  1. Mar 5, 2021 at 3:17 PM
    JeffMac
    JeffMac 2 Words, 1 Finger
    Jeff
    South Florida
    2015 Black Tundra OVTUNE
    Suspension: Bilstein 6150 Front Max Setting CB Shim 2x Driver 1x Passenger Bilstein 5160 Rear CB +3 Shackles Firestone Airbags w/ Daystar Craddles Engine: OVTUNE - 87 w/ Torque Modifier SABM w/ K&N Filter TB Coolant Bypass Fumoto Drain Plug Wheels/Tires: ProComp Bandidos 0mm Offset Nitto Exo Grappler AWT 285/70/18 Exterior: TRD Pro Grille Spyder Headlights/Taillights Ecoological Bumpershellz LED everything Tinted windows Bakflip MX4 Tonneau Cover K-Source Tow Mirrors Interior: Pioneer AVH-W4500NEX Radio 2x 10” Pioneer Subwoofers 1200W Pioneer Mono Amp 2000W Pioneer 4 Channel Amp
    Just finished debadging my truck. That 3M eraser tool was magical. Got some 50lbs fishing line from Walmart (the cheap kind) and god did it suck. Get what you pay for.
    TelemarkTumalo and Fotnot like this.
  2. Mar 5, 2021 at 3:31 PM
    junior
    junior Member
    Zach
    Santa Cruz, CA
    2016 Tundra TRD Off Road
    Black Rhino Rapid 17" 35x12.5 Mickey Thompson Baja Boss Fox Performance Elite 2.5 DSC at 3" with Coachbuilder 1/4" shim on driver side JBA UCAs Fox Performance Elite 2.5 DSC rear shocks Dobinsons HD Leaf Springs Firestone Airbags + Daystar Cradles Prinsu Cab Rack 2024 Four Wheel Camper Project M Camper Mods: Goal Zero Yeti 4000 house battery 200w solar IceCo fridge Truma Propane Heater
    After a lot of research and figuring out how this all works, I got my SwitchPros installed! I made a custom stainless bracket, and ended up using some quick disconnects for the trigger fuse taps so its easier to get the relay box cover off. I was super stoked when I converted my ditch lights from a dash switch+relay and hooked them up to SP... and they worked :D Got a couple more lights to convert now.
  3. Mar 5, 2021 at 4:21 PM
    jefroshm0
    jefroshm0 New Member
    Elk Grove, CA
    2018 Cement Tundra Crew 4x4 SR5
    4 months back order and they finally arrived! Califabrication did an amazing job on the install. Truck is handling corners like a champ and don’t forget those speed bumps too. Weather gets better, take her on some trails for a real challenge.
  4. Mar 5, 2021 at 4:32 PM
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
    What is that small round lid for?
  5. Mar 5, 2021 at 4:48 PM
    jefroshm0
    Elk Grove, CA
    It’s a cover for the key lock.
    War_Wagon312 likes this.
  6. Mar 5, 2021 at 5:03 PM
    bgdv1
    bgdv1 New Member
    Dave
    Butler,Pa
    2019 Limited CMSB
    Had truck inspected and fuel pump & turn signal recalls done.
    WILLINH likes this.
  7. Mar 5, 2021 at 5:04 PM
    100LL
    100LL smells better than Jet-A
    NW Oregon
    2020 SR5
    Potatoes.
    Dingo's kennel got a slight upgrade today... :D
    ARE MX ON!
    I de-badged it after taking these pictures, don't worry.
    Follow my dingus on IG @dingothedingus
    Edit: Also, PCS error came back after putting the topper on. Luckily I have airbags on order to bring the rear end back up to 42" which should adjust the angle back down.
  8. Mar 5, 2021 at 5:08 PM
    bgdv1
    bgdv1 New Member
    Dave
    Butler,Pa
    2019 Limited CMSB
    How was the install ?
  9. Mar 5, 2021 at 5:12 PM
    Sitting Sideways
    Sitting Sideways Probably stuck somewhere
    Beaverton, Oregon
    2021 White CM Tundra TRD Off Road
    Icon IR Coilovers, Icon Delta Joint tubular upper control arms, Icon PB CDC rear shocks, Icon Expansion Pack, Icon Hydraulic Bump Stops, Durobumps front bump stops, TRD dual exhaust black tips, TRD pro skid plate, TRD cold air intake system, TRD pro shift knob, TRD Pro Wheels, Falken Wildpeak AT3W tires, TRD radiator cap, ESP under seat storage, spray in bed liner, bed rail system, SDHQ abs guards, black tundra letter inserts, center console wireless charger, center console organizer/tray, charcoal filter removal, whistle screen removed, RCI Transmission/Transfer case skid plate, and ICON neoprene shock wraps
    Did the now classic drivers side grab handle install, should have come from the factory.
  10. Mar 5, 2021 at 5:27 PM
    They used to. I stole mine out of my 2013 before I sold it. :D
  11. Mar 5, 2021 at 6:26 PM
    NIOSH
    NIOSH New Member
    2021 1794 CrewMax Army Green
    ELKA, 35", Harrop, lockers w 4.88
    Retrax installed, order placed Harrop SC, Toytec Elka 2.5 with OME leafs, Vector 5 bronze with Toyo ATiii 25x11.5.17. Now trying to find a quality shop for elocker install. So if you know of one in the Denver area?
