What are your favorite mods/improvements?
Discussion in '1st Gen Tundras (2000-2006)' started by FirstGenVol, Jan 14, 2021.
  1. Jan 15, 2021 at 11:35 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    I LOVE my Compustar autostart. It's killer in the winter.
    Also, my Android phone and Torque Pro to monitor temperatures and the data.
  2. Jan 15, 2021 at 7:55 PM
    Brown Bear
    Brown Bear New Member
    Nor cal
    03 TRD offroad
    -6" RCD lift in front. -Custom leaf springs in rear 4" lift. -17" race line, raptor wheels. -35" Goodyear Duratrac. -4.88 gears. -ARB rear air locker. -ARB air compressor and tank. -Custom front sway bar quick disconnect -Custom one piece driveshaft -Black Oak Led 40 watt ditch lights.
    Yes. I made them myself. It's for a first gen though.20180814_161408.jpg 20180814_160148.jpg
  3. Jan 15, 2021 at 8:34 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    @Brown Bear I think that small pin is a bit too much of a weak point. But I suppose if you're not one to corner hard/fast, it's probably not going to be an issue. Looking at it just bothers me lol. :boink:
    Stud for the bottom heim with a spring retaining clip or pin like yours to keep it from sliding off until ready to remove and a wing nut at the top to remove completely from the control arm & swaybar. My Taco has a setup like this since 02 or 03.
    :eek: Anyways, just my unasked for 2 cents.
    _______________________________________________
    On topic, probably the remote start/alarm. That may change though.
    Glock 40, Darkness and BlueRibbon4x4 like this.
  4. Jan 15, 2021 at 9:16 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Pretty slick!
    Stuck in the '00s and Darkness like this.
  5. Jan 15, 2021 at 9:23 PM
    Brown Bear
    Nor cal
    03 TRD offroad
    It's a 1/4 inch pin and is strong enough for what it does. I do drive very windy roads almost every time I drive the truck. Half the time I'm towing as well. I have had the same pins for the last 2 1/2 years. They are still nice and smooth, no marks or wear spots. I know there are other ways to do it. But this works great for me and has been operating flawlessly.
  6. Jan 15, 2021 at 9:58 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Faves from my 2005 DC SR5...
    I really miss that truck..
    Retrax, even though it rattled on the road with the rear window down.
    I've heard they fixed that issue.
    RetraxMuth_545569027fd98bbf082af9d43fb9c9c7f74e777a.jpg Retraxopen_76ad0be85c4f2583f8a1cd93687c376dc110ef8e.jpg
    Full Bedrug..
    Bedrug4_f53385cb37981571f72dbda90e874e0c2ba12130.jpg Bedrug3_1e7d50da9eed02651f3d574eaba4ea03bcadd575.jpg
    Pioneer SuperTuner with an XM tuner.
    3 old school Fosgate amps (front, rear, and sub) and a custom removable 10" Fosgate Punch sub enclosure.
    IMG_0217_783600f7ba8e39d0e46b430c1b110c442e2bdce7.jpgIMG_0218_fcc80805fce360696e79195cca4bff2e17ab89b2.jpg
    WooferBox2_e4e9bd4e477af44a505cf4206a2e5a0b7393b9a2.jpg AmpMount3_914fe5077e9b8820f8d80776307b75d6ccce4b91.jpg WooferBox1_f538d9301c8e33d5d9c726c4dc9efa258c83ff08.jpg
  7. Jan 15, 2021 at 10:00 PM
    OnePuddleUnder
    OnePuddleUnder New Member
    NC
    01 Silver Tundra AC
    For those of you that updated to led headlights, did you have an issue where the fog lamps no longer work and the brights indicator doesn't show on your dash when you install them?
  8. Jan 15, 2021 at 10:20 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Jesus Christ its crazy to me how quick tech becomes obsolete. It seems like yesterday when I used to install those disc holder dash kits.
    Thank god for bluetooth.
  9. Jan 16, 2021 at 7:16 AM
    Mixb7
    Mixb7 New Member
    Napa Valley California
    2010 4x4 Tundra Platinum Crew Cab
    Bilsteins all around,110v and 12v in the bed, Rocklights, Dual Batteries, Trailer Brake Controller Mod, Lots of DIY Mods
    Brown Bear, what an excellent build! Do you have any more info on your build? What is the weight of that boat? Those got to be some heavy duty shocks. I have an 8 ft. Mini bass boat that I put on my truck and would like to build something such as this. I also noticed your in No. Cal. I am to, if I’m close enough I would love to be able to check it out in person.
    Brown Bear likes this.
