  1. May 15, 2021 at 12:01 PM
    nmjameswilson
    nmjameswilson New Member
    James
    Kansas City
    2021 Limited Nightshade Double Cab
    VLED bedlight bulb comparison... Brake lights need some kind of adapter so going to try auto parts store
    Screenshot_20210515-135935_Gallery.jpg Screenshot_20210515-140002_Gallery.jpg
    Wallygator, Ostrich, Jpd0144 and 3 others like this.
  2. May 15, 2021 at 12:17 PM
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
    @RainMan_PNW - Thanks Casey. The button remains in position, either stays pressed or extended. It is a push button that when pushed mirrors are folded and when extended mirrors are unfolded. So once it is turned off and pressed to unfold then the truck knows to unfold when started. Because I have both 2nd Gen and 3rd Gen I just checked and they both function the same.
    RainMan_PNW[QUOTED] likes this.
  3. May 15, 2021 at 12:28 PM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    '21 Cavalry TRD Sport CM Tundra & 25 TRD Pro Sequoia
  4. May 15, 2021 at 12:41 PM
    jackienguyener
    jackienguyener OKToyota
    Jackie
    2016 Tundra 1794
    You should re-use the stock bulb socket. The new VLEDS harness should plug right in
    nmjameswilson[QUOTED] likes this.
  5. May 15, 2021 at 12:45 PM
    nmjameswilson
    James
    Kansas City
    RainMan_PNW and Toe404[QUOTED] like this.
  6. May 15, 2021 at 1:13 PM
    nmjameswilson
    James
    Kansas City
    Before and after
    Screenshot_20210515-151149_Gallery.jpg Screenshot_20210515-151207_Gallery.jpg
    3xYOTA, Ostrich, a522467 and 8 others like this.
  7. May 15, 2021 at 1:40 PM
    jackienguyener
    Jackie
    2016 Tundra 1794
    Replaced tech BuiltRight Industries Tech Panel with the Greyman Tactical 11x6 RMP panel, makes for easy and convenient storage
    13E1C292-7E6B-40AD-9D25-55364F36176B.jpg CA5AFF6A-947F-4EF1-8DEE-0BDF6AE58A19.jpg
  8. May 15, 2021 at 1:40 PM
    French Avocado
    Utah / Wyo
    Which VLEDS LED bulb did you use?
  9. May 15, 2021 at 2:05 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Ok. Then I’ve got a hunch that the DPDT relay would work basically that same way it does with the non-memory switch, except you’d need one in each door. Basically, you’re setting up a relay so that when the ACC is on, the wiring uses the “stock” configuration (based connects the factory wiring per the factory setup), but when ACC is off, it sends power directly to the motor to fold the mirror.
  10. May 15, 2021 at 2:45 PM
    Convertedman
    Convertedman New Member
    Scotty
    Cumming, Ga
    2021 CM 4 wheeler Limited Cavalry Blue
    6in Ready lift, Toyo 35/12.50/20
    This happened on Thursday. Damn muddy jobsite.
  11. May 15, 2021 at 2:45 PM
    TNTundra16
    TNTundra16 YOU BIG DUMMY!
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    I used mine to carry the kids fishing. It was little man's first time and he had a blast!
  12. May 15, 2021 at 3:05 PM
    Classy63
    Classy63 Valhalla’s Shield guy
    Tyler
    Cypress Texas
    15 platinum Barcelona red
    Toytec Aluma 2.0 front and rear, Toytec shackles, Toytec add a leaf pack, Tuff Country UCA’s, Firestone bags with daystar cups. JBA long tubes, w/3” cats, Dirty Deeds TRD replacement, DAP tune, AFE filter
    I replaced my faded sun bleached spyder headlights with dead bugs in it.
    I got new super spyders (Recon) headlights
    Wallygator, Rippyro, Ostrich and 13 others like this.
  13. May 15, 2021 at 3:10 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    I needed to make some brackets to mount my amber spot lights, but didn’t want to buy the brackets available by a certain company. Originally I used pvc mounted to the crossmember, but they just bounce like crazy.
    I removed the air deflectors, and started with cardboard, utilizing two of the points and a stud on the crossmember. After making the template, I cut them out of 3/16” aluminum, bent and brazed the bends, and painted flat black. Super sturdy now, they don’t move at all. 029C0570-1E3E-4286-998F-5C87CD5E86FE.jpg
    WFD473, Wallygator, Ostrich and 21 others like this.
