  1. Mar 4, 2021 at 5:32 PM
    HighonFirewood
    HighonFirewood Everything can be fixed with a hammer.
    Stage Left. Colorado
    2019 Tundra
    The bottom of your truck is cleaner than the top of mine!
    War_Wagon312 and RainMan_PNW like this.
  2. Mar 4, 2021 at 5:32 PM
    JeffMac
    JeffMac 2 Words, 1 Finger
    Jeff
    South Florida
    2015 Black Tundra OVTUNE
    Suspension: Bilstein 6150 Front Max Setting CB Shim 2x Driver 1x Passenger Bilstein 5160 Rear CB +3 Shackles Firestone Airbags w/ Daystar Craddles Engine: OVTUNE - 87 w/ Torque Modifier SABM w/ K&N Filter TB Coolant Bypass Fumoto Drain Plug Wheels/Tires: ProComp Bandidos 0mm Offset Nitto Exo Grappler AWT 285/70/18 Exterior: TRD Pro Grille Spyder Headlights/Taillights Ecoological Bumpershellz LED everything Tinted windows Bakflip MX4 Tonneau Cover K-Source Tow Mirrors Interior: Pioneer AVH-W4500NEX Radio 2x 10” Pioneer Subwoofers 1200W Pioneer Mono Amp 2000W Pioneer 4 Channel Amp
  3. Mar 4, 2021 at 5:47 PM
  4. Mar 4, 2021 at 6:24 PM
    TrenThom86
    TrenThom86 New Member
    Trent
    NW Louisiana
    2021 TRD Pro Lunar Rock
    AJT shift knob finally came in. Ordered on 2/2.
  5. Mar 4, 2021 at 6:44 PM
    Ltaco17
    Ltaco17 New Member
    NC
    2023 TRD Pro
    285/75/18 Falken Wildpeak R/T color matched handles and mirrors.
    Same here!!!
  6. Mar 4, 2021 at 6:49 PM
    CappyKD
    CappyKD Older, grayer member.
    Kirk
    2025 Limited 4x4 TRD Off Road CC 6.5 Lunar Rock
    What switch panel and mount do you have installed in your center console?
  7. Mar 4, 2021 at 6:51 PM
    Ltaco17
    Ltaco17 New Member
    NC
    2023 TRD Pro
    SDHQ mount with Switch-Pros 9100 controller
    CappyKD[QUOTED] likes this.
  8. Mar 4, 2021 at 6:57 PM
    TelemarkTumalo
    TelemarkTumalo New Member
    Mark
    Bend, OR
    2020 Tundra TRD Pro Double Cab Army Green
    Driver side grab handle Door sill protectors Falken WildPeak 295/70 R18 X-Pel clear front paint protection 20% front window tint Go Rhino RB20 side steps - Bedliner finish Lock'er Down 1/2 console safe Toyota bed cargo divider Toyota auto tail gate lock
    Catalytic converter thieves? What has the world come to? I must live in a sheltered environment as I never knew this was a problem.
    jpod likes this.
  9. Mar 4, 2021 at 7:01 PM
    TimberToy20
    TimberToy20 New Member
    East Texas
    2020 Super White Crewmax
    612 Old Man Emu coilovers, Old Man Emu rear shocks, 1” rear block, diff drop.
    BEC7A864-DB18-4876-98A1-2C88B07019E9.jpg 047B7909-20DF-41B3-894E-001EDA6C49CE.jpg
    They really don’t stick out much more than the stock duratracs did. Yea the TSS wheels are +55 from what I have read. No clearance issues with the upper arms or joint but there is not much room to spare. Not sure how you could go any wider without a spacer and then you may have issues around other areas of the wheel well. I had to remove the mud flap on the front bumper but easy peasy. No problem rubbing stock skid either and I am off road every day. The back does sit about a half inch lower and makes my ocd flare every time I think about it. Looks fine on level ground though most of the time. 3/1 lift with old man emu coilovers and rear shocks. Probably replace the 1” block with a 2” in the future.
    Jpd0144, Krezz and mgm16trdpro like this.
  10. Mar 4, 2021 at 7:19 PM
    SpooledReel
    SpooledReel Insufficient Funds
    RickyP
    Spanish Fort, AL
    2015 Tundra CM Limited 4x4
    Anytime cameraCE5DA0DE-53A5-4A13-9C63-88D1660CCE20.jpg851CDAC0-075B-40CA-9110-21B9945E46EF.jpg
  11. Mar 4, 2021 at 7:35 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    We paid off our Tundra today. Super stoked. We rolled from one new car to the next after we paid them off but this one we're keeping. I haven't gone without a car payment in probably 15 years.
    Cosmoblu, Watson, Ostrich and 32 others like this.
  12. Mar 4, 2021 at 7:36 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    :thumbsup:
    JimboSlice413[QUOTED] likes this.
  13. Mar 4, 2021 at 7:39 PM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Congrats! If I keep up my quadruple payments, I’ll join the club this fall.
  14. Mar 4, 2021 at 7:47 PM
    El Two
    El Two I’m only talking to my dog today.
