  1. May 25, 2021 at 6:33 PM
    biebs96
    PA
    a black painted flat washer, some peel and stick felt padding for the back of it, a long skinny bolt, and a washer and wing nut on the back side of the wheel will stop.. deter that theft.
  2. May 25, 2021 at 6:40 PM
    YotaBro
    Calvin
    FL
    Lots of shenanigans.
    Holy crap, that is sick!
  3. May 25, 2021 at 6:42 PM
    R0CKETMAN
    R0CKETMAN IG: @rocketmanmtb
    NGAMTNS
    '17 TUNDRA TRD PRO CEMENT ‘15 TUNDRA SR-5 WHITE
  4. May 25, 2021 at 6:48 PM
    romad86
    romad86 New Member
    Warrenton, VA
    2021 Limited Cement
  5. May 25, 2021 at 6:52 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    When I had a spacer lift, I installed the fronts in two hours. Threw my back out loosening the alignment bolts. I vowed never to work on suspension again. But there are plenty of people with bigger muscles that get it done just fine. Shouldn’t take longer than half a day. Saving $400 is a good excuse I’d use to get yourself a new jack.
  6. May 25, 2021 at 7:13 PM
    nmjameswilson
    nmjameswilson New Member
    James
    Kansas City
    2021 Limited Nightshade Double Cab
    No it is great so far.
  7. May 25, 2021 at 7:38 PM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Can't wait until I can do this without gas spitting back up and all over my truck .. I have to manually put small amounts in, then stop when hearing gas backing up, then proceed slowly again. ugggg !!
    Yup, what Chelly said, but agree should be on the Pro as well.
    I suspect I will need a new 38g tank like that.
    Yup.
    Nice .. will have to look into doing the outside handles ... thought they were a hard install like the mirror caps are supposedly ?? ..btw do you think painting over existing chrome mirror caps with a flat black would look decent and match the black handles ? Thanks
  8. May 25, 2021 at 7:51 PM
    3rdTundra
    3rdTundra Hay Hauler
    Central Texas
    2017 Tundra SR5 Double Cab TSS 4x4
    FRAC harness / camera & Full set of Valhalla plates
    OK. Regarding your gas spitting up comment. I had that happen to me the last fill up. No top off done, but as soon as the gas pump shutoff, the gas started gurgling up and spilling out of the tank. I haven't had that happen before on this truck or my previous Tundra. Is this common?
  9. May 25, 2021 at 7:55 PM
    Tundrastruck91
  10. May 25, 2021 at 7:59 PM
    J's 4x4
    J's 4x4 New Member
    Juan
    Los Angeles County
    2020 Tundra Cement Grey TRD 4x4
    King lift,Leather seats,3m film wrap around,35's KO2 on FUEL Wheels,Line-X, backflip,Bam 10" exhaust with Toyota Black Chrome Exhaust tip,Amp research step,K&N air Filter,TRD air flow Accelerator
    Getting ready for the weekend install. Had a can of undercoating and engine black. I know you can't see them but couldn't live with myself knowing I didn't paint the wood. Have a good evening guys
    mgm16trdpro likes this.
  11. May 25, 2021 at 8:08 PM
    seniao
    seniao New Member
    Santi
    Buford, GA
    2019 Silver Sky Metallic SR5 Double Cab
    TRD Pro Head Lamps Spray Bed Liner Side steps Peragon Tonneau cover
    hey snappy where did u get the shifter trim? looks good!
  12. May 25, 2021 at 8:47 PM
    3rdTundra
    Central Texas
    AJT Designs
  13. May 25, 2021 at 8:49 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Exterior handles are silly easy. I went to look up the video before bed just to see what I was in for and ended up going outside and just doing them. Took 5 minutes. I've heard (and been told by shops) painting over chrome does not turn out well. Shops in my town wouldn't touch anything chrome which is why I've spent my life savings purchasing new instead of trying to paint.
  14. May 25, 2021 at 8:51 PM
    romad86
    romad86 New Member
    Warrenton, VA
    2021 Limited Cement
  15. May 25, 2021 at 9:11 PM
    TorinWallace
    TorinWallace Yota Addict
    2020 TRD Pro, DoubleCab, Army Green.
    CB Shim + Shackles | 305/70r18 KO2's | 18" Method NV's | Firestone Airbags | Tow Mirrors | Marlon Sleddeck | Spyder smoked taillights.
  16. May 25, 2021 at 9:55 PM
    HARPER306
    HARPER306 New Member
    SK, Canada
    2020 Voodoo TRD Sport CM
    Thanks, I wish it was glossier but it was also only $100 and easily removable should you/I decide for something else until new wheel time. As for tips.. I have a couple haha
    -Give yourself more time than you think you'll need, I probably didn't wait long enough between coats (gave about 20 mins between, 5-6 coats a wheel). Started cleaning them at 130 pm and didn't start painting until 345ish. Finished at about 6 then left to rest for a few hrs.
