What do you TOW with your Tundra?
Discussion in 'Towing & Hauling' started by T-Rex266, Jan 29, 2014.
  1. Jul 25, 2019 at 6:00 AM
    #1471
    redryder
    redryder New Member
    Ryder
    Louisiana
    2018 Limited Cement CM
    That's what I'm worried about. I love my tundra but don't want to be stuck with the smallest trailer and lose out on jobs because of it.
    Watt maker likes this.
  2. Jul 26, 2019 at 2:12 PM
    #1472
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    Just picked this sucker up. Can’t wait to get out camping. 1986 Fleetwood Prowler Lynx 24’.
    Looking to get a WDH with sway control, looking at the Fastway E2 2 point 600/6000. Trailer only weighs 3100 dry and max is supposedly only around 5k. I’m going to take it to the scale and verify. Anyone have this hitch and does it perform well? Truck didn’t even know the thing was back there just on a ball, but I need the sway control for sure.
    6K RB Fastway e2 2-point sway control hitch https://www.amazon.com/dp/B0071L3H2E/ref=cm_sw_r_cp_api_i_DT2oDbP9RQ1S6
  3. Jul 26, 2019 at 3:40 PM
    #1473
    Redstag
    Redstag New Member
    Summerland B.C.
    2019 Tundra trd offroad
    275/70r18 ko2 Chrome delete grill Chrome delete rear bump caps Tonneau Linex berliner ...old man emu coming
    One of our trailers, enclosed Workshop. We call it the shack. Sits right around 6,500 lb.
    The coach Builder +3s seem to make a big difference in ride when towing
  4. Jul 26, 2019 at 8:08 PM
    #1474
    YeeYeeTundra
    YeeYeeTundra Earl Dibbles III incarnate
    Ohio
    2018 Quicksand CrewMax Limited TRD
    Extang tri-fold tonneau cover, havoc hs2 steps, A1 tow mirrors, TRD RSB, weathertech mats, 24' Puma BH travel trailer, Yeti 75, LineX
    I've towed using this before (about 10 hours round trip). It performed very well on approx. 20' trailer weighing about 3200#. No issues and barely felt it behind me. I liked the set up. (Tow vehicle '14 CM). Trailer looks in good shape.
    kparrow[QUOTED] likes this.
  5. Jul 26, 2019 at 8:20 PM
    #1475
    legger99
    legger99 New Member
    The U.P. - MI
    2017 Tundra
    I had the square bar version in 6k when I had my smaller camper, but now have the 10k version for my bigger one.
    Fastway e2 square bar:
    https://www.amazon.com/dp/B0071L3T3G/ref=cm_sw_em_r_mt_dp_U_Xa8oDbZK4D48H
    I have no complaints. I did add the pads to quiet the bars down
    Hitch Pads:
    https://www.amazon.com/dp/B007HRJNIE/ref=cm_sw_em_r_mt_dp_U_Rd8oDbFZ4MEWQ
    I also transferred these to the new hitch. I don't see any adverse effects other than the hitch is a lot quieter.
    I am still dialing in the bigger hitch it has no sway, truck just seems to float at times. Could be the narrow roads or the rv length + weight. I did just get the extended shank (6" longer) to allow the tailgate open when hitched and this changed the alignment a little bit (dropped 3/4").
    I really wish I had a CAT scale closer to me.
  6. Jul 26, 2019 at 8:43 PM
    #1476
    I have a Fastway E2 and really like it. I will be using it on Monday after not needing it for about a year.
    Mine is the 1200 lb one, but function the same. Lots of adjustability in these LDH.
    Watt maker and kparrow[QUOTED] like this.
  7. Jul 26, 2019 at 11:26 PM
    #1477
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    Thanks for all the input guys! @legger99 , what shank did you go with? The tongue on this trailer is pretty short and I’d like to not have to worry about cranking the trailer into my tailgate and bumper. Is it the Curt 10” long extended shank or 15”?
