What do you TOW with your Tundra?
Discussion in 'Towing & Hauling' started by T-Rex266, Jan 29, 2014.
  1. May 10, 2023 at 5:45 AM
    #3481
    spicychickentundie
    spicychickentundie New Member
    Danny
    SOMD
    2014 Barcelona Red Tundra SR5 CM 4x4
    TRD RSB
    I see what you mean now. At first look the lines of the trick look squatted. Probably tows fine though. Boat can't be that heavy. 3000 lbs?
  2. May 10, 2023 at 6:46 AM
    #3482
    Cdunner
    Cdunner New Member
    2023 White Sequoia SR5 TRD Off-road
    Yeah around 3300 wet with trailer
  3. May 13, 2023 at 8:37 PM
    #3483
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    This time I got the tow dolly instead of the car hauler. It was a lot easier on the tongue weight. The squat is mostly because the bed is loaded with al my daughter's stuff from her dorm room.
  4. May 18, 2023 at 9:51 AM
    #3484
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    Hauled this beast from Lake of the Ozarks to Atlanta last Fall. Right around 8000lbs and it did just fine on stock gearing and 35" tires.
  5. May 22, 2023 at 11:48 AM
    #3485
    FI460
    FI460 New Member
    Rick
    2022 Limited CM/6.5' TRD OR 4x4
    Towed a little actual weight for the first time with my 2022. I was really impressed with how the truck performed. Less impressed with the 2005 Prowler I borrowed from my Dad, but beggars can't be choosers.
    120 miles one way across Southern Oregon and I was right around 9-10 mpg.
    Andersen wdh hitch seemed to do well. I don't have experience with any other wdh to compare to though.
    WVI, WAtundra4x4, Prostar 190 and 4 others like this.
  6. Jun 2, 2023 at 12:49 PM
    #3486
    Chelly
    Chelly ...
    Mt Hood / PDX OR
    2020 Platinum - Super White
    Elka DSC Suspension, Ray-10s, MaxTrax, Dirt King UCA, 295/70/18 Toyo AT3, TRD Skid + Intake, .25 Bumper Shim, UnderCover UltraFlex Tonneau, RoadActive Suspension, Tuffskinz, etc.
    Terndrerrr, FI460, TOYOTARIG and 2 others like this.
  7. Jun 4, 2023 at 6:00 PM
    Medikdoc
    Medikdoc New Member
    2011 Tundra SR5
    Just picked up this 2023 Heartland North Trail 24BHS last week. Towing with my 2011 SR5 (pic isn’t great I know). Currently have WDH and Tekonsha P3 brake controller, but looking to add some other things to help/improve tow and lessen wear and tear. Transmission cooler is already on the list, as well as Bilsteins. Question I have for all of you is sumo springs or airbags? I am leaning towards airbags with daystar cradles. Thoughts?
    WAtundra4x4, WVI and JDR76 like this.
  8. Jun 6, 2023 at 10:03 AM
    #3488
    Chelly
    Chelly ...
    Mt Hood / PDX OR
    Nice setup! You may also consider the Road Active Suspension kit. (RAS). I was considering the airbags and cradles as well but found the RAS to be a simpler solution. Your 2011 should have the factory transmission cooler, might be worth saving the $ there and investing in a BT dongle and app to monitor the temps (I covered this in the video above) as it may be just fine with the factory setup.
  9. Jun 6, 2023 at 11:53 AM
    #3489
    Medikdoc
    Medikdoc New Member
    2011 Tundra SR5
    Thanks for the info. After looking at the RAS info, it does sound like it will be a better option than airbags. And I’ve read others on the forum who say the stock transmission cooler just doesn’t cut it, so it’s something I’m worried about.
    Chelly[QUOTED] likes this.
  10. Jun 7, 2023 at 8:26 PM
    #3490
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    I added a secondary trans cooler after the factory cooler. I can say that it provides a lot of cooling capacity. After a long, hard climb in 2-3rd (No TC lock) in 60F degrees ambient, it the return line is cold.
    Ill find my links.
    Edit:
    https://www.tundras.com/threads/add...4-6l-tundra-for-under-400.77739/#post-2799217
  11. Jun 7, 2023 at 8:37 PM
    #3491
    Retroboy1989
    Northern Utah
    Different approach: I went with sumo springs and did as a secondary cooler that I think I kept around $120. With a decent WDH hitch, I'm happy.
    WVI likes this.
  12. Jun 7, 2023 at 10:00 PM
    #3492
    Chelly
    Chelly ...
    Mt Hood / PDX OR
    Sounds like a great solution! I can't speak for the factory setup, as mine is a 2020 where it was deleted so I added back the factory thermostat and lines and have an aftermarket cooler. I do wish there was a way to lock the TC in 3rd, there are times coming up over the mountain where its in 3rd for a good while pulling up steep grades. But the cooler does a great job and keeps the pan temps in check.
  13. Jun 9, 2023 at 8:47 AM
    #3493
    Retired...finally
    That's cute!
    Mattedfred likes this.
  14. Jun 9, 2023 at 9:17 AM
    #3494
    Chelly
    Chelly ...
    Mt Hood / PDX OR
    Thats a super cool little trailer! Is that little silver ?wing? near the top in the back like a vent or just styling / aero?
  15. Jun 9, 2023 at 9:21 AM
    #3495
    Retired...finally
    Those are yaw dampers.
  16. Jun 19, 2023 at 4:32 PM
    #3496
    Powder Hound
    Powder Hound New Member
    2015 Limited TRD Double Cab
    Regularly tow our 21’ Camplite trailer, fully loaded, I’m just shy of 5000 pounds. Tongue weight comes in at 550 pounds. Extra fuel, generator and the usual gear in the truck box, 200 pounds. Anderson WDH.
