What do you TOW with your Tundra?
Discussion in 'Towing & Hauling' started by T-Rex266, Jan 29, 2014.
  1. Dec 19, 2021 at 2:56 PM
    #3091
    Retired...finally
  2. Dec 19, 2021 at 3:34 PM
    #3092
    thearborbarber
    thearborbarber New Member
    SoDak
    2018 Tundra SR5
  3. Dec 20, 2021 at 7:06 AM
    #3093
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    We borrowed a trailer from friend to move some small “stuff” into the garage of our next home. Tundra did well, definitely sucked more gas as I used the tow/haul mode. Two trips so far about 250 miles, averaged about 10.6 to 11.1 mpg loaded / unloaded respectively. One day was a total heavy rain out day here in WA, lots of pooling water on roads, slow traffic in the Seattle suburbs and surrounding country. Some hills no mountains tho. Pleased how it handled the trailer, but it would be better with a suspension upgrade.
  4. Dec 20, 2021 at 7:40 AM
    #3094
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    Beautiful house! Congratulations!
    WAtundra4x4[QUOTED] likes this.
  5. Dec 20, 2021 at 9:39 AM
    #3095
    19 Cement Lmtd
    19 Cement Lmtd New Member
    2019 Cement Tundra Limited TRD Off-Road
    Leveling kit w/2 in. lift, aftermarket wheels, and tires
  6. Dec 20, 2021 at 10:39 AM
    #3096
    WAtundra4x4
    Den
    Wet side WA
    Thank you, we hope to get the final close in 2 days.
  7. Dec 20, 2021 at 10:54 AM
    #3097
    TundraMidwesterner
    TundraMidwesterner What?
    Northern Illinois
    2019 Magnetic Gray Metallic CrewMax TSSOR 4x4
    Katzkins, Rostra heated seats(4), Tint (all), TRD rear sway bar, TSS wheels, OEM black lug nuts and wheel locks, OEM LED black fog lights, Driver side grab handle, Rough country LED Bumper bar, Rough Country Hard tri fold tonneau cover, AVS ventshades, Bilstein 5100's on top setting in front, Ready lift 1 inch ready block in the rear with Bilstein 5100's. Fluid Film. ESP under seat storage. LED interior lights and cargo lights swapped. Rear USB charger port swapped for 12v port. Remote start. Leather wrapped steering wheel kit. TRD shift knob. Kenwood dmx1037s. Hertz K170 door speakers/ tweeters, Infinity Reference 7005A 5 channel amp, 2 JBL WS1000 10 inch subs. DDI Seat Jackers. RCI engine Skid and Vahalla's Shields (front and rear) 1/4 aluminum. Stillen intake. LED Pro Headlights with iHacker harness. Cartrimhome auto up and down window switches. Coupe's aluminum battery tie down. Color matched mirror caps. Color matched door handles. Chalk bag cup holder. NFab podium step bars, herculined. Powerstop z36 drilled slotted brake discs w/ceramic pads.
    Now that its cold out, not much. Occasional load of scrap wood from the lumber mill for a buddy with a wood burning boiler system. Occasional enclosed trailer from work.
    but in the summer, almost every weekend...
    19ft scarab 195 with the 250HO supercharged rotax motor
  8. Dec 20, 2021 at 11:15 AM
    #3098
    Mr_Ed
    Mr_Ed New Member
    Ed
    2018 Limited 5.7
    None
    For a borrowed trailer you probably didn't use a WDH (weight distribution hitch). We pull an approximately 6000 pound RV with ours using a WDH, and it does quite well on the stock suspension. I'm delighted how it handles the trailer, but we've only seen Arkansas mountains so far :) We'll be crossing the Rockies next July; I'll check back then :)
  9. Dec 20, 2021 at 8:09 PM
    #3099
    WAtundra4x4
    Den
    Wet side WA
    You are correct, no weight distribution hitch. Trailer alone was 2200 lbs, and with load about another 2000 lbs. it a very nice trailer with lots of tie downs and wood interior. Waterproof also! The back is a fold down ramp which helps a lot.
  10. Dec 31, 2021 at 11:30 AM
    #3100
    Tbuzbee
    Tbuzbee New Member
    Trevor
    2012 Tundra CrewMax
    Hello everyone. I’ve been reading through all of the travel trailer towing posts and I’m curious; am I the only one who gets 6 mpg at 62 with with my 7,000lb travel trailer? What are y’all doing to get 9-10 mpg?A57F7CF6-2ABC-49DF-A6B5-DAB06A1899F6.jpg
    Prostar 190 likes this.
