  1. Jul 25, 2021 at 7:29 PM
    NorthShore
    NorthShore New Member
    2014 SR5 TRD Offroad Crewmax
    Busy weekend. Pulled the tailpipe and got it wire wheeles, degreased, sanded and painted.
    Installed blacked out steering wheel emblem, black shift knob, console safe and dual USB charger. Wire wheel, sanded, degreased the hitch cargo carrier then coated in bedliner.
    Fixed one of the latching bars on the bakflip. Rivets had all pulled out. Redid them and added a few extra.
  2. Jul 25, 2021 at 7:29 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Are these installed over the OEM rails? What tonneau do you have? Did this come with tie down anchors? Where did you get them? This looks very interesting to me. The only problem I have with my Undercover Armor is the fact that I can't use my rails the way I want.
  3. Jul 25, 2021 at 7:56 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    :monocle:
    looks good
  4. Jul 25, 2021 at 8:03 PM
    okcowboy
    okcowboy New Member
    No Mans Land (Tulsa, OK)
    2021 Tundra 4x4 1794 Edition Wind Chill Pearl
    Macs has L-track cut and drilled to replace the factory deck rail system and that’s what I originally intended to do and then fabricate some way to attach the Ultra-Flex. BUT..since the L-track only sticks out less than 1/2” compared to the 1” of the deck rail I realized that tie downs could pull up on the Ultra-Flex mounting rail and bend it.
    I ended up making a bunch of 1” square nuts for the deck rail to screw 2 pieces of 1/4” x 1” aluminum between the deck rail and the L-track to move it out to the edge of the Ultra-Flex mounting rail. Then I decided it would be easier to cut the L-track up so I could continue to use the original Ultra-Flex anchors.
  5. Jul 25, 2021 at 8:04 PM
    okcowboy
    okcowboy New Member
    Thanks
  6. Jul 26, 2021 at 4:17 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Great find! I'm checking into it.
  7. Jul 26, 2021 at 5:19 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    The switches fit perfectly in a 20mm hole.
    AZTundra[QUOTED] likes this.
  8. Jul 26, 2021 at 6:12 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
  9. Jul 26, 2021 at 8:34 AM
    Long Duck Dink
    Long Duck Dink Nope
    North Salt Lake, UT
    2019 Super White 1794 Edition Tundra CrewMax 4x4
    3/2" Readylift, TRD Dual Exhaust, TRD Sway Bar, Line-X Bedliner, ArmorFlex Tonneau, ESP 3 bin storage, Amp Power-Steps, Driver Side Grab Handle, Ronin Antenna, Window Tint, ClearBra. Coming Soon: 20" Method MR305NV. BF Goodrich KO2 275/60/20
    Where'd you purchase the USB charger for the center console and how hard was the install?
  10. Jul 26, 2021 at 8:42 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Very easy. Here I've had a USB port installed for the external USB stick/SSD. The kiddos enjoy headrest monitors and HDMI player on the long trips.
  11. Jul 26, 2021 at 9:02 AM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Just throwing this out here instead of starting a new thread. Anyone have WetOkole seats covers on there front seats of there truck? Tossing it around about putting a set on my front seats.
    RainMan_PNW likes this.
  12. Jul 26, 2021 at 9:05 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Is that from US Cargo?
  13. Jul 26, 2021 at 9:06 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I do, over cloth seats. They are heat-neutral: not cold in winter, not hot in summer. Also should be easier to maintain the seats long-term, these can be wiped off, water-cleaned, washed at last. Cloth seats accumulate dust, impossible to get rid of it w/o a proper aid like Tornador.
  14. Jul 26, 2021 at 9:09 AM
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    Thanks brotha! It's the GoRhino BR5 with went tray and light bar mount.
    ryanryan34[QUOTED] likes this.
  15. Jul 26, 2021 at 9:13 AM
    Nic146
    Nic146 New Member
    Probably stuck somewhere
    2016 Barcelona Red TRD CM
    Today I decided to see how far an aired down 3rd gen with nothing more than a level and 34’s could go.
    The answer is, pretty impressively far.
