  1. Jan 26, 2021 at 8:25 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    With your elbow on the console, having the switch positioned like this is more natural to push/pull it for opening/closing the window with your finger. It matches the position that the main window switches are in. Otherwise you sort of have to turn your hand backwards to pull up on the switch.
  2. Jan 26, 2021 at 8:27 AM
    lonedrake
    lonedrake New Member
    Minnesota
    2020 TRD sport
    Super magnets.
  3. Jan 26, 2021 at 8:28 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    I like this. You should drive over to MT and do this on mine...
  4. Jan 26, 2021 at 8:50 AM
    TheBubbaDude
    TheBubbaDude New Member
    2020 Tundra TRD Pro
    AJT Blackout Kit 1.25" Wheel Spacers NRG 285/70/18 Meso Customs TRD Start Button
    Cool on both notes. I'll give the ring a shot because their DIY on the switch leaves the dash on. Always been my complaint about the AJT start button. They do an applique for the vents but not the start button? LOL damn I'm lazy
    RainMan_PNW[QUOTED] likes this.
  5. Jan 26, 2021 at 8:57 AM
    Casey, you have a overhead blue LED shining down?
  6. Jan 26, 2021 at 9:27 AM
    RainMan_PNW
    Casey
    Clark County, WA
    No, it's the camera switch. The light in the camera switch is about two or three "clicks" brighter than the rest of the factory buttons/switches, and it is also more vivid blue compared to the factory light blue. So it produces a similar effect to the LED that was/is in the Gen 2 consoles. Also, that picture was taken this morning shortly after sunrise, so there's "morning dawn" light in play as well.
  7. Jan 26, 2021 at 9:34 AM
    jefroshm0
    jefroshm0 New Member
    Elk Grove, CA
    2018 Cement Tundra Crew 4x4 SR5
    Cut the bottom tab to mimic the stock one. Very simple to do with a dremel. Used a piece of cardboard to draw out the cut out pattern. Then used the drawing to trace the shape on the new tab. Cut it out and slide it in.
    Astom22[QUOTED] likes this.
  8. Jan 26, 2021 at 9:39 AM
    :thumbsup:
  9. Jan 26, 2021 at 9:43 AM
    Black Dynamite
    Black Dynamite New Member
    2017 Toyota Tundra Limited Crew Cab
    Is there a write up or a video to help do this?
    Astom22 likes this.
  10. Jan 26, 2021 at 10:12 AM
    RBB
    RBB Member
    Vancouver Island B.C. Canada
    Barcelona Red Mettalic 2020 Tundra TRD off road
    Blackout badges, tailgate insert, sill protectors
    So I've read a bunch of threads on here and now I'm more confused. I don't have any real knowledge on lifts, so any advice will help. I spoke with a guy at a specialty lift and 4x4 shop, and he suggested doing the adjustable 5100s up front to level it. I wanted it at the highest setting, and read here that I should put a 1 inch block in the rear if the front is at highest setting. This guy said no, that I'd need to put the 5100s in the back so it wouldn't stretch something out (I forget exactly what). Does this sound correct? Am I being had? Anyone have better suggestions? The 5100s are top of my budget keep in mind. All this is already at 1500 plus tax Canadian.
  11. Jan 26, 2021 at 10:26 AM
    thetastelingers
    thetastelingers Master Baiter
    Soddy Daisy, TN
    2021 MGM CM Sport
    In process
    Some have had different results using 5100s on top setting. On my truck, the front was about 1/4" higher than the rear, so I ended up raising the rear as well.
  12. Jan 26, 2021 at 10:33 AM
    TNTundra16
    TNTundra16 YOU BIG DUMMY!
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    5100s in the rear don't provide any lift just better performance over stock. They will accommodate up to an inch of lift via shackles or blocks. I set mine on the middle because I didn't want to lift the rear any and it to be level. Tundras will appear nose high if your fender to ground measurements front and rear are the same. Here is mine right after I had mine installed. They are set on the middle setting 1.57".
  13. Jan 26, 2021 at 10:37 AM
    RainMan_PNW
    Casey
    Clark County, WA
    All my mods are linked in the build thread, which is linked in my signature.
