What do you TOW with your Tundra?
Discussion in 'Towing & Hauling' started by T-Rex266, Jan 29, 2014.
  1. Feb 3, 2022 at 12:54 PM
    #3151
    ezdog
    ezdog New Member
    Gateway To The West
    Nope its the 8’ long Bed!
    Took me a long time to find it too!
    Yodder J[QUOTED] likes this.
  2. Feb 3, 2022 at 3:28 PM
    #3152
    Yodder J
    Yodder J New Member
    Northwest Arkansas
    2011 Silver Tundra SR5 4WD DC
    DAP Tune, Truxedo ProX15 bed cover, WildPeak AT3s
    One more question, I see talk about being in s4 and/or s5, what exactly does this mean, standard 4, standard 5? thanks
  3. Feb 4, 2022 at 3:38 AM
    #3153
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    I'm still new to the Tundra but from my understanding S is Sport? mode, when you slide the shifter to the left from D. S4 is what it starts in and you can go up and down from there. S4 I believe locks the converter and gives you lower transmission temps but will cost you MPG when towing at faster speeds due to the higher RPM. I just got my Tundra in November and have only towed our boat from storage to the dealer for winterizing and back so I haven't towed with it much, in a couple months though that'll change, we put a lot of miles on towing during the summer and I'm looking forward to seeing how the Tundra does.
    Yodder J likes this.
  4. Feb 4, 2022 at 5:40 AM
    #3154
    EatSleepTacos
    EatSleepTacos New Member
    Randy
    West Valley, AZ
    2020 Crewmax SR5 TRD Sport
    I wouldn't overthink it too much, that's a pretty light trailer. My flatbed weighs 2500 empty and I really don't even feel it back there when I'm pulling it around. I wouldn't adjust tire pressure for that low of weight, personally. I like to use tow/haul and put the truck in S and jump around in gears to keep the RPM range ideal.
    Example. I put it in S5 on the highway, and I find myself going up a slight incline. The truck doesn't downshift on it's own because the incline is so gradual, but I can tell the truck is working harder than it needs to be. I'll drop down into S4 so it downshifts and keeps the engine in a more optimal RPM range.
    Regarding what S mode is, all it does is set the highest gear that the truck will go into. You can be in S4, pull away from a stop light and the truck will be starting out in 1st gear. It'll drive and shift like normal, but won't go any higher than 4th. Same thing applies to S2, S3, etc. I generally keep it in S4 if I'll be under 55mph and then jump into S5 on the highway and downshift as necessary.
    WVI and Yodder J[QUOTED] like this.
  5. Feb 4, 2022 at 5:32 PM
    #3155
    Yodder J
    Yodder J New Member
    Northwest Arkansas
    Thanks, I did not know this. All I did know is that whenever I move the shifter into S mode, and I'm driving around, it always says 4. It's like its default setting or something. I don't know why "S" stands for Sport, that doesn't make any sense to me, it's not a sports car...
  6. Feb 4, 2022 at 5:35 PM
    #3156
    Yodder J
    Yodder J New Member
    Northwest Arkansas
    Thanks for this info
  7. Feb 4, 2022 at 7:20 PM
    #3157
    Mobeyk
    Mobeyk New Member
    Oshawa Ontario Canada
    2012 Tundra TRD pro, 2018 SR5
    Vland headlights, LED fogs, Rough country lower bumper LED bar, third light switch to LED, ICL ceramic coating, hood fender
    IMG_8519.jpg That was my old 2012 Tundra, stock suspension. Drove it 200K. I lost the Stop bumps sometimes way before I noticed, the leaf springs took the abuse with stride, towing daily 7000 lb dump trailer and floating equipment. I learned a lot with her. My 2018 will have RAS and for heavy tows, ill use WD hitch.
    NUDRAT, Prostar 190, WVI and 2 others like this.
  8. Feb 4, 2022 at 7:55 PM
    #3158
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I thought it stood for sequential shift mode. You can move the lever to change the max gear it will go into.
    GODZILLA and Jaypown like this.
  9. Feb 6, 2022 at 3:38 PM
    #3159
    Red Dragon
    Red Dragon New Member
    Pocatello, Idaho
    2015 Barcelona Red Limited TRD
    Our trailer does not have a slide. The gross vehicle weight rating is 7,000. The last time we towed it, we filled the water tank and it still only weighed in at 5,680 on the trailer axle, 3,320 on the truck's steer axle and 3440 on the drive axle. The Tundra pulls it great! I keep it in tow haul mode and cruise along at 65 mph.
  10. Feb 6, 2022 at 7:46 PM
    #3160
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Sweet! The one we rented might be a little heavier with a slide and all the stuff my wife needs for a week but I'm thinking to tow it with the tanks empty since we'll have hook ups at the campground.
  11. Feb 10, 2022 at 3:08 PM
    #3161
    rideandfly
    rideandfly New Member
    Went for our first camping trip of the season to Lake Wateree State Park SC earlier this week towing a 4900 pound trailer with our 2022 Tundra. This Tundra is going to be a great tow vehicle. Averaged around 14.2 MPG (truck computer) round trip with speeds up to 65MPH on the interstates in 8th gear. Truck has less than 1500 miles, believe fuel economy will get better, will see.
  12. Feb 10, 2022 at 3:44 PM
    #3162
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Did you ever tow that with a gen 2 Tundra and, if so, what fuel economy did it get?
    JDR76 likes this.
