What else replace while doing 5100’s?
Discussion in '1st Gen Tundras (2000-2006)' started by MNtundra, Jul 30, 2020.
  1. Jul 30, 2020 at 3:17 PM
    MNtundra
    MNtundra [OP] New Member
    Tony
    Minnesnowta
    01' Tundra AC 4x4, 04' CRV 4WD
    Bilstein 5100's, 4runner Wheels 31" BFG, Rear Seat Delete
    Title says it all, what else should I replace while in there replacing the front shocks (24261425 Correct model #?)
    -Upper balls (see some ooze around them)?
    I will now be doing this ASAP (next week) instead of planning out my suspension modifications due to fact that current shock is cutting into the mount...:facepalm:
    Here is what I bought:
    -KYB mounts
    -5100’s
  2. Jul 30, 2020 at 3:18 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Any paint that is not black. :hattip:
    bmf4069 likes this.
  3. Jul 30, 2020 at 3:36 PM
    MNtundra
    Tony
    Minnesnowta
    Lol, bought it in CO... yes in the rear cross frame, plenty rust.
    Darkness[QUOTED] likes this.
  4. Jul 30, 2020 at 3:52 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Hard to say without being there but I would jack up the truck, grab the front tires and do the wiggle tests. If nothing fails that test, inspect the boots on the upper/lower ball joints, inspect the boots on outer tie rod ends, inspect the sway bar bushings. Anything that is showing signs of real wear you should consider replacing.
    Its really hard to see the upper/lower arm bushings enough to gauge wear. With the coilover removed you can grab them and try to wiggle them around but with the coilover in place they're under too much tension to reveal excessive play.
    Steering rack bshings are worth looking at, but they can be a pain to install so keep that in mind if yours don't seem too bad.
    Once that's done, buy black paint.
    MrAristo and bmf4069 like this.
  5. Jul 30, 2020 at 4:35 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    Have you considered these?
  6. Jul 30, 2020 at 5:17 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    This is what I would do if I were doing it again. Drop in complete units and then you've got the time to plan out what else you want to do. Literally 8 bolts to swap out both and no need to remove anything but the shock as a unit.
  7. Jul 30, 2020 at 9:18 PM
    noahrexion
    noahrexion New Member
    Washington
    2005 4WD DC
    Anybody install those on a DC or have first-hand experience with how much lift you got once settled? Better yet, have any hub:fender measurements? Those look interesting - I'll have to do some research!
    Aside from what was mentioned you could consider some extended sway bar end links for the lift (will come with new poly bushings), change your gearbox fluids/tranny fluid, check diff breathers, check brakes, check for leaks...etc I had to replace my drivers front wheel bearing @ 195k.
  8. Aug 3, 2020 at 2:56 PM
    MNtundra
    Tony
    Minnesnowta
    revtune[QUOTED] likes this.
  9. Aug 3, 2020 at 3:08 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I’d probably try to cut mounting tab and fab up another one while you’re in there. Looks like tat shock body has about rubbed through it.
  10. Aug 3, 2020 at 3:27 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    Darkness likes this.
  11. Aug 3, 2020 at 3:28 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    Darkness and Festerw like this.
  12. Aug 3, 2020 at 3:39 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
  13. Aug 14, 2020 at 7:18 PM
    MNtundra
    Tony
    Minnesnowta
  14. Aug 14, 2020 at 7:36 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    MNtundra[QUOTED][OP] likes this.
  15. Aug 14, 2020 at 7:45 PM
    MNtundra
    Tony
    Minnesnowta
    Re-Using factory coil springs. Guess it looks like the I will be using the KYB Mount supplied isolators! :annoyed:
  16. Aug 14, 2020 at 8:04 PM
    empty_lord
    05 rollover special
    yea. the smaller isolators are for running the Taco springs.
    good news is you can probably sell those to another member easily
  17. Aug 15, 2020 at 1:43 AM
    tunyota
    tunyota Wrenching w/ the beautiful wife.
    Phantom Gray 2006 Regular Cab Long Bed 4WD V8 4.7L
    Front Hitch Receiver, Bilstein 5100s, Denso 130A alternator, LED interior and exterior lighting, Kicker 46CSS674 Car Audio 6 3/4" Component Full Range Stereo Speakers, Pioneer AVHX2700BS w/Pioneer NDBC8 Backup Camera, Transcend Drivepro 550 Dual Lens Dash Camera, and much more!
    I recently installed 5100s all around that I got new on eBay after making an offer for $350 shipped.
    Depending on the condition, I would consider replacing brake rotors, pads, rusted brake lines, fluid, etc...
    I just replaced the rigid steel brake lines that run from the steering knuckle to the caliper with new OEM lines as they were starting to rust/blister and were easy enough to replace.
    Part No.: 47315-0C020
    Part No.: 47318-0C020
  18. Aug 15, 2020 at 5:41 AM
    MrAristo
    MrAristo Hounty Bunter
    South FL
    ‘01 4X4 Limited TRD
    Planning on doing the same, but replacing all four 5100s for 855 OME and looking to get 2.5-3” level. That is purely preference but maintenance wise I’m replacing LBJs, UCAs, sway links (one missing) and CV Boots (one torn).