  10. Jan 16, 2021 at 7:38 AM
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
    Very clever!
    Brown Bear[QUOTED] likes this.
  11. Jan 16, 2021 at 7:43 AM
    Stuck in the '00s
    Mikey
    SE Wisconsin
    Posted elsewhere, but this is MY favorite mod.
    Jack McCarthy, MS22, Bikeric and 7 others like this.
  12. Jan 16, 2021 at 9:37 PM
    Brown Bear
    Nor cal
    03 TRD offroad
    Im in Auburn area. I have a build page but I haven't really done a write up on the boat rack since I rebuilt it. https://www.tundras.com/threads/my-03-build.16259/ I used two 140lb gas struts. I could have gone with a 150lb to get a little more lift. But I didn't want it to be to hard to close if the boat is not on it. My boat is a 10 foot tracker topper 10 it weighs 87lb. Its the perfect size for the back of the truck. I can even fit a second one under it in the bed.20191129_091924.jpg
    fighthedude, MS22 and WILLINH like this.
  13. Jan 17, 2021 at 8:04 PM
    Mixb7
    Mixb7 New Member
    Thanks Brown Bear for the link to the other pics to your rack. Really helped to visualize in my head what I want to do. I’m going to have it lift from front of bed to back so my small boat will just slide off. I’m in Napa so a little far to see in person but I appreciate the help.
  14. Jan 18, 2021 at 7:01 AM
    It's gonna be a tie between the head unit / bluetooth / backup camera upgrade and the toolbox addition. Suspension stuff and wheels and tires are cool, but this truck likely was capable of anything I'll throw at it from the factory. The factory radio just plain sucked. And as often as I hook up to a trailer, the backup camera has been an invaluable time saver. These trucks come with practically zero storage so the toolbox has been so handy to be able to keep things like jumper cables, tools, tire pump, tarp and bed net, camp chair, shovel, and of course a cooler. And it's lockable. The inside of my truck is now clean and uncluttered and all of the seats are useable.
    abcinv likes this.
  15. Jan 18, 2021 at 7:19 AM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Aesthetically, my favorite is the lift and wheel/tire setup. No one really noticed my truck before except for die hard Yota guys. After the new setup, I get compliments on it from a lot more people. The discount tire boys loved it and I saw all the guys at the alignment shop gathering/walking around it. After he was done and brought me my keys, he said “that’s a cool little truck bro” lol. The most handy upgrades would probably be the remote start and camper shell. Never have to get into cold truck again and the shell has been more useful than I ever thought. How it looks now is how I imagined it to look when I first bought. I happy to say, I’ve finally got it there.
    alb1k, abcinv, MS22 and 4 others like this.
  16. Jan 18, 2021 at 11:10 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    My remote start for me too. LOL.
    SouthPaw likes this.
  17. Jan 19, 2021 at 4:29 AM
    06tacomadc
    06tacomadc New Member
    Motor City
    Tundra
    What lift and tire size are you running ?
  18. Jan 19, 2021 at 7:57 AM
    Brown Bear
    Nor cal
    03 TRD offroad
    RCD 6 inch lift in the front, custom made leaf pack with 4 inch lift in the rear, 35 inch tires.
    FrenchToasty likes this.
  19. Jan 20, 2021 at 6:53 PM
    #49
    GavinG83
    GavinG83 New Member
    Gavin
    Wilmington, NC
    2000 Tundra SR5
    You will need to add a resistor to the headlights for the dogs to work. Where in NC are you located?
    RoninGSX likes this.
  20. Jan 21, 2021 at 7:46 PM
    #50
    OnePuddleUnder
    NC
    01 Silver Tundra AC
    I'm a little south of Raleigh but likely to be moving to the mountains here soon! Thanks for the tip, I ended up ordering just the resistors for the head lights and from your comment and another older post I ended up finding I feel a bit safer in my choice!
    GavinG83[QUOTED] likes this.
  21. Jan 21, 2021 at 8:04 PM
    #51
    Hny_Bdgr
    Hny_Bdgr New Member
    black 2000 toyota tundra sr5 v8 4x4
    If it fits it ships
    alb1k, FrenchToasty and MS22 like this.
  22. Jan 22, 2021 at 2:48 PM
    #52
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    Currently I think I have to say the center console swap from a 05 sequoia to my 03 AC. But, hard to say cuz I'm not done yet.
  23. Jan 22, 2021 at 4:13 PM
    #53
    SouthPaw
    2000 Limited 4x4 AC
    You’ll love it.
  24. Jan 22, 2021 at 4:59 PM
    #54
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    I already do, and thanks for the help on that; whether you knew it or not, your threads helped me getting that figured out.
