What do you TOW with your Tundra?
Discussion in 'Towing & Hauling' started by T-Rex266, Jan 29, 2014.
  1. Oct 10, 2023 at 5:37 PM
    #3541
    Phoenix 216
    Phoenix 216 New Member
    Eric
    2023 metallic gray sr5
  2. Oct 10, 2023 at 5:43 PM
    #3542
    BuilderBee
    BuilderBee New Member
    Southern California
    2017 Tundra Double Cab TRD SR5
    BakFlip MX4 Tonneau Cover Stubby Antenna Husky Floor Liners
    Topper is an inflatable topper and weighs 65 lbs! Trailer dry weight is 5200 lbs.
  3. Oct 10, 2023 at 7:24 PM
    #3543
    3rdTundra
    3rdTundra Hay Hauler
    Central Texas
    2017 Tundra SR5 Double Cab TSS 4x4
    FRAC harness / camera & Full set of Valhalla plates
  4. Oct 11, 2023 at 3:28 AM
    #3544
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I'm with you. Not sure what others are thinking when it comes to airbags.
    Mattedfred[QUOTED] likes this.
  5. Oct 11, 2023 at 7:13 AM
    #3545
    BuilderBee
    Southern California
    Wow! I was simply asking for advice and not a rant. You have a great day and enjoy your lunch. :poking:
  6. Oct 11, 2023 at 7:27 AM
    #3546
    BuilderBee
    Southern California
    This is the first time towing a TT, I am also learning and I was looking for advice on sag, not needing to read an opinionated rant. Let’s just move on and I will make a decision based on what I feel is best for the safety of towing and not necessarily the look of my truck as I too can careless on how it looks. Safety of my family comes first. Have a great day. :cheers:
    HulkSmurf14 likes this.
  7. Oct 11, 2023 at 7:29 PM
    #3547
    oconnortatzz
    oconnortatzz New Member
    2018 tundra TRD crew max
    Interior carbon fiber, Leveling kit, 285/60-r20s and blacked out.
    She wasn’t a big fan of highway. But loved the twists and turns and hills.
    FI460, Cpl_Punishment and BuilderBee like this.
  8. Oct 14, 2023 at 6:54 PM
    #3548
    16MagSR5
    16MagSR5 New Member
    Buffalo
    2016 Magnetic SR5, leveled and capped
    Boost tow Mirrors, TRD rear sway, Rough Country Duals, Bilstein 5100's, diff breather mod, more that I'm forgetting...
    Darn, never heard of an inflatable topper. I have air bags, previous owner installed, But I don't use them to "even" out the weight. That's what the wdh is for, to plant the weight back on the front tires. Despite the peanut gallery, too much rake is going to cause drivability issues, hence safety issues. A properly set up wdh should lower the front and rear height evenly, theoretically. Realistically, it should still be damn close. And set up correctly, should provide the support needed when loaded.
    BuilderBee[QUOTED] likes this.
  9. Oct 14, 2023 at 7:17 PM
    #3549
    BuilderBee
    Southern California
    I only use the inflatable topper when we take out the trailer as we have a Great Dane. Quite happy with it and you can find it here:
    https://getflated.com/products/air-topper-full-size-standard
    Otherwise I have a Bakflip Tonneau Cover that is on most of the time, tonneau cover is easy to remove and store in my garage. I have to agree that the WDH is the way to go and the TT dealer set it up. May just need a better adjustment and I will look into it. I further researched air bags and I opted to not go that route.
  10. Oct 14, 2023 at 7:26 PM
    #3550
    16MagSR5
    16MagSR5 New Member
    Buffalo
    That is very cool. I saw the big head peaking out in one of your pics.
    I don't trust dealers. They want a sale and to get you out the door. Maybe find the setup instructions for your hitch and spend a little down time setting it back up correctly. Based on trailer weight, and subsequent hitch weight, you and the trailer should be riding level"ish". Probably just some measuring and an adjustment, and you'll be good to go.
  11. Oct 14, 2023 at 7:32 PM
    #3551
    BuilderBee
    Southern California
    Thanks for the advice and I will definitely look into readjusting the WDH. Heading to Arizona in November and I want to ensure we are good to go. :cheers:
    16MagSR5[QUOTED] and HulkSmurf14 like this.
  12. Oct 21, 2023 at 8:23 PM
    #3552
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
  13. Oct 22, 2023 at 8:20 AM
    #3553
    AZBoatHauler
    So.Arizona
  14. Oct 24, 2023 at 6:08 AM
    #3554
    GirlsLikeTrucksToo!