    Installed new Bilstein UCA’s, 6112’s, lowest setting, 5160’s with CB +1’s. I lost .625” of rear rake. Have a tremendous amount of mileage towing in all conditions, only issue to date, my leaf springs are just about flat, next project. Really wanted a bit more lift, but I’m limited in accessing my condos underground parking stall.
    The CB shackles made a huge impact with stability and the annoying bed bounce is almost completely gone.
  17. Jun 19, 2023 at 8:02 PM
    #3497
    KingsAustin
    KingsAustin Grey Goose II
    Morgan County, AL
    2021 Limited Night Shade
    BakFlip MX4, Gator All Weather mats, Console Safe, Ceramic Tint, Roadmaster Active Suspension, Interior/exterior LED conversion, Wireless console charger, AJT designs.
    Here's the Grey Goose II towing our Imagine XLS 23LDE sitting at 28'5" long and weighing in at 5740 lbs at about 95% loaded. I use a Curt Tru Track 4P (8k) WDH. The truck has the RAS (per members recommendations on here)....great addition...set it and forget it. I also have a Toyota OEM rear sway bar.
  18. Jul 1, 2023 at 7:51 PM
    #3498
    cconzelmann
    cconzelmann Extra new member
    Chad
    SLO, CA
    2017 Crewmax 4x4
    So stock.
    ROAD TRIP!!!!
    SLO->Sac, CA->Wells, NV->Thayne, WY
    Will most likely come back through St. George, UT and Vegas depending on the heat next weekend.
    So far after day 1 it is towing really well after dialing in the WDH. And my 5yo and 7yo daughters along with our 4yo Black Lab are all super comfy in the back seat. The Tundra is a pretty substantial upgrade over the 3rd gen Tacoma it replaced.
    FI460, _none_, twotrack and 4 others like this.
  19. Jul 2, 2023 at 7:57 PM
    #3499
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    Ok, it’s been awhile I’ve been camping with the old guys due to Covid and fires. A few photos of the set up up in the mountains on forest service roads. A bit differ than being on the slab. It was only about 10 miles of dirt, but a max speed of 15 mph, and a slow speed goi g around the blind switch backs. My trailer is about 2K lbs, stock suspension. You need 4 WD going up (and down) to prevent wheel spin. The old 18 was great and I love the reliability as there is no road service nor cell coverage out here. Even the paved road were one lane at times.
    FI460, JDR76, Cpl_Punishment and 3 others like this.
  20. Jul 3, 2023 at 12:11 PM
    #3500
    justcuz
    justcuz 2.5 Gen Member
    Towing in the city no problem. Freeway towing no issues. Backing up needs work. Any tips/ suggestions?IMG_2274.jpg
    FI460, WAtundra4x4 and Mattedfred like this.
  21. Jul 3, 2023 at 12:13 PM
    #3501
    Bergy24
    Bergy24 New Member
    2021 Cement Crewmax Limited TRD 4X4
    Practice. The more you do it, the better you'll get. If I dont tow in a while, i get rusty backing up.
  22. Jul 3, 2023 at 12:34 PM
    #3502
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Practice in an empty lot?
    I took RV Driver's Ed from AAA. The instructor gets you to drive forward through a slalom course of cones then says "if you can do it forwards, you can do it backwards."
    JDR76, PBNB and Mattedfred like this.
  23. Jul 3, 2023 at 1:15 PM
    #3503
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Another Towing Thread! Pic from April 2023.
  24. Jul 3, 2023 at 4:51 PM
    #3504
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    AMA offers one. Apparently it was brand new when I took it about a year ago. Not sure if it will have made its way to the other provinces or not.
    Mattedfred[QUOTED] likes this.
  25. Jul 4, 2023 at 10:16 PM
    #3505
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    Deception Pass State Park! Our favorite!
    AZBoatHauler, FI460, PBNB and 6 others like this.
  26. Jul 4, 2023 at 10:19 PM
    #3506
    JDR76
    JDR76 New Member
    WA
    Love it here!
  27. Jul 5, 2023 at 10:38 AM
    #3507
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    When you are backing up, put your hand on the bottom of the steering wheel, if you want the camper to go to the right move your hand to the right, if you want the camper to go to the left move your hand to the left.
  28. Jul 8, 2023 at 9:40 AM
    #3508
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Borrowed my buddies trailer! weighs about 2,500 lbs with the window washing platform. Put some sections on the DB cover as well!
    Not too worried about hitting the tailgate on the jack ;)
    This trailer is used to carry aluminum dock ramps usually 20 to 40' long. The tongue extends another 6' from what is shown in the pic.
    FI460 and WAtundra4x4 like this.
  29. Jul 8, 2023 at 11:56 AM
    #3509
    Lepdawg
    Lepdawg New Member
    Anthony
    South Carolina
    2021 Tundra Midnight Metallic TRD 4x4
    Rough Country Cat Back, Rough Country 3.5" Lift, Rough Country Bed Cover
    rental trailer for now. going to move a car next month. It hauls things just fine.
    Jtundra81, FI460, WAtundra4x4 and 2 others like this.
  30. Jul 9, 2023 at 3:03 PM
    #3510
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    Such a beautiful area!
    A couple of summers ago we launched our boat at Cornet Bay, went thru Deception Pass, and headed over to the San Juan for 10 days. Had never been there prior to that and was just in awe the entire time. Nice place!!