  11. Dec 31, 2021 at 11:55 AM
    #3101
    EatSleepTacos
    EatSleepTacos New Member
    Randy
    West Valley, AZ
    2020 Crewmax SR5 TRD Sport
    On my last trip I got 11mpg with 8k lbs and I chalked it up to a couple of things. I had bumped my tire pressure up a bit, my tacoma on a car trailer is gonna be a bit more aerodynamic than a travel trailer, and I kept the engine in S4 and S5 the whole time, jumping around to keep the RPM’s in the optimal range to reduce engine load, thus decreasing the amount of gas used.
  12. Dec 31, 2021 at 12:30 PM
    #3102
    Munk
    Munk Vol For Life
    Mickey
    Bristol, Tennessee
    2017 Black SR5 Tundra Crew Max
    3/2 Lift
  13. Dec 31, 2021 at 1:26 PM
    #3103
    Tbuzbee
    Tbuzbee New Member
    Trevor
    2012 Tundra CrewMax
    Thank you for your experience. I’ve tried S5 and S4 and found that it never really wants to shift to 5th gear. I’ve also tried D in tow/haul mode and if it goes to 5th the torque converter locks and unlocks too often. It really likes 3rd fear on the small upgrades. This is where it really sucks the fuel. All of these trips are fairly flat ground.
    I’m just wondering if everyone claiming 9-10 mpg are driving 45 mph for short camping trips. I love the Tundra but hate stopping every 115 miles to fill up while only going 60-65 mph.
  14. Dec 31, 2021 at 1:31 PM
    #3104
    EatSleepTacos
    Randy
    West Valley, AZ
    It’s tough to say as there are a ton of variables. I know on my last 800 mile trip I was on the highway 99% of the time at 70mph with some hill in there but not much, maybe 50 miles worth. I should say I was also in tow/haul on that trip.
  15. Dec 31, 2021 at 1:44 PM
    #3105
    Mr_Ed
    Mr_Ed New Member
    Ed
    2018 Limited 5.7
    None
    Our trailer is about 6000 pounds. We get 9.5 to 10.5, but that's probably 90% towing and 10% not. I have yet to fill up that at least a portion of that tank was not towing. Nonetheless, 6 seems bad. Was this a one trip calculation where you might have had a headwind?
    FWIW, I run 35psi in the truck tires and 65 psi on the trailer. That max per the sidewalls on both. I run 65 to 70 on the interstate. I wonder sometimes if running too slow, particularly with hills might actually hurt your mileage by keeping it in a lower gear all the time. I know that when mine downshifts the mileage indicator falls dramatically.
    WVI likes this.
  16. Dec 31, 2021 at 2:14 PM
    #3106
    scooter18
    scooter18 New Member
    Paul"Scooter"
    Kentucky
    2018 MBM Platinum CM
    N-Fab steps, JL subs, more to come
    Kawasaki KRX 1000 on my 18' crawler hauler trailer. I used this same trailer to haul my 85 Toyota Crawler on for years. This trailer has at least 30k miles on it. It has been all over the South East with that old truck on it. It's living a much better life now and the Tundra doesn't even know it's back there. I bought the Tundra 3 months ago and I love it more everytime I drive it.
  17. Dec 31, 2021 at 4:33 PM
    #3107
    Tbuzbee
    Tbuzbee New Member
    Trevor
    2012 Tundra CrewMax
    We’ve made a few trips. The best I got was 9 mpg with a pretty good tail wind. The last couple of trips were 6-7 mpg with no significant wind on fairly flat highway. The truck tires are rated for 44 psi and I run them about 43-44. Trailer tires are 50 psi max and I run them 49-50 psi. I average about 15 mpg empty.
  18. Dec 31, 2021 at 6:01 PM
    #3108
    X2 but only in Ohio
  19. Jan 4, 2022 at 8:55 AM
    #3109
    JDR76
    JDR76 New Member
    WA
    My travel trailer is about 5k lbs loaded. At freeway speeds, my baseline is right around 8.5 to 9.5 mpg. I can get up to about 11 mpg with a tailwind, but down to about 7.5 with a head or side wind.
