What do y’all think
Discussion in '1st Gen Tundras (2000-2006)' started by randomuser72, Oct 8, 2020.
  1. Oct 8, 2020 at 6:10 PM
    randomuser72
    randomuser72 [OP] New Member
    2005 Tundra 4wd
    Hey all, been stalking the forms for a little bit, but this is my first post here. I’m looking at getting my first 1stgen, the one I’m looking at is an 06 with 118k miles, frames been replaced from the recall, but I’m new to these trucks and rust scares me. What do y’all think about this under carriage? Anything pop out at y’all? Thanks for the help A20F263C-7F98-4410-B8D4-65196D2A3F46.jpgBF30B085-9E20-465F-8150-C1DC55BF042B.jpg43D90DCC-0290-40D7-8DA4-893BFE8B3AB9.jpg
    YardBird likes this.
  2. Oct 8, 2020 at 10:50 PM
    bassman417
    bassman417 "Tundra Time". My favorite time of day...
    Paul
    Las Vegas
    2004 DC 2wd Imperial Jade
    Welcome from Vegas.
    Id say those rusty ass bolts and leaf springs on the first pic pop out a bit. Seen worse?
    What does the rest of this truck look like and whats the pricetag?
    MS22 likes this.
  3. Oct 9, 2020 at 2:23 AM
    randomuser72
    2005 Tundra 4wd
    Price tag is 13k which feels a little high but prices on these things seem to be all over the place so I don’t really know. Rest of the truck looks nice, imperial jade (my favorite) DC 4wd and it has a leer shell.
  4. Oct 9, 2020 at 5:56 AM
    Professional Hand Model
    Hand Protectors
    Rear Axle has some bubbles and looks to be freshly painted over to hide those. Diff Cover Rust is a big problem to fix if it starts springing on you. The drive shaft is looking crusty along with many important bolts/nuts that will need servicing soon if this were a long term investment for you. The rocker panels and under body of the cab seem to be bubbling as well.
    I’d pass on this one unless the price was $4-5k. You’ve got lots of work to do on that thing.
    glowblue likes this.
  5. Oct 9, 2020 at 7:20 AM
    randomuser72
    2005 Tundra 4wd
    Thanks for the advice baseman and PHM, I appreciate it a ton
  6. Oct 9, 2020 at 7:25 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    @Professional Hand Model
    Doesn’t it look like the backing plate of the driver brake drum.......is pretty much flaked away?
    bmf4069 likes this.
  7. Oct 9, 2020 at 7:56 AM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
    the unpainted bolts look like an indicator of other rust that painted over.
    On my 06, there was far less rust and I live in VA. From my experience, the bolts on the undercarriage are almost all armor coat and don't rust as fast as zinc coated bolts. Those pictured bolts look bad. It boggles my mind why Toyota would replace an entire frame and not replace obvious visually worn out hardware. Replacing a frame is a huge undertaking.
    MS22 and bmf4069 like this.
  8. Oct 9, 2020 at 11:40 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I'd stay away. If those bolts are that bad, so are ALL the others. That would be a bitch to work on. Be patient and try to find a cleaner one, or one from the south.
    MS22 likes this.
  9. Oct 9, 2020 at 11:42 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Yes they are. They're supposed to be round. So that's a bunch of junk getting into the rear drums.
  10. Oct 9, 2020 at 2:13 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    As others have said, I'd keep looking. Be patient and you'll find the right deal, they are out there.
    MS22 likes this.
  11. Oct 9, 2020 at 2:16 PM
    Welcome from NY.
    I'd pass, keep looking.
    MS22 likes this.
  12. Oct 9, 2020 at 2:20 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Good lawd! For that kind of money, it should be super clean. The frame was replaced? Yikes..
    MS22 likes this.
  13. Oct 9, 2020 at 5:34 PM
    randomuser72
    2005 Tundra 4wd
    Appreciate y’all, I’ll keep looking, and learning from this form :cheers:
    bmf4069 likes this.
  14. Oct 9, 2020 at 10:01 PM
    bassman417
    Paul
    Las Vegas
    I got my 04 DC Jade 140k NO RUST for $7500 in LV. Dont give up, they are out there. where are you located @ Rando?
  15. Oct 10, 2020 at 3:01 AM
    randomuser72
    2005 Tundra 4wd
    I’m located in Texas, there just hasn’t been what I’m looking for locally unless it’s pushing 200k+ and priced about 10k
  16. Oct 10, 2020 at 6:46 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    What part of TX? There's no worries with 200k+ on these trucks.
