  1. Aug 26, 2021 at 3:13 PM
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    Would these apply even to the mx1.4? My UltraGauge is the stand alone hand held that works similarly to scanguage
  2. Aug 26, 2021 at 3:14 PM
    The Coachbuilder bumper shims would solve the problem and look a hell of alot better.
    PaulROahu and HulkSmurf14 like this.
  3. Aug 26, 2021 at 3:16 PM
    Honestly I'm not sure. Someone with a little more progamming/tuning knowledge may know.
  4. Aug 26, 2021 at 3:28 PM
    Installing in the bulge this weekend but my S8 arrived today. :thumbsup:
    AZ Red Nek, Hightide and RobertD like this.
  5. Aug 26, 2021 at 3:35 PM
    BWPRO
    BWPRO New Member
    Bryce
    2021 Tundra TRD PRO
    looks good. What winch is that btw?
    AZ Red Nek[QUOTED] likes this.
  6. Aug 26, 2021 at 3:46 PM
    JmikeLKA
    JmikeLKA Loving the truck
    2021 Limited
    Undercover Ultra Flex Cover, Rear Sway Bar, LED interior lights, Cargo Bars attachments, Console Safe, Husky Floor Mats,
    Is that with all your lights on or just those two on your hood you installed?
  7. Aug 26, 2021 at 3:58 PM
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    Some of that depends on the actual tires as far as sidewall/load classification. A C rated tire will generally feel softer on the road than an E rated tire. The extra sidewall on a 17” wheel versus a 20”, both tires being equal, the 34” on 17s will feel softer/bouncier, the 34” on 20s will give better cornering/street performance because of the narrower sidewall (less roll) but feel firmer/stiffer over bumps.
    Those 17s will have a visual illusion to look larger than they are because of the concave/sucked in dish with that 0 offset and the black outer lip.
    go to and you can compare tire sizes/offsets to see.
    Nice looking wheels, and one of the few I’d personally consider if getting 17s… I have a bias towards 20s with 35s; 18’s would be my close second choice on a Tundra; would have to really be the right wheel/price point to have considered 17s.
  8. Aug 26, 2021 at 4:02 PM
    Kantoosion
    Kantoosion New Member
    J
    SD
    Inferno Crewmax
    Yes I used it. You are right, it is a secondary measure just incase the mounting plates come off, but the way they are engineered/works I doubt it will. Any flex on the rack on one side, the other side will not lift because the way the mounting plates are designed.
  9. Aug 26, 2021 at 6:46 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    I grabbed a dash cam off Amazon. I used a mirror harness so the hookup wascrazy easy. Just a little peace of mind, really.
    FD8E16C7-5428-457C-9F4C-00DE1B19F1CF.jpg F1E8671E-23D5-4906-B3FD-3A583DE97E71.jpg 8FA9ACEF-9653-4B37-924D-7F9121FD31B4.jpg
    GAknight, AZTundra, kbark and 16 others like this.
  10. Aug 26, 2021 at 7:59 PM
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    No pictures, just a new windshield. Took a rock chip on a road trip that started a 15” crack. Ugh. Glad I no longer have to look at it!
    Jcmf52 likes this.
  11. Aug 26, 2021 at 8:07 PM
    Jr3volution
    Jr3volution New Member
    Johnnie
    DFW TX
    2022 Tundra Platinum
    How much did it cost to get your windshield fixed?
  12. Aug 26, 2021 at 8:21 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Turned 19091 miles.
    Got a picture, but uploads are being cranky on my crappy internet.
  13. Aug 26, 2021 at 8:44 PM
    PaulROahu
    PaulROahu New Member
    Paul
    Kaneohe, Hawaii
    2017 5.7 Tundra Platinum 4x4 MGM
    Coach builder 1/2” bumper shim plus SDHQ body mount chop plate, with RC6” lift w/Vertex coil overs. 20/10/-19, 35/12.5/20 no rub at full lock or reverse. If your gonna run anything over 33” and negative offset to clear steering/suspension components. Just do it right the first time. If you trim/heat/remove inside rubber fender. Will look hacked up and not look clean at all.
    GAknight, kbark, Beesta and 12 others like this.
  14. Aug 26, 2021 at 9:00 PM
    BlueRibbon4x4
    Geno
    3xYOTA, doggiecareman, equin and 13 others like this.
  15. Aug 26, 2021 at 9:08 PM
    I'm 99% sure that your toothbrush, pajamas, and bed sheets are all Blue Ribbon Metallic. :rofl:
    You're a color matching wizard!
    GAknight, kbark, swallace and 7 others like this.
