  1. Jan 26, 2021 at 4:07 PM
    Angry Gunny
    Angry Gunny New Member
    Rob
    Bedford, PA
    2016 SSM 1794 4X4
    Yes please
    How did you mount the HiLift base?
  2. Jan 26, 2021 at 4:09 PM
    poheller
    poheller 2018 Platinum
    Scot
    The great state Ohio
    2018 platinum
    I removed the bulge, removed the plastic grill assembly. Cut the plastic welds on the grill screen and installed Sloan Flexibrite Led neon light. Installed it all back and ran wire thru the hood and out a hole in the back. Used a fuse tap in the fuse block under the hood. I did this on my last tundra with Blue flexibrite.
  3. Jan 26, 2021 at 4:25 PM
    RobertD
    RobertD SSEM#123
    Robert
    DFW, Texas
    Interesting. Just looked at the Sloan FlexiBrite product and their other stuff. So I assume this is more of a glow then actual useable light? Did you just tie in to your DRL?
  4. Jan 26, 2021 at 4:27 PM
    jackienguyener
    jackienguyener OKToyota
    Jackie
    2016 Tundra 1794
    It’s just mounted with T-nuts on the bed rails with little knobs for easy removal
    GarTX526 and Angry Gunny[QUOTED] like this.
  5. Jan 26, 2021 at 4:31 PM
    poheller
    Scot
    2018 platinum
    Fuse tap into the ignition fuse.
  6. Jan 26, 2021 at 4:31 PM
    poheller
    Scot
    2018 platinum
    Yes just an accent light.
  7. Jan 26, 2021 at 4:54 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Added a little Tufskinz love to the ol console
  8. Jan 26, 2021 at 4:59 PM
    ErikTRDTUNDRA
    ErikTRDTUNDRA New Member
    Erik
    2018 Tundra crewmax 1794
    Is that a speaker installed in the console?
  9. Jan 26, 2021 at 5:16 PM
    TrashcanBand
    TrashcanBand New Member
    CenTex
    Tundra
    WITNESS.
  10. Jan 26, 2021 at 5:28 PM
    JeffMac
    JeffMac 2 Words, 1 Finger
    Jeff
    South Florida
    2015 Black Tundra OVTUNE
    Suspension: Bilstein 6150 Front Max Setting CB Shim 2x Driver 1x Passenger Bilstein 5160 Rear CB +3 Shackles Firestone Airbags w/ Daystar Craddles Engine: OVTUNE - 87 w/ Torque Modifier SABM w/ K&N Filter TB Coolant Bypass Fumoto Drain Plug Wheels/Tires: ProComp Bandidos 0mm Offset Nitto Exo Grappler AWT 285/70/18 Exterior: TRD Pro Grille Spyder Headlights/Taillights Ecoological Bumpershellz LED everything Tinted windows Bakflip MX4 Tonneau Cover K-Source Tow Mirrors Interior: Pioneer AVH-W4500NEX Radio 2x 10” Pioneer Subwoofers 1200W Pioneer Mono Amp 2000W Pioneer 4 Channel Amp
    Today I changed my oil with Shell Rotella Gas Truck.
    Transmission drain/fill with Toyota WS. Didn’t drop the pain because local dealer doesn’t carry gasket or filter. Dealer also had it 1 qt overfilled.
    Also did my Diffs and T-Case with Ravenol respectively. T-Case was 0.5qt low. The Ravenol is strange with the 75w-85 being Red like ATF (pic attached). Reached out to the company and they verified it was correct. May just switch to Amsoil (depends on shipping cost) or Mobil 1.
    I got my Eco BumperShellz last week but have been too lazy to tackle that with 10 degree weather.
    I used this Drill Pump for everything besides motor oil and it was tits.
    TOOLGUY REPUBLIC Transmission... https://www.amazon.com/dp/B08431ZFYY?ref=ppx_pop_mob_ap_share
    Wallygator, GAknight, Rica25 and 4 others like this.
