What do you TOW with your Tundra?
Discussion in 'Towing & Hauling' started by T-Rex266, Jan 29, 2014.
  1. Aug 13, 2020 at 10:32 AM
    #2161
    faquino
    faquino New Member
    Freddy
    Tundra
    Its Winnebago Micro Minnie 5th wheel with those specs. 7ft wide instead of the normal 8ft wide. Love Toyotas everything I've own has been a Toyota except 1962 VW, don't wanna go to 3/4 or 1 ton.
  2. Aug 13, 2020 at 10:34 AM
    #2162
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    You also didn't say which body style you have. I've heard there's a high probability of hitting your back window with the front of the 5th wheel if you have a CM with the short (5.5 ft) box. And on certain older 5th wheels the pin is set farther back/ doesn't move forward for hitching so you actually need an 8 ft box. My grandfather found that with his 5th wheel but it's at least 20 years old.
    BravoDeltaRomeo likes this.
  3. Aug 13, 2020 at 10:39 AM
    #2163
    faquino
    faquino New Member
    Freddy
    Tundra
    They currently have what is a 5th wheel slide, that the pin is in the stock position while driving straight and on a turn will slide back giving you the room to make an almost 90 degree turn. It will return to stock position once you are driving straight once again. Haven't decided on what model I need to get, probably with the most towing capacity
  4. Aug 13, 2020 at 10:46 AM
    #2164
    aggie_tundra
    aggie_tundra Always Tired
    2021 2500 Custom
    A 3/4 to one ton if towing a 5th wheel honestly.
  5. Aug 13, 2020 at 10:55 AM
    #2165
    18" TRD Off Road Wheels
    And that's the downfall. Look at the sticker on your Tundra's door frame and see what it says your payload is. Most are in the 1200-1300 lbs range at best, so that trailer is going to eat that in a hurry and that is before you put propane, batteries, or water in the trailer. If you hauled it dry and didn't have any passengers or gear in the truck, you'd be ok. Realistically, you're going to be over your payload with that trailer on just about any 1/2 ton truck. You are shopping trailers in the 3/4 and 1 ton range.
    Doesn't stop lots of people from doing it anyway, and the Tundra pulls those things around just fine, but you will be doing it beyond the manufacturer's limits and recommendations.
  6. Aug 13, 2020 at 10:59 AM
    #2166
    faquino
    faquino New Member
    Freddy
    Tundra
    That's what I didn't want to hear. Might have to go with a regular travel trailer. Thnx to all
  7. Aug 13, 2020 at 12:04 PM
    #2167
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I would run it. You maybe be slightly over payload but almost everything you tow your going to be over payload. If you were looking to buy the same weight of a TT with the same GVWR of 7K you would have less payload on the truck but you would still be over. Personally I would rather have 1,200lbs in the bed of the truck than 600lbs on the bumper. The handling of the 5th will be much better than the TT and no sway concerns. You are going to require either air bags or sumosprings to help with the weight and your should upgrade to 10ply tires.
    For reference, I tow a Coachman 204RD with a weight of around 5.5k and I'm over payload. I have a 2020 double cab 4X4.
    Bigjack likes this.
  8. Aug 13, 2020 at 1:05 PM
    #2168
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
    I try not to be that guy, lol. But seriously, when do you become the weight police? If someone asks if their truck, with a payload of 1,200 pounds, can safely tow a trailer with a pin weight of 1,200 lbs dry, do you....
    A: tell them, fuck yes, this truck can tow a space shuttle
    B: suggest that might be a little too much weight
    C: ignore the post, so you don't become the hated Tow Police, which they are currently trying to defund, if I understand the news correctly.
    16MagSR5 and GODZILLA like this.
  9. Aug 13, 2020 at 1:09 PM
    #2169
    Provide the info, and let them decide for themselves.
  10. Aug 13, 2020 at 1:23 PM
    #2170
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I'm just the opposite of the weight police. The payload decal on the Tundra is BS. 1200lbs in the bed of the truck isnt going to make it unsafe. Just to put in perspective my 2015 Camry has a higher payload than my 2020 Tundra. After weighting my truck and doing the math I can only carry 813lbs. My Camry can carry over 900lbs. Still think the payload number makes sense? Many on the forum have towed fifth wheels and have no issues but no one mentions it because forum members tend to get a little too excited about it (weight police).
    Camry
  11. Aug 13, 2020 at 1:35 PM
    #2171
    Melikeymy beer
    Muscogee Nation
    But a pin weight of 1,200 dry is not going to just put 1,200 lbs in the bed, right? It could put 1,500 in the bed, and then add possibly 400 or more inside the truck.
    Anyways, I usually select my option 3 and just MMOB, lol.
  12. Aug 13, 2020 at 1:36 PM
    #2172
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Nope, his pin weight was just over 1k dry.