  14. May 15, 2021 at 3:52 PM
    TunBrun
    TunBrun New Member
    Sunnyvale, CA
    2017 5.7L Crewmax Blazing Blue
    Just got my truck back from @dcsleeper408, thanks for another great install! :hattip:
    He installed new 6112s (pre assembled at 1.9"), 5160s in the back, and my new wheel caps. He also put in a strut shim to add 1/2" to the drivers side and the front is dead even side to side. (And diagnosed leaking cam shafts, at least the powertrain warranty is still in effect.)
    When I bought the truck it had some big strut spacers up front which I wanted to get rid of. Like Mark predicted, after putting in the 6112s, the truck is a touch nose high now. Next I will hook up my travel trailer to see how much higher I need to raise the back up. Just looking for a level ride when towing.
    Thinking of adding an HD Roadmaster Active Suspension and then seeing if I need a small shackle or not.
    Final numbers (fender to center of hub): Front Driver = 24 3/8", Rear Driver = 23 5/8", Front Passenger = 24 3/8, Rear Passenger = 24"
  15. May 15, 2021 at 4:10 PM
    Lassie
    Lassie New Member
    HKM
    TAMPA, FL
    My truck was towed away from the visitor parking lot only because my daughter forgot to extend my parking registration.... lol, costed me $250 to retrieve from the compound. Ouch!
    WFD473 and biebs96 like this.
  16. May 15, 2021 at 4:35 PM
    Newey
    Newey New Member
    Bill
    2021 Lunar Rock TRD Pro, 2016 Tundra TRD CM, 2010 Tundra SR5
    C0942944-4B40-4257-BA0B-C67FC0ADA2AA.jpg BF7FE0AF-3615-4351-A3A3-624EE12B0996.jpg B6260CEE-F8CF-4973-A147-D9CAE6614CEB.jpg
    The Lady had a spa day today... Full detail
    Beckusmc, AggiePhil, Ostrich and 21 others like this.
  17. May 15, 2021 at 4:44 PM
    nmjameswilson
    James
    Kansas City
    The red ones that are $180
  18. May 15, 2021 at 5:12 PM
    French Avocado
    Utah / Wyo
    Thanks - waiting for the 25% off sale.
  19. May 15, 2021 at 5:17 PM
    nmjameswilson
    James
    Kansas City
    Is that something they do often? I will buy more for other places if so.
  20. May 15, 2021 at 5:26 PM
    French Avocado
    Utah / Wyo
    I think it is Fourth of July and Black Friday. Spent a bunch last Fourth of July and planning on more this time.
  21. May 15, 2021 at 5:30 PM
    I have Vleds in mine. I have the V6 Triton for my brake lights. What did you purchase?
  22. May 15, 2021 at 5:34 PM
    Mr_Kane
    Mr_Kane New Member
    2019 TSS Crewmax
    :Eibach 2.5" Lift :SPC UCA's :34" Toyo AT3's :10" BA Muffler
    Beautiful Rig...
    The AT3's look even better in person....Ask me how I know!!
    Velocity72 and RRR1C0 like this.
  23. May 15, 2021 at 5:34 PM
    Ok after continuing the thread, you have the V6 Extreme. You still use the bulb socket and it plugs into it.
  24. May 15, 2021 at 5:38 PM
    They would be a hell of alot brighter with lenses that weren't blacked out. :D
    WFD473 and NewImprovedRon like this.
  25. May 15, 2021 at 5:40 PM
    Now Line-X those flares lol.
  26. May 15, 2021 at 5:41 PM
    TNTundra16
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    :101010:
    Newey[QUOTED] likes this.
  27. May 15, 2021 at 5:47 PM
    He has the V6 Extreme. His lenses are blacked out or they would be a hell of alot brighter. The turn as tail system will be going pre-order in a few weeks as well.
  28. May 15, 2021 at 5:48 PM
    Sign up for their newsletter and you will get emails when they have sales.
  29. May 15, 2021 at 5:49 PM
    Fastlane47
    Fastlane47 New Member
    Maryland
    2018 Platinum
    22x12 Weld wheels, TRD Lowering kit, TRD Rear sway bar, Honey D Fenders, Corsa side exhaust with black tips, Magnuson supercharger, pedal commander. Lux hard cover, TRD PRO Grill, Kicker 10in Subwoofer, Viper remote start, paint match mirrors and door handles, LED tail lamps, G10 rhino lined running boards. 3m on front fenders, hood, roof and rear fenders. Stop Tech Big Brake Kit front and rear.
  30. May 15, 2021 at 5:50 PM
    There is a shitload of Tundras here in Tampa and I still have not seen a single Lunar Rock.
