  1. Aug 7, 2021 at 6:11 AM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    I could be wrong but it sounds like you’re missing the on/off function of the drain. The knurled ring is threaded onto the inner sleeve. Screw the inner into the cap with the outer ring backed out. It won’t drain until you screw the outer ring in. Hope that makes sense.
  2. Aug 7, 2021 at 6:21 AM
    GPJoeyD
    GPJoeyD Super Duper Cool Guy
    Joey D
    Middle Tennessee
    2015 SR5 TSS CrewMAX
    They are 33x12.5R20LT Baja Boss A/T
    TNTundra16[QUOTED] likes this.
  3. Aug 7, 2021 at 6:27 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    You can always chalk test your tires, vids of that process on youtube. Correct tire pressure is not constant, meaning the best pressure for just you running on the highway will be different from when your truck is fully loaded, or hauling or towing. It is not rocket science or anything to really worry to much about. Play around with it some. You will know when it is too low or too high, Tundras as sensitive to tire pressure so just a pound or two adjustment can impact handling, ride. Trucks with heavy bumpers, toppers or other added weight will always need more pressure than a truck without all that added weight.
    Your 38/41 is in the ball park. Try pressures 1-3 lbs higher or lower depending on load and you will know what feels best for you. I find my truck ride is much better (normal driving, no load) when I have the rear at 36-38, higher than that and you start to get that tap in the kidney feel on bumps.
    Norfolk757[QUOTED] likes this.
  4. Aug 7, 2021 at 6:36 AM
    Norfolk757
    Norfolk757 עַם יִשְׂרָאֵל חַי
    Tom
    Norfolk, VA
    2015 White Tundra- CrewMax TRD Off Road
    Thanks for that input, ill try to lower the rear to about 37, what do you run at the front for your rig? Ill have to do the chalk test, but its wet and "moist" out here in VA today. :thumbsup::thumbsup:
  5. Aug 7, 2021 at 6:45 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Drove 500 miles and through/into 4 states. Time for a little R&R
    a522467, French Avocado and cochese like this.
  6. Aug 7, 2021 at 6:59 AM
    Bad66ss
    Bad66ss New Member
    Nick
    N. Las Vegas Nv.
    16 2wd SR5 double cab Blazing Blue Pearl
    Flowmaster dual after cat exhaust
    Just installed a tekonsha p3. Can someone tell me if the screen is supposed to lit up all the time
  7. Aug 7, 2021 at 7:24 AM
    Hamster14
    Hamster14 New Member
    Utah
    2014 Tundra Limited
    -46 gallon tank - shell
    It’ll turn off just give it some time
    I have mine installed under the tow/haul buttons. Bought mounting plastic from EPS kinda spendy $85 but now my knee doesn’t tap it while in the truck
  8. Aug 7, 2021 at 7:57 AM
    NCTundra18
    NCTundra18 New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
    20210806_081233.jpg Hit all 4's yesterday and no that's the name of the road. You can not purchase any pleasures there, lol.
  9. Aug 7, 2021 at 8:01 AM
    frichco228
    Yep, Im in Richmond and it is absolutely pouring here, expecting a few inches rain today. Was just down in Norfolk last weekend visiting family. I run the fronts 36-38 for the normal just me driving alone, no load. If I am going on a trip, long highway travel, I will bump it up a lb or two.
  10. Aug 7, 2021 at 8:03 AM
    RRR1C0
    RRR1C0 New Member
    2014 SR5 TRD CrewMax
    Riding on 275/70R18 Toyo AT3s w/ 1.75” RC leveling kit.
    We are expecting our 4th as well, luckily bought her a Sienna back in February
    TNTundra16 and Fotnot[QUOTED] like this.
  11. Aug 7, 2021 at 8:22 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    When installed it is a live all the time connection, it does turn off after 15 minutes though. I had one put on my taco right before I sold it a few weeks ago.
  12. Aug 7, 2021 at 8:30 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    We bought my wife an odyssey a couple years ago, but I pick up my kids and share the load pretty equally with my wife, so I needed the room for thr 4th seat. Congrats on the 4th coming man!
    RRR1C0[QUOTED] likes this.
  13. Aug 7, 2021 at 8:41 AM
    1904Tundra
    1904Tundra New Member
    Sam Diego
    2015 MGM Limited CM
    Added these cool TRD emblems to my door still
  14. Aug 7, 2021 at 8:56 AM
    Famof5Tundy
    Famof5Tundy New Member
    2020 MGM CM Platinum
    Just getting started
    Lifted her:
    specs...
    35x12.50r18 Falken Wilpeak MT
    on Icon rebounds with +25mm offset
    Aluma 2.0 coilovers set at 3 (like they came apparently)
    1.5 inch block in back with Eibach's in the back
    Brake line extension and diff drop kit.
    No rub at full lock on the cab mount, removed front plastic because it did rub, will modify tomorrow. Tires only slightly stick out....maybe 1/2 of tread or so.
    Alignment on Monday, but rides good, no issues.PXL_20210807_154213342.jpg PXL_20210807_154210089.jpg PXL_20210807_154202007.jpg PXL_20210807_154032000.jpg PXL_20210807_154102369.jpg PXL_20210807_154123597.jpg
    WFD473, Dc2015, GELCW and 26 others like this.
  15. Aug 7, 2021 at 9:11 AM
    RainMan_PNW
    Casey
    Clark County, WA
    Pics from yesterday’s 550 mile drive
    Milestone ODO
    Single tank miles when i finally stopped to fill up
    Tank average mpg on at that fill-up
    The Bunkhouse destination at the end of that trip
  16. Aug 7, 2021 at 9:19 AM
    blackoutt
    blackoutt YEAH BUDDY!
