  1. Oct 31, 2020 at 1:25 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    If I can ask, what duration/mileage did you own them? I had 11.5 yrs and over 250k miles on my TC USA cover. I hate the idea of spending $2.5k on a cover that won’t last the way I hold onto my rigs. :thumbsup:
  2. Oct 31, 2020 at 1:26 PM
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    I got my Super White Bulge today, my TRD Pro Grill should get here Monday and my life will be almost complete. Until I can find a painter or end caps for my bumper...:spending:20201031_152211.jpg
    Cosmoblu, Ostrich, Fotnot and 5 others like this.
  3. Oct 31, 2020 at 1:32 PM
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    Yeah no problem, my first one I had for six years and roughly 80,000 miles… I used it on my first two trucks that were double cabs… It was still going strong when I bought my current platinum that is a crew max which is the only reason I had to purchase a new one due to the smaller bed...and this time around I went with the XR for the ability to use the crossbars over it... I actually sold the original one to a friend who is still using it today… Wax the inside of the rails every now and then to keep it running smooth, that’s really the only maintenance I’ve done on them
    RainMan_PNW[QUOTED] likes this.
  4. Oct 31, 2020 at 1:50 PM
    CavalryCrew602
    CavalryCrew602 New Member
    2019 Crewmax XP Tundra
    Borla exhaust, Alpine Halo 9 head unit, Oracle Colorshift rock lights, 3in lift on 17in Fuel bead locks, Paragon bed cover, Recon lights...TBC
  5. Oct 31, 2020 at 2:07 PM
    getwiser88
    getwiser88 New Member
    2020 TRD Pro
    Got the UpTop sofTruss installed and my sliders on.
    RBB, CavalryCrew602, Ostrich and 6 others like this.
  6. Oct 31, 2020 at 2:35 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    I would say if you’re planning on adding a overhead rack go with the XR as they’re built into the design. Granted the Yakima overhead rack is pretty pricey and they get you with having to buy the special XR landing pads as well. Your toolbox options are limited with the XR but a lot of people seem to be happy with swingcases or tonneaumate. I like having my toolbox up top and easily accessible which is why I fabbed the American work cover from the roll cover. Added on the rails to work with Yakima crossbars and then made custom landing pads to work the my tracrac.
    what issues did you have with your tc USA? Mine has been fairly reliable
  7. Oct 31, 2020 at 3:22 PM
    HaveFun
    HaveFun Happy to be here
    Fair Oaks Ranch, Texas
    2019 Black Tundra CM SR5
    Wireless charger and USB plug
    ABE46429-7334-419F-834D-17153483C2D2.jpg B0EDF1F4-4B32-46DC-874F-90240B089A44.jpg
    Cosmoblu, Ostrich, GarTX526 and 11 others like this.
  8. Oct 31, 2020 at 3:22 PM
    HaveFun
    AJT chrome delete tomorrow
    Zilla18 likes this.
  9. Oct 31, 2020 at 3:35 PM
    NoCoToyo
    NoCoToyo New Member
    Northern Colorado
    2019 Long Bed 4x4
    it's coming
    Thanks bud, really appreciate that.
    I think I found what worked for me. Found some stout hooks for the bed bolts. And instead of notching the washer, I was able to put the hook between the bolt and washer. Looks cleaner.
  10. Oct 31, 2020 at 3:48 PM
    RainMan_PNW
    Casey
    Clark County, WA
    For sure XR if I go Retrax. I had one of the first TCUSA ones they made with the “integrated” rails (they bolted the Yamika rails to the side rails of the cover before shipping basically).
    Mostly little stuff. It really was a great cover. Not many things that get used like that will last for as long as it did (and likely will still for the new owner).
    I had the ripcord release handle and had to replace it twice (cables wore/frayed). The steel locking bars riding in the aluminum slots would gum up with crap over time and not extend or lock. It rains for three months straight here, and water gets into those lock bars and they just didn’t operate smooth. And if that water froze (I live higher elevation and get a lot of freeze in winter), then there was no getting it opened. Seemed to me if they sandwiched or lined that slot with UMHW then you’d get smooth operation regardless of water, gunk, or ice.
    Eventually, the plastic drain tube connectors got brittle and one broke. I’d have liked to have had those made of brass or aluminum. Any exposed plastic (trim caps on the canister, plastic side/end trim on rails) all started to disintegrate.
    And, after about 150k miles, it got to where it just wouldn’t stay in the very rear-most position...it would jump off the adjustable end lock spot (which I could no longer get to adjust) and would leave a 1” gap to the tailgate. And if I was on a bumpy road, the jimmy and shake of the bed would pop the lock bars out of their lock spots and the cover would roll open.
    Sounds worse than it was I guess, just has me looking for something that potentially solves some of those pain points. It was rock solid, and I never babied it.
    Whatever I do get, I’m expecting I’ll be modifying/tweaking a bit before install ensure it has hardware that won’t oxidize/corrode out on me, and look hard at making sure the drains will hold up for the long haul and abuse.
    Not sold on the toolbox add-on... how bad does it block your rear window?
    It would also be nice to maintain the factory tie-down rails better. The TCUSA solution that I paid extra for kinda sucked - it wasn’t very rigid...
    2020Platinum likes this.
  11. Oct 31, 2020 at 3:51 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Well, i was wrong. Off literally means off, no interior lights at all when you open the door. :eek2: This is no help. :)
    Wallygator and ElNopal like this.
  12. Oct 31, 2020 at 3:55 PM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    Oh yeah, I tried that this morning and forgot to chime in... yeah not an option. Thanks for the follow up
    Rica25, Wallygator and TILLY[QUOTED] like this.
