  1. Jan 10, 2021 at 12:12 PM
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    Finished moving my 2m/70cm ham antenna to the Rago mount I installed a week or so ago. When I installed the mount I only used 3 of the holes since I couldn’t get a rivnut into the 4th as my tool wouldn’t clear. Ended up using the 4th hole for the antenna wire.
    EE086032-7881-43BF-8990-5C5E3416F592.jpg 6C300AC4-821B-481F-9D69-AF813B1390B6.jpg
    Fotnot, Wallygator and mgm16trdpro like this.
  2. Jan 10, 2021 at 12:14 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Ghostface[QUOTED] likes this.
  3. Jan 10, 2021 at 12:21 PM
    XSP2020
    XSP2020 New Member
    Atlanta Ga
    2020 Black Tundra XSP
    I also did this and can say it is very much worth it! Very clean with the floor mats and storage together.
    SpyderRC[QUOTED] likes this.
  4. Jan 10, 2021 at 12:36 PM
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    ok, done. Took a couple days to find the inverter I used in old work van when I had to use old school windows laptop. I wired in to one of the rocker switches. I also figured out a unforeseen problem last week, with the hot wire from battery the usb charger had lights that would have been a battery drain. I wired a HD toggle switch as master power kill switch.
    GAknight, Ostrich, Fotnot and 8 others like this.
  5. Jan 10, 2021 at 12:42 PM
    AZBoatHauler
    So.Arizona
    There goes another $9
  6. Jan 10, 2021 at 12:47 PM
    jonclark96
    jonclark96 Not so new member
    Jon
    Maryland
    2021 Army Green SR5
    Exactly! I just ordered some too....
    Rica25 and Yzed608 like this.
  7. Jan 10, 2021 at 2:08 PM
    Wallygator
    That chrome is awesome!! Congrats!!
  8. Jan 10, 2021 at 2:13 PM
    Wallygator
    Washed the chassis as best I could, hate salty roads! Monthly recharge of the X2 and check of things under the hood. All good for another month or so:thumbsup:
  9. Jan 10, 2021 at 2:40 PM
    yodanadane
    yodanadane New Member
    Before and after pics from chrome handles and mirrors to black out and added hood Graphic.
  10. Jan 10, 2021 at 2:54 PM
    CorsoTundra
    CorsoTundra This is the way
    North GA
    2021 Cement Trail Edition
    Toytec Aluma 3/1.5, Pro headlights, OEM LED fog lights, AJT chrome delete, interior/exterior LEDs, front TRD sway, 18x9 Method Roosts, 285/75/18 Toyo A/T 3, RCI engine skid,
    I have that same battery. Is that recharge necessary on these? I put that one in thinking it would be better for the Spod and winch I'm about to install.
    Wallygator[QUOTED] likes this.
  11. Jan 10, 2021 at 4:11 PM
    jonclark96
    Jon
    Maryland
    2021 Army Green SR5
    if you don't mind, how much did you pay for the hood graphic? Did you install yourself? I'm looking to do the same on my truck.
    yodanadane[QUOTED] likes this.
  12. Jan 10, 2021 at 6:02 PM
    Yzed608
    Yzed608 New Member
    Wisconsin
    How close is the mount to your tailgate when it's shut? I've thought about getting these to use as a grab handle when getting in the bed, but I've seen some where it rubs the paint off of people's tailgate.
    biebs96 likes this.
  13. Jan 10, 2021 at 6:26 PM
    yodanadane
    400 for door handles and hood i believe hood was 150.00
    jonclark96[QUOTED] likes this.
  14. Jan 10, 2021 at 6:29 PM
    nhw544
    nhw544 Food fight!
    RVA
    2019 Black Tundra 4x4 Sport
    After...Pro Grille with matching surround and hood bulge, Pro headlights, OEM LED fogs thanks to @CAJUN_TRANSPLANT, and black Bumper Shellz.
    Installed stubby antenna...
    And started interior chrome delete. Painted cup holder surround, the silver piece around the shifter, and climate control rings with SEM Trim paint. Added the AJT piece for the shifter trim ring and installed a black OEM shifter thanks to @biebs96! Just ordered the black steering wheel emblem from AJT and the 4x4 trim ring from Meso, so hopefully getting those this week. Last will be the vent trim rings.
    Tundra805, CappyKD, GAknight and 19 others like this.
  15. Jan 10, 2021 at 6:40 PM
    biebs96
    PA
    Looks great!
    nhw544[QUOTED] likes this.
  16. Jan 10, 2021 at 7:04 PM
    FrozenTundraTim
    FrozenTundraTim New Member
    2017 Platinum CrewMax Gray
    3" lift, Window Tint, Toyota Nerf Bars, 20" Fuel MAVERICK Gloss Black w/Milled Accent, Extang Revolution Tonneau Cover
    Had my 2017 CM Platinum for a week and a half... the Tonneau that came on it leaked. Did some research, found an install video and whoever installed it, did so improperly. Couple tweaks and now it's bone dry in the bed!
    I'm curious about y'all's feedback on bed compartments or extenders?!?
  17. Jan 10, 2021 at 7:09 PM
    JerryH
    JerryH Gravy Boatin, I don’t park I dock.