    Indy
    07 DC Long Bed - Old Man Tan
    OEM+
    Not today but a couple days ago. Listed it for sale on facebook market place and OHHHH the comments! lol.
  17. Aug 7, 2021 at 9:20 AM
    SAGE63
    San Diego County
    milestone 9k..
  18. Aug 7, 2021 at 10:13 AM
    JeffMac
    JeffMac 2 Words, 1 Finger
    Jeff
    South Florida
    2015 Black Tundra OVTUNE
    Suspension: Bilstein 6150 Front Max Setting CB Shim 2x Driver 1x Passenger Bilstein 5160 Rear CB +3 Shackles Firestone Airbags w/ Daystar Craddles Engine: OVTUNE - 87 w/ Torque Modifier SABM w/ K&N Filter TB Coolant Bypass Fumoto Drain Plug Wheels/Tires: ProComp Bandidos 0mm Offset Nitto Exo Grappler AWT 285/70/18 Exterior: TRD Pro Grille Spyder Headlights/Taillights Ecoological Bumpershellz LED everything Tinted windows Bakflip MX4 Tonneau Cover K-Source Tow Mirrors Interior: Pioneer AVH-W4500NEX Radio 2x 10” Pioneer Subwoofers 1200W Pioneer Mono Amp 2000W Pioneer 4 Channel Amp
    Truck is cleaned. Put black out badge on to cover a scratch that couldn’t be buffed. Installed color match hood bulge to finally replace my plasti dipped one because the tabs started breaking.
    7AF34893-7D46-49C0-B71B-8B4570DDB027.jpg 7678FA8F-808A-4AD3-9443-48B9E93252E9.jpg FF36CF33-ED88-4C0E-A00E-FFEC12413BDE.jpg
  19. Aug 7, 2021 at 11:43 AM
    PKFan
    PKFan my pronouns are (she/it) - c'mon, say it fast
    2018 Inferno! DC SR5 4x4
    Tyger Blade running boards, Valhalla's Shield cat plates
    And I just hit 18K on my 2018.
    SAGE63[QUOTED] and RainMan_PNW like this.
  20. Aug 7, 2021 at 11:56 AM
    1794TX
    Steven
    N.TX
    '20 1794
    Nice looking truck. Not sure whether it's already your plan, but worth mentioning... If the rub on the front fender is 1/2" deep or less, if you want to keep the plastic intact, you can shim the bumper instead of trimming:
    https://shop-coachbuilder.myshopify.com/products/coachbuilder-front-bumper-shim-kit
    https://www.tundras.com/threads/wha...d-gen-tundra-today.713/page-2040#post-2341477
  21. Aug 7, 2021 at 12:06 PM
    Famof5Tundy
    Thanks. Yeah I've seen a lot of people do that and the push forward and screw method. It's a literal flash flood out there today so I'm gonna see what happens when I mess with it tomorrow. Thanks again!!!
  22. Aug 7, 2021 at 2:32 PM
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    Finally finished my ‘17 1794 build (at least for now). Added TRD Pro Fox suspension with Westcott Designs lift. 35x11.5R20 Ridge Grapplers on 20” Black Rhino Duggers +10 offset (no CMC/BMC needed). Also added a Barricade HD2 bumper with SD lighting 30” laser light bar (bumper came with fog lights)
    Piki, yoshi82, TunBrun and 16 others like this.
  23. Aug 7, 2021 at 2:45 PM
    SchnauzerMan
    SchnauzerMan New Member
    Southern New Mexico
    2019 SR5 CM 4x4
    Sumo Struts, Tiger Steps, Bed Rug, Undercover Flex Hard Folding Tonneau Cover
    Installed a front camera and a 4 way video selector with wireless controller. Right now I'm using it to switch on-demand between truck front, truck backup, and trailer cameras.
  24. Aug 7, 2021 at 4:24 PM
    Yotatundraaah
    Yotatundraaah My tundra stays hungrry
    Southern CA
    2016 Silver Sky Tundraaaah
    Kings suspension Built Right ufc 295/70-18 Toyo AT2 18" XD bully wheels Baja designs foglights Baja designs ditch lights Rago fabrication ditch brackets Tiger auto rock slider Extang solid fold 2.0 cover Read more....
    Finally got the rest line x'd (grill, roof and bed)
    Wifey said this will be the last thing I'll ever do to my truck and I just laughed at her
    Local Line X company is getting 4 star from me just because they scratched my plastic tail gate cover and over sprayed the roof (on my windshield ) but overall I'm happy and finally done with line x.
  25. Aug 7, 2021 at 4:50 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Show some output shots of that bar
  26. Aug 7, 2021 at 5:21 PM
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    I parked my truck in the street…first 1 is headlights only; 2nd is with light bar (no fogs on in either pic). You’ll notice the trees and bushes are much more lit up as is the end of the street with the light bar. I may adjust it up a bit, after running it more as I have it angled marginally downward so the laser light wasn’t pointed straight out (if that makes sense).
  27. Aug 7, 2021 at 5:28 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    You’d get a tan standing in front of that thing :eek:
  28. Aug 7, 2021 at 5:31 PM
    Or a call from the ISS. :rofl:
  29. Aug 7, 2021 at 5:35 PM
    Squatting Pigeon
    Holden
    North Texas
    Lol melanoma and a federal crime for blinding air/spacecraft :rofl:
  30. Aug 7, 2021 at 5:42 PM
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    :welder:Pretty much :rofl:
