  1. Jul 29, 2021 at 5:50 AM
    Army_of_One
    Army_of_One New Member
    2019 MGM 4X4 CrewMax, 2005 Cement 4x4 Double Cab
    OEM+
    Not necessarily. I have an EQ from the "tuner of tacos" and I don't use any adjustments on my factory head unit. I don't have to reset everything after disconnecting the battery either.
  2. Jul 29, 2021 at 6:04 AM
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    even if you had the JBL “premium” audio - it’s still not very good
  3. Jul 29, 2021 at 6:24 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    it actually is a blessing, now i can upgrade it relatively cheap and easily! premium locks you in to a much more expensive route.
  4. Jul 29, 2021 at 6:33 AM
    DerfM
    DerfM Knows nothing about trucks
    South Dakota
    2021 TRD Pro MBM
    Only if you want to keep any component of it. Otherwise, replacing it all is the same with or without.
    Angry Gunny and woods[QUOTED] like this.
  5. Jul 29, 2021 at 6:34 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    There’s some “stretch” to the valence straps that attach to the skid. Works fine with the shims.
  6. Jul 29, 2021 at 6:34 AM
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    i haven’t had any experience with replacing the JBL system because mine was the non JBL as well but you can pretty much replace everything including the HU and also add subs for around 2k with pretty decent equipment
  7. Jul 29, 2021 at 6:45 AM
    1794TX
    Steven
    N.TX
    '20 1794
    TY, sir!
  8. Jul 29, 2021 at 8:25 AM
    SAGE63
    San Diego County
    I have the RCI skids and the holes in the 3 tabs attaching the valance were still able to line up to the holes after the shim was installed. yeah a little push was needed but all good
    GELCW and 1794TX[QUOTED] like this.
  9. Jul 29, 2021 at 10:04 AM
    MikeyRedFL
    MikeyRedFL New Member
    SWFL
    2021 Limited Crew Max 4x4
  10. Jul 29, 2021 at 10:09 AM
    IndianaGeologist
    IndianaGeologist New Member
    It's more of a "why did I lift my truck this high?" handle. :rofl:
    3xYOTA, ryanryan34, Jcmf52 and 3 others like this.
  11. Jul 29, 2021 at 10:12 AM
    MikeyRedFL
    SWFL
    It helps with that feeling of falling out of the truck...:mudding:
  12. Jul 29, 2021 at 10:59 AM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Any reason for this over the larger tank offered on 16 and up ?
  13. Jul 29, 2021 at 11:00 AM
    TampaRD Pro
    TampaRD Pro Cunning Linguist
    Stanley
    Southwest Florida
    2020 MGM CM TRD Pro
    Lots.
    Installed my custom TRD Pro battery hold down bracket from @Coupe.
  14. Jul 29, 2021 at 11:03 AM
    TampaRD Pro
    Stanley
    Southwest Florida
    2020 MGM CM TRD Pro
    Lots.
    Also, got around to installing my Diode Dynamics SS3 Pro ditch lights on my Rago Low Pro Mounts.
    AZ Red Nek, TunBrun, GAknight and 5 others like this.
  15. Jul 29, 2021 at 12:34 PM
    Cl8NL
    Cl8NL Pocket-Sand
    MKE WI
    2017 SR5 5.7 4x4 quicksand dbl cab
    Installed DD Bamuffler 10”.
    I knew it wouldn’t fit like a glove but fingers crossed it’s good enough. I swung by the local muffler shop to see if they’d inspect it for leaks but they won’t since they didn’t put it on….
    I don’t hear any…..
    66Platinum, 3xYOTA, Fotnot and 8 others like this.
  16. Jul 29, 2021 at 3:50 PM
    Angry Gunny
    Angry Gunny New Member
    Rob
    Bedford, PA
    2016 SSM 1794 4X4
    Yes please
    Your clamp and gasket are not seated correctly, Sir.
    Orracle, Cl8NL[QUOTED] and Barrett50 like this.
  17. Jul 29, 2021 at 4:09 PM
    justcuz
    justcuz 2.5 Gen Member
    Getting rid of the chrome and silver. Painted shifter handle body color. 5E3C3D42-3A5E-4FEA-A649-E9C831FDAC9D.jpg5C5CA862-20D5-4A40-A2B0-3774299F141C.jpg
    Fotnot, DCB500, AZ Red Nek and 9 others like this.