  20. Jan 8, 2022 at 5:27 AM
    #3110
    WAtundra4x4
    Den
    Wet side WA
    My tow for today, my portable backhoe. Had to move it from the old house as the house goes up for sale next week. It was fun moving it from the far back yard to the front for loading onto the trailer. It was an epic rainy day here in the NW. Flooding and landslides due to the rain. I was out in the rain for hours, got soaked to the shorts with my rain gear. Then it took 2.5 hours of driving to go 80 miles. One road I went on was shut down due to a new landslide, so I had to turn around and drive the back roads for 10 miles in suburbs to get back to highway. Photo was next morning. A light weight tow for sure. The trailer is super light, all aluminum. You can push it with one hand. I borrowed it from some friends.
  21. Jan 11, 2022 at 12:51 PM
    #3111
    rdiddy5
    rdiddy5 New Member
    Ryan
    Arizona
    2018 Crewmax 1794 4x4
    We got 2021 Apex Nano 185BH last year, and took a few trips w/ our 2015 Highlander, and once with my 4runner. Went last weekend to check the hitch setup, wash it, and take a few items over- can't wait to hit the road w/ the new (to me) rig. Dealer appt this week to get the TSB 0036-19 done.
  22. Jan 11, 2022 at 3:42 PM
    #3112
    Infernotundra17
    Infernotundra17 2017 Inferno SR5 Crew Max
    Martin
    Las Vegas, Nevada
    2017 Tundra Inferno orange
    Black Rhino 20" Go Rhino RB20 steps Magnaflow muffler
    Very nice looking set up sir
  23. Jan 11, 2022 at 3:47 PM
    #3113
    Mr_Ed
    Mr_Ed New Member
    Ed
    2018 Limited 5.7
    None
    We have friends with an Apex, and it's a very nice, well-made trailer. We looked for one but couldn't find one locally.
  24. Jan 12, 2022 at 6:48 AM
    #3114
    Diesel Fumes
    Diesel Fumes Big Member
    Georgetown, Ontario, Canada
    2021 TRD Sport Premium
    MK4 Backflip, Go Rhino runners, Huskey liners, LED bulbs throughout, Chortau dashcam, decals/badges removed or blacked out.
    @rdiddy5 How did you find the visibility was with the 2021 non-towing mirrors? I want to be prepared for my incoming TT and worry that rearward visibility will be very limited. From my understanding 2020-21 have slightly different mirrors than 2019 - older.
    Great looking combo btw!!
    JDR76 likes this.
  25. Jan 12, 2022 at 7:20 AM
    #3115
    Bo Dangles
    Bo Dangles New Member
    Jesse
    Canada
    2021 Tundra TRD Sport Premium
    Usually only tow a few times a year to bring the 26’ camper out for hunting season, or to bring the boat to the lake in the spring and home in the fall. Always towing around my 12’ aluminum utility trailer and atv/sled.
    Jtundra81, D4x4TRD, scooter18 and 3 others like this.
  26. Jan 12, 2022 at 8:00 AM
    #3116
    JDR76
    JDR76 New Member
    WA
    How wide is your incoming trailer?
    I believe the Apex Nano 185BH is 90" wide. My GeoPro is 92" wide. I have the regular mirrors on my Tundra. I'm okay with them, though I wouldn't mind if they were a bit wider. If my trailer were any wider, I would more seriously consider swapping them out for tow mirrors, but I am comfortable enough with the non-towing mirrors at the width of my trailer.
  27. Jan 12, 2022 at 8:29 AM
    #3117
    rdiddy5
    rdiddy5 New Member
    Ryan
    Arizona
    I think it will be okay, we'll find out later this month. My trailer is 7.5' wide. I have some of those strap on CIPA 11950 Clip-On Towing Mirrors I can use in the meantime if needed. I've got a 1794, so it has BSM and power fold (also the seats have some kind of tie in) to prevent me from having aftermarket mirrors that retain all that functionality.
  28. Jan 12, 2022 at 8:46 AM
    #3118
    EatSleepTacos
    Randy
    West Valley, AZ
    Boostauto tow mirrors would be able to retain all of that if you really wanted to.
  29. Jan 12, 2022 at 8:50 AM
    #3119
    rdiddy5
    rdiddy5 New Member
    Ryan
    Arizona
    you're right, but they are $800+
    JDR76 likes this.
  30. Jan 12, 2022 at 1:44 PM
    #3120
    Retired...finally
    Even though Amazon says they don't fit 2021s I found they fit my 21 SR5 just fine. https://www.amazon.com/gp/aw/d/B00AFV7DHW?ref=ppx_pop_mob_b_asin_title
    OldSchoolV8 likes this.