  8. Jul 27, 2019 at 1:10 PM
    #1478
    Speedkills119
    Speedkills119 Shenanigator
    Ryan
    2017 Silver Tundra 1794
    Mostly Stock Procomp 4" lift Prospeed cold air intake Bakflip bed cover HID head and fog lights 2000W JL Audio build Magnuson supercharger w/ Sniv Pulley AR Headers/full exhaust Auburn Limited Slip Prospeed fuel system w/ 1000cc injectors Dual 450 in tank fuel pump 2nd pump on a Hobbs boost reference switch Lexus RCF throttle body Prospeed catch can system TRD sway bar Prospeed Flex Fuel Tune Dirt Logic coil-over and shocks VR forged wheels CalTracs Nitto 420V 305/50R18
  9. Jul 27, 2019 at 7:31 PM
    #1479
    legger99
    legger99 New Member
    The U.P. - MI
    2017 Tundra
    I purchased this shank: https://www.etrailer.com/Accessories_and_Parts/Equal~i~zer/EQ90-02-4500.html
    My RV has the lippert electric tongue jack and this allows the tailgate to drop and a little extra room between truck and camper as mine also has a short tongue because the body protrudes forward.
    And had to purchase these for chain extensions: https://www.etrailer.com/Accessories_and_Parts/Blue_Ox/BX229-0512.html
    They were the only ones I could find that were rated for 10k, my trailer GVWR is 8200, 6700 empty. and I didn't want to mess with extending the trailers chains.
    The trailer harness and breakaway cable reached fine (another thing to consider).
    I will also say I have LT Michelin Defenders and added the TRD sway bar and didn't tow this trailer without them. My old trailer was about 4000 lbs and I didn't really use much WDS, but more for sway as that camper was single axle and moved around.
  10. Jul 29, 2019 at 6:25 AM
    #1480
    HighonFirewood
    HighonFirewood Everything can be fixed with a hammer.
    Stage Left. Colorado
    2019 Tundra
  11. Jul 29, 2019 at 6:30 AM
    #1481
    buckeyes1975
    Kevin
    OH-IO
    2008 Limited Double Cab
  12. Jul 29, 2019 at 6:49 AM
    #1482
    HTGreen
    HTGreen New Member
    Halsey
    Central Virginia
    2018 SR5 TRD Tundra Quicksand
    I ended up with a Big Tex 12 foot, 9990 gross dump trailer, filled with 3 tons of gravel, the tundra does a good job of towing it. Here in Virginia the state is getting anal about 1/2 ton pickup towing over 10,000 lbs. I already had Air Lift bags, but if you don't have them, you will need them to end the squat.
  13. Jul 29, 2019 at 10:18 PM
    #1483
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    With everyone on here that pulls travel trailers, what are you all running for tires on your trailers? I’m wanting to avoid “china bombs” and have the least likelihood for a blowout. On the trailer now is 205/75/r15.
  14. Jul 30, 2019 at 7:50 AM
    #1484
    TundraPro2019
    TundraPro2019 New Member
    Barthold
    Western Slope, CO
    2019 Tundra TRD Pro
    KO2s, exactly for the reason you state.
  15. Jul 30, 2019 at 9:49 AM
    #1485
    spicychickentundie
    spicychickentundie New Member
    Danny
    SOMD
    2014 Barcelona Red Tundra SR5 CM 4x4
    TRD RSB
    KO2's on your trailer?!
  16. Jul 30, 2019 at 12:11 PM
    #1486
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    I would not run a car tire on your trailer. They are different than trailer tires.
    I bought Tow Master tires from Costco. Read good reviews on them, and obviously Costco has excellent customer service and warranty. Goodyears are also a good tire but $$$. My dad has had a lot of problems with Dico and Carlisle tires, I would stay away. (Bubbling and catastrophic blowouts on newer, good condition tires.)
