What do you TOW with your Tundra?
Discussion in 'Towing & Hauling' started by T-Rex266, Jan 29, 2014.
  1. Sep 18, 2019 at 11:01 PM
    #1561
    Jmad1997
    Jmad1997 New Member
    What ski carrier is that?
  2. Sep 18, 2019 at 11:34 PM
    #1562
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    https://ez-ski.wixsite.com/ez-ski
    Ez ski v2. Check them out on the PWC forums. That's where I found it with Google.
  3. Sep 19, 2019 at 3:16 PM
    #1563
    Sambo
    Sambo New Member
    Justin
    18 CrewMax Limited
    Not sure what the exact weight was but it was pretty heavy. Good think to mention about tundras is that 18 year old, 190,000 mile truck carried it 52 miles with no issues.
    Watt maker likes this.
  4. Sep 21, 2019 at 6:36 PM
    #1564
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
    So I went out to storage to level my new RV and decided to see how the trailer weight affected the truck. I measured to the top of my front wheel wells then dropped the trailer on the ball without the WDH arms attached. It barely moved. Like 1/4 inch maybe. This trailer has a hitch weight of about 550.
  5. Sep 23, 2019 at 6:12 PM
    #1565
    Dogfishlake
    Dogfishlake New Member
    2017 SR5 Crewmax 4x4
    @nuclearlemon , that's awesome! I saw your post before I noticed your username, and thus who you are. Didn't know you had a Tundra, but that figures. I'm new here but is a great place. Looking forward to hauling cruisers with my Tundra too!
    See you on mud!
    nuclearlemon likes this.
  6. Sep 23, 2019 at 10:12 PM
    #1566
    Jmad1997
    Jmad1997 New Member
    Can’t even tell it’s behind the truck. I’d love to get a camper or boat now that I actually have a truck that can pull something.
    Prostar 190 and Bigboitundra like this.
  7. Sep 24, 2019 at 5:50 PM
    #1567
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
  8. Sep 25, 2019 at 8:43 AM
    #1568
    CO_Native
    CO_Native New Member
    Englewood, CO
    2024 Limited CM Silver/Nightshade
    Just got back from South Dakota, each trip is better than the last with this truck. Damn I love it.
  9. Sep 25, 2019 at 9:12 AM
    #1569
    Bulldogz71
    Bulldogz71 New Member
    Clayton
    2018 Tundra CrewMax 4x4
    TRD Pro conversion in progress. Replaced every bulb on truck with LED. Ranch Hand brush guard.
  10. Oct 19, 2019 at 2:58 PM
    #1570
    rodm1
    rodm1 New Member
    What drop is best for a general purpose ball mount on factory stock trucks? I have a 6" and its way to much drop thinking 2" what is recommended?
  11. Oct 21, 2019 at 5:07 AM
    #1571
    spicychickentundie
    spicychickentundie New Member
    Danny
    SOMD
    2014 Barcelona Red Tundra SR5 CM 4x4
    TRD RSB
    The drop depends on what you tow. Need to see what is required for your trailer. All trailers are different.
    ColoradoTJ likes this.
  12. Oct 21, 2019 at 6:48 AM
    #1572
    dlowry81
    dlowry81 New Member
    Doug
    2004 Tundra Doublecab
    ^^^^What he said....buy a B&W and then never have to worry about it.
    runCMD likes this.
  13. Oct 21, 2019 at 1:05 PM
    #1573
    GreatBigAbyss
    GreatBigAbyss New Member
    2018 Tundra CrewMAX SR5 TRD Off-Road
    Towing a 7'x12' dump trailer this weekend with my truck. I was going around the neighbourhood helping people remove fallen branches from a storm we had last week. Trailer weighs about 5000lbs TARE, with a 10000lb capacity. The heaviest I got it to was 7500lbs Gross. I did about 8 dump runs this weekend. Was at it for 16 hrs.
    The truck drove absolutely fine. I could definitely feel the weight when accelerating, but as far as stability at speed, the big heavy Tundra (more like a 3/4 ton than a 1/2 ton amiright?!?) was absolutely stable and unaffected by the trailer.
  14. Oct 21, 2019 at 1:16 PM
    #1574
    HTGreen
    HTGreen New Member
    Halsey
    Central Virginia
    2018 SR5 TRD Tundra Quicksand
    If you are interested in an Airstream, read up on AIRFORM. We have a 1977 23 foot dual axle, they were made heavy at that time, 6400 pounds loaded on a year long trip. The design makes towing seam effortless.