  12. Mar 5, 2021 at 6:27 PM
    Tibetan Nomad
    Tibetan Nomad New Member
    marcelo73, tbutler, P-Factor and 3 others like this.
  13. Mar 5, 2021 at 6:30 PM
    Is that thief in his socks? And his license plate is visible.....:rofl:
  14. Mar 5, 2021 at 7:13 PM
    Jcmf52
    Jcmf52 New Member
    Rob
    2018-1794 S/C
    Shorty antenna Trifold hard top tonneau cover Center console safe Center console tray Rhino liner TRD air filter TRD rear sway bar TRD front sway bar Center console wireless charger kit Remote start Black 4x4 emblem swap
    Battery tie down from Coupe
    Had some help with install today as well!
  15. Mar 5, 2021 at 7:21 PM
    bkdelux
    bkdelux New Member
    This is my next purchase! How long did it take after ordering? Did you order aluminum or or stainless?
    WILLINH likes this.
  16. Mar 5, 2021 at 7:30 PM
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    Blast his ass. If you lie you steal if you steal you kill. POS!
    WILLINH likes this.
  17. Mar 5, 2021 at 7:32 PM
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    Ordered it Feb 15, got the stainless for $926 total with Valentines Promo code. Sounds awesome, can't hear my CAI anymore and can definitely feel the HP. Spins my wheels everytime I stepped on it.
    WILLINH and bkdelux[QUOTED] like this.
  18. Mar 5, 2021 at 7:34 PM
    bkdelux
    bkdelux New Member
    amazing, did you install yourself?
  19. Mar 5, 2021 at 7:39 PM
    Funnyguy713
    Houston TX
    Yea its only 5 bolts, I soaked them overnight and loosened them yesterday so it would be a quick install today. The only hard part was pulling the old muffler off the hangers but I hit them with WD40 and they came flying off.
    https://youtu.be/IwBlJZYRWFo
  20. Mar 5, 2021 at 7:40 PM
    bkdelux
    bkdelux New Member
    Thanks for the info friend. Did you jack up or drive up on blocks? I have a leveling kit and 34's so I already have some decent clearance.
  21. Mar 5, 2021 at 7:44 PM
    Funnyguy713
    Houston TX
    Got a 6" lift with 35s on 20s, I can do barrel rolls under there. :rofl:
  22. Mar 5, 2021 at 7:55 PM
    MatD13
    MatD13 New Member
    2018 Limited Cement Crewmax 4x4
    Install was pretty easy. At the most 30 minutes. Just be careful taking the liner out forward of the wheels. The bracket with 2 bolts is easy to crack. Use a pry tool and go slow.
    for some reason the whole fog assembly jiggles after you initially take it out and then reinstall, even with the stock bulbs. I believe it’s held in with only 2 clips. I’ve read on the forum it’s a common pain. So easy fix was to install 2 zip ties behind each fog assembly to secure. 1 may have been good enough but I wanted the extra reassurance
    bgdv1[QUOTED] likes this.
  23. Mar 5, 2021 at 8:13 PM
    jackienguyener
    jackienguyener OKToyota
    Jackie
    2016 Tundra 1794
    Installed the VanTop 612T digital rear view mirror today. Really helpful for showing you those blind spots and seeing past anything in the back seat.
    BB7AD700-EDAC-403C-A46B-B9AC00A1F971.jpg A58A1A2E-A0BB-42A4-922E-A76B1D71D9AF.jpg
  24. Mar 5, 2021 at 8:17 PM
    AggiePhil
    AggiePhil Texas Chapter President
    College Station, TX
    2020 Smoked Mesquite Platinum 4x4
    Where'd you mount the rear camera? Also, does it record like a dash cam?
  25. Mar 5, 2021 at 8:45 PM
    jackienguyener
    Jackie
    2016 Tundra 1794
  26. Mar 5, 2021 at 9:49 PM
    BulldogDan
    BulldogDan New Member
    Cement…Tundra #9
    27702128-C7CA-4B21-8C9B-26DA4A95DEC3.jpg I have been storing the Silver Bullet since November due to the fact I have 3 really nice vehicles and only a 2 1/2 car garage. I hated leaving one of them set out during the winter here in Ohio. So my Tundra was stored at a friends garage while she is snowbirding in FLA. Long story short, I sold one of our cars today so I brought my Tundra home and parked her where she belongs....in my garage. I need to get some miles on her. She only has 1,500 miles on the odometer!
  27. Mar 6, 2021 at 4:07 AM
    THOR's
    THOR's New Member
    Thor
    North Carolina
    2021 Tundra TRD Sport and XP Predator Package
    Congratulations on a job well done! You just decreased a major overhead expense every month and the truck is now totally yours! :cheers:
  28. Mar 6, 2021 at 5:12 AM
    :infantry:
  29. Mar 6, 2021 at 5:43 AM
    phi482
    phi482 New Member
    KY
    2020 Cement Limited TRD Off-road
    Welcome from Louisville. Where in Ky?
  30. Mar 6, 2021 at 6:08 AM
    tundrafez
    tundrafez New Member
    fez
    Massachusetts
    2001 3.4 v6 manual - 2017 tundra trd off road 5.7l
    I got my yokohama geolander go 15 tires mounted yesterday. LT 275 70 18.
