What can I do for a smoother ride?
Discussion in 'General Tundra Discussion' started by SullyMoto19, Mar 6, 2018.
  1. Mar 6, 2018 at 12:29 PM
    SullyMoto19
    SullyMoto19 [OP] New Member
    Tyler
    Houston, Texas
    2017 Magnetic Gray SR5 5.7 4X4
    8" ReadyLift w/ ReadyLift and Bilstein Adjustable Coilovers w/ Reservoirs, 3" PA Body Lift, Fox 2.0 Shocks, 24x14 RBP Atomics (custom powdercoat Gloss Black), 40x15.5r24 RBP Repulsor, Relentless Fabrication Stealth bumper, N-Fab side steps, Bedlined/Paintmatched Honeycomb Grill, 2019 LED Headlights, 4 Backlit RBG Cubes, 16 RGB PlashLight Rocklights, 5% Tint & Brow, 2 10" Kicker CVT Subs with Kicker Amp in custom sealed box, Husky all weather floor mats, LED White interior bulbs
    what would I be able to do to eliminate bed bounce and get a little smother right on my truck?
    I think the 37'' Cooper mud terrains are a big part of it.
    TheBeast and Pudge like this.
  2. Mar 6, 2018 at 1:07 PM
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    TRD pro suspension. Bolt on at don't look back.
    smooosh likes this.
  3. Mar 6, 2018 at 1:10 PM
    SullyMoto19
    Tyler
    Houston, Texas
    well im running an 8'' lift and fox 2.0s in the back.. but I was curious about shackles and that kinda stuff.. not really sure what they are used for
  4. Mar 6, 2018 at 1:12 PM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    You could always throw a sway bar on
    geno0506 likes this.
  5. Mar 6, 2018 at 1:12 PM
    seniramsu
    Nate
    VA
    You could also do this!!!!
  6. Mar 6, 2018 at 1:13 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Add weight to the bed maybe? I'm sure it's not the solution you're looking for
  7. Mar 6, 2018 at 1:14 PM
    SullyMoto19
    Tyler
    Houston, Texas
    I never thought of that lol
    @Roman do sway bars help out with bed bounce and help for a smoother ride?
  8. Mar 6, 2018 at 1:17 PM
    PMR
    PMR New Member
    Patrick
    South East Tennessee
    2017 White 1794
    Icon Stage 6 Lift w/ Billet UCAs Icon RXT Leaf Pack Icon Six-Speeds w/ BFGATKO2 285-70-17 TRD Exhaust TRD Sway Bar TRD Skid Plate TRD CAI TDR Shift Knob Weathertech Floor Mats & Window Visors 2018 Tundra LED Headlights Interior and Exterior LED Upgrade
    Change the leaf packs out. I know you have a tall lift, but the ICON RXT pack made a huge difference for me. I'm about 3" front and 1.75" rear. The RXT pack provided that much in the rear. The pack comes with another leaf that will lift the rear 3". I guess that with a block or shackles will get you there.
    SullyMoto19[OP] likes this.
  9. Mar 6, 2018 at 1:22 PM
    SullyMoto19
    Tyler
    Houston, Texas
    that's another thing im not so sure about.. I don't know a whole lot about leaf packs. ill definitely do some research on it though, thanks
  10. Mar 6, 2018 at 2:29 PM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    Not really. All it does is keep the truck flatter when cornering.
  11. Mar 6, 2018 at 2:32 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Sway bars won’t help w smooth ride. If you have an 8” lift you probably have a huge block back there to get lift. That probably doesn’t help. I would replace the block with a full leaf pack replacement like others has mentioned. You can go Alcan or Deaver.
  12. Mar 6, 2018 at 2:40 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I think your 2.0 are undersized for 37" tires. The smoothness of your ride is most effectively altered with leafs and shocks. I'm guessing you've got a bolck back there. Custom springs would make a world of difference. IMO
    joonbug, 14burrito, TheBeast and 2 others like this.
