What do you TOW with your Tundra?
Discussion in 'Towing & Hauling' started by T-Rex266, Jan 29, 2014.
  1. Aug 22, 2020 at 7:07 PM
    #2281
    SoFarKingFast
    SoFarKingFast New Member
    2019 Tundra 1794 Edition
    Bone stock
    Purchased.
    They might not make it in time for our trip, but it will be good to have a baseline for comparison.
    Ruggybuggy[QUOTED] likes this.
  2. Aug 22, 2020 at 7:10 PM
    #2282
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    PM me if would like a few pointers on the install.
    You might want to get them on before the trip. They are quite simple and quick to install.
    SoFarKingFast[QUOTED] likes this.
  3. Aug 22, 2020 at 7:46 PM
    #2283
    mikdes26
    mikdes26 New Member
    2020 Platinum (smoked mesquite)
    5C7B8EA2-E795-4B4A-AC8B-057161F20448.jpg Been towing this around lately. Lance 1685.
  4. Aug 22, 2020 at 8:14 PM
    #2284
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Lance sure does make a sweet TT.
    Jtundra81 and mikdes26[QUOTED] like this.
  5. Aug 22, 2020 at 8:34 PM
    #2285
    mikdes26
    mikdes26 New Member
    Love it so far. Not perfect, but tows great, really comfortable and functional, and I think it looks pretty good.
  6. Aug 22, 2020 at 8:41 PM
    #2286
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I use to have a Jayco Skylark that had the same windows the Lance has. Double pane, tinted and hinged at the top with built in screens and blinds. No condensation on cold days with a good R value.
    mikdes26[QUOTED] likes this.
  7. Aug 22, 2020 at 8:57 PM
    #2287
    Jtundra81
    Jtundra81 Just a member
    Joe
    2019 cement tundra crewmax
  8. Aug 22, 2020 at 10:20 PM
    #2288
    Jtundra81
    Joe
    How do
    what is your transmission temp towing?
  9. Aug 22, 2020 at 11:36 PM
    #2289
    FossilHunter
    FossilHunter New Member
    2017 Tundra TRD 4x4 Double Cab
    Any concerns with towing this set up with a 2017 DC SR5 5.7 w Tow pkg.? I currently tow a TT with about the same specs. Just wanted to double check with a few Tundra experts. Thank you in advance for your replies!
    Lance 2375
    Dimensions
    Floor Length 23'6''
    Overall Length 28'0''
    Exterior Width 96-3/8''
    Exterior Height w/Optional 13.5M A/C 10'2''
    Interior Height 78''
    Convertible Dinette Bed 42'' X 78''
    Weights
    Gross Dry Weight 5030 Lbs.
    Hitch Dry Weight 600 Lbs.
    Axle Weight 4430 Lbs.
    Cargo Carrying Capacity 1970 Lbs.
    GVWR 7000 Lbs.
    Bigboitundra likes this.
  10. Aug 23, 2020 at 12:40 AM
    #2290
    You shouldn’t have any issues with that camper. Enjoy it.
    FossilHunter[QUOTED] likes this.
  11. Aug 23, 2020 at 4:38 AM
    #2291
    Catmann1972
    Catmann1972 New Member
    Greg
    Rhode Island
    2020 TRD Sport
    I have used the Fires stone air bags in the past on my Tacoma. I am thinking on using the Sumo Springs on my new Tundra. I do have a question that maybe you could answer. When the sumo springs are mounted to the frame of the truck, do they hang over the axle or the leaf springs. Any chance you would have a pic.
    Thanks
  12. Aug 23, 2020 at 4:55 AM
    #2292
    booya69
    booya69 New Member
    Terry
    Maryland
    2020 Tundra SR5
  13. Aug 23, 2020 at 6:05 AM
    #2293
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    im pretty sure they mount to the leaf spring and impact the bump stop pad on the frame rail. Im hoping to install mine tomorrow afternoon
  14. Aug 23, 2020 at 6:11 AM
    #2294
    Catmann1972
    Greg
    Rhode Island
    2020 TRD Sport
    You would be correct. I found some you tube videos on the installation and they do in fact are mounted to the leaf springs. I think I will install the airbag system instead.
  15. Aug 23, 2020 at 6:18 AM
    #2295
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    The Sumosprings replace the bump stops and are secured using the U bolts that hold the axle and leaf spring together.