    The actual window switch relocate is linked here (and that post has a link to the harness I used), but it also ties in with the console switch blank that I 3D printed myself (link for that is also in my build thread - see the first post).
    https://www.tundras.com/threads/caseys-2021-lunar-rock-trd-pro-build.77317/page-8#post-2078995
    There is another user on here who prints/sells a very similar console switch plate - you can find him on facebook at CN Designs or here under username @Rocfrog
    ElNopal and BlueRibbon4x4 like this.
  14. Jan 26, 2021 at 10:48 AM
    RBB
    RBB Member
    Do you happen to have a pic with the end result? Thanks for responding as well
  15. Jan 26, 2021 at 10:50 AM
    RBB
    RBB Member
    Thanks man! That looks great.
    TNTundra16[QUOTED] likes this.
  16. Jan 26, 2021 at 10:51 AM
    TNTundra16
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    Thanks Matt :hattip:
  17. Jan 26, 2021 at 11:24 AM
    Black Dynamite
    YUP!:thumbsup:. I already ordered from CNDesigns & just waiting on the item to arrive. I just wanted a heads up or instructions to get it right! Thanks for your help!
  18. Jan 26, 2021 at 11:27 AM
    Tundra805
    Tundra805 Quality. Durability. Reliability.
    Tennessee
    2020 CrewMax SR5 TRD 4x4 5.7 Cement
    Installed my high-vis flag ...
  19. Jan 26, 2021 at 1:07 PM
    thetastelingers
    Soddy Daisy, TN
    2021 MGM CM Sport
    In process
    Here is 5100 on top setting, rear is stock.
  20. Jan 26, 2021 at 1:08 PM
    thetastelingers
    Soddy Daisy, TN
    2021 MGM CM Sport
    In process
    Here is 5100 on top setting and Coachbuilder +2 shackle.
  21. Jan 26, 2021 at 1:11 PM
    RBB
    RBB Member
    That's better! So 5100 top height for front, 5100 rear with a 2 inch block, or shackle? Or would the 1 inch in the rear with 5100 still get a bit of rake?
  22. Jan 26, 2021 at 1:40 PM
    Blocks ride rough.
  23. Jan 26, 2021 at 1:44 PM
    RBB
    RBB Member
    Thanks, that's good to know. So ask for shackles with the rear 5100s?
    GarTX526 likes this.
  24. Jan 26, 2021 at 1:48 PM
    Aftermarket shackles will always be a better option than a block. Stock shackles have splined bushings and don't articulate well. Shackles such as Toytec or Coachbuilder use poly bushings. I had a Readylift space and block kit for about a year and a half before I switched to coilovers and shackles. Night and day difference.
    GoldenGoon89 likes this.
  25. Jan 26, 2021 at 2:39 PM
    Gabrielo93
    Gabrielo93 New Member
    Gabriel
    Grand Prairie, TX
    2015 Black Toyota Tundra SR DC
    12 Volt Remote Starter Lockerdown Safe ICS Fab Dash Mount Husky All Weather Beaters Mats Rear Folding Seat Mod Linex Platinum Kicker Sub/Amp Combo CoverCraft Dash Cover Kenwood Headunit Cravenspeed Untenna CupHolderHero Aukee Tailgate Inserts OEM Deck Rails Rolling tonneau cover CravenSpeed Untenna
    Cleaned her up it’s been a while since the last wash..
  26. Jan 26, 2021 at 2:54 PM
    poheller
    poheller 2018 Platinum
    Scot
    The great state Ohio
    2018 platinum
    Added LED Neon to my little grill.
  27. Jan 26, 2021 at 2:58 PM
    jackienguyener
    jackienguyener OKToyota
    Jackie
    2016 Tundra 1794
    Added a Plano field box in the bed rail for storage, easy access for tie down straps, etc. Also the sticker for +5 hp
  28. Jan 26, 2021 at 3:17 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Drove it to work and got rained on. . . Love my ceramic!
  29. Jan 26, 2021 at 3:26 PM
    khunk
    khunk Tundra Fan
    Marty
    Leland, NC
    2017 CM Limited 4x4
    Sold them for asking price, which was $500, they went fast, should have asked for more :notsure:
  30. Jan 26, 2021 at 3:46 PM
    d_kinneyjr
    d_kinneyjr New Member
    Dave
    Southern NH
    2018 Crew Max SR5
    @poheller how did you mount the light bar behind the bulge plastic insert/front piece. Did you reinstall the actual bulge housing (black piece that attached to the bulge). Looks real good. Nice job!
    poheller[QUOTED] likes this.
