What engine oil/filter combo are you guys using?
Discussion in '1st Gen Tundras (2000-2006)' started by Alltimehigh, Mar 13, 2020.
  1. Mar 16, 2020 at 10:57 AM
    Tiamat
    Tiamat New Member
    2015 tundra crewmax xp
    What’s your gas mileage like with 5-30 oil. I know the land cruiser uses 5-30 but is also has 8 speeds
  2. Mar 16, 2020 at 12:12 PM
    Professional Hand Model
    Hand Protectors
    Horrible like all Tundra V8 trucks.
    RitcheyRch, revtune and bmf4069 like this.
  3. Mar 16, 2020 at 1:08 PM
    Tiamat
    Tiamat New Member
    I get it my truck gives me 16 mpg I drive mainly hwy. with limited city. I’m wondering if (5)w30 made it worse than 0w20
  4. Mar 16, 2020 at 2:12 PM
    Hand Protectors
    The 1st Gen is spec’d 5w-30. I follow directions and use what they say. Maybe someone has used 0w-20 and will chime in.
  5. Mar 16, 2020 at 3:30 PM
    bmf4069
    bmf4069 Captain wtf
    Beau
    TX
    02 AC sr5 4wd v8
    Live a little! Rules are made to be broken!
    HbbTundra08, Hoff, Hooptytrix and 2 others like this.
  6. Mar 16, 2020 at 3:35 PM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Star, Idaho
    TRD Lowered and Supercharged
    OEM filter and either Mobil 1 or Valvoline Synthetic
  7. Mar 16, 2020 at 11:05 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    0w-20 while giving an advantage would likely yield less than 1 mpg increase but potentially incorrect lubrication
    tvpierce and Hooptytrix like this.
  8. Mar 17, 2020 at 5:29 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    @FirstGenVol What are the Universal Averages in the right column? Is that the quantity of the element typically present in used oil samples in ppm? I assume they read it off an experience curve for the mileage? If true, then your aluminum wear appears to be about 25% higher than typical oil tests, but they make no comment about it. :notsure:
    I have heard engineers say that time was less important on seldom driven vehicles, and have run 18 month or longer OCI in the past. The most interesting comment in your report was the comment below. I had begun to rethink extending change interval due to slight fuel odor in the Tundra oil, but now?...wth? Did you express some concern about running your oil 14 months? :notsure:
  9. Mar 17, 2020 at 5:44 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    My understanding from their website is that the universal average is basically the average from every other 2UZ-FE they have sampled. Apparently they didn't find the aluminum concerning enough to mention. Good question about time intervals. When I sent this sample in a few years ago the Tundra was my spare vehicle and I was only driving it around 4,000 miles per year. I had asked them if it was ok to only change the oil every 14-16 months.
    @lsaami and @Festerw what were you aluminum counts on your Blackstone report? John's trying to give me a stroke here. :D
    lsaami and JohnLakeman[QUOTED] like this.
  10. Mar 17, 2020 at 5:53 AM
    JohnLakeman
    Thanks for your report, and the explanation. Sorry, I didn't intend to create anxiety for you. Maybe 1ppm higher per oil change is not significant, but over a lifetime of changes it's still, well actually, 33% higher than the universal number. Inquiring minds you know. :oops:
    Doesn't one of Tundras members work at Blackstone?
  11. Mar 17, 2020 at 5:54 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    I just wanted to be included in this thread. :bikewhoops:
  12. Mar 17, 2020 at 6:13 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Little lower.
    JohnLakeman likes this.
  13. Mar 17, 2020 at 7:25 AM
    Hand Protectors
    I’d not pay much attention to these Blackstone reports. If the engine blows (even though you’ve been taking good care of her), then there is not much you can do!
    Not sure what corrective measures can be done other than using the proper fluids. If those aren’t working, then its time to move on or rebuild.
  14. Mar 17, 2020 at 7:41 AM
    Deuxlatch
    Deuxlatch AirBus
    Chris (Latch)
    Tomball, Tx./Lafayette, La.
    2010 Super White Tundra CM
    TRD Supercharger, TRD Big Brake kit, MotoMetal wheels, Undercover Tonneau with dual swing out saddle bag tool boxes.
    2010 5.7 CM
    Mobil 1 Full Synthetic High Mileage 0W-20
    Wix filters
    10k mi intervals
  15. Mar 17, 2020 at 7:42 AM
    Hand Protectors
    Wheres my trailerhood brotha from anotha trailer motha? @bmf4069
    TX-TRD1stGEN likes this.
  16. Mar 17, 2020 at 7:57 AM
    JohnLakeman
    Your wear rate is actually 33% LESS than the Universal Average for 2UZ-FE. Blackstone would/could probably add some discussion about the variability and accuracy of ppm measurements on any one report, and "past results not being a indicator of future performance". As mentioned, owner's shouldn't put too much weight on any one oil analysis report, but elevated wear metal levels are something to be watched for on future reports.
