  1. Aug 28, 2020 at 2:49 PM
    Cthulhu
  2. Aug 28, 2020 at 3:14 PM
    100LL
    100LL smells better than Jet-A
    NW Oregon
    2020 SR5
    Potatoes.
    New shoes! KMC KM717 17x8.5 18mm offset and BFG AT KO2 35x12.5R17.
    I am absolutely in love.
    I really liked the Falkens, had them on my Dodge too. However, it's INSANE how much quieter the BFG's are.
    There's a bit of a shake over 70mph, I may have my alignment checked since my offset has changed.
    Oh, also installed the front hitch receiver today.
    RBB, Mountun Goat, Cosmoblu and 22 others like this.
  3. Aug 28, 2020 at 3:17 PM
    BoxersBrew
    BoxersBrew New Member
    Thomas
    Northern Virginia
    2020 Black Tundra Limited Crewmax TRD
    Dealer installed TRD dual exhaust system and tonneau cover. Personally installed TRD Pro grille and surround, side mirror caps, and TRD shifter.
  4. Aug 28, 2020 at 3:26 PM
    jr1016
    jr1016 New Member
    Ric
    Sacramento, CA
    2020 CM TRD Sport
    Looks like your battery needs a replacement soon. I've heard a lot of the stock batteries had been leaking a lot.
    rayk[QUOTED], 100LL and Beesta like this.
  5. Aug 28, 2020 at 4:08 PM
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    Replaced the 50W solar panel with a 100W panel. Fits perfectly and is black so it’s less noticeable.
    6EBA2EC9-4D70-4279-A519-CE85FAAB4129.jpg BD719E09-12E9-4E63-8537-77C04104D1F6.jpg
    Kanekz, Cosmoblu, Sean492 and 15 others like this.
  6. Aug 28, 2020 at 4:20 PM
    Hurricane
    Hurricane Default: Aggressive
    NC
    2017 White 1794
    None
    How do you like the ARB bumper? I keep eyeballing them but that’s a lot of cheddar to plunk down without doing proper research and such.
    100LL[QUOTED] likes this.
  7. Aug 28, 2020 at 4:42 PM
    TNTundra16
    TNTundra16 YOU BIG DUMMY!
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    :drool::drool::drool:
  8. Aug 28, 2020 at 5:04 PM
    Yzed608
    Yzed608 New Member
    Wisconsin
    Paint looks good! Let us know how it holds up, hoping yours works out better than when I did mine. I did the same thing but with VHT primer and VHT black (wire wheeled rust spots on welds, then scotch bright whole thing, and finally an alcohol wipe down before primer). I didn't wait so long between coats though. I think I did 3 coats (used whole can) and waited however long the can said between. It started flaking off in less than 6 months, it might be from all the road salt here though. I've thought about getting it cerakoted, but not sure it's worth the money, or if it'd last long :notsure:.
  9. Aug 28, 2020 at 5:21 PM
    100LL
    NW Oregon
    2020 SR5
    Potatoes.
    Well worth the money. The quality makes other bumpers I've seen in person look home-made. This thing is borderline aircraft quality. I believe it's the only bumper certified to be compatible with airbag systems. It has a crumple zone so a fender bender won't shoot the airbags off on ya.
    Mountun Goat, Cosmoblu, equin and 3 others like this.
  10. Aug 28, 2020 at 5:25 PM
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    2019 Pro Midnight Black Metallic
  11. Aug 28, 2020 at 5:27 PM
    18" TRD Off Road Wheels
    I love the coverage it provides and it's compatibility with safety equipment, but I can't bring myself to consider the ARB because of the cutting involved. I know that I'd mess it up. That, and it just sticks out too far up front for me. Your truck makes it look good, though.
    Cosmoblu and 100LL[QUOTED] like this.
  12. Aug 28, 2020 at 5:28 PM
    BoxersBrew
    Thomas
    Northern Virginia
    THx. I waited 24 hours as per instructions. Will try to remember to update on how it’s holding up next year.
    Yzed608[QUOTED] likes this.
  13. Aug 28, 2020 at 5:37 PM
    Hurricane
    NC
    2017 White 1794
    None
    :eek2:
    Cutting? :eek2::eek:
    Oh crap.
  14. Aug 28, 2020 at 5:47 PM
    100LL
    NW Oregon
    2020 SR5
    Potatoes.
    If it helps your decision, I can help you with the trimming. You being in WY and me being in MT... Not too far of a drive for us!
    Yep, although all the cutting is plastic bits. You need to trim the grille surround and the lower plastic pieces forward of the quarter panels.
  15. Aug 28, 2020 at 6:12 PM
    ttime4four
    ttime4four New Member
    West Linn, OR
    '20 Tundra Limited DC TRD Offroad
    In prepping the back of the rig for camping, I wanted switchable power for the fridge, phone charging, LED lights - whatnot.
    In the past, I've used a similar setup and mounted in my Tacoma bed in the right side cubby cover. After scratching my head and debating between drilling holes in the new truck or making an enclosure - I opted to do some woodworking.
    Original idea for placement
    Make a box (1/2" baltic birch). Quick cuts of existing scrap on the table saw, opening cuts on the drill press and router table, assemble with glue / pins, quick belt sand and finish with spray prime and spray trim black.