    -make sure the rims are really clean, prep is important
    -1 can black per wheel, use the whole can
    -put the cans in warm water for 10-15 mins before you start, it comes out smoother
    -I used armor all on the tires to keep the dip from sticking, it didn't really make a difference on the outer overspray part. Maybe it wasn't a slick enough compound. It will pressure wash off easily next wash though
    -I just left the wheels on, apparently the stuff doesn't like to spray nice at a horizontal angle if you were to pull the rims and lay them down. So I just left them on, pulled the center caps and popped out the emblems. Removed the valve stem caps and taped the stem(so the dip isn't a one piece layer on the stem/cap). Tape the nuts, covered the brakes /everything behind the wheel face with 1 large garbage bag each fished through the rim. I was skeptical at the ghetto-ness but it worked perfect
    I think there's another brand/offbrand called hyper dip that has some different finishes that are supposedly more glossy. I am forever skeptical of spraybombs that claim they are glossy though after spray painting my emblems in highschool. What was supposed to be gold was in fact Dijon mustard and I didn't even put the emblems back on lol. It just rained here for two days after I painted them, so I will wash my truck tomorrow and see how they clean up
  17. May 26, 2021 at 3:30 AM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Did not do any pics of the lights. Added headlight Revolution reverse lights in my 21 tundra pro yesterday. Man what a difference. I did the same to my 2020 4runner Pro. But both vehicles are terrible lighting when backing up. These headlight Revolution reverse lights are even more impressive. Yes a little pricy but you get what you pay for.
    WILLINH likes this.
  18. May 26, 2021 at 4:02 AM
    YotaTruckLtd
    YotaTruckLtd Secret Squirrel
    2014 MGM Limited CM
    Bilstein 6112/5160 Boss 4x4 shims Boss 4x4 shackles Fuel Off-Road Vector wheels 20X9 Nitto Terra Grappler G2 35" tires SPC UCAs OEM TRD Pro Grille OEM 2020 LED headlights and OEM LED fog lights OEM color matched mirror caps and door handles OEM black exhaust tip Ecoological color matched front and rear bumpershellz V3 Go Rhino RB20 running boards XPEL Prime XR Plus ceramic tint 30% front 15% rear 70% windshield BAKFlip MX4 tonneau cover Dasaita 13in Vivid Headunit AJT interior chrome delete black kit AJT climate control black knobs AJT V3 shift knob TVD exterior emblem black inlays 3BMakers Yota hitch cover Husky front and back floormats K&N Select engine air filter GTR Lighting Armor Series LEDs Reverse lights Cargo lights 3rd brake light License plate lights
    I did mine a few months ago and wish I would've done it sooner. Still waiting on my bumper caps to arrive. Nice truck btw..
  19. May 26, 2021 at 4:05 AM
    snappy924
    snappy924 New Member
    Garrett
    Pasadena, California
    2017 Tundra Crewmax 4x2
    Bilstein shocks, Tembren bump stops,
    AJT designs. I ended up buying the whole 9 yards from AJT designs, climate controls, rings, vent rings, and the same setup for my wife’s 4Runner. They also have great install videos that guide you step by step.
  20. May 26, 2021 at 4:53 AM
    NjPro
    NjPro New Member
    Tom
    Nj
    2017 Trd Pro Tundra cement
    Magnuson supercharger, Sprint booster, CB TRD PRO kit, 295/70/10 terra grapple G2, Black TRD shift knob, Rhino shackle hitch, Lund Tri-fold bed cover, 1.25 Spidertrax wheel spacers. TRD rear sway bar. Bud Built cross member. Arb Diff breather. Grab handle installed. 2012 DC SR5 TRD Supercharged, Gone but not forgotten.
    Had 4 new 295/70/18 Nitto terra grappler G2 installed yesterday. I did not get the E load or LT spec tires. I do not tow anything heavy nor do I have more then 500 or so pounds in the bed. These tires replaced Lt 285/70/18 ridge grapplers.
    Being they are just shy of a 10 pound difference between the two tires, what a major difference in ride quality. Much smother, soaks the bumps up better being it is a softer tire. Haven’t had them in the woods yet, so no opinion there. It completely changed the way the truck fills, it’s crazy what 40 less pounds can do for handling.
    I posted my old tires in market place if anyone is interested.
  21. May 26, 2021 at 6:12 AM
    jdg1982
    jdg1982 New Member
    Florence, Colorado (From Louisiana)
    2017 Magnetic Gray Tundra SR5 4x4
    Which bumper caps are you going with?
