What do you TOW with your Tundra?
Discussion in 'Towing & Hauling' started by T-Rex266, Jan 29, 2014.
  1. Sep 16, 2018 at 4:47 PM
    #1051
    Warreng
    Warreng New Member
    It is, and thanks :)
    Taco-Blender[QUOTED] likes this.
  2. Sep 17, 2018 at 9:54 PM
    #1052
    TundraTXTSS
    TundraTXTSS New Member
    Conroe
    2020 White TRD Pro
    Window Breakage add on Alarm,Wireless Charger. Console Safe, Rear Dif Breather Relocation, Rear Under seat Storage, Hard wire for Radar Detector, Tonnneau Cover, Brake Sensor Protection,SABM with TRD Filter, Tailgate lock, BFG's, LED Running lights.D-3 Tuner.
  3. Sep 17, 2018 at 9:56 PM
    #1053
    easleycrawler
    Travis
    Easley, South Carolina
    19 TRD SPORT CM MGM 4WD
  4. Sep 17, 2018 at 9:57 PM
    #1054
    easleycrawler
    Travis
  5. Sep 18, 2018 at 11:41 AM
    #1055
    Notachickmagnet
    Notachickmagnet New Member
  6. Sep 19, 2018 at 1:28 PM
    #1056
    Ike74
    Ike74 New Member
    Anthony
    Sugar Land, TX
    2020 Kia Forte
    20180919_095008.jpg 7x14 Haulmark cargo trailer for my cross country move.
  7. Sep 19, 2018 at 2:00 PM
    #1057
    sunnysideTRD
    sunnysideTRD New Member
    Sunny
    2019 Tundra TRD Pro Voodoo Blue
    Standard 2019 TRD Pro but will be a project car and add as I go
    Not sure if this is the place or it has been answered. I am picking up my truck in a couple of weeks. I plan on driving the truck (2019 Tundra TRD PRO) back to TX and towing my city car (BMW550). Im told that I need to break in my Truck first before I tow. Any response on this? I will be driving aprox 1500 miles.
    757TUNDRA likes this.
  8. Sep 19, 2018 at 2:09 PM
    #1058
    sprtbkr
    sprtbkr Average Member
    Scott
    Denver, CO
    2018 Tundra SR5 4x4 Double Cab - Inferno
    TRD Wheels & Tires, Double Cab Fold-down Back Seat mod, LED Interior Lighting, Turned Off Seat Belt Chime, Franken-key (Flip Key), Duraliner Bed Liner, Bed Rails, Hood Wind Deflector, Console Gun Safe, iBoard 5" Running Boards, TRD Sport Bed Vinyl, Fortin Evo One Remote Start with Mycar Cellular Module, Plasti-dipped Badges and Bumper End Caps, Tinted front windows, Extang Solid Fold 2.0, Pop-N-Lock, TUNDRA tailgate inserts, RCI Powder Coated Skid Plate - coming soon - 12” android radio, oemaudio+ Reference 500Q, under dash/seat lighting.
    per Toyota's break in guidance, you aren't supposed to tow for the first 500 miles. So take 5 x 100 mile drives before you move.
    ColoradoTJ likes this.
  9. Sep 19, 2018 at 4:13 PM
    #1059
    sunnysideTRD
    Sunny
    I guess, i better find some long back roads to drive through. maybe do an outer belt a few times around too. LOL
    ColoradoTJ and Watt maker like this.
  10. Sep 20, 2018 at 4:59 PM
    #1060
    Devcom
    Devcom Miles per Gallon? More like Smiles per Gallon!!
    2018 Blazing Blue Tundra Double Cab SR5 5.7L 4x4
    I towed this Dakota today was about 6500 pounds adding the Dakota and Trailer weights together. My Tundra did way better than I thought it would and the Brake controller that came with my truck is not horrible and it did well just needs more gain then I am used too putting. I would say its on par or better than my Ram ITBC I had before this truck but not as good as the Prodigy I had installed in a Company truck I used to drive before I left that job a couple years ago.
    EDIT: Dakota had an engine knock problem it runs enough to get it on a trailer but not to drive it anywhere. Friend is probably going the engine swap route it sounded really bad.
  11. Sep 22, 2018 at 10:31 AM
    #1061
    Pro-Yota
    Pro-Yota New Member
    Rick
    2019 TRD Pro Tundra CM
    my modified ATV trailer and yes those are 1972 Chevrolet way cool hubcapstundra and trailer.jpg
  12. Sep 24, 2018 at 5:44 AM
    #1062
    Hjabernathy
    Hjabernathy New Member
    Hans
    2014 4x4 Tundra with Towing Package
    2" Front Lift, 1" Rear Lift, Rear Leaf Spring Enhancers
    Does anyone have opinions about the weight ratings of the 2014 4x4 5.7l Tundra Limited? My manual says GCWR 16,000 and Trailer Weight Max 9,900. My experience indicates that these may be conservative numbers. Anyone know how Toyota, or any car company, determines these numbers? I will post of picture of what I tow, a 25' Bigfoot trailer, along with our "stuff" in and on the truck after I see if anyone responds. We are full time RVers and have been towing this rig and truck load for three years now. We use an Equal-I-Zer 1,2000lb WD/AS hitch with a 14,000lb hitch ball. We had the front lifted 2" with coil spacers and the rear lifted 1" with a block. Also had Hellwig rear leaf spring enhancers installed.
