  1. Jul 17, 2020 at 5:41 PM
    fiveduece
    fiveduece I like to party.
    Brandon
    2020 TRD sport MGM crewmax
    tint, N-Fabs, trifold cover, bilstein 5100 w/spacers, +2 shackles, MT deegan wheels
  2. Jul 17, 2020 at 6:50 PM
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    appreciate it! A couple things I forgot to ask is if I am only going with a plus one will I need to put in longer shocks or will the factory ones work? And will just shackles improve the ride/handling with the factory shocks. I don’t off-road and sometimes tow a boat but mainly a daily driver. If i do shocks was thinking something like Toytec boss, 5100’s....maybe go up to 5160’s. I have Toytec Boss Coil overs in the front.
  3. Jul 17, 2020 at 7:17 PM
    junior
    junior Member
    Zach
    Santa Cruz, CA
    2016 Tundra TRD Off Road
    Black Rhino Rapid 17" 35x12.5 Mickey Thompson Baja Boss Fox Performance Elite 2.5 DSC at 3" with Coachbuilder 1/4" shim on driver side JBA UCAs Fox Performance Elite 2.5 DSC rear shocks Dobinsons HD Leaf Springs Firestone Airbags + Daystar Cradles Prinsu Cab Rack 2024 Four Wheel Camper Project M Camper Mods: Goal Zero Yeti 4000 house battery 200w solar IceCo fridge Truma Propane Heater
    I bought it from Toyota Cool Springs: part 66140-0C030. When it arrived, it was actually branded "Stabilus Lift o Mat", which Im sure you could find on ebay for cheaper, but I knew this ordering from toyota it would fit/work
    Major[QUOTED] and biebs96 like this.
  4. Jul 17, 2020 at 7:19 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Where'd you get the color matched mirror caps?
  5. Jul 17, 2020 at 8:07 PM
    KneeYa
    KneeYa New Member
    Hood Bulge and TRD Pro Grille.
    DZ_, tennisfreak, Cosmoblu and 17 others like this.
  6. Jul 17, 2020 at 8:32 PM
    Will1606
    Will1606 New Member
    Will
    NJ
    2019 TRD DCLB
    Thanks for sharing the armrest link! Looks great.
  7. Jul 17, 2020 at 10:12 PM
    Highsierraguy
    Highsierraguy New Member
    Nor Cal
    Where did you get the plastic insert? Mine was also used and has glue stuck in it that I can't get out.
  8. Jul 17, 2020 at 11:22 PM
    SoCalTecHead
    SoCalTecHead New Member
    Tony
    Orange County California
    2020 Cement CM Limited
    Started with a wash at 6 am, installed OEM tailgate lock and then my Diamondback tonneau cover showed up at 3:30 so I had to install it. :)
  9. Jul 18, 2020 at 2:08 AM
    fiveduece
    Brandon
    You'll be fine with factory shocks.
    Shackles won't change ride quality. I've read on here people buying different bushings for their shackles and helping ride. I would just grind the factory bushing down so they are smooth and not worry about replacing them. But that statement will really upset some people on here.
  10. Jul 18, 2020 at 7:14 AM
    TundraHulk02
    TundraHulk02 New Member
    2020 White Tundra TRD Sport CrewMax
    Plastidipped the center bumper this morning.
    WFD473, Cosmoblu, Fotnot and 7 others like this.
  11. Jul 18, 2020 at 7:16 AM
    Cthulhu
    I put SDHQ shackles on mine that raises the truck by about 3/4" to get back to more of a factory rake; I have 2.5" spacers up front. I also replaced the bushings with CB ones. I, unlike what others on this forum have reported, really didn't notice a difference in ride, even on joints in the freeway. At first I only needed clearance for bigger tires, and knew I wouldn't get into off-roading situations where I could "taco" the front shocks, so that's why I only went with spacers in the front. Eventually, since I do mild off-roading, I am going to go with a 6110/5160 set-up. However, since you don't off-road, I personally think, from all I've read, that you'll be fine with 5100's. Or Toytecs for that matter.
    jewsNbrews likes this.