  13. Feb 10, 2022 at 3:56 PM
    #3163
    Tundy928
    Tundy928 New Member
    Curtis
    2015 Crewmax 4x4
    Island Park
  14. Feb 11, 2022 at 5:16 AM
    #3164
    rideandfly
    Towed same trailer and got 12MPG most of the time with our 2016 5.7L SR5 4X4 running in 2WD. Believe once this new engine is fully broken in it should top 15MPG towing this trailer in our area around Charlotte NC. Watching the MPG graphics and found this engine did better (MPG) at 1850 to 1900RPM in 8th gear at 65MPH compared to 1750RPM @ 60MPH in 8th gear on the interstate. Our trailer is aerodynamic, would not expect this MPG with a trailer that has more square corners.
  15. Feb 11, 2022 at 7:04 AM
    #3165
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    What model trailer is this? Thx.
  16. Feb 11, 2022 at 8:01 AM
    #3166
    rideandfly
    It's a 2015 Oliver Legacy Elite II twin bed model. They build a single axle trailer, too. Here's a shot with our 2016 Tundra:
    DmoHtx15, NUDRAT, Prostar 190 and 8 others like this.
  17. Mar 6, 2022 at 6:43 PM
    #3167
    CaptainMcJedi
    CaptainMcJedi New Member
    Durham, NC
    19 Tundra Sport
    Just went to new river state park this weekend with the camper. Pulled great with air bags and WDH.
  18. Mar 6, 2022 at 6:45 PM
    #3168
    CaptainMcJedi
    Durham, NC
    19 Tundra Sport
    Feeeckin apple and their upside down pics. I’ll post a better one tomorrow.
    GODZILLA, EatSleepTacos and Jtundra81 like this.
  19. Mar 6, 2022 at 7:41 PM
    #3169
    EatSleepTacos
    Randy
    West Valley, AZ
  20. Mar 7, 2022 at 4:34 AM
    #3170
    CaptainMcJedi
    Durham, NC
    19 Tundra Sport
    Thanks!
    EatSleepTacos[QUOTED] likes this.
  21. Mar 7, 2022 at 5:43 PM
    #3171
    drew.c.114
    drew.c.114 New Member
    Andrew
    Gilbert, AZ
    2021 Trail Edition
    Cross country move from Wa to NJ. I had zero problems on inclines or declines, passing, or braking. Even got cut off by someone “merging” on the freeway in St. Louis, and had to slam on the brakes, got out of there unscathed. Picked up the truck 5 months before the move and my family, dog, and I were comfortable the whole way.
    Hoping to pick up some toys and get out there!
  22. Mar 7, 2022 at 5:45 PM
    #3172
    Mobeyk
    Mobeyk New Member
    Two newer tools
    NUDRAT, twotrack, Prostar 190 and 6 others like this.
  23. Mar 10, 2022 at 8:53 AM
    #3173
    Gainer
    Gainer New Member
    Columbus, OH
    2018 SR w/8' Bed
    Leveling kit, TRD wheels, remote start, Hellwig helper springs, TRD Rear sway bar. TRD Rear shocks, Dirty Deed 10" exhaust, S&B Cold Air intake
    I'm guessing the Jeep and trailer are just over 7000 lbs. Tows like a dream.... gas mileage is like a nightmare... LOL
  24. Mar 10, 2022 at 2:27 PM
    #3174
    CaptainMcJedi
    Durham, NC
    19 Tundra Sport
    Well it took me a bit to get around to getting the pictures up. Took the camper and kayaks out last weekend. First time pulling it with the Tundra, and it's no slouch. And yeah... that gas mileage is brutal @Gainer
    Had a blast tho, and the setup with the kayaks worked nicely.
  25. Mar 18, 2022 at 8:21 AM
    #3175
    Warreng
    Warreng New Member
    Used our “camper” to get both sleds to the mountains. Sled in truck is 10.5’ long and the one in the trailer is damn near 12’. Truck took it like a champ and conversion works out to 13mpg average.BCBFF1D1-BC16-4220-87C3-545ADD3E7FBE.jpg
  26. Mar 25, 2022 at 9:27 PM
    #3176
    Dansly56
    Dansly56 New Member
    daniel
    Just bought this 2019 keystone hideout 28bhswe. I have Timbrens, trd sway bar, RAS, tekonsha break controller, tow mirrors, 10ply BFG ko2 at 33”, husky WDH and soon to switch it to the Anderson WDH, pro comp 2.5 pro runner front coilovers and soon to add the rear bilstein 5160. Tows great just sucks gas of course.
  27. Mar 26, 2022 at 8:18 AM
    #3177
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    She's a beaut Clark!
    YeeYeeTundra and Dansly56 like this.
  28. Mar 26, 2022 at 8:31 AM
    #3178
    Shadowfax1
    Shadowfax1 New Member
    San Francisco Bay Area
    2018 Toyota Tundra 1794 Edition w/ TRD Off-Road Package
    Gorgeous trailer man. Congrats.
    how much does she weigh?
    Dansly56[QUOTED] likes this.
  29. Mar 26, 2022 at 8:38 AM
    #3179
    Shadowfax1
    At the moment, we tow nothing more than a dump-run trailer we use frequently around our property for clearing our junk and endless tree debris (we live in a heavily forested area).
    But trying to decide if we want to buy a big trailer for camping and how big we want to get. Our 3.5 acres is very hilly and our driveway slope is 13.5 degrees. Down by the house, even the truck with no trailer doesn’t have enough turn around space without a three point turn. So I’m thinking I can’t really keep a big trailer here.
    Might get a compromise. I’d prefer a 28 footer or so but maybe an 18 footer would be more pragmatic here.
    In the meantime I’ll just leave this photo here. The best Tundra-towing porn of all time.
  30. Mar 26, 2022 at 3:27 PM
    #3180
    Dansly56
    Dansly56 New Member
    daniel
    Thanks man! 6600lb dry and 820 tongue weight and 33ft long
    J&ATundra and Shadowfax1[QUOTED] like this.