  18. Jul 29, 2021 at 5:37 PM
    Cl8NL
    Cl8NL Pocket-Sand
    MKE WI
    Thank you!!! I’m gonna fix that up here. Hope I didn’t bend it out of shape
    IsaiahCanada likes this.
  19. Jul 29, 2021 at 5:54 PM
    biebs96
    PA
    If it did bend, ask @DPlatinum I just sent him a stock clamp and a brand new gasket.
    Maybe if he ends up not needing it, he can re-pay it forward.
  20. Jul 29, 2021 at 6:55 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
  21. Jul 29, 2021 at 7:54 PM
    FortyNorth
    FortyNorth New Member
    Northern ON
    2014 Tundra Super White SR5
    Crossed off another item on the 7 Yr Refresh list: changed out front/rear dif and transfer case fluids. Rear oil (in pic) was pretty vile, front clearly used but not as bad, t-case looked like I changed it yesterday.
    3xYOTA, Fotnot, AZ Red Nek and 6 others like this.
  22. Jul 29, 2021 at 8:03 PM
    AZBoatHauler
    So.Arizona
    How many miles on the t-case oil? I’m at 60k and trying to decide whether to do it at 75k or 100k.
    Tundrastruck91 likes this.
  23. Jul 29, 2021 at 8:05 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Did you decide to go with a 3/6 lift?
    AZTundra and biebs96 like this.
  24. Jul 29, 2021 at 8:07 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Took some more before the rain.. the last picture is the top of the tail gate in line with my 4runner which is lifted 5" in the rear.
  25. Jul 29, 2021 at 8:10 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    That's the RTX leaf kit on the highest setting. Will be level with 750 pounds in the rear. Currently it's suppose to sit 4 above stock but it looks like more.
    TRDFerguson[QUOTED] likes this.
  26. Jul 29, 2021 at 8:28 PM
    okcowboy
    okcowboy New Member
    No Mans Land (Tulsa, OK)
    2021 Tundra 4x4 1794 Edition Wind Chill Pearl
    I think he has the brackets for Tundras with OUT the deck rail system. He needs these. This is what came with my Ultra Flex with Deck Rail mounts.
    mgm16trdpro likes this.
  27. Jul 29, 2021 at 8:35 PM
    MatD13
    MatD13 New Member
    2018 Limited Cement Crewmax 4x4
    Looks great! How’d you do it?
  28. Jul 29, 2021 at 8:40 PM
    FortyNorth
    Northern ON
    180k km so a dozen or so over 100k miles, didn’t get it tested or anything but visually still looked pretty good- also I use the 4x4 a fair bit of the year as they aren’t big on clearing snow up here. That said, if you can get a cheaper alternative to the chamillon dollar Toyo 75w it’s probably cheap insurance and is actually the easiest of the three points to do (low torques and lots of room to pour).
    AZBoatHauler[QUOTED] likes this.
  29. Jul 29, 2021 at 8:46 PM
    RoniusMaximus
    RoniusMaximus The One and Only
    J
    Tri-Cities, Washington
    2020 MGM Toyota Tundra TRD PRO
    Synthetic Blinker Fluid
    Finished my 2nd coat of griots 3-in-1. Rhinorack RB20s side steps are so nice to have when you need to get to your cab roof. Picture doesnt do any justice but I am so happy to finally complete my first wax job on my Tundra as mentioned before its been 15 years since I last waxed any car. My almost 1.5 year old boy takes priority in my life so its been hard to set aside time to get this done.
    RRR1C0, Fotnot, Yzed608 and 16 others like this.
  30. Jul 29, 2021 at 8:54 PM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Unbolted a bunch of stuff from the bed today and gave her a wash. I removed these mounts so I could sand the rust off and paint them (should have painted before using them, but I made them right before we left for CO a few weeks ago).
    I have seen lots of people looking for cheap shovel or axe mounts, so I wrote up a quick DIY. It'll cost you $30 and you won't have to drill any new holes in your bed. :thumbsup:
    Fotnot, romad86, nhw544 and 5 others like this.
