  1. Mar 1, 2021 at 4:55 PM
    CorsoTundra
    CorsoTundra This is the way
    North GA
    2021 Cement Trail Edition
    Toytec Aluma 3/1.5, Pro headlights, OEM LED fog lights, AJT chrome delete, interior/exterior LEDs, front TRD sway, 18x9 Method Roosts, 285/75/18 Toyo A/T 3, RCI engine skid,
    Did you have to get their fuel tank straps? I've been holding off on ordering this since I don't know how much of a pain it would be to have to add those.
    Barrett50 likes this.
  2. Mar 1, 2021 at 5:06 PM
    AZBoatHauler
    So.Arizona
    Mine came with the plastic factory skid so the straps with the studs were already in place. Literally a 10 minute install swapping plastic for steel.
    From what I’ve seen all it takes is low fuel level, a floor jack, and a 2x4 to change the straps out but I haven’t had to mess with them.
    CorsoTundra[QUOTED] likes this.
  3. Mar 1, 2021 at 5:42 PM
    Jmor6766
    Jmor6766 New Member
    Jon
    SW Colorado
    2014 White Tundra TRD SR5 4.6L
    My friends wife has a bumper sticker on her ride that says “Bigfoot doesn’t believe in you either “ funny stuff!
    cjmay13, GAknight and RainMan_PNW like this.
  4. Mar 1, 2021 at 5:59 PM
    Astom22
    Astom22 New Member
    Bob
    Celina, TX
    2021 SR5 Tundra Crewmax 4x4
    Bakflip G2 Tonneau Cover
    How does it feel? Good quality? I'm extremely interested in this "mod".
    Sadly, I'm not sure it's compatible with the '21 key. I'll keep researching.
    NAIVIAN likes this.
  5. Mar 1, 2021 at 6:01 PM
    JDavis.hondatech
    JDavis.hondatech New Member
    Jake
    2019 Red TSS
    TSS package, pro grill and headlights
    Do you have anymore info on the auto up and down windows? I wish my truck had this, it’s so annoying to not have it on a 45k$ truck.
    Estarr22 and CappyKD like this.
  6. Mar 1, 2021 at 6:08 PM
    Ryuu
    Ryuu Hwat!?
    Oz
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    Honestly feels pretty good, I'd say quality is decent for $15 but we'll see how it holds up over time.
    Astom22[QUOTED] likes this.
  7. Mar 1, 2021 at 6:09 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Maybe check these guys out
    https://mesocustoms.com/products/flipfob-tacoma
    Ltaco17 and BlancaLaGordita like this.
  8. Mar 1, 2021 at 6:24 PM
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    They're not too bad at all. Using a floor jack I was able to replace all 3 straps by myself for the threaded ones when I put my fuel tank skid on as my truck didn't come with the OR package or the el-cheapo skid. I did the ends first then middle using the jack & some 2x4 scrap to support it while I took the original one off and added the threaded version. Once those were replaced used the jack again to hold up the fuel tank skid while I bolted it in. Probably 30 minutes total.
  9. Mar 1, 2021 at 6:33 PM
    blackoutt
    blackoutt YEAH BUDDY!
    NWA
    07 DC Long Bed - Old Man Tan
    OEM+
    Had a slow rear axle seal leak, ordered the seal and oring, pulled it apart and found no damage to either BUT I found the ABS sensor oring was cut with a buildup of muddy gunk around it. My oring kit didn't seem to have the right size. Anyone know what size the ABS sensor oring is? Measured about 11mm by 1.5mm if anyone else could confirm.
    Edit: Measured again this morning and went with 10.5mm by 1.5mm, pack of 50 so if this works I should be able to supply everyone on here in need too.
  10. Mar 1, 2021 at 7:16 PM
    Astom22
    Astom22 New Member
    Bob
    Celina, TX
  11. Mar 1, 2021 at 7:31 PM
    Yzed608
    Yzed608 New Member
    Wisconsin
    The OEM were installed from factory on mine. I've don't have experience with other tow mirrors, but it seems like the main upper mirror seems like it has too high of a zoom, if it was less you could see more. The convex blind spot mirror seems too small (short), and can't really get it in the right position with only a left/right positioning and no up/down. If I ever damage mine in a parking garage or something I'd probably get the HD truck style.
    CappyKD likes this.
  12. Mar 1, 2021 at 7:44 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Gotcha - hadn’t read the reviews, just knew they made a flip style for the newer keys. I did an ebay special for my 2008, and it worked well for the 4-5 years I had it. But I no longer have the info on it.
