What fuel best 5.7
Discussion in 'Performance and Tuning' started by XFordGuy, Nov 23, 2018.
  1. Apr 10, 2023 at 9:57 PM
    Toyotaguy1654
    Toyotaguy1654 New Member
    2018 Tundra 5.7L
    Ffv 2018 tundra 5.7. Is 89 non ethanol. Or 89 better? I run 89 regular seems to do good. Don't want to switch to the non ethanol due to more expensive and if no difference why do it
  2. Apr 10, 2023 at 10:55 PM
    Ethanol is worse for anything that isn't a race engine tuned for it, and then it's only good for power in a high ethanol content fuel. The blended fuel or E85 will net you worse fuel mileage. You will get better fuel economy with zero ethanol. It's purely a subsidized farce that has no true benefit.
    As for octane, your truck will adjust for anything 87 or better, but tuners have found the truck runs happiest on 91 or better. Nothing that you'll feel in the seat of your pants, but it does run a little better.
  3. Apr 11, 2023 at 3:25 AM
    Demented Canine
    Demented Canine Hiding in the Baffles
    Extreme Southeast Georgia
    2020 MGM SR5 DC
    I have been driving Toyotas for 40 years. 22-RE, 2JZ-GE, 2UZ-FE, 1GR-FE, 3UR-FE. I have always used "Top Tier" gasoline at the Octane Level recommended by the Vehicle Manufacturer. I have never had a fuel system related issue with any of my vehicles. I have predominately used Exxon/Mobil formulated gasoline. You don't always know what you are putting in your tank if the pump is not marked. It is prudent to find out what "brand" of gasoline that your favorite Convenience Store pumps. For example, I generally fuel at Circle K Convenience Stores. Down here in the Southeast Georgia, Circle K has Mobil formulated gasoline. Brands that I prefer are Exxon, Mobil, Shell and Chevron.
    Take a look:
    https://www.toptiergas.com/gasoline-brands/
    Westerntowboss and bulldog93 like this.
  4. Apr 11, 2023 at 3:50 AM
    Toyotaguy1654
    2018 Tundra 5.7L
    I do at circle k also. But I use the 89 not the non ethanol tho
    Demented Canine likes this.
  5. Apr 11, 2023 at 4:28 AM
    Demented Canine
    2020 MGM SR5 DC
    My Gen 1 with 2UZ-FE has been on a steady diet of 87 Octane with 10% ethanol for 22 years. No issues.
  6. Apr 11, 2023 at 7:29 AM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    Just make sure you don't use 100+ octane. Your octane sensors will think its AV gas and the ECU will make the truck go airborne.
    Retired...finally and bulldog93 like this.
  7. Jun 23, 2024 at 6:39 AM
    Albinator
    Albinator SAINTRIOT
    Utah
    2008 Tundra Crew Cab 5.7 4x4
    RC 3.5” M1 Lift 18X9 5-150.00 12 Offset Vision Turbine
    Seems like no one is comfortable to answer this question because I’m wondering as well.
  8. Jun 23, 2024 at 8:21 AM
    Wallygator
    All this is probably in the owners manual
  9. Jun 23, 2024 at 8:38 AM
    Albinator
    Albinator SAINTRIOT
    Utah
    Yes, but not to my specific situation.
    It says to use only unleaded, octane rating 87 (research octane number 91) or higher but this is all rated at sea level so it doesn’t pertain to me in Utah with my two options of 85 and 91.
  10. Jun 23, 2024 at 9:01 AM
    AZBoatHauler
    So.Arizona
    I’ve put 85 in mine as long as I’m staying at altitude for the duration of that tank. When I’m getting ready to leave to lower elevation - don’t use 85.
    Albinator[QUOTED] and Wallygator like this.
