What do you mount to your Toyota factory bed rails?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundra9831, Jan 13, 2020.
  1. Jan 13, 2020 at 7:24 PM
    Tundra9831
    Tundra9831 [OP] New Member
    I just ordered 8 of these:
    https://shop-hondogarage.com/collec...ms/products/toyota-utility-track-t-nut-4-pack
    to get rid of my factory tie down points due to interference with my ordered Snugtop.
    What do you all bolt to your bed rails? Axe, tie down points, hi-lift jack, etc? Let's see your setup.
    One idea I have is eye bolts spaced over the 3 rails to then find a cover of some sort to hide valuables out of site when needed. Anyone know of a cover that fits well and serves this purpose?
  2. Jan 13, 2020 at 7:32 PM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    Hi-lift and base
    Tundra9831[OP] likes this.
  3. Jan 13, 2020 at 7:34 PM
    Tundra9831
    looks good...what mounts and model?
  4. Jan 13, 2020 at 7:55 PM
    Over the LINE
    New Orleans
    I used T nuts like you have with eye bolts, nuts and washers to give me the ability to tighten them down. If you notice I locked two eye bolts together to make my jack secure.
  5. Jan 13, 2020 at 8:22 PM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
    I’m tagging this. I’d like to mount a rotopax for water when hunting with my dogs.
  6. Jan 13, 2020 at 8:27 PM
    HighonFirewood
    HighonFirewood Everything can be fixed with a hammer.
    Stage Left. Colorado
    2019 Tundra
  7. Jan 13, 2020 at 8:44 PM
    Tundra9831
    The reason I bought the Hondo Garage units is because I want to be able to install, remove, or move them without moving the Snugtop. That's worth the extra price for me.
  8. Jan 13, 2020 at 8:47 PM
    HighonFirewood
    2019 Tundra
    Gotcha. Apologies, as I assumed it was just a run of the mill t-slot nut.
  9. Jan 14, 2020 at 7:36 AM
    bmann7
    bmann7 Silver Sky Platinum Pro
    WA
    2019 SSM Tundra Crewmax Platinum
    See signature line
    Watching here for ideas - and same issue, want something I can take in/out of rail without the task of sliding.