    We've taken it from Arizona to Alaska in year one (2016), Arizona to Newfoundland in year two (2017) and spent this summer in New Mexico and the Colorado Rockies (2018) pulling over 12,000' passes. The Tundra has performed excellently, both on-road and off. It has 92,000 miles on it, and I take excellent care of it. Had all the fluids (trans, transfer case, both diffs) changed at 50,000 and intend to do so at 100,000. Change the oil every 7,000 miles. Run 10-ply/E-Load 18" Michelin tires, rear - 80lbs, front - 65lbs. Also had the dealer clean the injectors at 46,000 and 92,000. The brakes wore down at 72,000.
    Any recommendations from Toyota mechanics as to what services I should consider in the near future? I've owned Toyotas before and know about the timing belt. Does this engine also require that it be changed. I saw on this forum something about doing the timing belt and water pump. I'll do the plugs around 125,000 according to Toyota and my excellent mechanic, who used to be a Toyota service manager. Thanks for any and all help.
  13. Sep 24, 2018 at 6:21 AM
    #1063
    You can purchase a heat gun at Harbor Freight for reasonable.
    When breaking in your truck, it’s just wearing in and heat cycling the gear sets. This is very important for long term longevity in my opinion. Check out these links. Personally, I would leave my car at home, take a one way flight and drive home following these break in procedures from the pro’s.
    https://eastcoastgearsupply.com/ft-1479-new-gear-break-in-procedure.html
    http://www.fourwheeler.com/how-to/t...129-1207-new-gear-set-break-in-or-break-down/
    Watt maker likes this.
  14. Sep 24, 2018 at 6:54 AM
    #1064
  15. Sep 24, 2018 at 6:57 AM
    #1065
    sunnysideTRD
    Sunny
    Thanks! I really appreciate this. This will help on my initial drive from Toledo to Columbus so I can properly break it in. This is all new to me, as I've nevered owned a truck before. One of the links suggest I change the gear oil after 500 miles, have you done this or anyone else?
    BTW, anyone know where to order a magnetic plug to catch these metal particles? I plan on changing the oil as well for the first 500 miles.
  16. Sep 24, 2018 at 12:48 PM
    #1066
    I have changed the gear lube at under 5000 miles depending on how much I follow the break in procedure.
    You should be able to make it home just fine without swapping the gear lube. This is something you can easily do yourself at 5000 miles or so.
    sunnysideTRD[QUOTED] likes this.
  17. Sep 24, 2018 at 12:50 PM
    #1067
    Good man!
    :thumbsup:
  18. Sep 24, 2018 at 1:28 PM
    #1068
    I have more if you want me to start a thread.
  19. Sep 24, 2018 at 1:37 PM
    #1069
    You could do that.
  20. Sep 26, 2018 at 8:27 PM
    #1070
    nuclearlemon
    nuclearlemon New Member
    wyoming
    2012 dc
    a lot, but mostly the raffle jeep right now
  21. Sep 26, 2018 at 8:39 PM
    #1071
    nuclearlemon
    wyoming
    2012 dc
    thanks, but that ain't gonna happen ;)
    two more months and i'll be free of the jeep though :)
  22. Sep 26, 2018 at 8:58 PM
    #1072
    nuclearlemon
    wyoming
    2012 dc
    if you're in colorado, you can buy tickets at any of the events it's at. (14erfest this weekend, 4wp denver show next saturday, coa4wdci quarterly meeting on the 20th, christmas caravan for kids dec 1st - when we pull the lucky winnner)
    if you're out of state, you can mail a check to
    coa4wdci
    po box 16995
    colo springs, co 80935
    and our secretary, Brian, will fill out your tickets and mail you your stubs.
    more pics at hightrails.org
  23. Sep 30, 2018 at 6:14 PM
    #1073
    bfd300
    bfd300 New Member
    EDFED61D-B24E-47D5-A470-1886ED08BD25.jpg My 2 4 wheelers.
  24. Oct 4, 2018 at 6:48 AM
    #1074
    Sixpack
    Sixpack New Member
    Central Florida
    2014 Silver Sky Tundra CM TRD 4x4 Limited
    Moto Metal 951 18x9 rims with 285x75x18 Nitto Terra Grapplers , ESP lockable under seat storage, Husky mats front and rear, ReadyLift 3/1, Undercover Flex trifold bed cover, Bed Rug, interior LED's, 15% tint all around, TRD CAI, Bully Dog Platinum GT tuner, TRD rear sway bar, Flowmaster Series 44 dual exhaust system, LED head lights and Fog lights, 32" LED light bar in lower bumper cover, Switchback running lights, much more to come...
    24' enclosed trailer
  25. Oct 4, 2018 at 6:53 AM
    #1075
    But the real question is what's in there?
  26. Oct 4, 2018 at 11:10 AM
    #1076
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    24 ft. Chaparral deck boat & 23 ft. Rockwood...
  27. Oct 4, 2018 at 11:15 AM
    #1077
    Ni foo ni fa! Nada!
  28. Oct 4, 2018 at 11:47 AM
    #1078
    IMG_20180902_090936727.jpg IMG_20180722_095513706.jpg [​IMG]
    And anything else I need to move! Lol
  29. Oct 4, 2018 at 1:32 PM
    #1079
    Theyfzman
    Theyfzman New Member
    Pa
    08 TRD
    Finally found one that is not molested into a drag car 4D883E3E-7FDB-4E5E-96DB-AA22B501BEFE.jpg
  30. Oct 4, 2018 at 1:37 PM
    #1080
    Very nice. You don't see too many of those around.