  15. Oct 21, 2019 at 1:17 PM
    #1575
    HTGreen
    HTGreen New Member
    Halsey
    Central Virginia
  16. Oct 22, 2019 at 5:00 AM
    #1576
    spicychickentundie
    Danny
    SOMD
    TRD RSB
    I've heard of people running small side businesses with dump trailers. Typically these folks have 2500/3500's and diesels, so they can tow a much larger trailer. I've considered getting one of the 10k lb capacity ones and running small loads of material for people.
  17. Oct 22, 2019 at 5:39 AM
    #1577
    MAGDADDY
    MAGDADDY TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    Leer 100XL, Bedrug, Go Rhino running boards, LED int/ext lighting, Bilstein 6112/5100 1/2”shims up front, Coachbuilder +3 shackles, CB drop, TRD front/rear sway bar, 275/65/20 Michelin LTX M/S 2, sequoia painted mirror cap/door handles, Rago Fab low pro ditch brackets, Baja Designs S2 sports ditch lights. Baja Designs S2 sport rear flush mount pod
    This was a tad embarrassing, had to tow this dingy 1,000 miles from Colorado to Texas.
    Prostar 190 likes this.
  18. Oct 22, 2019 at 7:45 AM
    #1578
    Pariverpirate
    Pariverpirate New Member
    Rich
    2015 Tundra TRD Off Road
    Non yet
    See if you had a double cab instead of that crew you could have just put the trailer stuff in the bed of the truck , lol
  19. Oct 22, 2019 at 8:15 AM
    #1579
    GreatBigAbyss
    Honestly, for that size of trailer, the Tundra was perfectly suited. I would have no issues using a Tundra to pull a loaded trailer of that size every day for business purposes. And when you consider that my truck is likely $20-$30k cheaper than a well equipped 3/4 ton diesel, well, it's an interesting value proposition.
    For example, a SuperCrew F250 Lariat with the 6.7 diesel and 4x4 is $61 370 USD, while a CrewMax Tundra limited 4x4 is $42 120 USD. If all you're doing is running a small landscaping business, and you don't need anything more than a 10 000lb trailer, you really don't need to spend extra on the Super Duty, just get the Tundra. It will handle the load and do the work just fine.
    These Tundra's are heavy beasts, and can therefore handle a heavy dump trailer better than you would think.
  20. Oct 22, 2019 at 9:17 AM
    #1580
    MAGDADDY
    MAGDADDY TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    All you double cab folks are the same! :rofl: Jk, I had a double cab prior to this one and bed space was perfect, but when we travel the dc was a bit tight.
    biebs96 likes this.
  21. Nov 8, 2019 at 3:02 PM
    #1581
    TxTaco
    TxTaco New Member
    2019 White 1794
    Pulls it very well ... love my Tundra
  22. Nov 8, 2019 at 3:32 PM
    #1582
    Squeaky
    Squeaky New Member
    Wisconsin
    ‘19 White TRD Pro
    Looking forward to pulling this with my new Tundra. My taco worked surprisingly well, but you definitely knew it was back there.
  23. Nov 8, 2019 at 3:44 PM
    #1583
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    1986 Toyota Corolla GT-S TRD N2 Supercharge
    Warreng, drobb and Prostar 190 like this.
  24. Nov 10, 2019 at 6:05 PM
    #1584
    wakeboarder
    wakeboarder New Member
    13 Tundra
    My Tundy tows my boat so much better than my old Avalanche did.
    Winterized the boat today. Gonna be a LONG winter...
  25. Nov 10, 2019 at 6:43 PM
    #1585
    biebs96
    PA
    12’ x 6.5’ utility trailer
    Upgraded some things like all the lights to LEDs, the axle from a 3500lb to a 5k and the springs from 3k to 5k and the tires from stock to 10 ply RV tires.
    I’ve beaten the crap out of it. And it is way cheaper to fix then my truck.
    drobb, Prostar 190 and Casper3 like this.
  26. Nov 10, 2019 at 6:48 PM
    #1586
    For sure going to be a long winter. I was cleaning on mine today dreaming of summer.
  27. Nov 10, 2019 at 8:38 PM
    #1587
    KMG
    KMG New Member
    Kevin
    Yacolt, WA
    2018 White Tundra Limited DC 4x4 TRD
    BFG KO2s, TRD Rear Sway Bar, Firestone RideRite Air Bags, B&W Gooseneck Hitch, Trail Ridge Extendable Towing Mirrors
  28. Nov 11, 2019 at 4:01 PM
    #1588
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    Winterize!?!!? What the heck is that!?!!
    I'm hoping to spend Christmas on my boat this year.
  29. Nov 11, 2019 at 6:05 PM
    #1589
    Boy that would be great.
    Taco-Blender[QUOTED] likes this.
  30. Nov 12, 2019 at 9:43 AM
    #1590
    GreatBigAbyss
    I LOVE that trailer. What a beauty. Does it have bunks at the back?
    Mike19 likes this.