    Of more interest to me is if apparent higher wear rate of Erik's sample indicates anything about using a "cheap blend" (no disrespect intended, Erik) versus more expensive branded oil. I use only major brand oil (Mobil 1, Valvoline) even if it's more expensive, but have had an automotive engineer tell me that Walmart's brand is just as good if it has the API rating stamp.
  17. Mar 17, 2020 at 8:43 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    I posted mine a little earlier in this thread. Aluminum count is 3 on my Mobil 1 High mileage Synthetic with a FRAM XG filter after 5000 miles.
  18. Mar 17, 2020 at 8:49 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    That was 8500 miles Valvoline Synpower 0w-20 and a Toyota filter.
    I'm not doing analysis every change just with it being (at that point) near 200k how it was doing. Mostly was curious about antifreeze and fuel to see if there were any issues I could correct ahead of time.
    Schcoman and JohnLakeman like this.
  19. Mar 17, 2020 at 8:50 AM
    #49
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I agree to an extent. This test is only going to tell you so much. That being said, for the part in bold they actually have examples on their website of how the test has been used to catch issues before they became expensive problems. They go beyond just metal content. The key there is timing. But I understand if someone doesn't want to spend the money.
    For me, I find the test to be interesting and I'm not going broke by doing one every 2-3 years.
    No offense taken. I switched to Mobile 1 a year or more ago. I'll likely do another test soon as it's been a while.
  20. Mar 17, 2020 at 11:25 AM
    #50
    JohnLakeman
    THAT was some high quality intel that was properly interpreted and applied. Pretty good sales pitch for Blackstone.
    Personally, I have never had an oil analysis done. Like PHM, I have believed that if I perform regular maintenance with good products according to OEM recommendations, I'll be fine. After establishing an early baseline, supplemental oil analysis performed occasionally could make a difference as the miles begin to pile up. If any anomalies are observed, then you can test a sample after every future change to see if a problem is developing.
    When you've had the analysis, post up the results. Appreciate it. :thumbsup:
  21. Mar 17, 2020 at 2:35 PM
    #51
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    The 0w part isn't bad in the winter if you're living in the north, the 20 is a problem no matter where you go.
    Hoff likes this.
  22. Mar 17, 2020 at 3:49 PM
    #52
    Hooptytrix
    Dirty South
    I'm actually going to this grade in the summer
  23. Mar 17, 2020 at 5:02 PM
    #53
    empty_lord
    05 rollover special
    I wouldn’t hesitate to run 0w-30. But 5w-30 is more available
  24. Mar 17, 2020 at 5:06 PM
    #54
    Hooptytrix
    Dirty South
    Correct me if I'm wrong on this.The larger the difference between numbers means more additives. if that is correct then I would prefer 10w30 since I'm in Florida.
  25. Mar 17, 2020 at 7:01 PM
    #55
    empty_lord
    05 rollover special
    10w-30 is similar to a ten weight oil cold, and a 30 weight warm. It has nothing to do with additives.
    lsaami likes this.
  26. Mar 17, 2020 at 7:11 PM
    #56
    Hooptytrix
    Dirty South
    The additives are how they make 30 weight oil act like 10 weight at 0 degrees. The additives in oil is why change intervals are setup. The additives begin to separate around 2700-3000 miles in conventional oil. I'm of the thinking, oil with less additives or oil designed from the ground up with these tolerances (quality synthetic) would be best. The big black clumps you see in engines has a lot to do with those additives
  27. Mar 17, 2020 at 7:22 PM
    #57
    empty_lord
    05 rollover special
    I go 15k between changes with mobil extended 5w-30. No black clumps to speak of. The additive package is part of the ANSI from my understanding
  28. Mar 17, 2020 at 7:28 PM
    #58
    Hooptytrix
    Dirty South
    Synthetic oil can do 15k change intervals and I believe the mobile extended is synthetic. There aren't many true synthetic oil's on the market, I know amsoil, liqui moly and royal purple are.
  29. Mar 17, 2020 at 8:01 PM
    #59
    JohnLakeman
    You need to do some research. Multi-viscosity oils are not made by an additive package in the conventional sense. Multi-visocosity motor oils are made from engineered long-chain hydrocarbon molecules that shrink and expand with changes in temperature, resulting in the viscosity changing. Those molecules are an integral part of the motor oil, not an additive.
    lsaami likes this.
  30. Mar 17, 2020 at 8:40 PM
    #60
    Hooptytrix
    Dirty South
    Maybe I'm not seeing it or saying it correctly. But this explanation and my interpretation is additives