  16. Aug 26, 2021 at 9:10 PM
    BlueRibbon4x4
    Geno
    :rofl: Ooooh my toothbrush….:monocle:
  17. Aug 26, 2021 at 9:25 PM
    SAGE63
    San Diego County
    mine is a +25 with toyo AT II 295/70 R18. I had to heat and push front liner a quarter inch. worked good no cmc. removed mud flaps. put in 1/2" bumper shim for added piece of mind...
  18. Aug 26, 2021 at 10:13 PM
    Blue By U
    Blue By U New Member
    Amber in the dark is a eye opening thing. They penetrate the fog quite well without the glare or over powering refraction.
  19. Aug 27, 2021 at 3:29 AM
    AZ Red Nek
    AZ Red Nek Native of the Valley, Bowl, Basin, ETC...
    Chuck
    2016 White SR5 Crew 4x4
    Hidden 1200# Waren winch, Baja Desgins lights, Switch Pro switch and controller, S&B air box and in bed tool box.
    Thanks, Warn ZEON 12S mounted on SDHQ hidden winch bumper.
  20. Aug 27, 2021 at 4:13 AM
    AZ Red Nek
    Chuck
    All Baja Designs, just ditch lights XL 80s. XL 80s plus S2s in grill. XL 80s S2s and S8 light bar. Squadron Pros in rear bumper. Then shot from rear with all front lights on and shot of front, and it looks like I'll be replacing fogs sooner than I thought20210827_011017.jpg 20210827_011043.jpg 20210827_011043.jpg 20210827_011043.jpg 20210827_011354.jpg 20210827_010953.jpg 20210827_011017.jpg 20210827_011043.jpg 20210827_011354.jpg 20210827_005303.jpg 20210827_010953.jpg 20210827_011017.jpg 20210827_011043.jpg 20210827_011354.jpg 20210827_005303.jpg 20210827_013327.jpg 20210827_010953.jpg
    20210827_013647.jpg okay some how it duplicated photos and didn't keep them in order, I'm sure you can guess what is what lol.
    GAknight, 3xYOTA, Paulskie and 11 others like this.
  21. Aug 27, 2021 at 4:27 AM
    Nice. I hooked up the S8 to the battery yesterday to test it out. :D:D:D
  22. Aug 27, 2021 at 4:30 AM
    AZ Red Nek
    Chuck
    If you looked directly in to it I bet if you close your eyes now you can still see it
  23. Aug 27, 2021 at 5:30 AM
    Barrett50
    Barrett50 New Member
    Barrett
    Wisco
    2015 DC silver
    Please post pics when you complete that!!
    And I want one. :rofl:
    GODZILLA and RobertD like this.
  24. Aug 27, 2021 at 5:33 AM
    :rofl: I would hate to be a deer that looked into one of these. I'll start the install tomorrow. Those SDHQ brackets are nice.
  25. Aug 27, 2021 at 5:51 AM
    AZ Red Nek
    Chuck
    Do they look like this in your neck of the woods?41GRE15mnlL._AC_SL1500_.jpg
    GAknight, 3xYOTA, GODZILLA and 7 others like this.
  26. Aug 27, 2021 at 6:01 AM
    :rofl: That's funny as hell lol.
  27. Aug 27, 2021 at 6:05 AM
    dugfur
    dugfur New Member
    doug
    2016 limited DC
    Where did you get the "TRD" badge on the grille? I like the look of that
  28. Aug 27, 2021 at 6:49 AM
    d_kinneyjr
    d_kinneyjr New Member
    Dave
    Southern NH
    2018 Crew Max SR5
    Yesterday, I installed the Tyger Sports Bar W/ Lights & the Tyger T3 Compatible Bed Cover!
  29. Aug 27, 2021 at 9:01 AM
    Long Duck Dink
    Long Duck Dink Nope
    North Salt Lake, UT
    2019 Super White 1794 Edition Tundra CrewMax 4x4
    3/2" Readylift, TRD Dual Exhaust, TRD Sway Bar, Line-X Bedliner, ArmorFlex Tonneau, ESP 3 bin storage, Amp Power-Steps, Driver Side Grab Handle, Ronin Antenna, Window Tint, ClearBra. Coming Soon: 20" Method MR305NV. BF Goodrich KO2 275/60/20
    Agree with you. I prefer a 20" rim and have decided to pass on these because I'd rather wait and get what I want rather than sacrifice because it's a good deal.
    I'll be going 20" rim with an overall goal of a 33" or 34" tire but am waiting until my OEM tires wear out and I need new tires.
    I personally think bumper shims look hacky. I'd do a BMC long before I'd do bumper shims.
    1UP and AggiePhil like this.
  30. Aug 27, 2021 at 9:32 AM
    Kung
    KG, VA
    Got the left front tire repaired.
    Also...changing a tire in 100 degree weather is not fun. Especially when some jack@$$ is sitting there watching you do it not 30' away w/o an offer for help. LOL
    Hightide and Long Duck Dink like this.