  12. Jul 18, 2020 at 8:47 AM
    Yzed608
    Yzed608 New Member
    Wisconsin
    Tested out my new Safe Jack last night.
    Max height with no extension.
    With included extension.
    Lifting up the rear off the axle. Can't use extension as it won't fit under. Max height gives about 3" tire clearance.
    Lifting front tried to use the U shape at the furthest point forward it would fit on the frame rail (good fit btw). Would not lift the wheel off the ground (also can not use the extension in that placement). Used the flat pad on the crossmember and gave just over 2" clearance.
    In it's new home, still kept the stock jack in it's spot against the rear cab wall (how jealous are you crewmax folk on all the storage? :rofl:).
  13. Jul 18, 2020 at 8:49 AM
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    Appreciate the input, thank you! So if I decide to go shackles first will the factory shocks accommodate that ~1” lift? I’ve seen some information saying that you need longer shocks but that may have been on bigger lifts.
    The posts I have seen that have noticed improved ride quality was due to the shackles being able to articulate with the new bushings which would make sense.
  14. Jul 18, 2020 at 9:36 AM
    Lowgybear
    Lowgybear It takes an iron will
    Ysai
    San Antonio Texas
    2018 TSS OFF ROAD Tundra
    Nice! So you put lighting in your esp storage? Do you have photos? How did it go?
    mgm16trdpro and ElNopal[QUOTED] like this.
  15. Jul 18, 2020 at 9:38 AM
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    "Cultured Redneck"
    Using a coaster for his PBR. :drunk:
  16. Jul 18, 2020 at 9:38 AM
    Lowgybear
    Ysai
    San Antonio Texas
    No problem! I figured others would want to look into it
  17. Jul 18, 2020 at 9:48 AM
    Lowgybear
    Ysai
    San Antonio Texas
    I’ll be honest it is not easy to find, mostly because Toyota does not sell it by itself. I saw a few at the forum marketplace but they had already been sold.
    I got smart about it and I started looking on the forum for people that might’ve replaced theirs with the wireless charger replacement. I started asking around on here and sure enough ended up finding one and buying it off of them.
    probably your best bet I’d say
  18. Jul 18, 2020 at 10:14 AM
    blueshound
    blueshound New Member
    2015 Red Tundra Platinum
    mgm16trdpro likes this.
  19. Jul 18, 2020 at 10:49 AM
    phi482
    phi482 New Member
    KY
    2020 Cement Limited TRD Off-road
    We paid off our 2018 Odyssey and I ordered the tailgate lock and TRD shift knob. Should have a few more bucks to play around with having only one car payment.
    jewsNbrews, Ted4311 and GODZILLA like this.
  20. Jul 18, 2020 at 10:55 AM
    TNTundra16
    TNTundra16 YOU BIG DUMMY!
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    Epic transformation sir! Love the Cavalry Blue :thumbsup:
  21. Jul 18, 2020 at 11:06 AM
    TNTundra16
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    I picked up a used set of halogen trd pro headlights from @jmevis (great guy) and ordered a black emblem kit and trd pro grille :bananadance:
    jmevis and TylerDurden311 like this.
  22. Jul 18, 2020 at 11:36 AM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    Yeah, I didn’t get all of neat and tidy yet but here are some early pics.
    9A16A19D-1D35-40E7-A211-2BFCC0C18159.jpg C04C6993-7511-4E6A-8859-C0320D21F607.jpg 6AFB8E3C-E784-4234-94CA-6390A9281D8B.jpg 22FA8EFC-7BDC-47B2-B4BF-FF943FF1045B.jpg
  23. Jul 18, 2020 at 12:18 PM
    Cthulhu
    I retained the factory shocks with the SDHQ shackles, and it has been fine. Your comment on articulation makes sense. Most people that put on CB shackles and bushings are going for a lift greater that 1” from what I’ve read.
    DCB500[QUOTED] likes this.