    GirlsLikeTrucksToo! New Member
    Stephanie
    Washington State
    2022 SR5 LONG BED
    The old man added a dual axel then put a trailer hitch on the back of the travel trailer to tow the motorcycle. The quad goes in the back of the truck. Full load but the truck handled so well. Gosh, I just love my truck!
  15. Oct 31, 2023 at 5:11 AM
    #3555
    EWilli150
    EWilli150 New Member
    Ed
    Thousand Oaks, CA
    2021 Tundra Limited TRD Off Road
    OBI Dweller13 Off-Road Trailer. Tundra tows great. Going to add in a transmission cooler....be on the safe side
    FI460, 22whatwedo, Chelly and 5 others like this.
  16. Oct 31, 2023 at 12:18 PM
    #3556
    DIYReid
    DIYReid New Member
    KC
    2024 Ice Cap Tundra Limited
    Either my Golf Cart or my 48" Zero Turn if I need to go mow a buddies or parents lawn.
    FI460 likes this.
  17. Nov 6, 2023 at 11:59 AM
    #3557
    tundramh
    tundramh New Member
    OHIO
    This. Because THAT let me know it was back there. Even the wife made a comment from the passenger seat you could really tell we had the camper hooked.
    atc250r and FI460 like this.
  18. Nov 6, 2023 at 12:26 PM
    #3558
    AZBoatHauler
    So.Arizona
  19. Nov 6, 2023 at 2:33 PM
    #3559
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
  20. Nov 6, 2023 at 3:11 PM
    #3560
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Really. Your Taco shouldn't have had any issues with something that small.
    WAtundra4x4 likes this.
  21. Nov 8, 2023 at 11:18 AM
    #3561
    tundramh
    tundramh New Member
    OHIO
    Yikes! I probably had more of an issue with it than the truck did. Was really annoyed with the long hills mostly. It was a great excuse to get something bigger for traveling for sure. Plus I'm pretty sure I'm getting better mileage now as well.
    Ruggybuggy[QUOTED] likes this.
  22. Nov 9, 2023 at 1:06 PM
    #3562
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    Not much, this guy comes in just under 2500lbs loaded...
    Bought the Tundra a month ago in preparation for a larger trailer (22-25'ish range). This weekend will be the first trip out with Pikey and the Tundra:
    The 4R has pulled this thing across the Southwest without a single issue for the past 2+ years. Just decided we wanted a bigger trailer so the teardrop will likely be up for sale shortly.
    FI460, Mattedfred and Cpl_Punishment like this.
  23. Nov 9, 2023 at 2:15 PM
    #3563
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Is your new trailer going to be blue to match the Tundra? :D
  24. Nov 9, 2023 at 2:24 PM
    #3564
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    Just might be...
    Boerseun, FI460, Retroboy1989 and 5 others like this.
  25. Nov 9, 2023 at 2:29 PM
    #3565
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I never heard of a Stratus before. Looks nice.
  26. Nov 9, 2023 at 2:52 PM
    #3566
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
  27. Nov 9, 2023 at 3:59 PM
    #3567
    danno266
    danno266 n00b
    2016 White CM SR5/TRD OR
    Retroboy1989 likes this.
  28. Nov 9, 2023 at 4:17 PM
    #3568
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    Yes, that was simply an example...maybe a291VQB? I'm interested in SR231VRB.
    danno266[QUOTED] likes this.
  29. Nov 11, 2023 at 4:58 AM
    #3569
    DannyG
    DannyG New Member
    Danny
    2023 Tundra Platinum| 2020 BMW X3 M| 2013 Porsche 911 C4S
    Just picked up our new 2023 Grand Design Imagine XLS 23LDE. Towed it about 150 miles home over a few passes and still managed to get 10mpg which I found impressive.
    Still need to figure out some weight distribution issues as there was a good amount of porpoising which leads me to believe the tongue is too light (rear kitchen model) but it towed great otherwise.
    PBNB, FI460, JMGmanAZ and 1 other person like this.
  30. Nov 11, 2023 at 5:41 AM
    #3570
    Catmann1972
    Catmann1972 New Member
    Greg
    Rhode Island
    2020 TRD Sport
    May I suggest looking into a RAS (Road Active Suspension) system. I should have put mine on my truck years ago. what a difference.
    https://activesuspension.com/?gad=1...sUki6PPEkIdnY7QX-ah0hplVm-uMWmIBoCqJkQAvD_BwE