  13. Oct 31, 2020 at 3:55 PM
    Clemshady
    Clemshady Bama Storm Trooper
    Jeff
    2017 Super White Limited DC TRD 4x4 Offroad
    \ Factory OEM LED Tundra Pro headlight upgrade Diode Dynamic amber Pro fogs 3" DD amber Pro ditch lights SDHQ ditch brackets 42" DD light bar SwitchPro 9100 Pedal Commander Vinyl wrapped bumpers Painted calipers Painted horns Chrome delete complete ARE CX Evolve Topper TRD rear swaybar Matching door handles and mirror caps Oh shit handle upgrade Matching grille surround/hood bulge TRD PRO insert grille BBS Forged TRD PRO wheels Coachbuilder +3 shackles Eibach Pro 2.0 Coilovers and rear shocks
    Got my paint matched bumper caps installed along with my wireless charger. Time for some football now. ROLL TIDE!!!
    PomDad, Ostrich, GarTX526 and 11 others like this.
  14. Oct 31, 2020 at 4:11 PM
    booya69
    booya69 New Member
    Terry
    Maryland
    2020 Tundra SR5
    Rica25 likes this.
  15. Oct 31, 2020 at 4:14 PM
    Jim LE 1301 Camaro Lover, SSEM # 11
    Rica25 and ElNopal like this.
  16. Oct 31, 2020 at 4:14 PM
    jr1016
    jr1016 New Member
    Ric
    Sacramento, CA
    2020 CM TRD Sport
    Gave her a wash and used the 3 in 1 Griots Ceramic spray. Picture doesn't show it justice on how shiny and smooth it is. Too bad I can't put a 2nd coat because truck stays outside. Didn't do the roof though, took me 2+ hrs already. Thing is a monster of a car wash.
    Cosmoblu, Watson, GAknight and 10 others like this.
  17. Oct 31, 2020 at 4:15 PM
    Piki
    Piki New Member
    2017 Tundra crewmax 1794 TRD
    I had fun project today, installed SPod Switches and ARB Compressor.
    Compressor is mounted on aluminum bracket made by our member @Bannock452 great product, very fast shipping.
    I just drilled 4 new holes for my single ARB.
    Very happy
    Rolling Biome, Cosmoblu, RBB and 13 others like this.
  18. Oct 31, 2020 at 4:27 PM
    Squatting Pigeon
    Holden
    North Texas
    Luxe Trail Pig
    MESO flip fob is a go!
    1B06D2BF-91B8-477B-9EBE-FDD6A2957C74.jpg 7B9E494A-8A96-4F16-839C-A02463847FD7.jpg
  19. Oct 31, 2020 at 4:28 PM
    booya69
    booya69 New Member
    Terry
    Maryland
    2020 Tundra SR5
    Wiring instructions were easy to follow and accurate
    Rica25 likes this.
  20. Oct 31, 2020 at 4:35 PM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    Was yours a work the first time straight out of the box type deal? Looks great!
    After some heavy modifications, I got mine to “work” today. However, the panic is still not the greatest but the other two work relatively well.
  21. Oct 31, 2020 at 4:37 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Do toad and star light up at night? If so, best mod I’ve seen to date!
    Rica25 likes this.
  22. Oct 31, 2020 at 4:37 PM
    Squatting Pigeon
    Holden
    North Texas
    Luxe Trail Pig
    I actually did two today with no issue. The panic button is weird on both because it’s only on one side on the stock fob. So only the right side of the MESO button clicks
    ElNopal[QUOTED] likes this.
  23. Oct 31, 2020 at 4:40 PM
    booya69
    booya69 New Member
    Terry
    Maryland
    2020 Tundra SR5
    where did you get those tailgate? Also love the quotes in signature. Semper Fidelis
    Rica25 likes this.
  24. Oct 31, 2020 at 4:49 PM
    CavalryCrew602
    Cosmoblu, Ostrich, Rely01 and 11 others like this.
  25. Oct 31, 2020 at 4:55 PM
    Squatting Pigeon
    Holden
    North Texas
    Luxe Trail Pig
    I wish, but they’re just stickers, so in the dead of night you can still see “tow/haul” and the traction off button picture :(
    Zilla18 and Rica25 like this.
  26. Oct 31, 2020 at 6:23 PM
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    Nice gents. I like the idea of a flip key more n more each day. I'm just wondering how hard, if possible to get it to work on my 16 w/ factory remote start?
    Just had to replace my windshield with OEM glass for the 3rd or 4th time. Maybe the ol lady is right, maybe I should give more room between the vehicle in front of me? Nah just added free replacement to my insurance policy not long ago so I can continue to push them slow drivers out the fast lane when they have no business. Pic just bc.
  27. Oct 31, 2020 at 6:25 PM
    Squatting Pigeon
    Holden
    North Texas
    Luxe Trail Pig
    It uses the internals from one of your existing key fobs, so it should affect the remote start at all :thumbsup:
  28. Oct 31, 2020 at 6:47 PM
    mgm16trdpro
    Northern NJ
    Nice tnx my man, appreciate the heads up.
  29. Oct 31, 2020 at 6:50 PM
    16MagSR5
    16MagSR5 New Member
    Buffalo
    2016 Magnetic SR5, leveled and capped
    Boost tow Mirrors, TRD rear sway, Rough Country Duals, Bilstein 5100's, diff breather mod, more that I'm forgetting...
    Added smoked headlights, and LED DRL's, courtesy of @longcat Just have to get the ihacker harness to fire up the LED's, and do the amber DRL delete. This is also after the oiling I had done. On the first day it kind of snowed.
  30. Oct 31, 2020 at 6:51 PM
    Squatting Pigeon
    Holden
    North Texas
    Luxe Trail Pig
    Of course! :fistbump:
    mgm16trdpro[QUOTED] and Rica25 like this.
