What do you TOW with your Tundra?
Discussion in 'Towing & Hauling' started by T-Rex266, Jan 29, 2014.
  1. Jan 18, 2017 at 9:03 AM
    #481
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I went to pick up some processed gravel for a base to lay a brick floor in a barn. 6,600 lbs of gravel in a 1,900 lb dump trailer. So 8,500 lbs. Hauled it about 5 miles, the truck pulled very well, was working up a long uphill grade but maybe 3500 rpm. I do not have a brake controller and I would absolutely get one if I Hauled this weight regularly that's for sure. But it stopped fine just had to be mindful.
  2. Jan 18, 2017 at 9:26 AM
    #482
    Is that a single axle dump or just not the full picture?
  3. Jan 18, 2017 at 9:56 AM
    #483
    Pudge
    CT
    Good eye. It's double axel
    ColoradoTJ likes this.
  4. Jan 18, 2017 at 11:56 AM
    #484
    I figured it had to have two axles....but you never know.
  5. Jan 18, 2017 at 12:11 PM
    #485
    Cuzin Eddie
    Cuzin Eddie New Member
    Shane
    2014 CM Black Platinum 4X4
    TRD Supercharged * BDS 4.5 level with Fox Shocks * AMP running Boards * Bed Rug, Spyder Headlights with HID Conversion * 46 Gal TransferFlow Fuel Tank * Fuel 2 Piece Hostage Wheels * 35" Toyo RT's * Backflip Bed Cover * Pioneer Avic NEX8200 with Amp, Speakers & Subs * Trailer Tow Mirrors * N-Fab Bumper Bar with 30" Vision LED Light Bar *
    2016 Super Air Natique.
    ntg, MotoTundra, Muleycrazy13 and 4 others like this.
  6. Jan 18, 2017 at 12:42 PM
    #486
    Damn you guys with boats.
    Last night I was watching a few minutes....ok hours, of cigarette boat racing. Now those machines look expensive, but so much fun!!!
    MotoTundra likes this.
  7. Jan 18, 2017 at 1:02 PM
    #487
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    that's a beautiful boat
    Cuzin Eddie[QUOTED] likes this.
  8. Jan 18, 2017 at 1:06 PM
    #488
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    Now there's a pussy magnet!
  9. Jan 18, 2017 at 1:33 PM
    #489
    Cuzin Eddie
    Shane
    Thank you!!!! My family loves it but I would rather been on a RZR or snowmobile. With Lake Powell as close as it is, its hard not having a boat.
  10. Jan 18, 2017 at 4:18 PM
    #490
    mdavis
    Michael
    Rock Hill, SC
    Lake Powell is awesome! I've spent several weeks on houseboats out there when I was younger. Then my mom just had to move east. :rolleyes:
  11. Jan 18, 2017 at 4:29 PM
    #491
    Fishin RGV-Trd Pro
    Fishin RGV-Trd Pro White is faster
    Alex
    RGV Texas
    2011 White Toyota Tundra Limited
    Going fishin chasing some Reds on the bay.
  12. Jan 18, 2017 at 4:39 PM
    #492
    Fly'n Family
    Fly'n Family New Member
    TX / CO
    2014 CM Limited
    Love Powell. We had our boat hauled to Powell two years ago and spent two weeks on the water. Only went around civilization once to restock beer, fuel, chow, pump out and refill potable water. Two weeks with only the family cruising, hanging out, and sleeping in the most amazing coves - can't put a price tag on that - and the scenery is something everyone should see. Hopefully with the good snowpack everywhere, Powell will start regaining herself.
    mdavis likes this.
  13. Jan 18, 2017 at 11:21 PM
    #493
    Cuzin Eddie
    Shane
    There is nothing like Powell! If my kids could pick between a vacation in Hawaii or Powell they would pick Powell! Yes, the snowpack situation looks to add a lot to the lake this year!
  14. Jan 19, 2017 at 12:18 PM
    #494
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  15. Jan 19, 2017 at 12:20 PM
    #495
    csuviper
    Broomfield, CO
  16. Jan 19, 2017 at 12:24 PM
    #496
    csuviper
    Broomfield, CO
    Tow Haul Mode:
    1. Holds lower gears longer
    2. Increases throttle response
    3. Increases pulling power
    4. Increases engine braking
    ColoradoTJ and TruckyTruck like this.