  17. Oct 10, 2020 at 6:59 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    Pass.
    Even the rattlecan overspray on the shock is evidence enough that they are hiding as much as they can. I traded my Limited DC 06', clean as a whistle, 150k, every service record, every oil change, rotation, and anything else that truck did that can get a document, for $14k back in 2017. It was sold before I handed the keys over. Just saying a truck in excellent condition would still be less than what you're looking at.
    randomuser72[OP] likes this.
  18. Oct 10, 2020 at 8:31 AM
    randomuser72
    2005 Tundra 4wd
    @bmf4069 I’m a little bit outside of Austin, what about you?
  19. Oct 10, 2020 at 9:01 AM
    Rotaryphoneuser
    Rotaryphoneuser New Member
    Ontario. Canada
    2018 Cement CrewMax
    Pass. Way too much.
  20. Oct 10, 2020 at 9:22 AM
    035VZFE
    035VZFE Restored a Tundra top to bottom
    James
    Vero Beach, Florida
    2009 Passat B6 2.0 Turbo
    ECS Tuning DV Spacer ECS Tuning Turbo Muffler Delete ECS Tuning Luft-Technik CAI System A-Spec 60mm Charge Pipe Straight piped from resonator back, stock cat and downpipe
    No factory swaybar? :rofl:
    I would pass.
  21. Oct 10, 2020 at 12:16 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Amarillo. Austin is a good place to be. There's quite a few bick cities a few hours away to widen your search.
  22. Oct 17, 2020 at 11:13 AM
    randomuser72
    2005 Tundra 4wd
    EB63527B-37AE-464C-BFB2-E4087253100A.jpg Update: picked up a rust free 05 yesterday, single owner Texas truck, thanks for the advice y’all F53822E2-B5F7-4555-8E33-7FCBF8C91CC2.jpg
    bmf4069, Lil Steve, Luckydog and 6 others like this.
  23. Oct 17, 2020 at 11:17 AM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Looks great, uh, random........user.
    randomuser72[OP] and 035VZFE like this.
  24. Oct 17, 2020 at 4:12 PM
    bassman417
    Paul
    Las Vegas
    Score!!
    Tell us a little more.
    How much, how many miles, dont see the V8 badge, V6?
    Very nice DC Tundra BTW.
  25. Oct 17, 2020 at 7:39 PM
    randomuser72
    2005 Tundra 4wd
    Thanks! It’s mostly de-baged, but it’s got a v8, it’s 197k miles, and I paid about 10 for it, a little more miles and price then I wanted but it seems to have been taken care of really well.
    Popped the timing belt cover open for a peak, and, being a 60 series guy, I’m not too familiar with them, but to me it doesn’t look in dire needs of replacement, what do y’all think?9B564E12-699C-4FA8-9D44-DC1A93A24DBF.jpg
  26. Oct 17, 2020 at 7:49 PM
    pock
    pock New Member
    USA
    2005 Access Cab 4.7L V8 4x4 SR5
    Looks like he swapped the wheels out. Also the head lamb assemblies look new.
  27. Oct 17, 2020 at 7:53 PM
    SuperWhite20
    SuperWhite20 New Member
    Robert
    Georgetown TX
    2020 Tundra Crewmax SR5 4X4
    TRD Sway bar. Deck Rails, Maxliner rear floor mat, Driver side grab handle. Dee Zee bed mat
    Austin used to be a great place, but the Mayor has turned it into a pit.
  28. Oct 17, 2020 at 7:56 PM
    randomuser72
    2005 Tundra 4wd
    Correct, the wheels are from a newer Tacoma, I like the look of them. Not sure about the head lamps but the blinkers look after market to me.
    Yea I’m about 20 mins outside of Austin and try to avoid the city at all cost
    SuperWhite20 likes this.
  29. Oct 17, 2020 at 8:04 PM
    SuperWhite20
    Robert
    Georgetown TX
    We never had shootings and under bridge villages. But Adler allows it and has defunded Austin Police Dept.
  30. Oct 17, 2020 at 8:13 PM
    randomuser72
    2005 Tundra 4wd
    Driving around Lamar and Menchaca is depressing, the homeless villages have taken over. I haven’t been in actual down town in years