    I saw these on Sparks and I am planning to give them a try in a couple months. My bumpers are wrapped at the moment, but it's started to fade and the rear has a couple tears in the vinyl.
    https://www.sparksparts.com/p-2014-tundra-color-keyed-front-rear-bumper-covers-0001634527
  22. May 26, 2021 at 6:35 AM
    Taco-Spike
    Two Trucks
  23. May 26, 2021 at 7:36 AM
    1794TX
    Steven
    N.TX
    '20 1794
    I went with the paintables from Sparks (they didn't carry 4x4 in stock)
    PKTUNFR
    3rd Gen Tundra Front Paintable Bumper End Caps Color: 4X4 - Smoked Mesquite; Sensor Holes: WS - With Sensor Holes
    $518.62
    As I was receiving those, someone wrote that they had a chrome shop strip the chrome from the steel on the existing ends and then had them painted. Thinking critically about it from any angle, I can't come up with a better solution than that. If you can get that done anywhere close to the cost of the Sparks caps, paint the ones you have.
  24. May 26, 2021 at 9:02 AM
    Long Duck Dink
    Long Duck Dink Nope
    North Salt Lake, UT
    2019 Super White 1794 Edition Tundra CrewMax 4x4
    3/2" Readylift, TRD Dual Exhaust, TRD Sway Bar, Line-X Bedliner, ArmorFlex Tonneau, ESP 3 bin storage, Amp Power-Steps, Driver Side Grab Handle, Ronin Antenna, Window Tint, ClearBra. Coming Soon: 20" Method MR305NV. BF Goodrich KO2 275/60/20
    The gifts keep coming from my most recent oil change experience at the local dealer...
    I was washing my Tundra yesterday and noticed the front bumper was loose. Ofcourse, they didn't put the screws back in that attach the front bumper to the skid plate and the frame. This is the same dealership that told me they'd rotated the tires but it turned out they didn't.
    Just another reason to do most/all service yourself!
  25. May 26, 2021 at 9:21 AM
    GELCW
    GELCW New Member
    Erik
    Northern Virginia
    2018 Gray Tundra Platinum
    Yeah it’s just not worth the headache. It’s a shame to say and if you call them they will tell you to bring it in and they will fix it. So then you have to take time out of your day for something that should have done right the first time. Sorry for my rant, you hit a nerve with me in this. I have fought this battle to many times that I won’t go back to dealership because of it.
  26. May 26, 2021 at 9:39 AM
    TorinWallace
    I went with 5500 pure white. Very natural looking, I've gone cooler before around 6k and while the blue' ish tint looks cool as an accent I find it to be a less "useful" light.
    WILLINH and Taco-Spike[QUOTED] like this.
  27. May 26, 2021 at 10:50 AM
    beowulf
    beowulf New Member
    Dave
    2021 Toyota Tundra SR5 4WD Double Cab Long Box
    Boost Auto Tow Mirrors w/motorized fold upgrade
    So, funny story: I went through your diagrams, tracked down all the possible fuses/relays that might be trouble, but couldn't identify anything out of the ordinary. Finally I made an appt last Friday to take it in to my local Toyota dealership to see whether they could help. They had it for about an hour and called me back into the service department to discuss. The service guy told me the techs found 15 (!) blown fuses in the truck, and every time they tried to put new ones in, those would blow too. He said they couldn't spend any more time on it that day because of all the people who had booked ahead of me, so could I bring it on Tuesday to leave it with them for a full day of diagnostics. I agreed and set up the next appt.
    When I got home and tried to fold the mirrors to pull the truck into the garage (we have a narrow tandem), they didn't fold. The dealer's techs hadn't replaced the fuse tap that powers the mirror folding. So I decided to replace both the fuses in the tap with fresh ones, just in case, then stuck it back into the ECU/ACC socket. I started the truck, put it in reverse, then looked for the backup display out of habit—and it was working. It had been one or both of those fuses in the tap the whole time! I know that I checked those fuses, but I heard that it's sometimes hard to visually tell whether those low profile fuses are blown, and I believe it now! So problem solved.
    And I hope those dealer technicians had a fun hour writing science fiction about my truck! :D
  28. May 26, 2021 at 11:01 AM
    SimpleMan
    SimpleMan New Member
    Chuck
    2021 SR5 TRD OR 4x4
    Diamondback HD
    Installed N-fab steps.
    Wallygator, point08, Sean492 and 5 others like this.
  29. May 26, 2021 at 11:05 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Glad you got it solved!
  30. May 26, 2021 at 11:24 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Did the rear diff breather relocation mod. Doubt I'll ever do much water crossing, but will the flash floods around here certain times of the year, it's something I wanted to have just in case.
    QrDzxi5rNY2OKl4NrzB1d93edxt716UsCS5RvH7X_777c4c7ae27db7e4eba5dccdd90467c2d0191643.jpg
