What brakes? Pad / rotors?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Erick, Dec 15, 2019.
  1. Dec 16, 2019 at 10:54 AM
    r4z0r51o
    r4z0r51o have fallen off the forum, but I’m still alive.
    Dave
    Northeast San Francisco Bay Area
    2016 Silver Sky Metallic Crewmax 5.7L TRD 4x4
    22x12”HostileRage/33”NittoRidgeGrap/StealthFighter/FOX-BDS
    Same set up I have ... slotted and drilled rotors :thumbsup:. Didn’t know how much dust they put out ... hope it’s not that bad.
  2. Dec 19, 2019 at 9:56 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    I just bought the EBC Stage 14 Kit. Now to wait for it to get here.
    Their "stages" are numbered oddly.
    Stage 1 is a basic kit with premium rotors and Ultimax 2 replacement pads. I would guess the pads are a small upgrade vs stock because thats what EBC is known for.
    The stage 14 is basically the same kit (premium rotors) with 1 step better pads (greenstuff). They tout it as modest brake upgrade over stock.
    Stage 2 seems like it should be stage 50 when you compare it to the stage 14. It upgrades both the pads and rotors. You get Greenstuff pads with slotted rotors. And I didn't want slotted rotors.
    I'm hoping the EBC Premium rotors will better resist warpage compared to OEM and the greenstuff pads will give a small improvement in stopping force. Even when I tow I've never been disappointed in the brakes on this truck. I've just needed new rotors for quite a while so it's time to do it all.
    I will update with my initial impressions and more.
    r4z0r51o likes this.
  3. Oct 7, 2021 at 4:46 AM
    Npowers66
    Npowers66 New Member
    Nick
    18 SR5 crew max
    I’m about to do my brakes at 53k. Are the TRD pads with OEM rotors a good upgrade ? I have a SR5. Or should I do the EBC ?
  4. Oct 7, 2021 at 6:01 AM
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    I bought R1 concepts pads and rotors.. very good
    Rodtheviking likes this.
  5. Oct 13, 2021 at 12:37 PM
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    2016 TRD Pro Super White
    Any update on these?
  6. Oct 13, 2021 at 2:13 PM
    ejes
    ejes New Member
    2020 1794 Tundra / 2023 4Runner TRD PRO
    I've had good service from the OEM actually, but I had good luck with Bendix Fleet MetLok pads and their "Severe Duty" rotors when I had to change them out. Their "Stop" ceramics are good too; I used those on the rear.
  7. Oct 14, 2021 at 8:57 PM
    mgnchakar
    mgnchakar New Member
    2016 Black Tundra TRD 4x4
    How long do brake pads usually last on the tundra 3rd gen ?
  8. Oct 14, 2021 at 9:26 PM
    ejes
    ejes New Member
    Well, 3rd gen isn't technically out yet according to recent definition...but it varies with demands and usage on the 2.5 and lower gens. It is pretty logical. If you tow a lot or hit your brakes hard a lot, you should expect more wear and shorter life; just like every other manufacture.
  9. Oct 14, 2021 at 9:28 PM
    mgnchakar
    I meant to say 2.5.
  10. Oct 15, 2021 at 5:57 AM
    timsp8
    NY
    My stock ones started wobbling by 20k. Some have gotten 80k out of theirs.
  11. Oct 15, 2021 at 7:02 AM
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    Organic pads will give you the shortest life but best stopping power for around town typically. They also generate lots of dust.
    Most today are composites like semi metallic or carbon metallic. They last longer and greatly reduce dust.
    But, they need to be hot to do their best stopping. The ticket if you carry large loads or do a lot of highway driving with heavy loads.
    Full metallics are not the ticket as they induce higher wear rates on rotors and are the pits for stop an go driving due to not enough heat generation.
    Nowadays, they have dialed in the pad matrix's so well that rotor wear is non existent in most cases and your safe under most conditions.
    Change fluid if you never have also and look into SS/Teflon brake lines on older / high mileage trucks.
    After time the rubber brake lines get soft and expand under brake pressure causing sponginess to the pedal.
    On my Trans am I went to to SS / Teflon during some of the restoration and what a big difference.
    I will be using a changeover to SS Teflon when I do my first brake job on my Tundra.