  13. Aug 13, 2020 at 1:37 PM
    #2173
    Melikeymy beer
    Muscogee Nation
    I wasn't talking about him. It was hypothetical.
    Edit: and intended to just be humorous.
  14. Aug 13, 2020 at 1:41 PM
    #2174
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I'm not saying you can tow any 5th wheel but going a little over payload isnt going to result in an unsafe tow. Common sense must prevail.
  15. Aug 13, 2020 at 1:44 PM
    #2175
    Melikeymy beer
    Muscogee Nation
    Exactly, but some consider you Tow Police if you advise against hauling shit that's 500 lbs over payload. I think there's actually a sticky thread on here about that. Or it could have been TacomaWorld. IDK.
    Ruggybuggy[QUOTED] likes this.
  16. Aug 13, 2020 at 2:04 PM
    #2176
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    The “new” setup
    Bigboitundra and Prostar 190 like this.
  17. Aug 13, 2020 at 2:08 PM
    #2177
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I'm more interested in that boat...
  18. Aug 13, 2020 at 2:13 PM
    #2178
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    You and me both, new neighbors that just moved in across the street. I'm envious, AXIS wake surf boat. The "budget" Malibu. It's summer and it hasn't been out yet in the 3 weeks they've been here....for shame! Hahahaha, some day
  19. Aug 13, 2020 at 2:35 PM
    #2179
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    New Axis A20 starts at $74k... :crazy:
    AZBoatHauler likes this.
  20. Aug 13, 2020 at 3:02 PM
    #2180
    AZBoatHauler
    So.Arizona
    I have a feeling the boat market bubble is about to burst. My 2011 Axis is worth just as much or more today than when I bought it 4 years ago. It has depreciated about $10-12k over its 9 year life. Even beats out a Tundra on resale!
  21. Aug 13, 2020 at 8:11 PM
    #2181
    faquino
    faquino New Member
    Freddy
    Tundra
    I've heard the from people who own Tundra's that it pull like crazy. There's a guy on YouTube that pulls a 5th wheel. I just retired and would like the reliability of the Tundra to go cross country. Any new on the 2022 Tundra's Hybrid / Twin Turbo with a smaller engine but higher towing capacities? Don't wanna wait two more years.
  22. Aug 13, 2020 at 10:54 PM
    #2182
    Highsierraguy
    Highsierraguy New Member
    Nor Cal
    I hope you're right. I'm sick of seeing people trying to sell their 2001 Ski Nautique for 18k.
  23. Aug 14, 2020 at 4:20 AM
    #2183
    Haggis777
    Haggis777 I.L.J.C.M.L.
    SW Michigan
    2015 Silver SR5 TRD Tundra Canadian Model
    LEDs interior & exterior, stubby antenna, Bak-Flip cover, 285's, AGM battery, block heater, Pine tree air freshener
  24. Aug 14, 2020 at 5:08 AM
    #2184
    So we ask what you tow, you say a badass classic, and then you tease us with that bullsh:censored:t picture? :rant:
    :worthless: MORE PICS!
  25. Aug 14, 2020 at 5:44 AM
    #2185
    Haggis777
    SW Michigan
    Sorry, bro....
    1969 RS SS Camaro
    (Owned 20 years this summer!)
    - 427 big block
    - Power windows!
    - 4 speed
    - Original A/C car
    - One of only ~2,500 with M-22 'Rock Crusher' transmission
  26. Aug 14, 2020 at 5:50 AM
    #2186
    Seeing the old classics like that.... I was born in the wrong decade. :rofl:
    That thing is gorgeous. Love that it doesn't have 23" wheels, hasn't been slammed to the ground, had the ass lifted, or been molested in other terrible ways.:fistbump: I bet it sounds glorious too.:drool::drool:
    johnnyv5, kparrow and Cpl_Punishment like this.
  27. Aug 14, 2020 at 8:08 AM
    #2187
    ka1sersoze
    ka1sersoze Newish
    Aaron
    '20 DC 4x4 limited TRD cement
    3" toytec coils,18x9 fuel tactic, 35s
    love when I see a triple tow going by
    kparrow[QUOTED] likes this.
  28. Aug 14, 2020 at 8:25 AM
    #2188
    WBW
    WBW Resident lurker
    Bruce
    Surface of the Sun - AZ
    2015 CM Tundra SR5 2WD
    Beautiful car!!! Awesome that you've owned it so long and taken care of it so well.
  29. Aug 14, 2020 at 10:01 AM
    #2189
    Haggis777
    SW Michigan
    Thank you....I have attempted to leave it as classic as possible.
    After owning it a few years, I found out an interesting and coincidental tidbit:
    The last 1969 Camaro was produced
    on Feb. 26, 1970...
    The date I was born...
  30. Aug 14, 2020 at 10:04 AM
    #2190
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I want to see him back it up. :D