  13. Mar 1, 2021 at 7:55 PM
    Astom22
    Astom22 New Member
    Bob
    Celina, TX
    Did you have a transponder that you had to put in the fob?
  14. Mar 1, 2021 at 8:00 PM
    Ryuu
    Ryuu Hwat!?
    Oz
    SouthEast, TX
    a few
    gutted it out of my original key, was in the circled slot
  15. Mar 1, 2021 at 8:03 PM
    Astom22
    Astom22 New Member
    Bob
    Celina, TX
    Nice, I ordered one after watching a guy do a conversion with a different fob. I think this will work, will post with pics once I try it on my '21 H Key.
    Thanks for the heads up and quick replies.
  16. Mar 1, 2021 at 8:14 PM
    Ryuu
    Ryuu Hwat!?
    Oz
    SouthEast, TX
    a few
    Sure thing, no problem.
    For the H key I believe this is the shell you would need for yours, https://www.ebay.com/itm/3-Buttons-...l-Case-Cover-For-Toyota-RAV4-New/281640748126
    saw another member post it in another thread for the H keys. No idea on the quality of that one though, if you prefer Amazon searching GQ4-52T flip key shell will bring it up but its a bit pricier on there.
  17. Mar 1, 2021 at 8:16 PM
    RainMan_PNW
    Casey
    Clark County, WA
    That’s basically the same one I did for my 2008, only it was the o key.
  18. Mar 1, 2021 at 8:28 PM
    TelemarkTumalo
    TelemarkTumalo New Member
    Mark
    Bend, OR
    2020 Tundra TRD Pro Double Cab Army Green
    Driver side grab handle Door sill protectors Falken WildPeak 295/70 R18 X-Pel clear front paint protection 20% front window tint Go Rhino RB20 side steps - Bedliner finish Lock'er Down 1/2 console safe Toyota bed cargo divider Toyota auto tail gate lock
    What am I looking at?
  19. Mar 1, 2021 at 8:37 PM
    Steve66
    Steve66 New Member
    2017 Tundra SR5
    It's the one that Jim recommended in his forum, it's from speedtech lights. It cost about $70 ... I can't find my paperwork on it for the exact model
  20. Mar 1, 2021 at 8:41 PM
    The price went up some but still a good deal.
    Don't forget the referral code and the FREE shipping code.
    https://www.tundras.com/threads/tailgate-led-lightbar.77966/#post-1977104
  21. Mar 1, 2021 at 8:47 PM
    Ryuu
    Ryuu Hwat!?
    Oz
    SouthEast, TX
    a few
    seems like a lot of these key shells are interchangeable between different lettered keys, the insides and buttons just get matched up to the original, but they're a neat option for not having to program a key
  22. Mar 1, 2021 at 8:50 PM
    RainMan_PNW
    Casey
    Clark County, WA
    The one I bought for my 2008 came with a new transponder chip and new transmitter too, so I didn’t have to butcher/sacrifice an existing key to make the new one. I already had Techstream, so programming the new one was pretty easy.
  23. Mar 1, 2021 at 8:53 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Those look great!
  24. Mar 1, 2021 at 10:08 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Thank you.
  25. Mar 2, 2021 at 3:19 AM
    Ltaco17
    Ltaco17 New Member
    NC
    2023 TRD Pro
    285/75/18 Falken Wildpeak R/T color matched handles and mirrors.
    ARB dual compressor mounted vertical, with relocated power steering reservoir.
  26. Mar 2, 2021 at 4:42 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
  27. Mar 2, 2021 at 8:10 AM
    BWPRO
    BWPRO New Member
    Bryce
    2021 Tundra TRD PRO
    Drove around today running around doing chores. But looking for a kayak rack for the truck. Any recommendations?
  28. Mar 2, 2021 at 8:28 AM
    abomb60
    Massachusetts
    Braved the 10 degree weather and 30 mph winds to pull off the OEM tri-fold tonneau. Finally getting my ARE topper installed tomorrow morning!
  29. Mar 2, 2021 at 8:32 AM
    TheBlackPearl
    TheBlackPearl Newish member
    La Gulf Coast
    2020 Black TSS Crewmax 4x4
    Just ordered the Yakima Overhaul HD, found a deal on Amazon. I like the way it looks and the fact that it’s compatible with my Retrax bed cover.
    a522467, RainMan_PNW and WILLINH like this.
  30. Mar 2, 2021 at 9:17 AM
    How much does that thing weigh? Looks like it would help against gas theft lol.