  17. Jan 19, 2017 at 2:59 PM
    #497
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    Thanks for posting Brian. I personally tow an 8000lb travel trailer with tow/haul mode and it works great. I remember my 1st outing with it, and I lightly tapped the brakes on a long and steep down grade and the engine/trans does almost all the breaking for you. Toyota did a great job with this feature.
  18. Feb 6, 2017 at 4:36 PM
    #498
    oul
    oul Old New Member
    Larry
    Huntington Beach, CA
    2017 Tundra White SR5 TRD Off Road CM
    First tow with my 2017 this last weekend. The trailer is 18' and has a GVWR of 5900 lbs so I'm guessing it was around 5000 lbs. Over all it did fine as I'm comparing it to my 2005 Chevy Crew Cab Z-71 5.3. It feels stronger (as it should) than the Chevy. I don't want to get into a towing with cruise control debate but I do. The Chevy did it great up hill, down hill all day. The Tundra doesn't like it in the hills so I turned the CC off when I got to the hills. The Tundra steering is more sensitive and I'm getting used to it. The tow/haul mode makes a big difference. I'm pleased as it is getting near the Chevy towing milage at 9.51 mpg. although I haven't calculated how far the odo is off with the larger tires. I'm still playing with the air bags pressure, I added a bit more after the picture.
    plumber802 likes this.
  19. Feb 6, 2017 at 4:46 PM
    #499
    Fly'n Family
    TX / CO
    2014 CM Limited
    Nice rig and set-up.
    I found this site to be accurate as far as knowing different speeds and odo with a change in tire size...
    iHacker and oul[QUOTED] like this.
  20. Feb 6, 2017 at 4:48 PM
    #500
    oul
    oul Old New Member
    Larry
    Thanks, I'll check it out.
  21. Feb 6, 2017 at 5:33 PM
    #501
    CM-LENNY
    San Diego, CA
    Just be careful with the air bag pressure. To much, and you take away from the WD hitches job. Not sure how much you've towed and used a WD hitch, but measure your trucks fender wells with the truck alone, and record the settings. Ideally you want the same measurements with the trailer hooked up. Takes a little time of back and forth with the WD hitch and bags. Excuse me if I step on your toes, but thought it might help others too. Now shut up and go camping already ! :cheers:
    oul[QUOTED] likes this.
  22. Feb 6, 2017 at 5:46 PM
    #502
    oul
    oul Old New Member
    Larry
    Thanks Lenny, good advice. The Tundra hitch sits about 1" higher than the last one so I really need to start over and set it up correctly.
    CM-LENNY[QUOTED] likes this.
  23. Feb 11, 2017 at 9:15 PM
    #503
    The Fast Forester
    The Fast Forester New Member
    Berthoud, CO
    2016 Inferno Tundra TRD
    Towing this out to the race track tomorrow. Have an old g-body '79 Cutlass in there, dirt track car.
    FirstGenTundra and CM-LENNY like this.
  24. Feb 25, 2017 at 10:03 AM
    #504
    Medic
    Medic New Member
    Ontario, Canada
    2014 Limited Crew Max
    Recovery mission for a co-worker.
    FirstGenTundra likes this.
  25. Mar 17, 2017 at 8:21 AM
    #505
    VA10
    VA10 New Member
    2020 Tundra Limited TRD Off-Road
    which airport or air field is this?
  26. Mar 17, 2017 at 8:25 AM
    #506
    VA10
    VA10 New Member
  27. Mar 17, 2017 at 12:57 PM
    #507
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    2014 Toyota Tundra TRD
    Top three pictures were from Yeager Airport in Charleston, WV, the rest were from Winchester Regional Airport.
  28. Mar 17, 2017 at 4:46 PM
    #508
    xj2202009
    xj2202009 New Member
    x
    Lutz, Fl
    2017 tundra sr double cab v8 5.7L black 4x2
    looking to replace factory Radio with a pioneer avix588bhs
    Some times I tow a ford, sometimes is a Chevy..it all depends what's on the side of road.
    CM-LENNY, Medic and FirstGenTundra like this.
  29. Mar 21, 2017 at 4:20 PM
    #509
    LibertySand
    LibertySand IH Support Rig
    Montclair, CA
    07 TRD DC 5.7 Tow 4X4
    Probably one of the cooler things I'll be towing today. A Pair of Axletechs. Go Big or Go Home!
  30. Mar 28, 2017 at 7:34 AM
    #510
    swede78
    swede78 Not so new member
    Lars
    westminster co
    2019 tundra platinum mgm crew max
    Nothing yet