    Wire it up and did a little shrink wrap on the wires to keep it tidy. I opted to leave the back open as the mounting spot had limited space.
    Affix with velcro on the canopy rail - it's not going anywhere.
    Tomorrow's task - run power.
    Kanekz, Skippy, Cosmoblu and 17 others like this.
  16. Aug 28, 2020 at 6:41 PM
    Foster
    Foster New Member
    NE Ohio
    2020 Platinum Crewmax
    What is the stock airbox mod. I tried searching to no avail.
  17. Aug 28, 2020 at 7:21 PM
    Yzed608
    Yzed608 New Member
    Wisconsin
    Might be a dumb question, do you know where the the airbag sensors are? I've take the stock bumper off to put caps on them, and now thinking about it don't remember removing anything sensor wise (and never thought about it at the time).
    The stuff you used might just be that much better!
  18. Aug 28, 2020 at 7:28 PM
    beaver6713
    beaver6713 2015 CM
    Kleve
    Safford Arizona
    2015 Tundra CM
    6 inch Pro Comp lift. OME rear springs with Coach Builder +3 shackles. Coach Builder tie rod ends. ICON 2.5 front and rear shocks with remote res. ICON Hyd bump stops. 35" Nitto Trail Grapplers on 18" fuel rims. Kenwood DNX 892 head unit with JL audio and RF amp pushing 2 Image Dynamics idq10 subs. SABM, S POD switches for 42" in bumper and 32" behind grille LED light bars. Full interior and exterior LED conversion. LED flush mount back up lights in rear bumper. Valentine one radar detector. V Leds under dash and seats foot well lighting. TRD pro head lights and grille. Full AJT dash kit
    Dragracer_Art likes this.
  19. Aug 28, 2020 at 7:46 PM
    TILLY likes this.
  20. Aug 28, 2020 at 7:50 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    All that work and mutilation of your truck that i imagine produces nothing more then just some extra noise. The stock air box has been proven to perform very well as designed. Never blindly trust a vid on YouTube, especially when the comments are turned off. Just my 2 cents of course. :eek2:
  21. Aug 28, 2020 at 7:55 PM
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    Supposed to be a cold air intake i think ...
  22. Aug 28, 2020 at 8:04 PM
    By moving the hole a whopping 8 inches?
  23. Aug 28, 2020 at 8:07 PM
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
    I wanna do something similar and was going to drill like you were. This is a meat idea. Are you running power to a secondary battery?
  24. Aug 28, 2020 at 8:48 PM
    ttime4four
    West Linn, OR
    I'm not running a second battery and everything is wired off the main truck battery.
    When I go camping, I've got a Renogy Monocrystalline 100W solar panel connected to the main battery via a Renogy Wanderer 30A PWM Charge Controller. With a bit of cable, I can move / position the panel to catch the best sunlight. My fridge is pretty efficient and has a cut-off to prevent it from fully draining my battery. To make sure I can still start the truck after I'm finished camping, I keep a NOCO Boost Plus GB40 in the center console. It's always plugged in to the 12v outlet in the console making sure the NOCO is always fully charged.
    Little bit of belt and suspenders, but having a second battery is mucho dinero and is probably overkill for my needs. When my OEM battery gives up, I'll most likely replace it with the biggest Northstar AGM I can squeeze in there.
    Cosmoblu and twistedcricket like this.
  25. Aug 28, 2020 at 10:00 PM
    Jcmf52
    Jcmf52 New Member
    Rob
    2018-1794 S/C
    Shorty antenna Trifold hard top tonneau cover Center console safe Center console tray Rhino liner TRD air filter TRD rear sway bar TRD front sway bar Center console wireless charger kit Remote start Black 4x4 emblem swap
    Its actually not a bad idea. One hole bringing air in from the fender is good, wouldn’t a second hole only be better at providing more “cold air” for the engine.
    I am not doing this mod, cause I don't want to cut a new hole in the new truck.
  26. Aug 28, 2020 at 10:29 PM
    Not sure that'd be the case. Having a twin tip on your exhaust doesn't let out any more exhaust than a single tip because you are still working with a single pipe. 1, 2, or 10 holes, you are still restricted by what the filter and the intake pipe allow.
    I could be wrong, but this is just how my brain is seeing it.
  27. Aug 28, 2020 at 10:38 PM
    Jcmf52
    Jcmf52 New Member
    Rob
    2018-1794 S/C
    Agree, but maybe the air filter and tube could be pulling in more air if there were more available
    Hurricane likes this.
  28. Aug 28, 2020 at 10:44 PM
    That's possible, but I'm with you. No way am I drilling a hole in my truck! ;) I still flinch looking at @100LL 's snorkel install pics. :eek2::eek:
    Beesta likes this.
  29. Aug 29, 2020 at 12:50 AM
    Heath423
    Heath423 New Member
    Heath
    Chattanooga, TN
    2020 Magnetic Gray CM SR5 4WD
    Console tray/dividers, Interior LED's
    Ordered the Undercover Armor Flex bed cover. Now to sit and wait for delivery.
    Long Duck Dink, Cfincke and Beesta like this.
  30. Aug 29, 2020 at 4:34 AM
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    what paint did you happen to use ?
    Beesta likes this.
