  1. Jun 27, 2021 at 6:31 PM
    Some go up to 2018 models. Wiring is different on the 20/21's so you would have to check compatibility closely.
  2. Jun 27, 2021 at 6:59 PM
    Holy hell....do you have a tractor? That's a whole lot of yard to cut.
    Fotnot[QUOTED] likes this.
  3. Jun 27, 2021 at 7:03 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
  4. Jun 27, 2021 at 7:42 PM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    :rofl:Its only 2.5 acres. 54" ztr knocks it out in about an hour
    Barrett50 likes this.
  5. Jun 27, 2021 at 7:46 PM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Just a curious question for anyone adding the phone charger in the console. Don’t you like using the cord since there are plenty of USB ports. I just keep my cord plugged in and plug my phone in it.
    AggiePhil likes this.
  6. Jun 27, 2021 at 7:50 PM
    Barrett50
    Barrett50 New Member
    Barrett
    Wisco
    2015 DC silver
    Old school! Love it. I have another question. Why y’all gotta charge your phones so much?I’ve been up since 0630 and mines still above 50%
    BlueRibbon4x4 likes this.
  7. Jun 27, 2021 at 8:02 PM
    RusPro21
    Don
    Pa.
    I have to charge mine a lot because I still have iPhone 7plus and the battery does not hold a charge very long. But there is no reason to upgrade since my phone works fine. I will soon get the 12 max eventually.Also I plug my phone in because of my Apple Music.
  8. Jun 27, 2021 at 8:07 PM
    ATOYOTA
    ATOYOTA New Member
    I felt the same way until I got the wireless car play dongle. Now I either leave my phone in my pocket or place it on the console to charge.
  9. Jun 27, 2021 at 8:10 PM
    Barrett50
    Barrett
    Wisco
    2015 DC silver
    Had the same problem with my 7, you can get a new battery cheap if you’re gonna keep it a while. I didn’t bother though, just upgraded.
  10. Jun 27, 2021 at 8:12 PM
    RusPro21
    Don
    Pa.
    Yeah I’m going to upgrade eventually that’s why I’m not changing the battery out. Soon as Verizon give me a good discount on the 12 max then I will. Lol.
    Barrett50[QUOTED] likes this.
  11. Jun 27, 2021 at 8:24 PM
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
    because it is fun to do simple mods!
    I really like it for longer drives.
  12. Jun 27, 2021 at 8:27 PM
    UFG8R75
    UFG8R75 New Member
    2021 Cement Tundra Limited
    I'm looking to get cement bulge, grille and bumper end caps for my CM limited as well.. where'd you get yours?
  13. Jun 27, 2021 at 9:17 PM
    point08
    point08 New Member
    Kyle
    2014 Toyota Tundra 5.7L SR5 4WD DC
    AirLift LoadLifter 5000 Ultimate Plus, AirLift Wireless One 2nd Gen, TRD Rear Sway Bar, Bakflip G2 Tonneau Cover, Running Boards, Tint, Power Tailgate Lock, Hike-It X9 Throttle Controller, Tekonsha P3 Brake Controller with Custom In-Dash Housing, Method 701 Wheels, Toyo Open Country III Tires, 3WLiner Window Mod, External Fuse Box, Dash Cam, Pioneer DMH-1500NEX
    Got my Anytime Camera wired up. Just gotta cut the wires to flip it from reverse but didn't notice until after i got the grill back on.
    prevent, BlueRibbon4x4, Jego and 9 others like this.
  14. Jun 27, 2021 at 9:42 PM
    junior
    junior Member
    Zach
    Santa Cruz, CA
    2016 Tundra TRD Off Road
    Black Rhino Rapid 17" 35x12.5 Mickey Thompson Baja Boss Fox Performance Elite 2.5 DSC at 3" with Coachbuilder 1/4" shim on driver side JBA UCAs Fox Performance Elite 2.5 DSC rear shocks Dobinsons HD Leaf Springs Firestone Airbags + Daystar Cradles Prinsu Cab Rack 2024 Four Wheel Camper Project M Camper Mods: Goal Zero Yeti 4000 house battery 200w solar IceCo fridge Truma Propane Heater
    Added two SR Rigid 6" Midnight spot beam lights between my two 6" SAE yellow ones in my lower bumper; they're super bright! I wired the new ones separate from the ambers on my switch-pros controller. I was able to connect the four lights together using stainless threaded rod and jam nuts and no bracketry between each
  15. Jun 28, 2021 at 3:14 AM
    JerryH
    JerryH Gravy Boatin, I don’t park I dock.