    What I meant above is that I'm not done making modifications yet.:cheers:
    SouthPaw[QUOTED] likes this.
  25. Dec 22, 2021 at 2:27 PM
    #55
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    When i got my truck in march the first thing i did was bandaid the brake problems and bed bounce with a load of roadside workbench. Worked like a champ.
    alb1k and bmf4069 like this.
  26. Dec 22, 2021 at 2:35 PM
    #56
    -I enjoy my Flowmaster muffler every time I drive it.
    -The stereo upgrade is also nice.
    -Backup camera is awesome.
    -led interior light conversion.
    -headlight harness and bulb upgrade
    -toolbox in the bed is awesome. Like having a backpack for my truck that locks.
    -looks wise, the level with 5100’s and bigger wheels and tires is nice. Don’t use the functionality of them often. But looks better.
    alb1k and Darkness like this.
  27. Dec 26, 2021 at 7:56 AM
    #57
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 DC SR5 Tundra TRD Off Road
    Dirt Deeds injectors, Addco rear sway, AEM dry flow air filter, last ever set of Stan's Try-Y headers, Borla full custom exhaust, front level, wheel spacers, and lots of electronics.
    For a mostly street driven 1st gen my favorite mod to date is the Addco rear sway. Cheap, compliments the stock front sway, and relatively easy to install.
    It has completely changed the road manners of this truck for the better. Much more confident in the corners and feels so much more secure and stable.
    Second place are the headers and exhaust. Only reason they're not first is how much it hit my wallet. But the increase of 30tq in the low end does put a smile on my face.
    assassin10000 and FrenchToasty like this.
  28. Dec 26, 2021 at 12:53 PM
    #58
    celchlepp
    celchlepp New Member
    2002 White LTD access cab 4wd 4.7
    WELL reinforced Gooseneck ball hitch in bed, nerf bars, window rain guards, Backup camera, dashcam, among other little improvements.
    Sdtrucksprings.com's site states: "We always recommend you install sway bars in pairs to ensure maximum steering and cornering performance. Check out the Front 2176 Addco stabilizer bar for the complete anti-sway package."
    How critical is it to put on both at the same time? I haven't looked yet, but the former owner of my truck did rig it up to pull his travel trailer all over the Western U.S. for years. As you can see from my profile photo, I also pull a g/n horsetrailer with my tundra, and it really does well. Not the pulling power of a PowerStroke of course, but it's not intended to be in the same league as the beefy rigs. For occasional hard work though, my 4.7 LTD tundra really delivers.
    Might be hard to justify at nearly $300 for the front if it's doing good enough for this long... ya? There may already be one on my truck, but I don't see one on a quick lookaround underneath the front.
  29. Dec 26, 2021 at 7:50 PM
    #59
    Riverdale21
    OTP ATL
    You should already have a factory front bar, depending on year and model I think they come in different thicknesses. I have an 06 DC TRD Off Road and the factory front bar is 27mm. The Addco rear bar from Summit is only 19mm. On a street driven vehicle you want a smaller rear bar than your front. It will keep you in the safe zone and understeer at the limit. If your rear bar were larger than the front it could cause snap oversteer or lift-off throttle oversteer. Neither situation is fun if you're not expecting it.
    Hellwig is the only other bar manufacturer I know of for the 1st gen. Buying both their front and rear bars adds up to about $700. Just the Addco rear cost me around $130. For the price I got the Addco rear and keep the front stock bar. The Hellwig pieces are overkill for normal high profile all season truck tires.
    I can't say enough about how happy I was with just this cheap mod.
    assassin10000 likes this.
  30. Dec 27, 2021 at 1:18 AM
    #60
    artsr2002
    'Yonder
    In no particular order I enjoy the following that I have added or modified over the years.
    Android Auto Kenwood Double DIN Stereo
    Backup Camera (Not the highest quality but its tucked in the tailgate handle for good view angle) (Tried wireless first, too much lag, poor image, tiny screen included)
    Retrofitted Mini D2S 5.0 Morimoto projectors with HID - Let there be light!!! :D (Retrofit all the things!) :yes:
    LED bulbs front/back/interior - Nice and bright and crispy
    Amplifiers/Subwoofer - Thump, even small thump, add so much to music enjoyment.
    Seat covers - Nice and comfy and have saved seats from minor spills
    Remote Start - half working. LOL
    Tailgate Assist - I wonder if there is enough room to install a second one on the passenger side that would allow the tailgate to fall on its own nice and sloooooow like my Ferd? Hmmmm :monocle:
    alb1k likes this.
