lock, BFG's, LED Running lights.D-3 Tuner.
    Looks like one of your driving lights needs to be replaced. But looks awesome!
    AZ Red Nek[QUOTED] likes this.
  24. Aug 27, 2021 at 8:23 PM
    jordoncloutier
    jordoncloutier New Member
    Jordon
    Alberta , Canada
    2019 Tundra CrewMax SR5 Plus 4x4
    Daily Driver / Tow Vehicle , Retrofitted Trans Cooler , 10 Ply tires , Raptor Lined Ranch Hand Grille Guard
    How do you like the hercules terra trac at2's ? , Im running the same tire except in 275/65/18 E rated, I feel Its a very under rated tire , been very happy with its performance over the past 2 years and 40.000 miles
  25. Aug 27, 2021 at 9:12 PM
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    agree more sidewall helps protect the wheel; a more concave wheel design, if planning to off-road, can help minimize that too. Mine came with replaceable rock guard rings.
    Long Duck Dink, equin, kbark and 6 others like this.
  26. Aug 27, 2021 at 9:16 PM
    normagene
    normagene New Member
    Normagene
    New England
    2021 Cement DC Limited Texas Edition
    Texas Edition
    Are those OEM and if so do you know the part number. Look really sharp. Thanks
    Oey12[QUOTED] likes this.
  27. Aug 27, 2021 at 10:32 PM
    CoachJ
    CoachJ New Member
    J.
    2021 Tundra Trail
    TRD Pro Exhaust Muffler Delete
    i went with 50% ceramic on windshield, 25% ceramic on front, clear ceramic on back sides & rear…
    IMO it works really well…
    a_double[QUOTED] and Hightide like this.
  28. Aug 28, 2021 at 12:28 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Installed this little guy today. This guy on max feels amazing. Paired with the bully dog performance tune I'm smoking my tires with the littlest of pressure on the throttle.
  29. Aug 28, 2021 at 4:43 AM
    Oey12
    Oey12 New Member
    Joey
    New York
  30. Aug 28, 2021 at 5:24 AM
    Lassie
    Lassie New Member
    HKM
    TAMPA, FL
    I have no complaint. 95% on-road use. Reasonably quiet and smooth. Good looking too. Feel good traction when 4Hi or Lo engaged. When this worn out I would replace by the same ones. BFs are too noisy to me.