    SOMD
    2020 Crewmax Limited Cement
    I got everything from Sparks Parts.
    Tundrastruck91 likes this.
  16. Jun 28, 2021 at 3:29 AM
    Djone27
    Djone27 New Member
    2017 MGM Crewmax TSS 4x4
    HID Headlights, full LEDs, TRD front and rear sway bars, CB +2s, Eibach Stage 2s, SABM w/ pro intake tube
    Yes, there's the plug at the bottom (I had to undo mine with an impact last time due to shop overrightening it) and then the housing itself. There is a metal spring clip that keeps the actual housing from unscrewing on its own. You may need to flex that away from the housing while unscrewing it.
  17. Jun 28, 2021 at 4:29 AM
    If you haven't drained your filter yet, do that first. There is a plastic tube about 2 inches long in the box with the filter. It pushes a plunger to drain the oil when you snap it in, so make sure the pan is under it.
  18. Jun 28, 2021 at 4:40 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    https://www.youtube.com/watch?v=j8_kUPEDp_U
    got to the 2:50 mark. it shows the oil filter drain attachment. but i believe the box shows the way to change the filter including draining the oil from the filter since it has the attachment inside the box....at least the toyota ones do.
    Tundrastruck91 and GaTundra79 like this.
  19. Jun 28, 2021 at 4:53 AM
    Black Dynamite
    Black Dynamite New Member
    2017 Toyota Tundra Limited Crew Cab
    Nice Stereo...which one is that?
  20. Jun 28, 2021 at 5:12 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    i think after a first oil change, the dealer (whether intentional or not) slightly flexes/bends it back to do it. but i agree that it doesn't really make contact or do anything IMO.
  21. Jun 28, 2021 at 5:42 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Cap is definitely not reverse thread. Did my first oil change on it Saturday and I had to use a breaker bar to get it off. I fully thought I was going to break the plastic housing but it finally started turning. Then my next problem was trying to get the tool off the filter housing, I had to smack it with a hammer a few times to get it free.
  22. Jun 28, 2021 at 5:45 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    All of it regular. turn left to unscrew it. not sure how you're doing it, but i always drain oil with oil fill cap off. then open up cap with 3/8 drive, push plastic adapter drain into it, then remove filter housing. never had issues on my 2011 or my 2017, but maybe dealer put on too tight or something.
  23. Jun 28, 2021 at 5:49 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    when removing, i find it helps to leave the filter wrench on it until after i put the housing back on (no real need to take it off unless swapping for the metal housing one). then after tightening, it is easier to take it off since it's back attached to the truck. if too bad, i grab a 3/4" open end wrench and put it on the end nut on the wrench housing perpendicular to it and wobble it off. most times i can get it off with the 3" extension used to put it on and off.
  24. Jun 28, 2021 at 5:55 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    I wouldn't suggest the impact, but thats just me. i've found me and a breaker bar is usually stronger and more efficient than an impact in most cases anyway. i'm assuming you have another vehicle to go get parts if needed if/when things go south? if time is allowed, i'd suggest getting a metal filter housing. just my $.02
  25. Jun 28, 2021 at 6:03 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    I also want to get a metal housing now that I've got the first oil change out of the way and I know what I'm doing. Any particular brand I should get?
  26. Jun 28, 2021 at 6:26 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
  27. Jun 28, 2021 at 6:51 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
  28. Jun 28, 2021 at 8:12 AM
    1794TX
    Steven
    N.TX
    '20 1794
    You might consider a non-factory alternative. I have a service agreement, so it's not relevant yet, but it will be soon. Others here may have experience-based advice.
    https://jowettperformance.com/products/coming-soon-billet-oil-cap-for-filter
    And yes, I will extremely selfishly ask your opinion of it if you purchase. :D
    co2owen likes this.
  29. Jun 28, 2021 at 8:26 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Out of stock... I'll keep an eye on it. Won't need it for a few months
  30. Jun 28, 2021 at 8:44 AM
    Barrett50
    Barrett
    Wisco
    2015 DC silver
    They’ve been out of stock for 2-3 months.