  24. Jul 18, 2020 at 12:48 PM
    BoxersBrew
    BoxersBrew New Member
    Thomas
    Northern Virginia
    2020 Black Tundra Limited Crewmax TRD
    Dealer installed TRD dual exhaust system and tonneau cover. Personally installed TRD Pro grille and surround, side mirror caps, and TRD shifter.
    Very cool! But, not jealous enough to give up that back window that goes all the way down.
  25. Jul 18, 2020 at 12:55 PM
    Lowgybear
    Ysai
    San Antonio Texas
    Very cool, even for being early pics. Are you following some kind of instructions to do it or do you just know how to do this stuff?
    Id like to get my storage lit at some point
    ElNopal[QUOTED] likes this.
  26. Jul 18, 2020 at 1:03 PM
    Cthulhu
    It’s been 2 years since I bought my truck, and life and COVID have gotten in the way, but I FINALLY was able to take it off-road today. Man it was a TREMENDOUS BLAST!! The Francis Marion National Forest outside of Charleston, SC is loaded with trails. Most are easy to moderate, but several are VERY deceptive. For all you locals, Ackerman B road in the FM Forest has a section that is NOT for the faint of heart, especially if you’re running stock or don’t have at least 6” of lift, maybe even more. I had been driving along for a couple of hours, hitting some awesome puddles and some light technical spots, when I came up on Ackerman B. There were ROAD CLOSED signs on both ends of the road, but they were pushed aside. So I said F it :D. Going along it was riddled with puddles, but manageable. Deep ditches on both sides, so no turning back unless you reverse all the way out. I come up on a section with several larger diameter puddles back to back, and you HAVE to go through them. Because everything had been very manageable before this, I just slowly crept forward. When i get into the first one, it almost swallowed the truck :eek2:. I powered through it after seeing the forward exit angle wasn’t too bad, and came up and out. But when I started entering the next puddle while still not completely out of the first, BOOM, it sounds like a shotgun went off in my cab! :confused:. I am now stuck. I start rockin’ it back and forth, and it finally breaks free. I get out to see WTF. I had indeed bottomed out, and the rear of my passenger side running board was bent up into the lower corner of my cab! Lower cab corner has a small dent, a chip off the LineX on my running board, and all the running board brackets are bent to hell. Got my tape measure out, and them mofo’ing puddles were almost 2 feet deep! I wish I would have taken pics but I was too pissed off :mad:. Got home and took the running boards off, put the brackets to my bench vice and started hammering, and now all good. The cab dent isn’t bad at all...I’ll wear it as a badge of honor, or badge of dumbass, take your pick :rofl:. Did a thorough exam of the underbelly of the beast, no other damage, PTL!!
    :amen:
    Lessons learned for my future off-roading adventures:
    1) Don’t take for granted that just because a puddle might look easy, it could be the maw of doom! Might want to measure puddle depth if it runs the entire width of the trail and you have to go through it, ya big dummy!!
    2) Time to start saving up for sliders! :spending:
    3) I’m letting too much of life get in the way from awesome fun times in the woods! :mudding:
    All fixed :thumbsup:
  27. Jul 18, 2020 at 1:09 PM
    18" TRD Off Road Wheels
    Awesome story! Glad you had fun and didn't need a rescue. This is the kind of stuff that I see that made me opt in for a rear diff breather kit. I wanna be able to get through it if needed like you did.
    Cthulhu[QUOTED] likes this.
  28. Jul 18, 2020 at 1:16 PM
    Cthulhu
    Yep SO GLAD I did the diff mod, I was stuck there for probably a whole minute, I was terrified I was going to start taking on water!!
    :eek:
    GODZILLA[QUOTED] likes this.
  29. Jul 18, 2020 at 1:18 PM
    Yeah, without the breather relo....... Pretty sure you'd be playing Taps for that rear end.
  30. Jul 18, 2020 at 1:22 PM
    mghtyducks93
    mghtyducks93 Bubble Head
    Southern California
    2015 White Double Cab
    Swapped out my Plasti-Dipped chrome grill with a color-matched Pro grill. Also made use of a recently broken hockey stick for a new shift knob.