    SOMD
    2020 Crewmax Limited Cement
    Trying to order driver’s side grab handle. Does this look like the two parts I would need? The diagrams on these dealer sites are killing me.
    WILLINH and Ted4311 like this.
  18. Jan 10, 2021 at 7:15 PM
    TNTundra16
    TNTundra16 YOU BIG DUMMY!
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    Spent the afternoon in the woods taking down deer stands. My FIL made a video of me climbing one of the hills.
    GAknight, equin, Steve18 and 9 others like this.
  19. Jan 10, 2021 at 7:32 PM
    heyacker
    heyacker New Member
    I think you have them wrong. These are part numbers and colors. Also try parts.lewistoyota.com and use code “freeship” I just order a few things from them.
  20. Jan 10, 2021 at 7:55 PM
    abomb60
    Massachusetts
    There's a tiny bit of room between the tailgate and mount ... the antenna wire is in there pretty snug but looks like it barely is touching the tailgate. That's why I wrapped it with spiral loom and put head shrink over it just in case. I think on their website they say you need 1/8" or so gap for it to work and that you may not have it on both sides so take a look at that before deciding which side mount to order.
    Yzed608[QUOTED] likes this.
  21. Jan 10, 2021 at 9:07 PM
    a522467
    a522467 Life’s short. Live now.
    Michelle
    Ohio
    2020 Black Tundra Doublecab 4X4 SR5 with SX pkg
    Rear spring upgrade, rear shock upgrade, front & rear sway bars, bed step, bed mat, console organizer & tray, black lug nut covers, rear underseat storage box, black seat covers, Bluetooth CarPlay adapter, LED fogs, blue footwell lighting, LED cargo, reverse, tail, and stop bulbs, tinted tail and 3rd stop/cargo lights, tinted glass all around, tinted front emblem, matte black tailgate emblem inserts, retractable tonneau cover w/trac system and load bars, front facing camera, 8” exhaust upgrade, LED bed lights, 8-ball shifter knob, shifter boot, LED headlights, custom wheel center caps, 3”x30’ tow recovery strap, bed rail clamps, LED puddle lights, phone mount, OBD2 scanner, touchscreen glass protector/overlay, trailer hitch lock, tire traction aid, tinted license plate cover, power relay module, 6-way fuse block with cover, stainless mesh cowl screens, LT265/70R18 A/T tires, driver’s side swing case toolbox, dual air horn kit, rear Husky Liner, cat converter theft deterrent covers, front & rear dash cam, LED tail light bar, trailer plug wiring harness, locking fuel door, matte black interior door handles, glovebox & fuel door keyhole decals, TUNDRA sill plates decals, chalk bag cup holder / trash can, HD Roadmaster active suspension kit, HD front struts, Backlit window control panel, tailgate gap cover, matte black radio surround. https://www.tundras.com/threads/740-yota-2020-sr5-4x4-dc-w-sx-pkg.79742/
    Does anyone have a link or p/n for the yellow clips that hold in most of the dash trim pieces? I lost one in the abyss while installing the anytime backup camera kit today.
    :facepalm:
  22. Jan 10, 2021 at 9:15 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Not yellow, but this might help
    25 Door Trim, Instrument Panel, Rear Deck Trim Clip Compatible with Toyota and Lexus 90467-12080 https://www.amazon.com/dp/B008FHX22I/ref=cm_sw_r_cp_api_glc_fabc_X69-FbH2SMX7Z
  23. Jan 10, 2021 at 9:36 PM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    I have used the following for the dash clips:
    90467-10203 - Clip Dash Bezel -yellow clips 67771-58010 - Corner Cover Retainer-white clips
    it would also appear that the ones Casey suggested should work too.
    Best!
  24. Jan 10, 2021 at 9:42 PM
    a522467
    Michelle
    Ohio
    Thank you!
    ElNopal[QUOTED] likes this.
  25. Jan 10, 2021 at 9:42 PM
    a522467
    Michelle
    Ohio
    ElNopal likes this.
  26. Jan 10, 2021 at 9:47 PM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    :hattip:
    De nada. You’re welcome.
    a522467[QUOTED] likes this.
  27. Jan 11, 2021 at 3:56 AM
    Ted4311
    Ted4311 Don't Sweat The Small Stuff
    SOMD
    14 Tundra MGM TRD-OFFROAD 4X4
    A LOT... NEVER ENDS
    Hell yeah man!!
    One of the best mods I have done thus far!! I still think its nuts this isn't stock.
    WILLINH likes this.
  28. Jan 11, 2021 at 6:19 AM
    chinadog
    chinadog New Member
    Knoxvegas
    2018 Midnight Black Metallic 1794, 2013 Black Platinum
    Can you link the install video? I put my OEM cover on my son's 2013 and we've had issues with it leaking.
  29. Jan 11, 2021 at 6:41 AM
    jfits
    jfits New Member
    2014 tundra 5.7L 4x4
    Small mod: install a 8mm led tap into a near light bar switch.. good amount of light not it’s too bright just right
  30. Jan 11, 2021 at 8:07 AM
    Pangaea
    Pangaea New Member
    BC
    2021 Cement Tundra CM TRD Off Road Premium
    Nice! Adding this to the "when the dash is all torn apart" list!
    NewImprovedRon and jfits[QUOTED] like this.