  11. Jan 26, 2021 at 5:43 PM
    JeffMac
    Jeff
    South Florida
    I have 5100s all around. Front on highest setting with 2 CB shims on Driver and 1 shim on Passenger. CB +3” shackles in the rear.
    RBB[QUOTED] and Rica25 like this.
  12. Jan 26, 2021 at 6:26 PM
    a522467
    a522467 Life’s short. Live now.
    Michelle
    Ohio
    2020 Black Tundra Doublecab 4X4 SR5 with SX pkg
    Rear spring upgrade, rear shock upgrade, front & rear sway bars, bed step, bed mat, console organizer & tray, black lug nut covers, rear underseat storage box, black seat covers, Bluetooth CarPlay adapter, LED fogs, blue footwell lighting, LED cargo, reverse, tail, and stop bulbs, tinted tail and 3rd stop/cargo lights, tinted glass all around, tinted front emblem, matte black tailgate emblem inserts, retractable tonneau cover w/trac system and load bars, front facing camera, 8” exhaust upgrade, LED bed lights, 8-ball shifter knob, shifter boot, LED headlights, custom wheel center caps, 3”x30’ tow recovery strap, bed rail clamps, LED puddle lights, phone mount, OBD2 scanner, touchscreen glass protector/overlay, trailer hitch lock, tire traction aid, tinted license plate cover, power relay module, 6-way fuse block with cover, stainless mesh cowl screens, LT265/70R18 A/T tires, driver’s side swing case toolbox, dual air horn kit, rear Husky Liner, cat converter theft deterrent covers, front & rear dash cam, LED tail light bar, trailer plug wiring harness, locking fuel door, matte black interior door handles, glovebox & fuel door keyhole decals, TUNDRA sill plates decals, chalk bag cup holder / trash can, HD Roadmaster active suspension kit, HD front struts, Backlit window control panel, tailgate gap cover, matte black radio surround. https://www.tundras.com/threads/740-yota-2020-sr5-4x4-dc-w-sx-pkg.79742/
  13. Jan 26, 2021 at 6:44 PM
    jefroshm0
    jefroshm0 New Member
    Elk Grove, CA
    2018 Cement Tundra Crew 4x4 SR5
    Made the hump to 35’s.
    Method 312’s in 17 mounted to Toyo Open Country r/t. Total chaos upper controls and soon some Kings coil overs when they actually ship them. This back order from Kings is beyond ridiculous. Approaching 2.5 months of waiting.
    KyoKomodo, Wallygator, JJ305 and 31 others like this.
  14. Jan 26, 2021 at 6:46 PM
    ToyotaProTyler
    ToyotaProTyler New Member
    Tyler
    Ontario
    2020 Toyota Tundra TRDPro
    This weekend I got around to finally installing the Alpharex tail lights on my 3rd Gen
    Also at the same time I installed some VLED bulbs in the reverse lights, 3rd brake light, cargo lights and license plate bulbs
  15. Jan 26, 2021 at 6:48 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yes for my CB
  16. Jan 26, 2021 at 6:52 PM
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    I plan on replacing the center dash speaker for my external on my kenwood. Where’d you put your face plate?
  17. Jan 26, 2021 at 6:52 PM
    Kdogg77
    Kdogg77 If it ain't broke, it will be...
    Ken
    Central Cali
    2017 Tundra Crewmax
    6" RC suspension lift, 18" Pro Comp wheels, 35x12.5x18 tires, RC front/rear bumpers, RC Grill insert, Spider No Drill Roof Rack, Lighting by RC and Cali Raised. Interior mods include AJT Designs, Pioneer, and Rockford Fosgate.
    Or use your thumb??
    NewImprovedRon and Rica25 like this.
  18. Jan 26, 2021 at 6:54 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I tried that... didn’t feel right.
    Rica25 likes this.
  19. Jan 26, 2021 at 6:56 PM
    Kdogg77
    Ken
    Central Cali
    2017 Tundra Crewmax
    That would mess with my OCD so bad...lol.
  20. Jan 26, 2021 at 7:30 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Yeah... I’ve been researching alternative switches that don’t have the word “REAR” on them.
    this orientation matches how the 4Runner switch sits, but that switch is a different shape and won’t work.