    She ran all the way over Pearl Pass with only a little wheel rash to show for it. 4D4D7EE4-91C3-45BF-B510-7EE3861A0D49.jpg FFC1DF41-7F83-4956-8664-66AEA683EAB6.jpg
  16. Jul 26, 2021 at 9:14 AM
    greg8765
    greg8765 New Member
    Grant
    Utah
    2021 Cement Tundra
    they look awesome! i always put predator steps on my trucks and never have a problem hitting my ankles :)
    bll05c likes this.
  17. Jul 26, 2021 at 9:16 AM
    RusPro21
    Don
    Pa.
    Thanks. I had them on my tacoma years ago and liked them. I’m looking to put a set on my 21 Pro but there leather but not really.
  18. Jul 26, 2021 at 10:28 AM
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    After a three month wait I received my BedRug XLT. Waiting for it to relax a bit before final install. My knees are already happy!
  19. Jul 26, 2021 at 11:58 AM
    Cfincke
    San Antonio
    A car blew a tire on the highway and a piece caught one of my tires, caused it to have a leak. Got to install my spare on the side of the highway. Also learned i need a jack capable of lifting a truck on 37s in the truck at all times now. A couple People from a local offroad recovery group on FB showed up in 20 minutes with jacks to help out. AAA was 1.5-2 hours out
    Have an odd ball black wheel on the truck right now till i can get it discount tire to have them look at the other
    gabex35, AggiePhil, Yzed608 and 12 others like this.
  20. Jul 26, 2021 at 12:04 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    That why I love car people, I'm always down to help someone in need if I can.
  21. Jul 26, 2021 at 1:08 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    I heard your ride lasts longer the more fellow drivers you help. Hoping to never retire my ol 4runner.
  22. Jul 26, 2021 at 1:11 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    HA! I see what you did there.
  23. Jul 26, 2021 at 2:09 PM
    Torque
    Torque New Member
    Ft Collins, CO
    2016 DC TRD 4x4
    Agri-Cover,RCI skid,ADARAC,Fox 2.0,TruDuals
    Here's one someone else on here used that I had saved in my Amazon cart: https://www.amazon.com/dp/B082PNLMDS/?coliid=I2LJHSVDND71GL&colid=2Q3USKXJ17IDJ&ref_=lv_ov_lig_dp_it
    There's power for the OEM 12V accessory port right there you can tap into using either solderless taps/crimps for a super fast install.
    The post I saw, used the one I just linked to replace the 12V port, so it was just plug and play.
    Black Dynamite likes this.
  24. Jul 26, 2021 at 2:55 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    That Landess plaza though; Parktown Pizza is the shizzness! Lookin' good Geno!!! Maybe I'll see you rollin' down the road when I come back in a couple of weeks!
  25. Jul 26, 2021 at 2:56 PM
    Long Duck Dink
    Long Duck Dink Nope
    North Salt Lake, UT
    That's what I want to do...just replace the cigarette lighter type power source and replace it with a USB. Thanks for the link!
  26. Jul 26, 2021 at 2:57 PM
    NorthShore
    Purchased on Amazon. Saw it from another Tundras.com user who had installed. Very easy install. It was my first attempt with wiring on a vehicle. Probably took about 30 mins. A little trimming of the hole with a utility knife was the most difficult part.
  27. Jul 26, 2021 at 3:25 PM
    KS1371
    KS1371 New Member
    21 CM MGM TRD SPORT
    Got my Valhalla front shield yesterday and rattle canned it. Threw it on today.
    Nothing is a guarantee, if someone wants something bad enough they will find a way. This will at least make them think twice, and give me a little peace of mind.20210726_171457.jpg
  28. Jul 26, 2021 at 3:58 PM
    FancyPants
    FancyPants Not my Husband’s truck
    Amber
    Oregon
    ‘19 SUPER WHITE Platinum Crewmax
    Washed her. She was a dirty girl after my solo camping excursion this weekend.
  29. Jul 26, 2021 at 4:18 PM
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    Awesome!
  30. Jul 26, 2021 at 4:25 PM
    Lassie
    Lassie New Member
    HKM
    TAMPA, FL
    Joined the team today....
