What do you TOW with your Tundra?
Discussion in 'Towing & Hauling' started by T-Rex266, Jan 29, 2014.
  1. Feb 27, 2020 at 9:54 AM
    #1711
    AZBoatHauler
    So.Arizona
    If it isn't too late, you might want to consider +2 shackles as the +2 shackles actually only give you 1.25" of lift per CB website.
    https://shop-coachbuilder.myshopify.com/
    Bad Cow likes this.
  2. Feb 27, 2020 at 10:27 AM
    #1712
    KeetAz
    KeetAz New Member
    Gilbert AZ
    2020 SuperWhite PRO
    I don’t like the look of the +2’s. I’m trying to keep my level look as much as I can. And if I don’t have to do shims, I don’t want to do them. It’s a freakin small utility trailer for gods sake! I hate the fact I even have to do shackles!!! (Even though I’ve heard the CB are awesome regardless of my towing situation)
    AZBoatHauler[QUOTED] likes this.
  3. Feb 27, 2020 at 10:33 AM
    #1713
    Bad Cow
    Bad Cow GOD Bless The USA
    Georgia USA
    2019 TRD PRO - SUPER WHITE
    Leather Steering Wheel, +1.5" Shackles
    Shackles are great, but for me, I think the air bags are a better solution. And after speaking with another forum member who advised me of the DayStar Air Bag Cradles, the air bags will not limit my trucks suspension articulation. Best of both worlds.
    AZBoatHauler likes this.
  4. Feb 27, 2020 at 10:35 AM
    #1714
    KeetAz
    KeetAz New Member
    Gilbert AZ
    2020 SuperWhite PRO
    Sorry Cow, I posted my reply before chiming in on your setup. Totally agree with you on your desired setup. I’m sure that badass boat weighs a tad more than my quad. Sounds like that will work great for your needs!
    Bad Cow[QUOTED] likes this.
  5. Feb 27, 2020 at 10:42 AM
    #1715
    Bad Cow
    Georgia USA
    Still have not decided WHEN this will happen. The truck tows that boat just fine, with very minimal sag, so no big hurry. And yes sir that is a BadAss Boat. Bought it because we fish the Inshore Bay down at Apalachicola. We run in very shallow water, like 12 inches. This boat is a tunnel hull with flotation pods and hydraulic jack plate. It can hole-shot in 10 inches of water, and run in 6 inches. NEVER going to try that of course, but I'm done with getting stuck in the grass flats at low tide.
  6. Feb 27, 2020 at 10:43 AM
    #1716
    KeetAz
    KeetAz New Member
    Gilbert AZ
    2020 SuperWhite PRO
    You just said a bunch of crazy s**t I don’t understand, but it sounds cool!!
    GODZILLA and Bad Cow[QUOTED] like this.
  7. Feb 27, 2020 at 10:48 AM
    #1717
    Bad Cow
    Georgia USA
    My bad, it's all boating & fishing talk. :facepalm:
  8. Feb 29, 2020 at 9:33 AM
    #1718
    Hatwsneezing
    Hatwsneezing New Member
    Old Post but in the same situation. What did you figure out or do?
  9. Feb 29, 2020 at 9:57 AM
    #1719
    19crewmaxTRD
    19crewmaxTRD Tundra Enthusiast
    Seth
    2019 white tundra crewmax
    Wdh does remove some tongue weight by shifting it to the front axle and the trailer axles and while the weight shifted to your front axle still counts against your payload what is put only the trailer doesn't. The other thing that really helps is load everything you can into the trailer, clothes, food, drinks, bikes and other toys. That keeps the weight off the truck. And with proper loading can offset the weight of propane tanks and the batteries
  10. Feb 29, 2020 at 10:05 AM
    #1720
    A-A-Ron
    A-A-Ron Done messed up
    Aaron
    Seattle
    2021 Ford F-250 Lariat Diesel
    I have a Grand Design 2800BH, specs are 6,200# dry and 600# hitch. Only have done a couple trips so far but it has gone well. One thing to keep in mind is that our trucks rating is based on SAE standards, includes 300# of passengers and #100 of hitch plus a full tank of gas. Realistically I know my hitch weight is over 800# once I’m on the road. I don’t put much in my truck and I put some of the gear in the back of the trailer. You could get a hitch scale from Amazon for about $130. This could allow you to balance your weight of stuff in the trailer to keep your hitch weight at 10%. Meeting the payload rating is a bigger obstacle than the overall weight. Not planning to travel with water since I am pushing the limits already. Obviously you will need a weight distribution hitch also.
    Hatwsneezing[QUOTED] likes this.
  11. Feb 29, 2020 at 10:37 AM
    #1721
    Hatwsneezing
    How'd you figure your hitch weight being 800?
  12. Feb 29, 2020 at 10:39 AM
    #1722
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    Not a darn thing...:rofl:
  13. Feb 29, 2020 at 12:53 PM
    #1723
    Bad Cow
    Georgia USA
    After checking out SO many products that assist with towing, such as air bags, shackles, etc... I think I have found what I prefer over them all. I'm sure it's Old News to some of you guys, but it's New to me. The RoadMaster Active Suspension system. Wow, it don't get much more simple than this. No you can't adjust your ride height, but all I want is for my truck not to SAG when towing, and to ride smooth when NOT towing. I like this product for it's KISS acronym (keep it simple, stupid).
    Hatwsneezing likes this.