  13. Mar 6, 2018 at 3:35 PM
    SullyMoto19
    Tyler
    Houston, Texas
    Sounds expensive.. like I said, I don't know a whole lot about leaf springs. I just put the 2.0s on last week, so haven't got a whole lotta miles on em
  14. Mar 6, 2018 at 3:59 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    it is not cheap but if you want a good ride, you gotta pay some.
    Newm, 14burrito, TheBeast and 2 others like this.
  15. Mar 6, 2018 at 4:03 PM
    Let's see what your ride looks like now
  16. Mar 7, 2018 at 6:42 AM
    SullyMoto19
    Tyler
    Houston, Texas
    yeah... I mean 8" and 37s, I cant be too picky lol but would love if it rode like a Cadillac lmao
  17. Mar 7, 2018 at 6:42 AM
    SullyMoto19
    Tyler
    Houston, Texas
    Ill see if I can get a pic when I leave work.. just got her washed the other day to.
  18. Mar 7, 2018 at 7:04 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Triple bypass rear shocks for that Cadillac ride.:anonymous:
  19. Mar 7, 2018 at 7:22 AM
    SullyMoto19
    Tyler
    Houston, Texas
    shiiiiiieeeeeeeeeeeettttttttttttttttttttt.............. I need to quit and go back to the refineries for that :rofl:
    831Tun[QUOTED] likes this.
  20. Mar 7, 2018 at 9:03 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    i run 37s (mickey thompson atz p3) on my 6" lift and it rides great. rear pro comp shocks, ome drakar leaf pack and coach builder +3 shackles. no block. previous had a 3" block or some garbage. i reached out to coachbuilder directly for guidance on ride and i did what he said. Very happy. for comparison. my wife dd's an escalade. my truck rides slightly firmer (slightly) but every bit as smooth. @Coachbuilder1
  21. Mar 7, 2018 at 9:04 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    to add to this i also run coachbuilders tie rod ends also very much worth the $ in steering response esp at speed when the suspension is cycling down.
  22. Mar 7, 2018 at 9:23 AM
    SullyMoto19
    Tyler
    Houston, Texas
    I think the block is a big part of it... I think you may be on to something with the shackles. I just have no idea what is needed for an 8"
  23. Mar 7, 2018 at 12:22 PM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    how is your front lifted? extended coils or a spacer?
  24. Mar 7, 2018 at 12:54 PM
    SullyMoto19
    Tyler
    Houston, Texas
    its a ready lift so im running all stock components up front (besides UCAs), but its a big ass spacer that goes above my coils. the front end seems fine I think
  25. Mar 7, 2018 at 1:00 PM
    15whtrd
    15whtrd Mr. Blonde
    This is my go to answer. Start with adjusting your tire pressure’s. Let some more air out of those big fat rear tires. Adding weight always helps too. I do agree with shackles and upgraded leaf packs.
    andy9743 likes this.
  26. Mar 7, 2018 at 1:08 PM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    this is good advise also. i never realized you do not fill pressure up to what the tire side wall says. i was chasing rough ride on my 8" lifted excursion on 37s. had 60 lbs of pressure in tire, lowered to the recommended 35 and that made a substantial difference. lowered the pressure in my tundra and that also aided in a better ride.
    15whtrd[QUOTED] likes this.
  27. Mar 7, 2018 at 1:21 PM
    15whtrd
    15whtrd Mr. Blonde
    You can also do the chalk test to really fine-tune it. https://youtu.be/ojGsavK0Uwc this is a random video I found on YouTube.
  28. Mar 7, 2018 at 1:34 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    You can always add a set of these too for a cheaper easier way to soften the blows than new leaf packs. A friend of mine has them on his lifted superduty- night and day difference.
    ColoradoTJ likes this.
  29. Mar 7, 2018 at 2:01 PM
    You do realize Fox shocks are valved for off-road and aggressive driving right? For a pavement princess and the desire to ride like a caddy, I would have went a different route. Sounds cool though.
    Not all is lost. Re-valve your shock. Slow down your rebound a bit.
    Mountun Goat likes this.
  30. Mar 7, 2018 at 2:06 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
