  1. Jun 27, 2021 at 10:08 AM
    romad86
    romad86 New Member
    Warrenton, VA
    2021 Limited Cement
    X2. I’d definitely try another dealer, I’ve had good luck with that previously.
  2. Jun 27, 2021 at 10:08 AM
    romad86
    romad86 New Member
    Warrenton, VA
    2021 Limited Cement
    Put the AJT knob in, not sure I like it. I think I’ll look for a TRD one.
  3. Jun 27, 2021 at 10:25 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Which knob don't you like?
  4. Jun 27, 2021 at 10:31 AM
    RobertD
    Robert
    DFW, Texas
    The one in the picture I'd assume
    gabex35 and romad86 like this.
  5. Jun 27, 2021 at 10:35 AM
    romad86
    romad86 New Member
    Warrenton, VA
    2021 Limited Cement
    The AJT one pictured.
  6. Jun 27, 2021 at 10:51 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Looks like you purchased the climate knobs and the 4wd knob so I was just curious. I also am not a huge fan of the climate ones.
  7. Jun 27, 2021 at 11:06 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Did a LOF, transmission drain and fill, cabin filter, topper re-install and swapped to a metal housing on the oil filter...Tuesday, the Falcon suspension is installed and Friday I "test" it out on a 800 trip...
  8. Jun 27, 2021 at 11:23 AM
    romad86
    romad86 New Member
    Warrenton, VA
    2021 Limited Cement
    Oh crap, my bad. I see how that wasn’t super clear.
    I was referring to the shift knob. The climate knobs are ok. I’m not sure if it’s the knobs or my installation of them, but they don’t turn as smoothly/freely as the factory ones. I like the looks of all of them. I’m just not a fan of the feel of the shift knob.
  9. Jun 27, 2021 at 11:35 AM
    cochese
    cochese New Member
    Oregon
    '21 Lunar Rock TRD Pro Double Cab
    Snuck in one more thing this weekend, the wireless charging tray. Real easy install other than having to unscrew and then put back a ton of screws.
    Question for those who have this, is there a way to make it default to "off" instead of "on" when I start up the truck? I'm planning to use this sometimes, but more often I'd just like it to be off. Do I have to hit the off button every time I start up the truck now if I'm not going to use the charger?
  10. Jun 27, 2021 at 11:38 AM
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
  11. Jun 27, 2021 at 11:39 AM
    French Avocado
    Utah / Wyo
    correct - default is on and cannot be changed from what I have seen.
  12. Jun 27, 2021 at 11:43 AM
    Rabidllamas
    Rabidllamas New Member
    Phil
    WA
    2019 Cement Crewmax TRD OffRoad
    My build- https://www.tundras.com/threads/rabbidllamas-old-man-build.80802/
    Considered the ajt knob when I blacked out some of the interior but went with the trd shift knob. Only have the top view.
    Ostrich, YotaBro and Fotnot like this.
  13. Jun 27, 2021 at 11:48 AM
    romad86
    romad86 New Member
    Warrenton, VA
    2021 Limited Cement
    Yea, I like that better. I’ll check the inter webs and see what I can find. Thanks
  14. Jun 27, 2021 at 12:11 PM
    cochese
    cochese New Member
    Oregon
    Bummer, I would have preferred the opposite.
  15. Jun 27, 2021 at 12:22 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    I haven't found a way. It's just become routine to turn off when I get in the truck.
    French Avocado likes this.
  16. Jun 27, 2021 at 12:24 PM
    Wallygator
    I bought a knock off carbon fiber one on Amazon. So much better than the stock SR5 shifter, you may like it. One issue I had with it is it doesn't tighten up. I think the inset is spinning. Is not loose enough and has not been a big enough deal for me to take it off and fix it yet.
    https://www.amazon.com/gp/product/B07Y1NFDRL/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8
  17. Jun 27, 2021 at 12:26 PM
    cochese
    cochese New Member
    Oregon
    Anyone have the schematics for the PCB? I bet we can find a way.
  18. Jun 27, 2021 at 1:30 PM
    romad86
    romad86 New Member
    Warrenton, VA
    2021 Limited Cement
    Thanks, I’ll check it out.
  19. Jun 27, 2021 at 1:44 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Wouldn’t it just be easier to cut a simple single-pole switch into the hot power lead to the charger? Leave it off by default and it’ll never turn on unless you flip it on…
  20. Jun 27, 2021 at 1:47 PM
    cochese
    cochese New Member
    Oregon
    Yeah, that's an option. I was looking for something easier, like maybe they put a switch on the PCB already that flips the default or an easy solder job, but may end up doing something like you mention. Not a big deal, just like to dial everything in just the way I want.
    RainMan_PNW[QUOTED] likes this.
  21. Jun 27, 2021 at 2:43 PM
    MikeyRedFL
    MikeyRedFL New Member
    SWFL
    2021 Limited Crew Max 4x4
    So what happens if you have your device plugged in to the USB (for Android Auto) and in the charging tray at the same time...Is it like crossing the streams in Ghostbusters?
  22. Jun 27, 2021 at 2:50 PM
    cochese
    cochese New Member
    Oregon
    Your phone should manage that situation properly.
    AggiePhil and RainMan_PNW like this.
  23. Jun 27, 2021 at 3:06 PM
    redrum448
    redrum448 New Member
    youll have a hard time putting it in the tray flat with a cord plugged into the phone
    AggiePhil likes this.
  24. Jun 27, 2021 at 3:41 PM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
  25. Jun 27, 2021 at 4:02 PM
    RobertD
    Robert
    DFW, Texas
    Fotnot[QUOTED] likes this.
  26. Jun 27, 2021 at 4:59 PM
    Elroy_unlimited
    Elroy_unlimited New Member
    Eric
    Murfreesboro TN
    2017 limited crew max
    Added the paint matched door handles that showed up at my door today! Thanks to Sparks Toyota. Before and after
  27. Jun 27, 2021 at 5:59 PM
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    Installed Tesla Style Radio. New video coming soon.
    Astom22, yoshi82, Part_time and 19 others like this.
  28. Jun 27, 2021 at 6:08 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Please tell me how you like it. I've had this sitting in my cart for months but haven't found any solid reviews on them and I don't like that I lose my xm radio.
    Jego[QUOTED] and Ted4311 like this.
  29. Jun 27, 2021 at 6:12 PM
    Rustedfenders
    Rustedfenders If it ain't broke, don't fix it.
    Wally
    Rosedale Md.
    2016 Blazing Blue Pearl TRD Tundra Crew Max
    Aries 4" Bull Bar, 3-2 Level Lift Havoc Stainless hoop steps.
  30. Jun 27, 2021 at 6:29 PM
    jimbrophotodotcom
    jimbrophotodotcom New Member
    Hawaii
    2021 Lunar Rock Tundra TRD Pro
    IG: @LunaTheTundra, Coachbuilder kit and 35s soon
    where sells this?