  14. Feb 29, 2020 at 10:48 PM
    #1724
    A-A-Ron
    Aaron
    Seattle
    I believe my listed 600# hitch weight is without the propane tanks and battery. Also including the weight for my bins in the front pass-thru storage. It’s an approximation but I’m tempted to buy a hitch scale to help balance out the trailer.
  15. Mar 1, 2020 at 7:20 PM
    #1725
    cforman61
    cforman61 Pupper
    Chuck
    Highlands Ranch, Colorado
    2019 Tundra SR5 TRD CrewMax
    I use a hitch scale on mine. I like being able to check it when I change things up with the camper.
  16. Mar 9, 2020 at 7:38 AM
    #1726
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Picked this up on Saturday. 1992 and 32’. Got it for free since it needs some work. Soft floor in the back but no water signs and everything is dry. Had no safety chains, trailer brakes (weren’t working), wdh and only one taillight worked. Had someone behind us following and limped it home. Barely went over 35. With all things considered, the tundra handled this like a dream. I wasn’t winning any races but I was shocked how well the tundra held the road. First time towing with this truck. Camper is 5100lbs dry and 840# tongue weight.
    Camper WILL have brakes, chains, lights, and WDH before we move it again.
    Note: The camper has sat at the campground since 92. A tractor pulled (dragged) it out of it's home and to the spot where this picture is taken. We hooked it to the truck to hold while we jacked it up to swap some new rims/tires
    316KS_Runner, Prostar 190 and Bad Cow like this.
  17. Mar 9, 2020 at 7:50 AM
    #1727
    Bad Cow
    Georgia USA
    Man, that Tundra will tow that trailer like nobody's business.
  18. Mar 9, 2020 at 8:01 AM
    #1728
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    For sure. I pulled a 21' 2300# dry camper with my Tacoma. I felt that in my bones. Driving straight down a road, I could barely tell the camper was behind. Really impressed.
  19. Mar 10, 2020 at 4:39 PM
    #1729
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    99 sun ridge, king beds on each end
  20. Mar 10, 2020 at 7:04 PM
    #1730
    70fj4045
    70fj4045 New Member
    Carl
    Connecticut
    2019 White Trunda TRD PRO
    Driver side grab handle, AMP Power steps, Front window tints, TRD Front & Rear Sway Bars, rear bumper step,TruXedo Tonneau cover.
    truck was a week old, 4600 dry, 6000 loaded running a Anderson wdh with built in sway, pulled like dream.upload_2020-3-10_22-3-12.jpg
  21. Mar 10, 2020 at 7:09 PM
    #1731
    70fj4045
    70fj4045 New Member
    Carl
    Connecticut
    sorry about the double pics, new at this...
  22. Mar 11, 2020 at 3:11 AM
    #1732
    Bad Cow
    Georgia USA
    You might want to look into the Roadmaster Active Suspension. That's what I have decided on for my PRO to tow my boat. Love the concept and simplicity.
    yoshi82 likes this.
  23. Mar 11, 2020 at 5:08 AM
    #1733
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Do you have a picture of these installed?
  24. Mar 11, 2020 at 6:05 AM
    #1734
    Bad Cow
    Georgia USA
    Not on my truck yet. But here is how they fit your springs, pretty straight forward. They prevent the leaf springs from flattening out. Hold the rear end up, prevent sway. Best of all there's ZERO maintenance, not air bags, no lines, no compressor. Just adjust them to the ride height and tension you prefer and roll with it. I like KISS (keep it simple, stupid). Simplicity and function is the way to go.
  25. Mar 11, 2020 at 6:10 AM
    #1735
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I like the concept. I'm curious about clearance issues. Aren't the Tundra's leaf springs relatively flat similar to the Tacoma? 2nd Gen Tacomas are nearly flat without any weight.
    With that said though, i was thinking with weight, springs will want to flatten some, this will prevent it. AND they have adjustment nuts to tighten up the leaf's if needed.
    When you get yours on, do a review on them for us here and let us know what you think post-install!
  26. Mar 11, 2020 at 6:17 AM
    #1736
    Just skip to 6:55 and see how this F150 is jacked up in the rear. Unless you have the static load all the time (topper, tool boxes, ladder rack), this might not be the way to go.
    For me, a properly sized and set up LDH is the way to go.
    Jaypown, ezdog and Bad Cow like this.
  27. Mar 11, 2020 at 6:37 AM
    #1737
    stewtopia
    stewtopia 4RunningTundra
    Stew (nickname)
    Masshole
    What I like about my air bags is that I can dial in depending on load.
  28. Mar 11, 2020 at 6:38 AM
    #1738
    stewtopia
    Stew (nickname)
    Masshole
  29. Mar 11, 2020 at 6:53 AM
    #1739
    ezdog
    ezdog New Member
    Gateway To The West
    Mostly these with my '01!
    I need to wash that Casita badly too.
    57CC2B0E-10B6-4E2B-AE74-4E45630A0605.jpg 73DFC210-036D-4CAD-8B70-5F7AC4A7557A.jpg 50B90C34-EF04-4034-A230-BDACA8FEA862.jpg 4A83EB39-F2E3-4ADA-9809-959994C440A7.jpg
  30. Mar 11, 2020 at 6:59 AM
    #1740
    Warreng
    Warreng New Member
    If you like simple, have a look at hellwig helper springs. Used them on my gen1 because I put a 1 snowmobile/sled deck in the bed (800lb or so). They worked great and no harsh ride unloaded.
