  1. Mar 28, 2021 at 4:21 PM
    Elfine
    Elfine Doing my best to break this beast
    Pensacola, FL
    2017 Quicksand Tundra TRD
    Datin Metal Fab 18" Bed Rack, ARB Diff Breather, SDHQ ABS Guards, RCI Engine/Transmission/Fuel Skid, ICON Stage 5, Rago Bed Stiffener/Ditch light brackets, ARB twin air compressor, 295/70R18 Cooper Evolution M/T, Spydertrax 1.25" spacers
    Gave my winch a workout today. For the record, I had no issues.
  2. Mar 28, 2021 at 4:23 PM
    Aggiekey
    Aggiekey New Member
    Dustin
    2021 5.7 crewmax 4wd
    Leveling kit, 33 tires
  3. Mar 28, 2021 at 4:41 PM
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    did it just take of surface hard water or did it work for etched in spots?
  4. Mar 28, 2021 at 4:45 PM
    MatD13
    MatD13 New Member
    2018 Limited Cement Crewmax 4x4
    Currently putting black handles on the cement. Did all 3 doors but the drivers side screw will not line up. Anybody have this problem and what did you do? Second pic it shows black sharpie with the screw hitting just to the side of the hole. Been at this 1 damn handle for the past 3 hours
    Wallygator and Fotnot like this.
  5. Mar 28, 2021 at 4:49 PM
    Aggiekey
    Aggiekey New Member
    Dustin
    Not sure I have any etched in spots. It’s fairly new. But this is the best it’s looked after 3-4 washes using meguires.
  6. Mar 28, 2021 at 4:49 PM
    More details on what you used and why....:D
  7. Mar 28, 2021 at 4:55 PM
    JimBeam
    JimBeam Moderator Staff Member
    South Carolina
    2015 Limited
    Started doing a thing today
    Wallygator, Ostrich, Fotnot and 5 others like this.
  8. Mar 28, 2021 at 4:57 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    1 - are you sure the lock shaft is fully engaged in the lock mechanism?
    2 - i remember being able to angle the screw side-to-side inside the little plastic keeper it is in. Seems that there’d be enough play to make up for minor misalignment
    3 - is the plastic housing correctly attached to the lock body?
    just stabbing at ideas
    BlueRibbon4x4 and MatD13[QUOTED] like this.
  9. Mar 28, 2021 at 5:02 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    I had issue with this and it was the angle of the screw. Run the screw backwards and angle it back and forth horizontally until you feel the threads skipping in the female side.
  10. Mar 28, 2021 at 5:08 PM
    MatD13
    MatD13 New Member
    1. I hope so. The black key fob thingy has been nice and flush with no wiggle room.
    2. I’ve tried so many times trying to wiggle that screw back and forth. Getting a pry tool for some leverage and going again.
    3. definitely.
    Thanks for the ideas @RainMan_PNW So much for a quick 15 minute job. All the other doors took literally 30 seconds to take out and replace. Now it’s getting dark out. Boo
    BlueRibbon4x4 likes this.
  11. Mar 28, 2021 at 5:10 PM
    NoKenDo
    NoKenDo New Member
    Ken
    Grand Rapids MI.
    2018 Platinum 4x4 Mesquite Brown
    TRD Pro Suspension. Moonroof. Front window tint. Compustar Pro T11 remote starter. N-FAB running boards Bedrug Bedmat XLT DiamondBack HD Tonneau Weather Tech Window Visors
    Turned 60,000 miles
  12. Mar 28, 2021 at 5:10 PM
    MatD13
    MatD13 New Member
    Thanks @BlueRibbon4x4 I’ll try that again tomorrow
  13. Mar 28, 2021 at 5:32 PM
    Aggiekey
    Aggiekey New Member
    Dustin
    I was using meguires previously and no matter how much buffing, I couldn’t get the hard water spots off, especially on the windows. I heard someone on here say to use chemical guys. I didn’t use something specific for hard water, but these in combination took the hard water stains off.
  14. Mar 28, 2021 at 5:34 PM
    Thanks. Yeah we got water spots on the glass here in Fl too. Drives me nuts.
  15. Mar 28, 2021 at 5:38 PM
    Rube207
    Rube207 New Member
    Rob
    Atlanta
    2010 Pyrite Mica Limited CM
    Also make sure the plastic trim in the door is clicked into place correctly. I had trouble with one door and this was the issue.
    MatD13[QUOTED] likes this.
  16. Mar 28, 2021 at 5:44 PM
    Jmor6766
    Jmor6766 New Member
    Jon
    SW Colorado
    2014 White Tundra TRD SR5 4.6L
    Travolta or Cage?
    Wallygator, WFD473 and BlueRibbon4x4 like this.
  17. Mar 28, 2021 at 5:48 PM
    briarpatch
    briarpatch New Member
    What Meguiars product(s) were you using? You mentioned buffing....machine buffing or by hand? Neither of the two products you pictured have anything in them that will remove water spots....my guess is that the multiple layers of protection you're putting down are simply hiding them
    Fotnot likes this.
  18. Mar 28, 2021 at 5:56 PM
    Astom22
    Astom22 New Member
    Bob
    Celina, TX
    2021 SR5 Tundra Crewmax 4x4
    Bakflip G2 Tonneau Cover
    Got my flag vinyls installed this week, another coating of Griots, drivers side grab handle installed (just missed having it too much), and some Toyota scuff guards installed.
  19. Mar 28, 2021 at 6:23 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Bummer. Every time I’ve done them it’s been super easy.
  20. Mar 28, 2021 at 6:37 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
  21. Mar 28, 2021 at 6:42 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Part of every good face lift should come with a little work under the chin...
  22. Mar 28, 2021 at 6:48 PM
    jhardy1979
    jhardy1979 New Member
    Justin
    MGM 2015 Tundra Crewmax Limited 4x4
    Did you move your rear window switch to the center console?
    RainMan_PNW likes this.
  23. Mar 28, 2021 at 6:49 PM
    Piki
    Piki New Member
    2017 Tundra crewmax 1794 TRD
    Yeah, I did. Perfect location for the switch.
    jhardy1979[QUOTED] likes this.
  24. Mar 28, 2021 at 6:52 PM
    GoForthMGM
    GoForthMGM New Member
    Kyle
    2014 TUNDRA SR5 TRD OFF ROAD
    How did your secure your topper to the bed? Were you able to keep the rail system?
  25. Mar 28, 2021 at 6:52 PM
    BlueRibbon4x4
    Geno
    Yeaaaah buddy!!! :thumbsup:
  26. Mar 28, 2021 at 6:54 PM
    RobertD
    Robert
    DFW, Texas
    That's awesome!
  27. Mar 28, 2021 at 6:54 PM
    BlueRibbon4x4
    Geno
    I spy a sneak peak in the corner...
  28. Mar 28, 2021 at 6:55 PM
    YotaBro
    Calvin
    FL
    Lots of shenanigans.
    Hell ya!!!:oldglory::oldglory::oldglory:
  29. Mar 28, 2021 at 7:14 PM
    AZBoatHauler
    So.Arizona
    Wow. :fistbump::101010::oldglory:
    WFD473 likes this.
  30. Mar 28, 2021 at 7:17 PM
    AZTundra
    Paul
    Phoenix, AZ
    Added the Tuffy safe from another local member on here. I was surprised my tray organizer still fits with the safe installed.