  21. Jan 26, 2021 at 7:33 PM
    eick
    eick New Member
    Can’t you just take the text off the switch? Scrape it or use acetone or something
    Rica25 and RainMan_PNW[QUOTED] like this.
  22. Jan 26, 2021 at 7:44 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Face plate? I have the CB mounted to my overhead light console
    Rica25 likes this.
  23. Jan 26, 2021 at 7:55 PM
    Teegee
    Teegee Around
    Grouch
    21 MAX
    Rica25 likes this.
  24. Jan 26, 2021 at 8:02 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Was also considering something like that too. I’ve only had the switch in the new spot 24 hours, and only turned it around about 13 hours ago, so haven’t dug too deep yet.
  25. Jan 26, 2021 at 9:22 PM
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    2020 Tundra Limited TRD Off-Road
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    Thanks for pointing this out. My switch is in the same place and I just felt something was off about it since moving it.
    Right now I use my thumb, and rolling it up is awkward.
    Its obviously way better than the factory location, but I'm turning mine around tomorrow.
  26. Jan 26, 2021 at 9:24 PM
    OnespeedTRD
    Don
    San Diego
    I didn't have to remove anything for my AJT start button ring. Just pop the chrome one off and pop the new on on.
    TheBubbaDude[QUOTED] likes this.
  27. Jan 26, 2021 at 9:32 PM
    STiLL WILL
    STiLL WILL MY NAME ISN'T WILL
    CA
    2021 Tundra SR5 TRD Sport
    After a month wait, got the BAMuffler dropped off by FedEx and installed ASAP. Couldn't be any happier.
    This is the 6" Standard system, and I requested for the Helmholtz to be welded on by @dirtydeeds prior to being shipped out. Reason being - in case I've gotta modify it as a "dump" style exit for future rear suspension clearance, the resonator will already be on. Keith will be the first to tell you that it's not the most ideal placement of the resonator, but it will definitely help. As a couple people have done with their BAM systems on here, I've also replaced the factory clamp at the rear with a proper Vibrant v-band clamp (p/n: 1491C) for peace of mind.
    - Volume level: rowdy as advertised. You will be heard, bottom line. Anything over half throttle input, it growls - even more rowdy in Tow/Haul mode.
    - Drone level: very tiny rpm window where it slightly drones(around 1700-1900 rpm), but only at very low speeds(ie: stop/go around town) because these transmissions chase lockup so aggressively. I'd imagine if the resonator was in the "normal location" on tailpipe section, this may not happen at all. At highway speeds, there is absolutely no drone.
    - Sound quality: 10/10. Best balance of throaty and rasp. The 6" system is great for folks who want a loud(er) volume, raspier tone, but still relatively controllable with the gas pedal.
    - Gains? At the moment, indiscernible. Maybe, I just need more seat time? :notsure: I'll take Keith's word for it. :D
    Sound clip: (headphones for a more immersive sound)
    -Matt
  28. Jan 26, 2021 at 9:45 PM
    OnespeedTRD
    Don
    San Diego
    The +2 shackle is only 1" lift. The +1 is a little over .5". Either way, you shouldn't need more than 1" of lift in the rear to maintain a little rake with the 5100s on the top setting.
    As far as the shop saying you need the 5100 rears, that's only if you raise the rear, since the stock shocks aren't really meant for more height. if you go top setting in the front and want to add height in the rear then you should consider the 5100 rear shocks as well.
    RBB[QUOTED] likes this.
  29. Jan 26, 2021 at 10:44 PM
    aresenalgunner007
    aresenalgunner007 New Member
    San Diego
    2019 Black TRD PRO
    BFG KO2’s
    New head unit today.
  30. Jan 26, 2021 at 10:46 PM
    Tundra805
    Tundra805 Quality. Durability. Reliability.
    Tennessee
    2020 CrewMax SR5 TRD 4x4 5.7 Cement
    Wow that is beading up nice!
    PS– love that quote in your sig lol