  17. Aug 4, 2019 at 1:24 PM
    #1487
    Corr2626
    Corr2626 New Member
    Corey
    2014 Tundra Limited
    What's going on everybody. Got a towing/weight question for all you experienced towers. I just put a deposit down on a beautiful 2013 Forrest River Shockwave 26FQDX for our first trailer. I have a 2014 CrewMax 4x2 5.7 with the 5.5 bed tow package and just installed brake adjuster and Firestsone bags. Will be getting a good 4 point WDH as well. I know my biggest issue is the tongue weight but I don't plan on getting close to the trailers max weight and actually plan on keeping it under 9k as much as possible and only passengers in truck during travel (No other cargo, ie clothes). With the specs I know below, am I getting over my head or what? TIA
    Truck:
    Actual weight = somewhere around 5,800
    GVWR = 7,000
    TWR = 10,000
    GCWR = 16,000
    Trailer:
    Dry weight 7,219 (Posted on label, I know will be more) 100 gal water @ 833 pound (IF* if filled it all the way up)
    GVWR = 11,550 ( I plan on being around 9,000-9,500 max)
    Tongue weight = ??? (I can't get an official one or idea anywhere. 10-15% right???
  18. Aug 4, 2019 at 9:21 PM
    #1488
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    Tongue weight will be 1100 lbs plus probably. Seems like too much trailer honestly
    ColoradoTJ and Corr2626[QUOTED] like this.
  19. Aug 7, 2019 at 7:25 PM
    #1489
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    Our, new to us, 1989 C-Dory 22' cruiser. Just drove 1838 miles to Ohio to pick it up and now "boaterhome" our way back to AZ with it.
    Hammerhead, ntg, Tony v and 9 others like this.
  20. Aug 7, 2019 at 9:22 PM
    #1490
    2017redtrd
    2017redtrd New Member
  21. Aug 7, 2019 at 9:40 PM
    #1491
    Rabidllamas
    Rabidllamas New Member
    Phil
    WA
    2019 Cement Crewmax TRD OffRoad
    My build- https://www.tundras.com/threads/rabbidllamas-old-man-build.80802/
  22. Aug 8, 2019 at 2:55 AM
    #1492
    Safe travels
  23. Aug 8, 2019 at 7:17 AM
    #1493
    Taco-Blender
    AZ
    2010 DC 4x4
    Thank you gents!
    Slow and steady wins this race
  24. Aug 8, 2019 at 8:47 AM
    #1494
    Volchek
    Volchek New Member
    18 Tundra DC XPS 5.7
    Nice! Another MicroMinnie!
    What's the model?
    We LOVE ours (2106FBS)!
  25. Aug 8, 2019 at 9:03 AM
    #1495
    Rabidllamas
    Phil
    WA
    We have the 2106DS. Murphy bed and slide out couch. So far we love it too. Just upgraded from a Taco.
    Bigboitundra likes this.
  26. Aug 8, 2019 at 9:14 AM
    #1496
    Volchek
    Volchek New Member
    We upgraded from a 2017 Tacoma 4x2 to a 2018 Tundra 5.7L after towing our new MicroMinnie on our first camping trip. The Taco would tow it but it struggled too much for my taste. Got the Tundra 2 weeks later. LOVE em both!
  27. Aug 12, 2019 at 7:25 AM
    #1497
    Devi8
    Devi8 New Member
    Dave
    2017 crewmax limited
    Iron cross steps, weather techs, rain/big guards, access cover, tracrac with cantilever
    2018 Cruiser MPG 2750 BH, 6300 lb dry, 680 tongue weight, 33 ft. Truck has Firestone bags, China tow mirrors, Equal-i-zer hitch, and rear TRD sway. I could use a little more power on the hills but it tows nice.
  28. Aug 12, 2019 at 7:35 PM
    #1498
    BigDaddy22
    BigDaddy22 New Member
    2016 Tundra SR5 DC
    Our 2016 Forest River Wildwood X-Lite 231RKXL. 28' hitch to bumper.
    Last summer = 5,500 miles camping
    This summer = 3,350 miles camping
    Tows like a breeze.
  29. Aug 14, 2019 at 9:42 AM
    #1499
    G2G
    G2G New Member
    Chicago
    2018 White Platinum Tundra
    eddie98, Prostar 190 and JH5370 like this.
  30. Aug 15, 2019 at 7:07 PM
    #1500
    AZBoatHauler
    So.Arizona
