What could this be?
Discussion in '2nd Gen Tundras (2007-2013)' started by Muntazir, Nov 19, 2017.
  1. Nov 28, 2017 at 9:31 PM
    #61
    BakNBlk2014
    BakNBlk2014 So Impossibly Black
    Donald
    Virginia Beach VA
    2014 limited cm attitude black 4x
    BDS 4 1/2 Nitto Terra Grappler 35x12.5/18 BW Fender Flares Moto Metal 970 Wheels Leer Tonneau Bed Cover Black Plastidip Grill CF Wrap Interior AJT Shift Knob 35% Tint Weather Tech Mats Toyota Bed Mat AFE Intake
    Hey Sean. I'm 14 CM w 29k miles. So I should def get this checked by late 2018 for warranty coverage? Also I'm bumper to bumper extended for 6yr 90k would that cover this issue as well? If you know. I'm out shipping now but will take a peak in about two weeks at it. Good info on coverage. Appreciate
  2. Nov 29, 2017 at 7:08 AM
    #62
    Just take a look at it. If you want it documtend, just bring it by the dealer for a courtesy inspection. If they find it- you’ll know. If not, it’s still documented. Keep in mind, warranty works pays techs less..I keep one to two tech in my “back pocket” and either tip them with cash, or adult beverages. Take care of those who take care of you if you can find a good one.
  3. Nov 29, 2017 at 9:17 AM
    #63
    BakNBlk2014
    Donald
    Virginia Beach VA
    Courtesy inspect. Good idea. Thanks.
    T-Rex266[QUOTED] likes this.
  4. Nov 29, 2017 at 2:18 PM
    #64
    TheBeast The Beach
    the way I see it, if you have it get it done asap, don't wait til end of your warranty .So that if it comes back, you still under warranty.
  5. Nov 29, 2017 at 8:10 PM
    #65
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I'm pretty certain that Toyota will only fix it once under warranty, but I could be confusing it with the AIP issue. I've read about owners having more than one AIP failure on the same truck, but I can't recall reading of anyone having a warrantied Cam Tower repair fail. I could be mistaken and mixed up though.
  6. Jan 11, 2019 at 11:24 AM
    #66
    Schoward105
    Schoward105 New Member
    2012 White Tundra
    I have a 2012 Tundra (90,000 miles) that has been serviced regularly. Yesterday during a scheduled oil/filter change I was told that the driver side cam tower was beginning to leak. The technician put the truck up and showed me where the leak was....slight dry residue on the heat shield. They said $2,000 to 3,000 to repair it but I'm not inclined to have it done unless I'm convinced that it is worth it...the truck doesn't use any oil between changes. Thanks for any comments!
    Stormtrooper81 likes this.
  7. Jan 11, 2019 at 11:59 AM
    #67
    Professional Hand Model
    Hand Protectors
    Judging from the paranoia reponses and cat fighting in between, it sounds like ‘cam tower’ leak will be a great negotiating tool to knock (at least) $4k off the asking price of a used truck. Buy it and drive away smiling knowing the leak is fake news?
    Am I wrong here?
    Also, if it looks like an oil leak around the cam tower then what does adding dye to the oil prove? A cam tower leak?
    Too simplistic of thinking?
  8. Jan 11, 2019 at 1:53 PM
    #68
    Dr_Al
    Dr_Al New Member
    Al
    I would ignore it. Sorry but my first Toyota was a '77 Corolla SR5. If after 100k that's all the oil it as leaking I would have been happy as a pig in mud. The car was great and sold it with over 200k on it. But it did leak oil. The worst was the gaskets in the valve cover for the spark plugs. The thing got so bad that they would fill up with oil. Back then 30k on a set of plugs was about it. You couldn't get most of the oil out from around the plug so it would just go into the cylinders. I would have to turn the engine over with the starter and the plugs out praying oil everywhere to get most of it out of the cylinders. Once I started the engine up I would smoke the whole street out. I would keep a piece of cardboard under it in the garage.
    To me that's just not a big enough leak to worry about. I have an old International truck I use for plowing that leaks pretty bad. After a few minutes the oil on the exhaust manifolds starts to burn away. After a few minutes things get hot and it stops. If it bothers you then fix it.
  9. Jan 11, 2019 at 4:31 PM
    #69
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    I had a '78 Chevy Bonaza that leaked so bad I bought oil by the case and had to put a quart in every other fill up. Fun truck, straight duals with glasspacks.:burnrubber:
  10. Jan 11, 2019 at 6:43 PM
    #70
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Forty year old vehicles are suppose to leak oil.
  11. Jan 11, 2019 at 7:01 PM
    #71
    Moon Puppy
    Bob
    South Carolina
    2020 Tundra Limited
    That was 30 years ago....:thumbsup:
    Wynnded[QUOTED] likes this.
  12. Jan 12, 2019 at 4:08 AM
    #72
    Dr_Al
    Dr_Al New Member
    Al
    Sure it would be nice if it didn't leak oil but the fact remains that a small oil leak is more of an annoyance than a problem. If it was just a matter of changing out a valve cover gasket then I would most likely do it. But $3k to $4k because of a tiny leak? My point is that small oil leaks in older vehicles are not all that uncommon. I've seen vehicles that look worse just from oil being spilled when doing an oil change. If it was my money it would need to be a lot worse than what that picture shows for me to drop that kind of cash.
    kparrow and Wynnded[QUOTED] like this.