    Lisa
    2018 SR5 Crewmax TRD Off Road
    How much time do you have? . . . . . . . . . . . . . . . . . . . . .......... Eaton rear eLocker, Camburg 1.5” shackles, Rear Seat Delete, S&B CAI, sPOD, Air Bag Helpers w/ Daystar Cradles, RCI engine & fuel tank skid plates, ABS Guards, Job Box Storage, Tailgate Power Lock, Desert Eagle Offroad tranny/cat security skid plate, Added Driver’s Side Grab Handle, VLEDS Footwell & Step Lighting, Anytime Front Camera, Illuminated Ignition Ring, Console Molle Panel, Sound Dampening in Ceiling/Doors/Floor, Yakima Rack, Paracord Grab Handle Wraps, BD Underhood Light, Tuffy Console Safe Insert, WeBoost System, Midland GMRS Radio, Console Interior Lighting, Power Inverter, Custom Center Switch Panel, and Dual Air Compressors
    Mounted the front Anytime camera. Because of the way it is mounted the angle can be adjusted a few degrees to better aim the camera. Still working on the install so I haven’t had a chance to test it yet. I have an idea on how to provide even greater range of movement. If this version doesn’t work out, I’ll try plan B.
    Front and rear pics below. Details can be found on my build thread (link in signature block) at post #35.
  15. Mar 4, 2021 at 7:55 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Well...you do live in Bend. ;)
  16. Mar 5, 2021 at 4:39 AM
    Rgross2112
    Rush
    2020 Silver TRD Limited
    Gave her a bath to knock off the Pennsylvania salt68736733-8790-4381-8E91-E6C2470BD2B5.jpg
  17. Mar 5, 2021 at 4:51 AM
    Yep....its spreading pretty rapidly too. The palladium that is in them is $2600 per ounce right now. Gold is around $1800 if that tells you anything. The hot vehicles right now are the Tundra, Prius, and Honda passport, but they will steal them from anything.
  18. Mar 5, 2021 at 6:46 AM
    49ºNRTH
    49ºNRTH New Member
    2025 Limited MGM
    Installed my suspension, wheels and had my canopy arrive and get fitted. All within a week or so of each other
    Suspension is Falcon tow/haul set to level
    Leer 100r w/headliner, tracks and removable front slider
    295.70.18 Coopers on SCS SR8 wheels
  19. Mar 5, 2021 at 7:05 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    964592C7-B77D-422B-A2D7-98604289559B.jpg 03054CC4-1767-49C3-9474-EA544FC746EE.jpg It’s mod day! Finally free to install these two essentials for #belugathetundra!
    KyoKomodo, Ostrich, Hightide and 18 others like this.
  20. Mar 5, 2021 at 7:48 AM
    jpod
    jpod its Finally here
    London Canada
    2020 Tundra CM Cement Grey
    Diamondback HD, 1Up Racks, Yakima Bars, Garbage Weston Steps
    That's a hell of a car wash. I wish I had anything at all like that around here for the winter.
  21. Mar 5, 2021 at 7:52 AM
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    Look awesome! :thumbsup:
    49ºNRTH[QUOTED] likes this.
  22. Mar 5, 2021 at 8:09 AM
    316KS_Runner
    316KS_Runner There's no place like...
    Along the CT River
    2019 MGM CM Ltd
    Front 6112 @ 1.9 Rear 5160 | Falken Wildpeak AT3W 295/70R18 | TRD Off Road wheels | Compustar Pro R3 remote start | Baja Designs SAE fog lights | VLEDS V6 Triton Extreme (amber) front turn signals | Hot Tails Option A | 6” stubby antenna | Window tint 15% rear / 35% front | WeatherTech side window deflectors | RCI Front Skid | Talons Garage front and rear CAT Protection
    :101010:
  23. Mar 5, 2021 at 8:12 AM
    CorsoTundra
    CorsoTundra This is the way
    North GA
    2021 Cement Trail Edition
    Toytec Aluma 3/1.5, Pro headlights, OEM LED fog lights, AJT chrome delete, interior/exterior LEDs, front TRD sway, 18x9 Method Roosts, 285/75/18 Toyo A/T 3, RCI engine skid,
    Shit....maybe I'll steal my own. That's some good MOD money :rofl:
  24. Mar 5, 2021 at 8:49 AM
    49ºNRTH
    49ºNRTH New Member
    2025 Limited MGM
    Agreed, bays are huge and there is like 20 of them. The guys there don't mind you toweling off your wheels once you're finished washing if there isn't a line up to get in. Big plus when it is -25c outside and you're trying to keep everything from freezing up
  25. Mar 5, 2021 at 9:12 AM
    Astom22
    Astom22 New Member
    Bob
    Celina, TX
    2021 SR5 Tundra Crewmax 4x4
    Bakflip G2 Tonneau Cover
    2 grams per converter would be about $150 or so per theft (my math may be wrong, but close)... Then whoever is fencing them takes a cut, since they are hot and it drops the thieves profit. They could make more selling them as used converters to people they are stolen from like the old T-top days in the 70's and 80's.... :)
    All this theft driving the secondary market for converter protection devices.
  26. Mar 5, 2021 at 12:09 PM
    War_Wagon312
    War_Wagon312 Puddle Dodger
    Rich
    2025 sequoia MGM TRD PRO
    Stock horse
    Roughed in for now. Gotta figure a way to keep it in place.
  27. Mar 5, 2021 at 12:34 PM
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    Just got my Dirty Deeds 10" BAMuffler, I am installing this thing ASAP. Without the resonator :thumbsup:
  28. Mar 5, 2021 at 1:04 PM
    carsonhudson
    carsonhudson New Member
    Looks awesome! Thanks for the extra pics
  29. Mar 5, 2021 at 2:47 PM
    BWPRO
    BWPRO New Member
    Bryce
    2021 Tundra TRD PRO
    All washed up!
  30. Mar 5, 2021 at 3:07 PM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    Congratulations on paying off your truck!!