  16. Aug 23, 2020 at 6:38 AM
    #2296
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    When you install if your not a huge guy you can do the install without removing the tires or lifting the truck. Make sure the parking brake is on and the truck is on level ground. Spray penatraring fluid on the threaded part of the U bolts. Unbolt the U bolts one side at a time. Remove the plate at the bottom and slide the U bolts up to allow removal of the factory bump stop. Give the top of the spring a wipe with a rag to make sure it's free of sand and dirt. Insert the Sumospring and reinstall the U bolts and torque to spec. Make sure the U bolts are securing the Sumospring at the top and are straight vertically as you tighten the U bolts. You should have the same amount of bolt protruding from the nuts after you tighten the U bolts. Some say that you should replace the U bolts after removal but I've personally haven't seen a problem with reusing them if the U bolts are in good shape. Make sure to wire bush any corrosion and inspect the threads for damage.
    Hbjeff[QUOTED] likes this.
  17. Aug 23, 2020 at 7:27 AM
    #2297
    Catmann1972
    Greg
    Rhode Island
    2020 TRD Sport
    Thanks for all the info and the pic. It looks like their is minimal to no gap between the frame and the spring. This is a good sign. I have used Timbran's in the past and when you go over a bump the Timbran slaps the frame and gives the truck a hard ride. What I see on your truck doesn't look too bad. Is their any weight on the rear of the truck with these pics
  18. Aug 23, 2020 at 7:43 AM
    #2298
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    There is only a very slight gap. The truck has no weight in the back except for a hard tonneau cover that's about 60lbs and a rubber bed mat. The top portion of the Sumo is fairly soft and I didnt really notice much of a ride change.
    SoFarKingFast likes this.
  19. Aug 23, 2020 at 8:01 AM
    #2299
    Catmann1972
    Greg
    Rhode Island
    2020 TRD Sport
    This is all good information. Thanks for sharing :thumbsup:
  20. Aug 23, 2020 at 4:41 PM
    #2300
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Headed to the lake for a week. Camping in a tent with the family and throwing to the fish. Looking forward to an office break!
    Hopefully the smoke doesn't choke us out!
  21. Aug 23, 2020 at 5:24 PM
    #2301
    Bigjack
    Bigjack New Member
    If you were going to exclusively use your Tundra to pull a 7500lb gross travel trailer which Sumos would you go with?
  22. Aug 23, 2020 at 5:52 PM
    #2302
    Jetfan101
    Jetfan101 New Member
    Tom
    2013 black Tundra trd
  23. Aug 23, 2020 at 5:56 PM
    #2303
    Jetfan101
    Tom
    I a buying a 2013 I don't think it has integrated brake control? If you don't mind what control and hitch sway bar do you use? Thanks
  24. Aug 23, 2020 at 6:02 PM
    #2304
    Rabidllamas
    Rabidllamas New Member
    Phil
    WA
    2019 Cement Crewmax TRD OffRoad
    My build- https://www.tundras.com/threads/rabbidllamas-old-man-build.80802/
    In S4 towing our tt weighing roughly 4600lb. From E WA through pan handle of ID to Yellowstone so lots of climbs. Steep climbs would go to 255 but come back down to 215ish.
  25. Aug 23, 2020 at 6:20 PM
    #2305
    Jtundra81
    Joe
    Thanks, yeah I average 215 pulling my 4000lb travel trailer on s4 , it goes up when In traffic , up the hills in Vermont , around 217 -218 on pan and a bit higher on torque
  26. Aug 23, 2020 at 10:35 PM
    #2306
    A-A-Ron
    A-A-Ron Done messed up
    Aaron
    Seattle
    2021 Ford F-250 Lariat Diesel
    I’m doing a similar route right now. Went from western Washington to Missoula today, heading to west Yellowstone tomorrow. I pinned open the transmission cooler before I left, first time trying it. I’m running about 20 degrees cooler than my last trip, worst has been 225 in S4/S3 for far and mostly around 190. Pulling about 7,500# right now too.
    Rabidllamas[QUOTED] likes this.
  27. Aug 25, 2020 at 8:14 PM
    #2307
    SoFarKingFast
    Bone stock
    So, this IS NOT the goal, right? :)
    It is a 2500...the trailer was twice as long as you can see, and it had four more tanks of something on the back!
  28. Aug 26, 2020 at 6:23 AM
    #2308
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
    Driver: I can't even tell it's there.
  29. Aug 26, 2020 at 6:43 AM
    #2309
    spicychickentundie
    spicychickentundie New Member
    Danny
    SOMD
    2014 Barcelona Red Tundra SR5 CM 4x4
    TRD RSB
    Tows like a dream
  30. Aug 26, 2020 at 1:24 PM
    #2310
    Melikeymy beer
    Muscogee Nation
    While reading a towing forum today...
    Ruggybuggy likes this.
